Add a platform device in the board file to specify a reset key-combo.
The first time the key-combo is detected a work function that syncs
the filesystems is scheduled. If all the keys are released and then
pressed again, it calls panic. Reboot on panic should be set for
this to work.
Change-Id: I9d54283ca1fba45e4b1ae1a407524cdda8171143
Signed-off-by: Arve Hjønnevåg <arve@android.com>
drivers/input is reserved for input core code and input handlers with
drivers belonging to one of the sub-directories.
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next
drivers/input/Makefile
In preparation for common code to handle a larger set of MT slots
devices, move the slots handling over to a separate file.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
The proper way to specify multi-source object is to use <name>-y instead
of <name>-obj (which is deprecated) as it allows conditional inclusion
of modules in the list.
More and more devices choose to reimplement support for sparse keymaps
first introduced by wistron driver. Move it into a library module so it
can be easily used by interested parties.
Reviewed-by: Anisse Astier <anisse@astier.eu>
Currently, evdev has working 32bit compatibility and uinput does not. uinput
needs the input_event code that evdev uses, so let's refactor it so it can
be shared.
[dtor@mail.ru: add fix for force feedback compat issues]
Signed-off-by: Philip Langdale <philipl@overt.org>
This is a pair of Xen para-virtual frontend device drivers:
drivers/video/xen-fbfront.c provides a framebuffer, and
drivers/input/xen-kbdfront provides keyboard and mouse.
The backends run in dom0 user space.
The two drivers are not in two separate patches, because the
intermediate step (one driver, not the other) is somewhat problematic:
the backend in dom0 needs both drivers, and will refuse to complete
device initialization unless they're both present.
Signed-off-by: Markus Armbruster <armbru@redhat.com>
This patch adds a very simple input power event to APM user suspend
event bridge. Its currently only works for the systems using the
emulated APM driver but could easily be extended to work with anything
with a true APM BIOS too.
This covers a standard embedded system need which is to suspend when the
user presses a suspend button. It leaves options open to system
integrators to ignore (or unload) this code and implement their own more
complex event handling system.
Its hidden behind the EMBEDDED Kconfig option since its only likely to
be of use to embedded style systems. It can be built as a module so the
"hardcoded" policy can easily be removed from the kernel at runtime if
desired too.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Remove the obsolete tsdev.c driver as scheduled.
To work around deficiences in Kconfig that allows to "select"
a symbol without automatically selecting all dependencies for
that symbol move input-polldev from drivers/input/misc to
drivers/input thus removing extra dependency on CONFIG_INPUT_MISC.
This will allow concentrating all input devices in one place
in {menu|x|q}config.
Delete the never-compiled source file drivers/input/power.c, and
remove its entry from the corresponding Makefile, as there is no
Kconfig file that refers to the config option INPUT_POWER
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
This modifies Makefiles and Kconfigs to properly reflect the creation of
generic HID layer.
It also removes the dependency of BROKEN, which was introduced by the
first patch in series (see the comment). Also updates credits.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Consolidate core implementing memoryless devices in one module; added
support for gain and envelopes and periodic => rumble conversion.
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com>
Implement a new force feedback interface, in which all non-driver-specific
operations are separated to a common module. This includes handling effect
type validations, locking, etc.
The effects are now file descriptor specific instead of the previous strange
half-process half-fd specific behaviour. The effect memory of devices is not
emptied if the root user opens and closes the device while another user is
using effects. This is a minor change and most likely no force feedback
aware programs are affected by this negatively.
Otherwise the userspace interface is left unaltered.
This will allow building input core module from several files
which is needed for the reworked force feedback support.
infrastructure for it.
Let it rip!
