path: root/drivers/input/mouse/sentelic.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-13Input: sentelic - fix left/right horizontal scroll mappingTai-hwa Liang
Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-20Input: psmouse - rework setting of BTN_MIDDLE capabilityDmitry Torokhov
Do not start protocol detection assuming that middle mouse is present, instead let individual protocols explicitly set this capability. This fixes issue with Synaptics touchpads pretending that they have middle button when hardware clearly reports otherwise. Reported-and-tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-17Input: libps2 - additional locking for i8042 portsDmitry Torokhov
The serio ports on i8042 are not completely isolated; while we provide enough locking to ensure proper serialization when accessing control and data registers AUX and KBD ports can still have an effect on each other on PS/2 protocol level. The most prominent effect is that issuing a command for the device connected to one port may cause abort of the command currently executing by the device connected to another port. Since i8042 nor serio subsystem are not aware of the details of the PS/2 protocol (length of the commands and their replies and so on) the locking should be done on libps2 level by adding special handling when we see that we are dealing with serio port on i8042. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-10Input: psmouse - use boolean typeDmitry Torokhov
2009-08-19Input: add new driver for Sentelic Finger Sensing PadTai-hwa Liang
This is the driver for Sentelic Finger Sensing Pad which can be found on MSI WIND Netbook. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
