Let's switch the driver to use managed resources, this will simplify
error handling and driver unbinding logic.
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no
driver is bound) removes the need to set driver data field to
NULL.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to
save some platform_driver boilerplate code. Use it.
Signed-off-by: JJ Ding <dgdunix@gmail.com>
The ctrl_xxx routines are deprecated, switch over to the __raw_xxx
versions.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
... and we have few enough places using the latter to make it
simpler to do search and replace...
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias
is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable
"input" platform drivers, to re-enable auto loading.
[dbrownell@users.sourceforge.net: more drivers, registration fixes]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This patch fixes the HP Jornada 6xx keyboard default keymap which had some
bad keymap values. This resulted in wrong key being returned when pressed
(for example, key 'y' returned 'r').
Also, while we are at it lets arrange the include files in alphabetical order.
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
