Add an ioctl, EVIOCSSUSPENDBLOCK, to enable a wakelock that will block
suspend while the event queue is not empty. This allows userspace code to
process input events while the device appears to be asleep.
The current code holds the wakelock for up 5 seconds for every input
device and client. This can prevent suspend if sensor with a high data
rate is active, even when that sensor is not capable of waking the
device once it is suspended.
(cherry picked from commit 4dc43d7079bdae572212368e1d29abea0177c932 from
android.googlesource.com/common.git)
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Change-Id: I160d2afe77aa76c9d2bbe01cd4b81434201361a9
Reviewed-on: http://git-master/r/78895
If there is no SYN_REPORT event in the buffer the buffer data is invisible
to user-space. The wakelock should not be held in this case.
(cherry picked from commit 7cc846069a8a9116d8c81526c459070eed0e3477 from
Change-Id: I7555b190ff8e4e526291dd353c3c0291b05dfff2
Reviewed-on: http://git-master/r/78894
In evdev_read() the local variable retval is not initialized.
If this variable is not initialized then in case of NONBLOCK READ
retval will have invalid value.
Bug: 922453
Change-Id: I534cbfacf8a0514fcb5bc481a98d0e94a4d73b04
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/74898
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
Reviewed-by: Yogish Kulkarni <yogishk@nvidia.com>
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
If there is a full packet in the buffer, and we overflow that buffer
right after checking for that condition, it would have been possible
for us to block indefinitely (rather, until the next full packet) even if
the file was marked as O_NONBLOCK.
Change-Id: Icd0f59f8cc98392be4c4d13bd45b5cf94317eb5a
Signed-off-by: Dima Zavin <dima@android.com>
Change-Id: I5f0da721f74e5de111cffc7e7b375b72dd80e530
Without this, it was possible for the reader to get ahead of packet_head.
If the the input device generated a partial packet *right* after the
reader got ahead, then we can get into a situation where the device is
marked readable but read always returns 0 until the next packet is
finished (i.e a SYN is generated by the input driver).
This situation can also happen if we overflow the buffer while a reader
is trying to read an event out.
Change-Id: If01ab371bc7de1bf1f90c122dcc5a29242b01a09
Change-Id: Ief1ef44d98a197e5b457f5e8617c413e76e3c6d2
Signed-off-by: Benoit Goby <benoit@android.com>
wakelock names are now contain evdev->name and pid
Signed-off-by: Mike Chan <mike@android.com>
Since wall time can jump backwards, it cannot be used to determine if one
event occured before another or for how long a key was pressed.
Allows userspace code to process input events while
We should only wake waiters on the event device when we actually post
an EV_SYN/SYN_REPORT to the queue. Otherwise we end up making waiting
threads runnable only to go right back to sleep because the device
still isn't readable.
Reported-by: Jeffrey Brown <jeffbrown@android.com>
There is no need to call synchronize_rcu() after a list insertion,
or a NULL->ptr assignment.
However, the reverse operations do need this call.
This patch modifies evdev so that it only becomes readable when
the buffer contains an EV_SYN/SYN_REPORT event.
On SMP systems, it is possible for an evdev client blocked on poll()
to wake up and read events from the evdev ring buffer at the same
rate as they are enqueued. This can result in high CPU usage,
particularly for MT devices, because the client ends up reading
events one at a time instead of reading complete packets.
We eliminate this problem by making the device readable only when
the buffer contains at least one complete packet. This causes
clients to block until the entire packet is available.
Signed-off-by: Jeff Brown <jeffbrown@android.com>
Add a new EV_SYN code, SYN_DROPPED, to inform the client when input
events have been dropped from the evdev input buffer due to a
buffer overrun. The client should use this event as a hint to
reset its state or ignore all following events until the next
packet begins.
[dtor@mail.ru: Implement Henrik's suggestion and drop old events in
case of overflow.]
As was recently brought up on the busybox list
(http://lists.busybox.net/pipermail/busybox/2011-January/074565.html),
evdev_write doesn't properly check the count argument, which will
lead to a return value > count on partial writes if the remaining bytes
are accessible - causing userspace confusion.
