path: root/drivers/input/mouse/elantech.c
2009-09-10Input: psmouse - use boolean typeDmitry Torokhov
2009-04-18Input: elantech - make sure touchpad is really in absolute modeArjan Opmeer
There exist laptops with Elantech touchpads where switching to absolute mode does not happen, although writing the configuration register succeeds without error. Reading back the register afterwards reveils that the absolute mode bit is not set as if masked out by the touchpad firmware. Always read back register 0x10, make sure that for hardware version 1 the absolute mode bit is actually set and fail otherwise. This prevents the case where the touchpad is claimed by the Elantech driver but is nonetheless not working. Signed-off-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-18Input: elantech - provide a workaround for jumpy cursor on firmware 2.34Arjan Opmeer
It seems that Elantech touchpad firmware version 2.34 on the Hercules eCAFÉ suffers from a problem where bogus coordinates get reported at the beginning of a touch action. This causes the mouse cursor or the scrolled page to jump. Included patch provides a workaround that discards mouse packets that are likely to contain bogus coordinates. The workaround is activated when we detect touchpad with fimware version 2.34. Signed-off-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-02-28Input: elantech - touchpad driver miss-recognising logitech miceArjan Opmeer
Some Logitech mice react to the magic knock like Elantech touchpad would. This leads to those mice being misdetected as Elantech touchpads. Add a version query to elantech_detect() to distinguish the two. [dtor@mail.ru: - lower severity of some messages - when we are not sure yet if device is Elantech or not not responding to knock is not an error. ] Signed-off-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-10-16Input: psmouse - add support for Elantech touchpadsArjan Opmeer
This is version 5 of the driver. Relative mode support has been dropped (users wishing to use touchpad in relative mode can use standard PS/2 protocol emulation done in hardware). The driver supports both original version of Elantech protocol and the newer one used by touchpads installed in EeePC. Signed-off-by: Arjan Opmeer <arjan@opmeer.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
