Here we introduce logic in alps_identify to set the ALPS_DUALPOINT flag
for touchpad hardware responding to E7 report with 73 03 28, as is found
in the Dell Latitude E7470.
Tested-by: Michal Hocko <mhocko@suse.com>
Signed-off-by: Ben Gamari <ben@smart-cactus.org>
The SS5 hardware can report this.
While a button is held SS5 hardware will give us single-finger packets
with x, y, and pressure equal to zero. This causes annoying jumps in
pointer position if a touch is released while the button is held. Handle
this by claiming zero contacts to ensure that no position events are
provided to the user.
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
Add touchstick support for the so-called SS5 hardware, which uses a
variant of the SS4 protocol.
This patch moves v3 pinnacle code for trackstick detection from
alps_hw_init_v3() to alps_set_protocol() so ALPS_DUALPOINT flag can be
cleared before registering trackstick input device in kernel.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
This patch adds detection of trackstick for v7 protocol devices. Code in
this patch is used in official Dell touchpad linux drivers for Dell models:
Dell Latitude E5250/5250, E5450/5450, E5550/5550
Detection code and base reg for alps v3 rushmore and v7 devices is exacly
same.
Also user in bug https://bugzilla.kernel.org/show_bug.cgi?id=94801 reported
that Toshiba Sattellite Z30-A-1DG has only alps v7 touchpad device without
trackstick and kernel reports to userspace also redundant trackstick
device.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Alex Hung <alex.hung@canonical.com>
button bits
commit 92bac83dd79e ("Input: alps - non interleaved V2 dualpoint has
separate stick button bits") assumes that all alps v2 non-interleaved
dual point setups have the separate stick button bits.
Later we limited this to Dell laptops only because of reports that this
broke things on non Dell laptops. Now it turns out that this breaks things
on the Dell Latitude D600 too. So it seems that only the Dell Latitude
D420/430/620/630, which all share the same touchpad / stick combo,
have these separate bits.
This patch limits the checking of the separate bits to only these models
fixing regressions with other models.
Reported-and-tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: stable@vger.kernel.org
Tested-by: Hans de Goede <hdegoede@redhat.com>
Acked-By: Pali Rohár <pali.rohar@gmail.com>
sticks
It turns out that only Dell laptops have the separate button bits for
v2 dualpoint sticks and that commit 92bac83dd79e ("Input: alps - non
interleaved V2 dualpoint has separate stick button bits") causes
regressions on Toshiba laptops.
This commit adds a check for Dell laptops to the code for handling these
extra button bits, fixing this regression.
This patch has been tested on a Dell Latitude D620 to make sure that it
does not reintroduce the original problem.
Reported-and-tested-by: Douglas Christman <douglaschristman@gmail.com>
Prepare first round of input updates for 4.2 merge window.
On some v7 devices (e.g. Lenovo-E550) the deltas reported are typically
only in the 0-1 range dividing this by 2 results in a range of 0-0.
And even for v7 devices where this does not lead to making the trackstick
entirely unusable, it makes it twice as slow as before we added v7 support
and were using the ps/2 mouse emulation of the dual point setup.
If some kind of generic slowdown is actually necessary for some devices,
then that belongs in userspace, not in the kernel.
Reported-and-tested-by: Rico Moorman <rico.moorman@gmail.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@gmail.com>
On v7 touchpads sometimes when 2 fingers are moved down on the touchpad
until they "fall of" the touchpad, the second touch will report 0 for y
(max y really since the y axis is inverted) and max x as coordinates,
rather then reporting 0, 0 as is expected for a non touching finger.
This commit detects this and treats these touches as non touching.
See the evemu-recording here:
https://bugzilla.redhat.com/attachment.cgi?id=1025058
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1221200
Now that the generic process_bitmap function has been improved to offer
accurate coordinates for the first touch we can use it for v5 (dolphin)
touchpads too.
Besides being a nice code cleanup this also fixes the saw tooth pattern
in the coordinates for the second touch the dolphin specific version had.
Rename alps_set_abs_params_mt to alps_set_abs_params_semi_mt,
to make it clear that it is only (to be) used for semi-mt devices.
With the recent process_bitmap() changes all semi-mt devices always report
the first finger down in slot 0, so stop using input-mt finger tracking
for these.
All alps semi-mt touchpads give us the following data when 2 (or more)
fingers are touching: 1 more or less accurate touch for the first finger
down, and a bitmap with columns and rows in which 1 or more fingers are
seen resulting in a crude (low res) bounding box.