Fix it by only handling each full input_event structure and return -EINVAL
if less than 1 struct was written, similar to how it is done in evdev_read.
Reported-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
include/linux/input.h
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next
Today, userspace sets up an input device based on the data it emits.
This is not always enough; a tablet and a touchscreen may emit exactly
the same data, for instance, but the former should be set up with a
pointer whereas the latter does not need to. Recently, a new type of
touchpad has emerged where the buttons are under the pad, which
changes logic without changing the emitted data. This patch introduces
a new ioctl, EVIOCGPROP, which enables user access to a set of device
properties useful during setup. The properties are given as a bitmap
in the same fashion as the event types, and are also made available
via sysfs, uevent and /proc/bus/input/devices.
Acked-by: Ping Cheng <pingc@wacom.com>
Acked-by: Chase Douglas <chase.douglas@canonical.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
The desire to keep old names for the EVIOCGKEYCODE/EVIOCSKEYCODE while
extending them to support large scancodes was a mistake. While we tried
to keep ABI intact (and we succeeded in doing that, programs compiled
on older kernels will work on newer ones) there is still a problem with
recompiling existing software with newer kernel headers.
New kernel headers will supply updated ioctl numbers and kernel will
expect that userspace will use struct input_keymap_entry to set and
retrieve keymap data. But since the names of ioctls are still the same
userspace will happily compile even if not adjusted to make use of the
new structure and will start miraculously fail in the field.
To avoid this issue let's revert EVIOCGKEYCODE/EVIOCSKEYCODE definitions
and add EVIOCGKEYCODE_V2/EVIOCSKEYCODE_V2 so that userspace can explicitly
select the style of ioctls it wants to employ.
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Jarod Wilson <jarod@redhat.com>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits)
Input: wacom - specify Cinitq supported tools
Input: ab8500-ponkey - fix IRQ freeing in error path
Input: adp5588-keys - use more obvious i2c_device_id name string
Input: ad7877 - switch to using threaded IRQ
Input: ad7877 - use attribute group to control visibility of attributes
Input: serio - add support for PS2Mult multiplexer protocol
Input: wacom - properly enable runtime PM
Input: ad7877 - filter events where pressure is beyond the maximum
Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting
Input: ad7877 - implement specified chip select behavior
Input: hp680_ts_input - use cancel_delayed_work_sync()
Input: mousedev - correct lockdep annotation
Input: ads7846 - switch to using threaded IRQ
Input: serio - support multiple child devices per single parent
Input: synaptics - simplify pass-through port handling
Input: add ROHM BU21013 touch panel controller support
Input: omap4-keypad - wake-up on events & long presses
Input: omap4-keypad - fix interrupt line configuration
Input: omap4-keypad - SYSCONFIG register configuration
Input: omap4-keypad - use platform device helpers
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (52 commits)
sched: fix RCU lockdep splat from task_group()
rcu: using ACCESS_ONCE() to observe the jiffies_stall/rnp->qsmask value
sched: suppress RCU lockdep splat in task_fork_fair
net: suppress RCU lockdep false positive in sock_update_classid
rcu: move check from rcu_dereference_bh to rcu_read_lock_bh_held
rcu: Add advice to PROVE_RCU_REPEATEDLY kernel config parameter
rcu: Add tracing data to support queueing models
rcu: fix sparse errors in rcutorture.c
rcu: only one evaluation of arg in rcu_dereference_check() unless sparse
kernel: Remove undead ifdef CONFIG_DEBUG_LOCK_ALLOC
rcu: fix _oddness handling of verbose stall warnings
rcu: performance fixes to TINY_PREEMPT_RCU callback checking
rcu: upgrade stallwarn.txt documentation for CPU-bound RT processes
vhost: add __rcu annotations
rcu: add comment stating that list_empty() applies to RCU-protected lists
rcu: apply TINY_PREEMPT_RCU read-side speedup to TREE_PREEMPT_RCU
rcu: combine duplicate code, courtesy of CONFIG_PREEMPT_RCU
rcu: Upgrade srcu_read_lock() docbook about SRCU grace periods
rcu: document ways of stalling updates in low-memory situations
rcu: repair code-duplication FIXMEs
448cd16 ("Input: evdev - rearrange ioctl handling") broke EVIOCSABS by
checking for the wrong direction bit.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Tested-by: Sven Neumann <s.neumann@raumfeld.com>
This fixes a regression introduced by the dynamic allocation of absinfo
for input devices. We need to bail out early for input devices which
don't have absolute axis.
