commit 5b189201993ab03001a398de731045bfea90c689 upstream.
A helper purported to look up a child node based on its name was using
the wrong of-helper and ended up prematurely freeing the parent of-node
while searching the whole device tree depth-first starting at the parent
node.
Fixes: 64b9e4d803b1 ("input: twl4030-vibra: Support for DT booted kernel")
Fixes: e661d0a04462 ("Input: twl4030-vibra - fix ERROR: Bad of_node_put() warning")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit dcaf12a8b0bbdbfcfa2be8dff2c4948d9844b4ad upstream.
Fix child-node lookup during probe, which ended up searching the whole
device tree depth-first starting at parent rather than just matching on
its children.
Later sanity checks on node properties (which would likely be missing)
should prevent this from causing much trouble however, especially as the
original premature free of the parent node has already been fixed
separately (but that "fix" was apparently never backported to stable).
Fixes: e7ec014a47e4 ("Input: twl6040-vibra - update for device tree support")
Fixes: c52c545ead97 ("Input: twl6040-vibra - fix DT node memory management")
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: H. Nikolaus Schaller <hns@goldelico.com> (on Pyra OMAP5 hardware)
commit ea04efee7635c9120d015dcdeeeb6988130cb67a upstream.
Before trying to use CDC union descriptor, try to validate whether that it
is sane by checking that intf->altsetting->extra is big enough and that
descriptor bLength is not too big and not too small.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ac2ee9ba953afe88f7a673e1c0c839227b1d7891 upstream.
Make sure to check the number of endpoints to avoid dereferencing a
NULL-pointer should a malicious device lack endpoints.
Fixes: c04148f915e5 ("Input: add driver for USB VoIP phones with CM109...")
commit 5cc4a1a9f5c179795c8a1f2b0f4361829d6a070e upstream.
Fixes: aca951a22a1d ("[PATCH] input-driver-yealink-P1K-usb-phone")
commit 1916d319271664241b7aa0cd2b05e32bdb310ce9 upstream.
NULL-pointer should a malicious device lack control-interface endpoints.
Fixes: 628329d52474 ("Input: add IMS Passenger Control Unit driver")
commit 601bbbe0517303c9f8eb3d75e11d64efed1293c9 upstream.
If user tries to initialize uinput device mixing old and new style
initialization (i.e. using old UI_SET_ABSBIT instead of UI_ABS_SETUP,
we forget to allocate input->absinfo and will crash when trying to send
absolute events:
ioctl(ui, UI_DEV_SETUP, &us);
ioctl(ui, UI_SET_PHYS, "Test");
ioctl(ui, UI_SET_EVBIT, EV_ABS);
ioctl(ui, UI_SET_ABSBIT, ABS_X);
ioctl(ui, UI_SET_ABSBIT, ABS_Y);
ioctl(ui, UI_DEV_CREATE, 0);
Reported-by: Rodrigo Rivas Costa <rodrigorivascosta@gmail.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191811
Fixes: fbae10db0940 ("Input: uinput - rework ABS validation")
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 5a8a6b89c15766446d845671d574a9243b6d8786 upstream.
We were assigning I2C bus controller instead of client as parent device.
Besides being logically wrong, it messed up with devm handling of input
device. As a result we were leaving input device and event node behind
after rmmod-ing the driver, which lead to a kernel oops if one were to
access the event node later.
Let's remove the assignment and rely on devm_input_allocate_device() to
set it up properly for us.
Signed-off-by: Jingkui Wang <jkwang@google.com>
Fixes: 7132fe4f5687 ("Input: drv260x - add TI drv260x haptics driver")
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"You will get
- a new driver for Elan eKTF2127 touchscreen controllers
- a new "gpio-decoder" driver to read and report state of several
GPIO lines
- an ADC resistor ladder driver
- the ft6326 driver is removed because edt-ft5x06 handles the same
devices just fine.
