commit a7ef82aee91f26da79b981b9f5bca43b8817d3e4 upstream.
Sometimes on Dell Latitude laptops psmouse/alps driver receive invalid ALPS
protocol V3 packets with bit7 set in last byte. More often it can be
reproduced on Dell Latitude E6440 or E7440 with closed lid and pushing
cover above touchpad.
If bit7 in last packet byte is set then it is not valid ALPS packet. I was
told that ALPS devices never send these packets. It is not know yet who
send those packets, it could be Dell EC, bug in BIOS and also bug in
touchpad firmware...
With this patch alps driver does not process those invalid packets, but
instead of reporting PSMOUSE_BAD_DATA, getting into out of sync state,
getting back in sync with the next byte and spam dmesg we return
PSMOUSE_FULL_PACKET. If driver is truly out of sync we'll fail the checks
on the next byte and report PSMOUSE_BAD_DATA then.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
commit 9d720b34c0a432639252f63012e18b0507f5b432 upstream.
On some Dell Latitude laptops ALPS device or Dell EC send one invalid byte
in 6 bytes ALPS packet. In this case psmouse driver enter out of sync
state. It looks like that all other bytes in packets are valid and also
device working properly. So there is no need to do full device reset, just
need to wait for byte which match condition for first byte (start of
packet). Because ALPS packets are bigger (6 or 8 bytes) default limit is
small.
This patch increase number of invalid bytes to size of 2 ALPS packets which
psmouse driver can drop before do full reset.
Resetting ALPS devices take some time and when doing reset on some Dell
laptops touchpad, trackstick and also keyboard do not respond. So it is
better to do it only if really necessary.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit 4ab8f7f320f91f279c3f06a9795cfea5c972888a upstream.
5th and 6th byte of ALPS trackstick V3 protocol match condition for first
byte of PS/2 3 bytes packet. When driver enters out of sync state and ALPS
trackstick is sending data then driver match 5th, 6th and next 1st bytes as
PS/2.
It basically means if user is using trackstick when driver is in out of
sync state driver will never resync. Processing these bytes as 3 bytes PS/2
data cause total mess (random cursor movements, random clicks) and make
trackstick unusable until psmouse driver decide to do full device reset.
Lot of users reported problems with ALPS devices on Dell Latitude E6440,
E6540 and E7440 laptops. ALPS device or Dell EC for unknown reason send
some invalid ALPS PS/2 bytes which cause driver out of sync. It looks like
that i8042 and psmouse/alps driver always receive group of 6 bytes packets
so there are no missing bytes and no bytes were inserted between valid
ones.
This patch does not fix root of problem with ALPS devices found in Dell
Latitude laptops but it does not allow to process some (invalid)
subsequence of 6 bytes ALPS packets as 3 bytes PS/2 when driver is out of
sync.
So with this patch trackstick input device does not report bogus data when
also driver is out of sync, so trackstick should be usable on those
machines.
This adds support for another flavor of ALPS protocol used in newer
"Dolphin" devices.
Signed-off-by: Yunkang Tang <yunkang.tang@cn.alps.com>
The device uses special MPU controller that necessitates the new
initialization sequence for the device. We also define a new protocol for
the trackpad that allows reporting better resolution than older V2
protocol.
Change the dev2's name from "PS/2 Mouse" to "ALPS PS/2 Device".
This form is more concise.
These touchpads use a different protocol; they have been seen on Dell
N5110, Dell 17R SE, and others.
The official ALPS driver identifies them by looking for an exact match
on the E7 report: 73 03 50. Dolphin V1 returns an EC report of
73 01 xx (02 and 0d have been seen); Dolphin V2 returns an EC report of
73 02 xx (02 has been seen).
Dolphin V2 probably needs a different initialization sequence and/or
report parser, so it is left for a future commit.
Signed-off-by: Dave Turvene <dturvene@dahetral.com>
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Now that alps_identify() explicitly issues an EC report using
alps_rpt_cmd(), we no longer need to look at the magic numbers returned
by alps_enter_command_mode().
