The Zaurii drivers were partially fixed up for the IRQ register
changes, but unfortunately missed some bits, resulting in build
errors. Fix these.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Remove the numbered SW_* entries from the input system and assign names
to the existing users.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
* Change the scan interval from 100ms to 50ms. This stops the key
repeat from triggering on double letter presses.
* Remove unneeded stale hinge code from corgikbd
* Change unneeded corgi GPIO pins to inputs when suspended
* Add support for the headphone jack switch for both corgi and spitz
(as switch SW_2)
Some ARM platforms have the ability to program the interrupt controller to
detect various interrupt edges and/or levels. For some platforms, this is
critical to setup correctly, particularly those which the setting is dependent
on the device.
Currently, ARM drivers do (eg) the following:
err = request_irq(irq, ...);
set_irq_type(irq, IRQT_RISING);
However, if the interrupt has previously been programmed to be level sensitive
(for whatever reason) then this will cause an interrupt storm.
Hence, if we combine set_irq_type() with request_irq(), we can then safely set
the type prior to unmasking the interrupt. The unfortunate problem is that in
order to support this, these flags need to be visible outside of the ARM
architecture - drivers such as smc91x need these flags and they're
cross-architecture.
Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the
property that the device would like. The IRQ controller code should do its
best to select the most appropriate supported mode.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Input: convert drivers/input/keyboard to dynamic input_dev allocation
This is required for input_dev sysfs integration
The corgi keyboard has need of a switch event type with slightly type to the
input system as recommended by the input maintainer.
Cc: Vojtech Pavlik <vojtech@suse.cz>
The input system handles key state tracking so there's no need for the driver
to do so as well. Also tidy up some comment formatting and remove a now
unneeded function.
Add some power management code to the corgi keyboard driver so that only one
power event gets reported within any reasonable time frame and the driver
doesn't enter an infinte loop due to key repeat.
Fix a couple of compile errors in the corgi keyboard driver.
This patch converts kcalloc(1, ...) calls to use the new kzalloc() function.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
as function keys instead of special keys.
Signed-off-by: Vojtech Pavlik <vojtech@suse.cz>
infrastructure for it.
Let it rip!