.. plus the regular slew of driver fixes/enhancements"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (26 commits)
Input: elan_i2c - fix return tests of i2c_smbus_read_block_data()
Input: ektf2127 - mark PM functions as __maybe_unused
Input: snvs_pwrkey - drop input_free_device call if input_register_device fails
Input: add support for Elan eKTF2127 touchscreen controller
Input: serio - add hangup support
Input: tps65218-pwrbutton - add support for tps65217 variant
Input: jornada720_ts - get rid of mach/irqs.h and mach/hardware.h includes
Input: jornada720_kbd - remove unneeded mach/hardware.h include
Input: focaltech - mark focaltech_set_resolution() static
Input: wdt87xx_i2c - fix the flash erase issue
Input: gpio-keys-polled - don't use unit-address with button nodes
Input: add generic input driver to read encoded GPIO lines
Input: add ADC resistor ladder driver
Input: pegasus_notetaker - directly include workqueue header
Input: elants_i2c - get product id on recovery mode for FW update
Input: wm97xx - remove deprecated create_singletheread_workqueue
Input: mc13783_ts - remove deprecated create_singletheread_workqueue
Input: psmouse - remove deprecated create_singletheread_workqueue
Input: jornada720_kbd - switch to using dev_dbg
Input: jornada720_kbd - get rid of mach/irqs.h include
The power button found in tps65217 device is very similar to the tps65218,
so let's enhance the driver to support both variants.
This driver enables us to use tps65217's power button as KEY_POWER on
am335x boards (directly connected button in chiliboard, accessible pin
via expansion header in beaglebone). This patch has been tested with
chiliboard.
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
Many modules call misc_register and misc_deregister in its module init
and exit methods without any additional code. This ends up being
boilerplate. This patch adds helper macro module_misc_device(), that
replaces module_init()/ module_exit() with template functions.
This patch also converts drivers to use new macro.
Change since v1:
Add device.h include in miscdevice.h as module_driver macro was not
available from other include files in some architectures.
Signed-off-by: PrasannaKumar Muralidharan <prasannatsmkumar@gmail.com>
Add a driver to read group of GPIO lines and provide its status as a
numerical value as input event to the system. This will help in
interfacing devices, that can be connected over GPIOs, that provide
input to the system by driving GPIO lines connected to them like a
rotary dial or a switch.
For example, a rotary switch can be connected to four GPIO lines. The
status of the GPIO lines reflect the actual position of the rotary
switch dial. For example, if dial points to 9, then the four GPIO lines
connected to the switch will read HLLH(0b'1001 = 9). This value
can be reported as an ABS_* event to the input subsystem.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Acked-by: Rob Herring <robh@kernel.org>
Change my email address to kernel.org instead of Samsung one for the
purpose of any future contact. The copyrights remain untouched and are
attributed to Samsung.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Pull more input updates from Dmitry Torokhov:
"Two new drivers for touchscreen controllers:
- Silead touchscreen controllers
- SiS 9200 family touchscreen controllers
and a few driver fixes"
Input: silead - remove some dead code
Input: sis-i2c - select CONFIG_CRC_ITU_T
Input: add driver for SiS 9200 family I2C touchscreen controllers
Input: ili210x - fix permissions on "calibrate" attribute
Input: elan_i2c - properly wake up touchpad on ASUS laptops
Input: add driver for Silead touchscreens
Input: elantech - fix debug dump of the current packet
Input: rotary_encoder - support binary encoding of states
Input: xpad - power off wireless 360 controllers on suspend
Input: i8042 - break load dependency between atkbd/psmouse and i8042
Input: synaptics-rmi4 - do not check for NULL when calling of_node_put()
Input: cros_ec_keyb - cleanup use of dev
It's not advisable to use this encoding, but to support existing devices
add support for this to the driver.