Separate out the common trackstick probe/setup sequences, then call them
from each of the v3 init functions.
Credits: Emmanual Thome furnished the information on the trackstick init
and how it affected the report format.
Tested-by: Dave Turvene <dturvene@dahetral.com>
Rushmore touchpads are found on Dell E6230/E6430/E6530. They use the V3
protocol with slightly tweaked init sequences and report formats.
The E7 report is 73 03 0a, and the EC report is 88 08 1d
Credits: Emmanuel Thome reported the MT bitmap changes.
A number of different ALPS touchpad protocols can reuse
alps_process_touchpad_packet_v3() with small tweaks to the bitfield
decoding. Create a new priv->decode_fields() callback that handles the
per-model differences.
Newer touchpads use different constants, so make them runtime-
configurable.
Pinnacle class devices should return "88 07 xx" or "88 08 xx" when
entering command mode. If either the first byte or the second byte is
invalid, return an error.
The official ALPS driver uses the EC report, not the E7 report, to detect
these devices. Also, they check for a range of values; the original
table-based code only checked for two specific ones.
This allows alps_identify() to override these settings based on the
device characteristics, if it is ever necessary.
In anticipation of adding more ALPS protocols and more per-device quirks,
use function pointers instead of switch statements to call functions that
differ from one device to the next.
If the E6 report test passes, get the E7 and EC reports right away and
then try to match an entry in the table.
Pass in the alps_data struct, so that the detection code will be able to
set operating parameters based on information found during detection.
Change the version (psmouse->model) to report the protocol version only,
in preparation for supporting models that do not show up in the ID table.
Several ALPS driver init sequences repeat a command three times, then
issue PSMOUSE_CMD_GETINFO to read the result. Move this into a helper
function to simplify the code.
This will minimize the number of forward declarations needed when
alps_get_model() starts assigning function pointers.
Not every type of ALPS touchpad is well-suited to table-based detection.
Start moving the various alps_model_data attributes into the alps_data
struct so that we don't need a unique table entry for every possible
permutation of protocol version, flags, byte0/mask0, etc.
Preparing to move more repeated code into the mt core, add a flags
argument to the input_mt_slots_init() function.
Reviewed-and-tested-by: Benjamin Tissoires <benjamin.tissoires@enac.fr>
Tested-by: Ping Cheng <pingc@wacom.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Instead of open-coded reporting number of fingers on the touchpad
let's use input_mt_report_finger_count() helper.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
This patch adds semi-MT support for ALPS v4 protocol touchpads.
It is based on the work by Seth Forshee for ALPS v3 and v4 protocol
support. Three packets are required to assemble and process the MT
data. ST events are reported at once to avoid latency. If there
were two contacts or more, report MT data instead of ST events.
Thanks to Seth Forshee for providing most of the code, guidance
and insight for producing this patch.
Signed-off-by: George Pantalos <gpantalos@gmail.com>
ALPS touchpad detection fails if some buttons of ALPS are pressed.
The reason is that the "E6" query response byte is different from
what is expected.
This was tested on a Toshiba Portege R500.
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Akio Idehara <zbe64533@gmail.com>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: Chase Douglas <chase.douglas@canonical.com>
This patch adds support for two ALPS touchpad protocols not
supported currently by the driver, which I am arbitrarily naming
version 3 and version 4. Support is single-touch only at this time,
although both protocols are capable of limited multitouch support.
Thanks to Andrew Skalski, who did the initial reverse-engineering
of the v3 protocol.
In preparation for version 4 protocol support, which has 8-byte
data packets, remove all hard-coded assumptions about packet size
and use psmouse->pktsize instead.
In preparation for adding support for more ALPS protocol versions,
add a field for the protocol version to the model info instead of
using a field in the flags. OLDPROTO and !OLDPROTO are now called
version 1 and version 2, repsectively.
In preparation for new protocol support, move the protocol
information currently documented in alps.c to
Documentation/input/alps.txt, where it can be expanded without
cluttering up the driver.
