Fix a typo in a comment.
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c.
It was broken in so many ways, and results in random odd pty issues.
It re-introduced the buggy schedule_work() in flush_to_ldisc() that can
cause endless work-loops (see commit a5660b41af6a: "tty: fix endless
work loop when the buffer fills up").
It also used an "unsigned int" return value fo the ->receive_buf()
function, but then made multiple functions return a negative error code,
and didn't actually check for the error in the caller.
And it didn't actually work at all. BenH bisected down odd tty behavior
to it:
"It looks like the patch is causing some major malfunctions of the X
server for me, possibly related to PTYs. For example, cat'ing a
large file in a gnome terminal hangs the kernel for -minutes- in a
loop of what looks like flush_to_ldisc/workqueue code, (some ftrace
data in the quoted bits further down).
Some more data: It -looks- like what happens is that the
flush_to_ldisc work queue entry constantly re-queues itself (because
the PTY is full ?) and the workqueue thread will basically loop
forver calling it without ever scheduling, thus starving the consumer
process that could have emptied the PTY."
which is pretty much exactly the problem we fixed in a5660b41af6a.
Milton Miller pointed out the 'unsigned int' issue.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: Milton Miller <miltonm@bga.com>
Cc: Stefan Bigler <stefan.bigler@keymile.com>
Cc: Toby Gray <toby.gray@realvnc.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
it makes it simpler to keep track of the amount of
bytes received and simplifies how flush_to_ldisc counts
the remaining bytes. It also fixes a bug of lost bytes
on n_tty when flushing too many bytes via the USB
serial gadget driver.
Tested-by: Stefan Bigler <stefan.bigler@keymile.com>
Tested-by: Toby Gray <toby.gray@realvnc.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: rpckbd - fix a leak of the IRQ during init failure
Input: wacom - add support for Lenovo tablet ID (0xE6)
Input: i8042 - downgrade selftest error message to dbg()
Input: synaptics - fix crash in synaptics_module_init()
Input: spear-keyboard - fix inverted condition in interrupt handler
Input: uinput - allow for 0/0 min/max on absolute axes.
Input: sparse-keymap - report KEY_UNKNOWN for unknown scan codes
Input: sparse-keymap - report scancodes with key events
Input: h3600_ts_input - fix a spelling error
Input: wacom - report resolution for pen devices
Input: wacom - constify wacom_features for a new missed Bamboo models
In rpckbd_open prror path, free_irq() was using NULL rather than the
driver data as the data pointer so free_irq() wouldn't have matched.
On a "really fragile" laptop I noticed a single
i8042.c: i8042 controller selftest failed. (0x1 != 0x55)
error in the log. But there's no reason to print this message at
KERN_ERR level each time that loop fails, especially since the message
telling about the overall selftest failure is printed at KERN_INFO level
(on X86).
Add an actual error message for non-X86 systems, where a selftest
failure is (apparently) more serious. Remove a space in an another error
message.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Scripted with coccinelle.
master.kernel.org:/home/rmk/linux-2.6-arm
* 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6647/1: add Versatile Express defconfig
ARM: 6644/1: mach-ux500: update the U8500 defconfig
* 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6764/1: pl011: factor out FIFO to TTY code
ARM: 6763/1: pl011: add optional RX DMA to PL011 v2
ARM: 6758/1: amba: support pm ops
ARM: amba: make amba_driver id_table const
ARM: amba: make internal ID table handling const
ARM: amba: make probe() functions take const id tables
ARM: 6662/1: amba: make amba_bustype non-static
ARM: mmci: add dmaengine-based DMA support
ARM: mmci: no need for separate host->data_xfered
ARM: mmci: avoid unnecessary switch to data available PIO interrupts
ARM: mmci: no need to call flush_dcache_page() with sg_miter API
ARM: mmci: avoid reporting too many completed bytes on fifo overrun
ALSA: AACI: make fifo variables more explanitory
ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period
ALSA: AACI: use snd_pcm_lib_period_bytes()
ALSA: AACI: clean up AACI announcement printk
ALSA: AACI: fix channel mask selection
ALSA: AACI: fix number of channels for record
ALSA: AACI: fix multiple IRQ claiming
* 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm:
VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var()
VIDEO: cyberpro: remove useless function extreg pointers