Pull input updates from Dmitry Torokhov:
"Updates for the input subsystem. This contains the following new
drivers promised in the last merge window:
- driver for touchscreen controller found in Surface 3
- driver for Pegasus Notetaker tablet
- driver for Atmel Captouch Buttons
- driver for Raydium I2C touchscreen controllers
- powerkey driver for HISI 65xx SoC
plus a few fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits)
Input: tty/vt/keyboard - use memdup_user()
Input: pegasus_notetaker - set device mode in reset_resume() if in use
Input: pegasus_notetaker - cancel workqueue's work in suspend()
Input: pegasus_notetaker - fix usb_autopm calls to be balanced
Input: pegasus_notetaker - handle usb control msg errors
Input: wacom_w8001 - handle errors from input_mt_init_slots()
Input: wacom_w8001 - resolution wasn't set for ABS_MT_POSITION_X/Y
Input: pixcir_ts - add support for axis inversion / swapping
Input: icn8318 - use of_touchscreen helpers for inverting / swapping axes
Input: edt-ft5x06 - add support for inverting / swapping axes
Input: of_touchscreen - add support for inverted / swapped axes
Input: synaptics-rmi4 - use the RMI_F11_REL_BYTES define in rmi_f11_rel_pos_report
Input: synaptics-rmi4 - remove unneeded variable
Input: synaptics-rmi4 - remove pointer to rmi_function in f12_data
Input: synaptics-rmi4 - support regulator supplies
Input: raydium_i2c_ts - check CRC of incoming packets
Input: xen-kbdfront - prefer xenbus_write() over xenbus_printf() where possible
Input: fix a double word "is is" in include/linux/input.h
Input: add powerkey driver for HISI 65xx SoC
Input: apanel - spelling mistake - "skiping" -> "skipping"
Sync up to bring in wacom_w8001 changes to avoid merge conflicts later.
... as being the simpler variant.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
This driver provides a input driver for the power button on the
HiSi 65xx SoC for boards like HiKey.
This driver was originally by Zhiliang Xue <xuezhiliang@huawei.com>
then basically rewritten by Jorge, but preserving the original
module author credits.
Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
[jstultz: Reworked commit message, folded in other fixes/cleanups
from Jorge, implemented some larger cleanups suggested by DmitryT]
Signed-off-by: John Stultz <john.stultz@linaro.org>
trivial fix to spelling mistake in pr_notice message
Trivial fix to spelling mistake
Let's bring in HDMI CEC defines to ease merging CEC support in the next
merge window.
Pull more input subsystem updates from Dmitry Torokhov:
"Just a few more driver fixes; new drivers will be coming in the next
merge window"
Input: pwm-beeper - fix - scheduling while atomic
Input: xpad - xbox one elite controller support
Input: xpad - add more third-party controllers
Input: xpad - prevent spurious input from wired Xbox 360 controllers
Input: xpad - move pending clear to the correct location
Input: uinput - handle compat ioctl for UI_SET_PHYS
Pwm config may sleep so defer it using a worker.
On a Freescale i.MX53 based board we ran into "BUG: scheduling while
atomic" because input_inject_event locks interrupts, but
imx_pwm_config_v2 sleeps.
Tested on Freescale i.MX53 SoC with 4.6.0.
Signed-off-by: Manfred Schlaegl <manfred.schlaegl@gmx.at>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This set of changes introduces an atomic API to the PWM subsystem.
This is influenced by the DRM atomic API that was introduced a while
back, though it is obviously a lot simpler. The fundamental idea
remains the same, though: drivers provide a single callback to
implement the atomic configuration of a PWM channel.
As a side-effect the PWM subsystem gains the ability for initial state
retrieval, so that the logical state mirrors that of the hardware.
Many use-cases don't care about this, but for others it is essential.
These new features require changes in all users, which these patches
take care of. The core is transitioned to use the atomic callback if
available and provides a fallback mechanism for other drivers.
