path: root/drivers/input/keyboard/spitzkbd.c
2008-05-21MODULE_LICENSE expects "GPL v2", not "GPLv2"Al Viro
... and we have few enough places using the latter to make it simpler to do search and replace... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: wacom - add support for Cintiq 20WSX Input: ucb1400_ts - IRQ probe fix Input: at32psif - update MODULE_AUTHOR with new email Input: mac_hid - add lockdep annotation to emumousebtn Input: i8042 - fix incorrect usage of strncpy and strncat Input: bf54x-keys - add infrastructure for keypad wakeups Input: add MODULE_ALIAS() to hotpluggable platform modules Input: drivers/char/keyboard.c - use time_after Input: fix ordering in joystick Makefile Input: wm97xx-core - support use as a wakeup source Input: wm97xx-core - use IRQF_SAMPLE_RANDOM Input: wm97xx-core - only schedule interrupt handler if not already scheduled Input: add Zhen Hua driver Input: aiptek - add support for Genius G-PEN 560 tablet Input: wacom - implement suspend and autosuspend Input: xpad - set proper buffer length for outgoing requests Input: omap-keypad - fix build warning Input: gpio_keys - irq handling cleanup Input: add PS/2 serio driver for AVR32 devices Input: put ledstate in the keyboard notifier ...
2008-04-24Input: add MODULE_ALIAS() to hotpluggable platform modulesKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable "input" platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-03Input: spitzkbd - fix suspend key handlingRichard Purdie
The spitz keyboard driver reports KEY_SUSPEND events but doesn't register its use of this event in the keybit bitfield, breaking input events for this key. This patch fixes that by registering the key in the keybit bitfield. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-12Input: keyboards - switch to using input_dev->dev.parentDmitry Torokhov
In preparation for struct class_device -> struct device input core conversion, switch to using input_dev->dev.parent when specifying device position in sysfs tree. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-04-12Input: drivers/input/keyboard - don't access dev->private directlyDmitry Torokhov
Use input_get_drvdata() and input_set_drvdata() instead. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-11-05Input: keyboards - handle errors when registering input devicesDmitry Torokhov
2006-10-15[ARM] Fix Zaurii keyboard/touchscreen driversRussell King
The Zaurii drivers were partially fixed up for the IRQ register changes, but unfortunately missed some bits, resulting in build errors. Fix these. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-29Input: change from numbered to named switchesRichard Purdie
Remove the numbered SW_* entries from the input system and assign names to the existing users. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-26Input: spitzkbd - fix the reversed Address and Calender keysRichard Purdie
2006-03-14Input: zaurus keyboard driver updatesRichard Purdie
* Change the scan interval from 100ms to 50ms. This stops the key repeat from triggering on double letter presses. * Remove unneeded stale hinge code from corgikbd * Change unneeded corgi GPIO pins to inputs when suspended * Add support for the headphone jack switch for both corgi and spitz (as switch SW_2) Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-08[PATCH] IRQ type flagsRussell King
Some ARM platforms have the ability to program the interrupt controller to detect various interrupt edges and/or levels. For some platforms, this is critical to setup correctly, particularly those which the setting is dependent on the device. Currently, ARM drivers do (eg) the following: err = request_irq(irq, ...); set_irq_type(irq, IRQT_RISING); However, if the interrupt has previously been programmed to be level sensitive (for whatever reason) then this will cause an interrupt storm. Hence, if we combine set_irq_type() with request_irq(), we can then safely set the type prior to unmasking the interrupt. The unfortunate problem is that in order to support this, these flags need to be visible outside of the ARM architecture - drivers such as smc91x need these flags and they're cross-architecture. Finally, the SA_TRIGGER_* flag passed to request_irq() should reflect the property that the device would like. The IRQ controller code should do its best to select the most appropriate supported mode. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] drivers/input/keyboard: convert to dynamic input_dev allocationDmitry Torokhov
Input: convert drivers/input/keyboard to dynamic input_dev allocation This is required for input_dev sysfs integration Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-14[ARM] 3014/1: Spitz keyboard: Correct the right shift keyRichard Purdie
Patch from Richard Purdie Correct the right shift key entry in the spitz keyboard driver. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-13[PATCH] SharpSL: Add an input keyboard driver for Zaurus cxx00 seriesRichard Purdie
Add a input driver for the keyboard found on the Zaurus Cxx00 series (Spitz, Akita, Borzoi). Its based on corgikbd but there are enough subtle differences to justify a separate driver. Signed-Off-by: Richard Purdie <rpurdie@rpsys.net> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