VIDEO: cyberpro: update handling of device structures
VIDEO: cyberpro: add support for video capture I2C
VIDEO: cyberpro: make 'reg_b0_lock' always present
VIDEO: cyberpro: add I2C support
VIDEO: cyberpro: select lowest multipler/divisor for PLL
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32: (40 commits)
unicore32: rewrite arch-specific tlb.h to use asm-generic version
unicore32: modify io_p2v and io_v2p macros, and adjust PKUNITY_mmio_BASEs
unicore32: replace unicore32-specific iomap functions with generic lib implementation
unicore32 machine related: add frame buffer driver for pkunity-v3 soc
unicore32 machine related files: add i2c bus drivers for pkunity-v3 soc
unicore32 io: redefine __REG(x) and re-use readl/writel funcs
unicore32 i8042 upgrade and bugfix: adjust resource request region type
unicore32 upgrade to v2.6.38-rc5: add one more paramter for pte_alloc_map call
unicore32 i8042: adjust io funcs of i8042-unicore32io.h
unicore32: rename PKUNITY_IOSPACE_BASE to PKUNITY_MMIO_BASE
unicore32: modify function names and parameters for irq_chips
unicore32: remove unused lines in arch/unicore32/include/asm/irq.h
unicore32 time.c: change calculate method for clock_event_device
unicore32: ADD MAINTAINER for unicore32 architecture
unicore32 machine related files: ps2 driver
unicore32 machine related files: pci bus handling
unicore32 machine related files: hardware registers
unicore32 machine related files: core files
unicore32 additional architecture files: boot process
unicore32 additional architecture files: low-level lib: misc
-- by advice of Arnd Bergmann
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
replace inb/outb with readb/writeb in i8042-unicore32io.h
and correct typecasting of register and region macros
-- by advice with Arnd Bergmann
This patch implements arch-specific ps2 driver.
By reviewed with Dmitry Torokhov:
1. move i8042-ucio.h to drivers/input/serio/i8042-unicore32io.h
2. move puv3_ps2_init() to arch/unicore32/kernel/puv3-core.c
3. remove unused comments.
Acked-by: Dmitry Torokhov <dtor@mail.ru>
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits)
tty: serial: altera_jtaguart: Add device tree support
tty: serial: altera_uart: Add devicetree support
dt: eliminate of_platform_driver shim code
dt: Eliminate of_platform_{,un}register_driver
dt/serial: Eliminate users of of_platform_{,un}register_driver
dt/usb: Eliminate users of of_platform_{,un}register_driver
dt/video: Eliminate users of of_platform_{,un}register_driver
dt/net: Eliminate users of of_platform_{,un}register_driver
dt/sound: Eliminate users of of_platform_{,un}register_driver
dt/spi: Eliminate users of of_platform_{,un}register_driver
dt: uartlite: merge platform and of_platform driver bindings
dt: xilinx_hwicap: merge platform and of_platform driver bindings
ipmi: convert OF driver to platform driver
leds/leds-gpio: merge platform_driver with of_platform_driver
dt/sparc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: Eliminate users of of_platform_{,un}register_driver
dt/powerpc: move of_bus_type infrastructure to ibmebus
drivercore/dt: add a match table pointer to struct device
dt: Typo fix.
altera_ps2: Add devicetree support
Final step to eliminate of_platform_bus_type. They're all just
platform drivers now.
v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell)
Get rid of old users of of_platform_driver in arch/sparc. Most
of_platform_driver users can be converted to use the platform_bus
directly.
drivers/spi/pxa2xx_spi_pci.c
Input: serio/gameport - use 'long' system workqueue
Input: synaptics - document 0x0c query
Input: tegra-kbc - add function keymap
Commit 8ee294cd9def0004887da7f44b80563493b0a097 converted serio
subsystem event handling from using a dedicated thread to using
common workqueue. Unfortunately, this regressed our boot times,
due to the fact that serio jobs take long time to execute. While
the new concurrency managed workqueue code manages long-playing
works just fine and schedules additional workers as needed, such
works wreck havoc among remaining users of flush_scheduled_work().
To solve this problem let's move serio/gameport works from system_wq
to system_long_wq which nobody tries to flush.
Reported-and-tested-by: Hernando Torque <pantherchen@versanet.de>
Acked-by: Tejun Heo <tj@kernel.org>
Make Primecell driver probe functions take a const pointer to their
ID tables. Drivers should never modify their ID tables in their
probe handler.
Add match table for device tree binding.
v2: use const and add compat version.
v3: change compatible vendor to ALTR.
add dts binding doc.
v4: condition module device table export for of.