Changes to transition users and drivers to the atomic API are
postponed to v4.8"
* tag 'pwm/for-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (30 commits)
pwm: Add information about polarity, duty cycle and period to debugfs
pwm: Switch to the atomic API
pwm: Update documentation
pwm: Add core infrastructure to allow atomic updates
pwm: Add hardware readout infrastructure
pwm: Move the enabled/disabled info into pwm_state
pwm: Introduce the pwm_state concept
pwm: Keep PWM state in sync with hardware state
ARM: Explicitly apply PWM config extracted from pwm_args
drm: i915: Explicitly apply PWM config extracted from pwm_args
input: misc: pwm-beeper: Explicitly apply PWM config extracted from pwm_args
input: misc: max8997: Explicitly apply PWM config extracted from pwm_args
backlight: lm3630a: explicitly apply PWM config extracted from pwm_args
backlight: lp855x: Explicitly apply PWM config extracted from pwm_args
backlight: lp8788: Explicitly apply PWM config extracted from pwm_args
backlight: pwm_bl: Use pwm_get_args() where appropriate
fbdev: ssd1307fb: Use pwm_get_args() where appropriate
regulator: pwm: Use pwm_get_args() where appropriate
leds: pwm: Use pwm_get_args() where appropriate
input: misc: max77693: Use pwm_get_args() where appropriate
When running a 32-bit userspace on a 64-bit kernel, the UI_SET_PHYS
ioctl needs to be treated with special care, as it has the pointer
size encoded in the command.
Signed-off-by: Ricky Liang <jcliang@chromium.org>
The newly added Atmal captouch driver fails to build when CONFIG_I2C
is disabled:
drivers/input/misc/atmel_captouch.c: In function 'atmel_read':
drivers/input/misc/atmel_captouch.c:115:8: error: implicit declaration of function 'i2c_transfer' [-Werror=implicit-function-declaration]
This adds an explicit Kconfig dependency to prevent the broken
configuration.
Fixes: b06d43f7a3db ("Input: add Atmel Captouch Button driver")
"First round of updates for the input subsystem. No new drivers here,
just some driver fixes"
Input: rotary-encoder - fix bare use of 'unsigned'
Input: cm109 - spin_lock in complete() cleanup
Input: cm109 - fix handling of volume and mute buttons
Input: byd - don't wipe dynamically allocated memory twice
Input: twl4030 - fix unsafe macro definition
Input: twl6040-vibra - remove mutex
Input: bcm_iproc_tsc - DT spelling s/clock-name/clock-names/
Input: bcm_iproc_tsc - use syscon to access shared registers
Input: ti_am335x_tsc - use SIMPLE_DEV_PM_OPS
Input: omap-keypad - remove set_col_gpio_val() and get_row_gpio_val()
Input: omap-keypad - drop empty PM stubs
Input: omap-keypad - remove adjusting of scan delay
Input: gpio-keys - clean up device tree binding example
Input: kbtab - stop saving struct usb_device
Input: gtco - stop saving struct usb_device
Input: aiptek - stop saving struct usb_device
Input: acecad - stop saving struct usb_device
Add I2C driver for Atmel Capacitive Touch Button device.
Signed-off-by: Hung-yu Wu <hywu@google.com>
Signed-off-by: Grant Grundler <grundler@chromium.org>
Call pwm_apply_args() just after requesting the PWM device so that the
polarity and period are initialized according to the information
provided in pwm_args.
This is an intermediate state, and pwm_apply_args() should be dropped as
soon as the atomic PWM infrastructure is in place and the driver makes
use of it.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
use of it.
The PWM framework has clarified the concept of reference PWM config (the
platform dependent config retrieved from the DT or the PWM lookup table)
and real PWM state.
Use pwm_get_args() when the PWM user wants to retrieve this reference
config and not the current state.
This is part of the rework allowing the PWM framework to support
hardware readout and expose real PWM state even when the PWM has just
been requested (before the user calls pwm_config/enable/disable()).
Prepare first round of input updates for 4.7 merge window.
Pull input subsystem fixes from Dmitry Torokhov.
Input: max8997-haptic - fix NULL pointer dereference
Input: byd - update copyright header
commit e7ec014a47e4 ("Input: twl6040-vibra - update for device tree support")
made the separate vibra DT node to a subnode of the twl6040.