This will ensure our reporting is consistent with the rest of the system
and we do not refer to obsolete source file names.
Reviewed-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Reviewed-by: JJ Ding <dgdunix@gmail.com>
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: joydev - allow binding to button-only devices
Input: elantech - ignore high bits in the position coordinates
Input: elantech - allow forcing Elantech protocol
Input: elantech - fix firmware version check
Input: ati_remote - add some missing devices from lirc_atiusb
Input: eeti_ts - cancel pending work when going to suspend
Input: Add support of Synaptics Clickpad device
Revert "Input: ALPS - add signature for HP Pavilion dm3 laptops"
Input: psmouse - ignore parity error for basic protocols
This reverts commit 5e28d8eb68c12eab9c4a47b42ba993a6420d71d3 since
the magic knock does not work for this model of the touchpad and the
device stays in PS/2 compatibility mode.
Input: wacom - switch mode upon system resume
Revert "Input: wacom - merge out and in prox events"
Input: matrix_keypad - allow platform to disable key autorepeat
Input: i8042 - spelling fix
Input: sparse-keymap - implement safer freeing of the keymap
Input: update the status of the Multitouch X driver project
Input: clarify the no-finger event in multitouch protocol
Input: bcm5974 - retract efi-broken suspend_resume
Input: sparse-keymap - free the right keymap on error
Tested by a user running Ubuntu 9.10 in the following bug report.
BugLink: http://bugs.launchpad.net/bugs/545307
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
Cc: stable@kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Enable button release event redirection to the device that got the
button press not only for touchpads with interleaved protocols, but
unconditionally for all Alps touchpads. This is required at least
for the touchpads in Dell Inspiron 8200 and Latitude d630.
Signed-off-by: Martin Buck <mb-tmp-yvahk-vachg@gromit.dyndns.org>
Signed-off-by: Thomas Bächler <thomas@archlinux.org>
Properly handle version of the protocol where standard PS/2 packets
from trackpoint are stuffed into middle (byte 3-6) of the standard
ALPS packets when both the touchpad and trackpoint are used together.
The patch is based on work done by Matthew Chapman and additional
research done by David Kubicek and Erik Osterholm:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/296610
Many thanks to David Kubicek for his efforts in researching fine points
of this new version of the protocol, especially interaction between pad
and stick in these models.
Signed-off-by: Sebastian Kapfer <sebastian_kapfer@gmx.net>
Relative events are only reported via secondary device therefore device
associated with the touchpad should not advertise these capabilities.
The touchpad on Acer Aspire 5720, 5520 and some other Aspire models
(signature 0x73, 0x02, 0x50) has a button that can be rocked in 4
different directions. Make the driver to generate BTN_0..BTN_3 events
in response. The Synaptics driver by default maps BTN_0 and BTN_1 to
up and down, so there should be no visible changes with the old setup
that generated BTN_FORWARD and BTN_BACK (also mapped to up and down).
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
When pressing any button belonging to the touchpoint, the generated
click events don't belong to the touchpoint but to the touchpad.
This patch fixes this behaviour, the events will be sent via the
correct device, so scrolling with touchpoint is possible.
Signed-off-by: Ulrich Dangel <uli@spamt.net>
Dell Latitude D630/D800 have DualPoint (touchpad plus trackpoint)
instead of a simple touchpad and a pass-through port for external
PS/2 mouse.
This toshiba has a touchpad with trackpoint and 2 sets of left
and right buttons (above and below touchpad).
Signed-off-by: Elvis Pranskevichus <el@prans.net>
ALPS_FW_BK_1 protocol flavor seems to have forward and backward
keys reversed.
Signed-off-by: Laszlo Kajan <kajla@bioinfo.pl>
Secondary input device did not have parent set up causing it
to appear in the root of sysfs device hierarchy.
The recently added support for Dell Volstro 1400 was causing protocol
synchronization errors on Acer Aspire 5720ZG, fix it.
