path: root/drivers/input/keyboard/qt1070.c
2011-06-21Input: qt1070 - remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata pointer on exit or error. This is not required anymore since the core will do it for us. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-04-27Input: qt1070 - add MODULE_DEVICE_TABLEAxel Lin
Adding the necessary MODULE_DEVICE_TABLE() information allows the driver to be automatically loaded by udev Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-13Input: add Atmel AT42QT1070 keypad driverBo Shen
The AT42QT1070 QTouch sensor supports up to 7 keys. The driver has been tested on Atmel AT91SAM9M10-G45-EK board, and it should work fine on other platforms. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