So far for v3, rushmore and v4 touchpads we've been reporting the
coordinates of 2 opposite corners of the box when 2 fingers are touching.
Ignoring the much better resolution data given in the normal position
packet.
This commit actually uses this data for the first touch, figures out which
corner of the bounding box is closest to the first touch, and reports the
coordinates of the opposite corner for the second touch, resulting in
much better data for the first touch and for the single touch
pointer-emulation events.
This approach is similar to the one in alps_process_bitmap_dolphin, that
function takes the single accurate touch info, calculates the distance to
the center of the bounding box, and then puts the 2nd touch mirrored to
the center. The downside of that approach is that if both touches move
slowly in the same direction, the bounding box will stay the same for a
while (as it is low res) and the second touch will thus been seen moving
in the opposite direction until the bounding box actually changes, and
then the second touch snaps to its new position resulting in a saw tooth
pattern in the coordinates for the second touch, hence this new approach.
This commit fixes 2 finger scrolling being choppy / jumpy on these
touchpads.
We should decode the position packet before the packet with the bitmap
data. This way we can use the more accurate position info in
process_bitmap() to get better results.
Pinnacle / Rushmore packets contain either position info, or bitmap info,
never both. So far we've in essence been storing garbage in the position /
bitmap fields of the fields struct when decoding a bitmap / pos packet.
We've been relying on the following sequence to get away with this:
1) Decode bitmap packet
2) Process bitmap packet
3) Decode position packet
4) Use position / button info
This patch allows us to change this sequence, which will allow using the
position info when processing the bitmap for more accurate results.
Change alps_decode_rushmore to do all decoding itself, rather then relying
on alps_decode_pinnacle and then overriding some fields + or-ing in some
bits.
This is a preparation patch for modifying the decode functions to properly
differentiate between position and bitmap packets.
Prepare first round of input updates for 4.1 merge window.
Non interleaved V2 dualpoint touchpad / stick combos have separate stick
button bits in the touchpad packets, if we do not check these then the
trackpoint buttons will not work when using the touchpad, and when pressed
when the user starts using the touchpad will report a release event even
though the button is still pressed.
This commit fixes this by checking the separate bits, note that we simply
combine the buttons, since the hardware does the same when using the touchpad
buttons with the trackpoint, so we do not have enough information to properly
separate them.
Reported-by: Hans de Bruin <jmdebruin@xmsnet.nl>
When the left touchpad button gets pressed, and then the trackpoint is
moved, and then the button is released, the following happens:
1) touchpad packet is received, touchpad evdev node reports BTN_LEFT 1
2) pointing stick packet is received, the hw will report a BTN_LEFT 1 in
this packet because when the trackstick is active it communicates the
combined touchpad + pointing stick buttons in the trackstick packet,
since alps_report_bare_ps2_packet passes NULL (*) for the dev2 parameter
to alps_report_buttons the combining is not detected and the
pointing stick evdev node will also report BTN_LEFT 1
3) on release of the button a pointing stick packet with BTN_LEFT 0 is
received and the pointing stick evdev node will report BTN_LEFT 0
Note how because of the passing as NULL for dev2 the touchpad evdev node
will never send BTN_LEFT 0 in this scenario leading to a stuck mouse button.
This is a regression in 4.0 introduced by commit 04aae283ba6a8
("Input: ALPS - do not mix trackstick and external PS/2 mouse data")
This commit fixes this by passing in the touchpad evdev as dev2 parameter
when calling alps_report_buttons for the pointingstick on alps v2 devices,
so that alps_report_buttons correctly detect that we're already reporting
the button as pressed via the touchpad evdev node, and will also send the
release event there.
Cc: stable@vger.kernel.org # 4.0
Acked-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com>
This change adds support for SS4 touchpad devices as ALPS_PROTO_V8
protocol. They are real multi-touch devices and can be found in TOSHIBA
Tecra C50.
In preparation for adding support for SS4 touchpads, let's split
alps_set_abs_params_mt into common, v7-specific, and other protocols
portions.
On V2 devices the DualPoint Stick reports bare packets, these should be
reported via the "AlpsPS/2 ALPS DualPoint Stick" dev2 evdev node, which also
has the INPUT_PROP_POINTING_STICK propbit set.
Note that since there is no way to distinguish these packets from an external
PS/2 mouse (insofar as these laptops have an external PS/2 port) this means
that we will be reporting PS/2 mouse events via this evdev node too, as we've
been doing in kernel 3.19 and older.