[ 929.664303] Pid: 2989, comm: input Not tainted 2.6.36-rc8+ #14 MS-7260/MS-7260
[ 929.664318] EIP: 0060:[<c12bdc01>] EFLAGS: 00010246 CPU: 0
[ 929.664331] EIP is at evdev_ioctl+0x4f8/0x59f
[ 929.664341] EAX: 00000040 EBX: 00000000 ECX: 00000006 EDX: f45a1efc
[ 929.664355] ESI: 00000000 EDI: f45a1efc EBP: f45a1f24 ESP: f45a1eb8
[ 929.664369] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 929.664402] f470da74 f6a30e78 f462c240 00000018 bfe4a260 00000000 f45b06fc 00000000
[ 929.664429] <0> 000000c4 b769d000 c3544620 f470da74 f45b06fc f45b06fc f45a1f38 c107dd1f
[ 929.664458] <0> f4710b74 000000c4 00000000 00000000 00000000 0000029d 00000a74 f4710b74
[ 929.664500] [<c107dd1f>] ? handle_mm_fault+0x2be/0x59a
[ 929.664513] [<c12bd709>] ? evdev_ioctl+0x0/0x59f
[ 929.664524] [<c1099d30>] ? do_vfs_ioctl+0x494/0x4d9
[ 929.664538] [<c10432a1>] ? up_read+0x16/0x29
[ 929.664550] [<c101c818>] ? do_page_fault+0x2ff/0x32d
[ 929.664564] [<c108d048>] ? do_sys_open+0xc5/0xcf
[ 929.664575] [<c1099db6>] ? sys_ioctl+0x41/0x61
[ 929.664587] [<c1002710>] ? sysenter_do_call+0x12/0x36
[ 929.684570] ---[ end trace 11b83e923bd8f2bb ]---
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Several devices use a high number of bits for scancodes. One important
group is the Remote Controllers. Some new protocols like RC-6 define a
scancode space of 64 bits.
The current EVIO[CS]GKEYCODE ioctls allow replace the scancode/keycode
translation tables, but it is limited to up to 32 bits for scancode.
Also, if userspace wants to clean the existing table, replacing it by
a new one, it needs to run a loop calling the ioctls over the entire
sparse scancode space.
To solve those problems, this patch extends the ioctls to allow drivers
handle scancodes up to 32 bytes long (the length could be extended in
the future should such need arise) and allow userspace to query and set
scancode to keycode mappings not only by scancode but also by index.
Compatibility code were also added to handle the old format of
EVIO[CS]GKEYCODE ioctls.
Folded fixes by:
- Dan Carpenter: locking fixes for the original implementation
- Jarod Wilson: fix crash when setting keycode and wiring up get/set
handlers in original implementation.
- Dmitry Torokhov: rework to consolidate old and new scancode handling,
provide options to act either by index or scancode.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Split ioctl handling into 3 separate sections: fixed-length ioctls,
variable-length ioctls and multi-number variable length handlers.
This reduces identation and makes the code a bit clearer.
As all callers are now changed to only use the input_abs_*() access
helpers, switching over to dynamically allocated ABS information is
easy. This reduces size of struct input_dev from 3152 to 1640 on
64 bit architectures.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Change all call sites in drivers/input to not access the ABS axis
information directly anymore. Make them use the access helpers instead.
Also use input_set_abs_params() when possible.
Did some code refactoring as I was on it.
Cc: Dmitry Torokhov <dtor@mail.ru>
With the rapidly increasing number of intelligent multi-contact and
multi-user devices, the need to send digested, filtered information
from a set of different sources within the same device is imminent.