It now calls of_find_node_by_name() to locate the "vibra" subnode.
This function has a side effect to call of_node_put on() for the twl6040
parent node passed in as a parameter. This causes trouble later on.
Solution: we must call of_node_get() before of_find_node_by_name()
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
fix checkpatch.pl warning about 'Prefer 'unsigned int' to bare use of
'unsigned''
Signed-off-by: Clifton Barnes <clifton.a.barnes@gmail.com>
NULL pointer derefence happens when booting with DTB because the
platform data for haptic device is not set in supplied data from parent
MFD device.
The MFD device creates only platform data (from Device Tree) for itself,
not for haptic child.
Unable to handle kernel NULL pointer dereference at virtual address 0000009c
pgd = c0004000
[0000009c] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
(max8997_haptic_probe) from [<c03f9cec>] (platform_drv_probe+0x4c/0xb0)
(platform_drv_probe) from [<c03f8440>] (driver_probe_device+0x214/0x2c0)
(driver_probe_device) from [<c03f8598>] (__driver_attach+0xac/0xb0)
(__driver_attach) from [<c03f67ac>] (bus_for_each_dev+0x68/0x9c)
(bus_for_each_dev) from [<c03f7a38>] (bus_add_driver+0x1a0/0x218)
(bus_add_driver) from [<c03f8db0>] (driver_register+0x78/0xf8)
(driver_register) from [<c0101774>] (do_one_initcall+0x90/0x1d8)
(do_one_initcall) from [<c0a00dbc>] (kernel_init_freeable+0x15c/0x1fc)
(kernel_init_freeable) from [<c06bb5b4>] (kernel_init+0x8/0x114)
(kernel_init) from [<c0107938>] (ret_from_fork+0x14/0x3c)
Cc: <stable@vger.kernel.org>
Fixes: 104594b01ce7 ("Input: add driver support for MAX8997-haptic")
[k.kozlowski: Write commit message, add CC-stable]
Pull input fixes from Dmitry Torokhov.
Input: atmel_mxt_ts - use mxt_acquire_irq in mxt_soft_reset
Input: zforce_ts - fix dual touch recognition
Input: twl6040-vibra - fix atomic schedule panic
Complete() will be run with interrupt enabled, so change to
spin_lock_irqsave().
Signed-off-by: Ming Lei <ming.lei@canonical.com>
The CM109 driver reported key press events of volume up / down and
record / playback mute buttons, but no release events. Report those events
properly by handling volume and mute keys seperately. For the record and
playback mute buttons, only presses are registered by the CM109, therefore
simulate press-n-release. This fixes the volume control buttons of various
USB headsets.
Signed-off-by: Florian Euchner <florian.euchner@gmail.com>
The mutex does not seem to be needed. twl4030-vibra doesn't
use one either.
commit c6f39257c952 ("mfd: twl6040: Use regmap for register cache")
did remove the private cache for the vibra control registers and replaced
access within twl6040_get_vibralr_status() by calls to regmap. This is OK,
as long as twl6040_get_vibralr_status() uses already cached values or is
not called from interrupt context. But we call this in vibra_play() for
checking that the vibrator is not configured for audio mode.
The result is a "BUG: scheduling while atomic" if the first use of the
twl6040 is a vibra effect, because the first fetch is by reading the
twl6040 registers through (blocking) i2c and not from the cache.
As soon as the regmap has cached the status, further calls are fine.
The solution is to move the condition to the work() function which
runs in context that can block.
The original code returns -EBUSY, but the return value of ->play()
functions is ignored anyways. Hence, we do not loose functionality
by not returning an error but just reporting the issue to INFO loglevel.