This has been tested on a Dell Latitude D620 and a Dell Latitude E6400,
which both have a V2 touchpad + a DualPoint Stick which reports bare packets.
Bare packets should be reported via the same evdev device independent on
whether they are detected on the beginning of a packet or in the middle
of a packet.
This has been tested on a Dell Latitude E6400, where the DualPoint Stick
reports bare packets, which get reported via dev3 when the touchpad is
idle, and via dev2 when the touchpad and stick are used simultaneously.
This commit fixes this inconsistency by always reporting bare packets via
dev3. Note that since the come from a DualPoint Stick they really should be
reported via dev2, this gets fixed in a later commit.
Commit 3296f71cd2fde7a2ad52e66a27eae419f6328066 ("Input: ALPS - consolidate
setting protocol parameters") inadvertently moved call to
alps_dolphin_get_device_area() from v5 to v7 protocol, causing both
protocols report incorrect maximum values for X and Y axes which resulted
in crash in Synaptics X driver.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=94801
Reported-by: Santiago Gala <sgala@apache.org>
Reported-by: Pali Rohár <pali.rohar@gmail.com>
This fixes memory leak introduced by commit
a09221e83e13e09a33109b9b037484eade901cea
This patch move all packet info from driver source code to documentation
and adds info about v6 packet format (from driver source code).
The comment about suspicions entry 0x20, 0x02, 0x0e has over time drifted
away and it become hard to figure out what it meant. Let's move it back so
it is clear.
Previously dev2 device was used for both external PS/2 mouse and internal
trackstick device (if available). This change introduces dev3 device which
is used for external PS/2 mouse data and dev2 is now used only for
trackstick.
In case that trackstick is not present dev2 is not created, so userspace
does not see non existent device in system.
Because laptops with ALPS devices often do not use i8042 active
multiplexing all data (from touchpad, trackstick and external PS/2 mouse)
come to one port. So it is not possible to know if external PS/2 mouse is
connected or not. In most cases external PS/2 mouse is not connected so
driver will create dev3 input device after first bare PS/2 packet will be
received. So there will not be "ghost" input device.
This change also helps in identifying possible problems in future if driver
decides to report 6-bytes trackstick packets as 3-bytes bare PS/2 (data
will be reported to dev3 instead dev2).
On some Dell Latitudes we fail to identify presence of trackstick unless we
reset the device. The issue is quite benign as we do perform reset in
alps_init(), so the trackstick ends up working, but mouse name reported to
userspace is not accurate.
In order to fix the issue while avoiding the additional lengthy reset we
move the resrt to alps_detect() and keep the discovered state to be used
later in alps_init().
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Move setting of all protocol properties into alps_set_protocol (former
alps_set_defaults) instead of having it split between several functions.
In preparation of reworking the way we set protocol parameters let's
split certain protocol items from alps_model_info into a separate
structure.
Even though Rushmore is very close to V3 protocol it is sufficiently
different to warrant it's own protocol name.
In order to accommodate new protocol number for Rushmore touchpads
let's shift protocol numbers by 8 bits (i.e. 1 -> 0x100) - this way
we keep protocol version reported in input device id the same as it
was, but add some holes in numbering.
Some devices are not fast enough to differentiate between a fast-moving
contact and a new contact. This problem cannot be fully resolved because
information is truly missing, but it is possible to safe-guard against
obvious mistakes by restricting movement with a maximum displacement.
The new problem formulation for dmax > 0 cannot benefit from the speedup
for positive definite matrices, but since the convergence is faster, the
result is about the same. For a handful of contacts, the latency difference
is truly negligible.
Suggested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Tested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Henrik Rydberg <rydberg@bitmath.org>
Merge with mainline to bring in the latest thermal and other changes.
Make sure that driver does not process bogus packets as trackstick data
when there is no trackstick present and emit warnings in dmesg so potential
issues with trackstick handling will be visible for debugging.
This change fixes name, product and version of dev2 input device based on
format used in function psmouse_switch_protocol() in file psmouse-base.c.
Second round of input updates for 3.19.
Add a table documenting where all the bits are in the v7 touchpad packets.
Protocol v7 uses the middle / right button bits on clickpads to communicate
"location" information of a 3th touch (and possible 4th) touch on
clickpads.
Specifically when 3 touches are down, if one of the 3 touches is in the
left / right button area, this will get reported in the middle / right
button bits and the touchpad will still send a TWO type packet rather then
a MULTI type packet, so when this happens we must add the finger reported
in the button area to the finger count.