This patch adds the concept of slots to the MT protocol. The slots
enumerate a set of identified sources, such that all MT events
can be passed independently and selectively per identified source.
The protocol works like this: Instead of sending a SYN_MT_REPORT
event immediately after the contact data, one sends an ABS_MT_SLOT
event immediately before the contact data. The input core will only
emit events for slots with modified MT events. It is assumed that
the same slot is used for the duration of an initiated contact.
Acked-by: Rafi Rubin <rafi@seas.upenn.edu>
When the client buffer is very small and wraps around a lot, it may
well be that a write increases the head such that head == tail. If
this happens between the point where a poll is triggered and the
actual data is being read, there will be no data to read. This is
confusing to applications, which might end up closing the file.
This patch solves the problem by making sure the client buffer is
never empty after writing to it.
Some devices, in particular MT devices, produce a lot of data. This
may lead to overflowing of the event queues in evdev driver, which
by default are fairly small. Let the drivers hint the average number
of events per packet generated by the device, and use that information
when computing the buffer size evdev should use for the device.
Allocate the event buffer dynamically, and prepare to compute the
buffer size in a separate function. This patch defines the size
computation to be identical to the current code, and does not contain
any logical changes.
The HID layer has some scan codes of the form 0xffbc0000 for logitech
devices which do not work if scancode is typed as signed int, so we need
to switch to unsigned it instead. While at it keycode being signed does
not make much sense either.
Acked-by: Márton Németh <nm127@freemail.hu>
Acked-by: Matthew Garrett <mjg@redhat.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Seeking does not make sense for input interfaces such as evdev and joydev
so let's use nonseekable_open to mark them non-seekable.
When using realtime signals, we'll enqueue one signal for every event.
This is unfortunate, because (for example) keyboard presses are three
events: key, msc scancode, and syn. They'll be enqueued fast enough in
kernel space that all three events will be ready to read by the time
userspace runs, so the first invocation of the signal handler will read
all three events, but then the second two invocations still have to run
to do no work.
Instead, only send the SIGIO notification on syn events. This is a
slight abuse of SIGIO semantics, in principle it ought to fire as soon
as any events are readable. But it matches evdev semantics, which is
more important since SIGIO is rather vaguely defined to begin with.
Signed-off-by: Adam Jackson <ajax@redhat.com>
Commit 3d5cb60e ("Input: simplify name handling for certain input
handles") introduced a regression for the EVIOCGNAME/JSIOCGNAME
ioctl.
Before this, patch, the platform device's name was given back to
userspace which was good to identify devices. After this patch, the
device is ("event%d", minor) which is not descriptive at all.
This fixes the behaviour by taking dev->name.
Reviewed-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Synaptics uses anisotropic coordinate system. On some wide touchpads
vertical resolution can be twice as high as horizontal which causes
unequal sensitivity on x/y directions. Add support for reading the
resolution with EVIOCGABS ioctl.
Signed-off-by: Tero Saarni <tero.saarni@gmail.com>
For evdev, joydev and mousedev, instead of having a separate character array
holding name of the handle, use struct devce's name which is the same.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Most fasync implementations do something like:
return fasync_helper(...);
But fasync_helper() will return a positive value at times - a feature used
in at least one place. Thus, a number of other drivers do:
err = fasync_helper(...);
if (err < 0)
return err;
return 0;
In the interests of consistency and more concise code, it makes sense to
map positive return values onto zero where ->fasync() is called.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
As it is, all instances of ->release() for files that have ->fasync()
need to remember to evict file from fasync lists; forgetting that
creates a hole and we actually have a bunch that *does* forget.
So let's keep our lives simple - let __fput() check FASYNC in
file->f_flags and call ->fasync() there if it's been set. And lose that
crap in ->release() instances - leaving it there is still valid, but we
don't have to bother anymore.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Currently, evdev has working 32bit compatibility and uinput does not. uinput
needs the input_event code that evdev uses, so let's refactor it so it can
be shared.
[dtor@mail.ru: add fix for force feedback compat issues]
Signed-off-by: Philip Langdale <philipl@overt.org>