Tested-on: Pyra (omap5) prototype
Pull input subsystem fixes from Dmitry Torokhov:
"Just minor driver fixes"
Input: twl4030-vibra - do not reparent to grandparent
Input: twl6040-vibra - do not reparent to grandparent
Input: twl6040-vibra - ignore return value of schedule_work
Input: twl6040-vibra - fix NULL pointer dereference by removing workqueue
Input: pmic8xxx-pwrkey - fix algorithm for converting trigger delay
Input: arizona-haptic - don't assign input_dev parent
Input: clarify we want BTN_TOOL_<name> on proximity
Input: xpad - add Mad Catz FightStick TE 2 VID/PID
Input: gtco - fix crash on detecting device without endpoints
For devm-managed input devices we should not modify input device's parent,
otherwise automatic release of resources will not work properly.
Tested-by: "H. Nikolaus Schaller" <hns@goldelico.com>
Returning ret is wrong. And checking for an error as well. User space
may call multiple times until the work is really scheduled.
twl4030-vibra.c also ignores the return value.
commit 21fb9f0d5e91 ("Input: twl6040-vibra - use system workqueue")
says that it switches to use the system workqueue but it did neither
- remove the workqueue struct variable
- replace code to really use the system workqueue
Instead it calls queue_work() on uninitialized info->workqueue.
The result is a NULL pointer dereference in vibra_play().
Solution: use schedule_work
The trigger delay algorithm that converts from microseconds to
the register value looks incorrect. According to most of the PMIC
documentation, the equation is
delay (Seconds) = (1 / 1024) * 2 ^ (x + 4)
except for one case where the documentation looks to have a
formatting issue and the equation looks like
delay (Seconds) = (1 / 1024) * 2 x + 4
Most likely this driver was written with the improper
documentation to begin with. According to the downstream sources
the valid delays are from 2 seconds to 1/64 second, and the
latter equation just doesn't make sense for that. Let's fix the
algorithm and the range check to match the documentation and the
downstream sources.
Reported-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Fixes: 92d57a73e410 ("input: Add support for Qualcomm PMIC8XXX power key")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Tested-by: John Stultz <john.stultz@linaro.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
We shouldn't assign the parent device of the input_dev to be the
parent MFD device, because this will be used for devres which causes
input_unregister_device to run after the haptics device has been
removed, since it is itself a child of the MFD device. The default
of using the haptics device itself as the parent is correct.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Merge fourth patch-bomb from Andrew Morton:
"A lot more stuff than expected, sorry. A bunch of ocfs2 reviewing was
finished off.
- mhocko's oom-reaper out-of-memory-handler changes
- ocfs2 fixes and features
- KASAN feature work
- various fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (42 commits)
thp: fix typo in khugepaged_scan_pmd()
MAINTAINERS: fill entries for KASAN
mm/filemap: generic_file_read_iter(): check for zero reads unconditionally
kasan: test fix: warn if the UAF could not be detected in kmalloc_uaf2
mm, kasan: stackdepot implementation. Enable stackdepot for SLAB
arch, ftrace: for KASAN put hard/soft IRQ entries into separate sections
mm, kasan: add GFP flags to KASAN API
mm, kasan: SLAB support
kasan: modify kmalloc_large_oob_right(), add kmalloc_pagealloc_oob_right()
include/linux/oom.h: remove undefined oom_kills_count()/note_oom_kill()
mm/page_alloc: prevent merging between isolated and other pageblocks
drivers/memstick/host/r592.c: avoid gcc-6 warning
ocfs2: extend enough credits for freeing one truncate record while replaying truncate records
ocfs2: extend transaction for ocfs2_remove_rightmost_path() and ocfs2_update_edge_lengths() before to avoid inconsistency between inode and et
ocfs2/dlm: move lock to the tail of grant queue while doing in-place convert
ocfs2: solve a problem of crossing the boundary in updating backups
ocfs2: fix occurring deadlock by changing ocfs2_wq from global to local
ocfs2/dlm: fix BUG in dlm_move_lockres_to_recovery_list
ocfs2/dlm: fix race between convert and recovery
ocfs2: fix a deadlock issue in ocfs2_dio_end_io_write()