Likewise we must also add fingers reported this way to the finger count
when we get MULTI packets.
BugLink: https://bugs.freedesktop.org/show_bug.cgi?id=86338
Cc: stable@vger.kernel.org # 3.17
The v7 proto differentiates between a primary touch (with high precision)
and a secondary touch (with lower precision). Normally when 2 fingers are
down and one is lifted the still present touch becomes the primary touch,
but some traces have shown that this does not happen always.
This commit deals with this by making alps_get_mt_count() not stop at the
first empty mt slot, and if a touch is present in mt[1] and not mt[0]
moving the data to mt[0] (for input_mt_assign_slots).
NEW packets are send to indicate a discontinuity in the finger coordinate
reporting. Specifically a finger may have moved from slot 0 to 1 or vice
versa. INPUT_MT_TRACK takes care of this for us.
NEW packets have 3 problems:
1) They do not contain middle / right button info (on non clickpads)
this can be worked around by preserving the old button state
2) They do not contain an accurate fingercount, and they are
typically send when the number of fingers changes. We cannot use
the old finger count as that may mismatch with the amount of
touch coordinates we've available in the NEW packet
3) Their x data for the second touch is inaccurate leading to
a possible jump of the x coordinate by 16 units when the first
non NEW packet comes in
Since problems 2 & 3 cannot be worked around, just ignore them.
Sometimes on Dell Latitude laptops psmouse/alps driver receive invalid ALPS
protocol V3 packets with bit7 set in last byte. More often it can be
reproduced on Dell Latitude E6440 or E7440 with closed lid and pushing
cover above touchpad.
If bit7 in last packet byte is set then it is not valid ALPS packet. I was
told that ALPS devices never send these packets. It is not know yet who
send those packets, it could be Dell EC, bug in BIOS and also bug in
touchpad firmware...
With this patch alps driver does not process those invalid packets, but
instead of reporting PSMOUSE_BAD_DATA, getting into out of sync state,
getting back in sync with the next byte and spam dmesg we return
PSMOUSE_FULL_PACKET. If driver is truly out of sync we'll fail the checks
on the next byte and report PSMOUSE_BAD_DATA then.
On some Dell Latitude laptops ALPS device or Dell EC send one invalid byte
in 6 bytes ALPS packet. In this case psmouse driver enter out of sync
state. It looks like that all other bytes in packets are valid and also
device working properly. So there is no need to do full device reset, just
need to wait for byte which match condition for first byte (start of
packet). Because ALPS packets are bigger (6 or 8 bytes) default limit is
small.
This patch increase number of invalid bytes to size of 2 ALPS packets which
psmouse driver can drop before do full reset.
Resetting ALPS devices take some time and when doing reset on some Dell
laptops touchpad, trackstick and also keyboard do not respond. So it is
better to do it only if really necessary.
5th and 6th byte of ALPS trackstick V3 protocol match condition for first
byte of PS/2 3 bytes packet. When driver enters out of sync state and ALPS
trackstick is sending data then driver match 5th, 6th and next 1st bytes as
PS/2.
It basically means if user is using trackstick when driver is in out of
sync state driver will never resync. Processing these bytes as 3 bytes PS/2
data cause total mess (random cursor movements, random clicks) and make
trackstick unusable until psmouse driver decide to do full device reset.
Lot of users reported problems with ALPS devices on Dell Latitude E6440,
E6540 and E7440 laptops. ALPS device or Dell EC for unknown reason send
some invalid ALPS PS/2 bytes which cause driver out of sync. It looks like
that i8042 and psmouse/alps driver always receive group of 6 bytes packets
so there are no missing bytes and no bytes were inserted between valid
ones.
This patch does not fix root of problem with ALPS devices found in Dell
Latitude laptops but it does not allow to process some (invalid)
subsequence of 6 bytes ALPS packets as 3 bytes PS/2 when driver is out of
sync.
So with this patch trackstick input device does not report bogus data when
also driver is out of sync, so trackstick should be usable on those
machines.
Since the change to struct input_mt_pos some variables are now bitfields
instead of integers. Automatic conversion from integer to bitfield entry
destroys information, therefore enforce boolean interpretation instead.
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1114768
Fixes: 02d04254a5df ("Input: alps - use struct input_mt_pos to track coordinates")
Signed-off-by: Andreas Bosch <linux@progandy.de>