Signed-off-by: Walter Goossens <waltergoossens@home.nl>
[dustan.bower@gmail.com: fixed missing semicolon]
Input: matrix_keypad - increase the limit of rows and columns
Input: wacom - fix error path in wacom_probe()
Input: ads7846 - check proper condition when freeing gpio
Revert "Input: do not pass injected events back to the originating handler"
Input: sysrq - rework re-inject logic
Input: serio - clear pending rescans after sysfs driver rebind
Input: rotary_encoder - use proper irqflags
Input: wacom_w8001 - report resolution to userland
When rebinding a serio driver via sysfs drvctl interface it is
possible for an interrupt to trigger after the disconnect of the
existing driver and before the binding of the new driver. This will
cause the serio interrupt handler to queue a rescan event which will
disconnect the new driver immediately after it is attached.
This change removes pending rescans from the serio event queue after
processing the drvctl request but before releasing the serio mutex.
Reproduction involves issuing a rebind of device port from psmouse
driver to serio_raw driver while generating input to trigger
interrupts. Then checking to see if the corresponding
i8042/serio4/driver is correctly attached to the serio_raw driver
instead of psmouse.
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Input: wacom - pass touch resolution to clients through input_absinfo
Input: wacom - add 2 Bamboo Pen and touch models
Input: sysrq - ensure sysrq_enabled and __sysrq_enabled are consistent
Input: sparse-keymap - fix KEY_VSW handling in sparse_keymap_setup
Input: tegra-kbc - add tegra keyboard driver
Input: gpio_keys - switch to using request_any_context_irq
Input: serio - allow registered drivers to get status flag
Input: ct82710c - return proper error code for ct82c710_open
Input: bu21013_ts - added regulator support
Input: bu21013_ts - remove duplicate resolution parameters
Input: tnetv107x-ts - don't treat NULL clk as an error
Input: tnetv107x-keypad - don't treat NULL clk as an error
Fix up trivial conflicts in drivers/input/keyboard/Makefile due to
additions of tc3589x/Tegra drivers
Parse and pass the status byte information to the registered serio
drivers as well as the data bytes.
Signed-off-by: David Engraf<david.engraf@sysgo.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
If request_irq() fails we should return the proper error instead of -1.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Input: add SW_ROTATE_LOCK switch type
Input: fix force feedback capability query example
Input: wacom_w8001 - add single-touch support
Input: add Austria Microsystem AS5011 joystick driver
Input: remove aaed2000 keyboard driver
Input: i8042 - introduce 'notimeout' blacklist for Dell Vostro V13
Input: cy8ctmg110_ts - Convert to dev_pm_ops
Input: migor_ts - convert to dev_pm_ops
Input: mcs5000_ts - convert to dev_pm_ops
Input: eeti_ts - convert to dev_pm_ops
Input: ad7879 - convert I2C to dev_pm_ops
i8042 controller present in Dell Vostro V13 errorneously signals spurious
timeouts.
Introduce i8042.notimeout parameter for ignoring i8042-signalled timeouts
and apply this quirk automatically for Dell Vostro V13, based on DMI match.
In addition to that, this machine also needs to be added to nomux blacklist.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits)
Input: wacom_w8001 - support pen or touch only devices
Input: wacom_w8001 - use __set_bit to set keybits
Input: bu21013_ts - fix misuse of logical operation in place of bitop
Input: i8042 - add Acer Aspire 5100 to the Dritek list
Input: wacom - add support for digitizer in Lenovo W700
Input: psmouse - disable the synaptics extension on OLPC machines
Input: psmouse - fix up Synaptics comment
Input: synaptics - ignore bogus mt packet
Input: synaptics - add multi-finger and semi-mt support
Input: synaptics - report clickpad property
input: mt: Document interface updates
Input: fix double equality sign in uevent
Input: introduce device properties
hid: egalax: Add support for Wetab (726b)
Input: include MT library as source for kerneldoc
MAINTAINERS: Update input-mt entry
hid: egalax: Add support for Samsung NB30 netbook
hid: egalax: Document the new devices in Kconfig
hid: egalax: Convert to MT slots
Fixed up trivial conflict in drivers/input/keyboard/Kconfig
This patch adds notebook Acer Aspire 5100 to the list of Dritek HW. Acer
Aspire 5100 needs Dritek keyboard extension to support all Fn keys.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
Fix kernel warnings caused by the driver name of GSC PS/2 containing '/'.
The following warnings are observed on a K410 system :
[ 10.700000] name 'GSC PS/2 keyboard'
[ 10.732000] ------------[ cut here ]------------
[ 10.772000] WARNING: at fs/proc/generic.c:323
[ 10.828000] Modules linked in:
[ 10.916000]
[ 10.916000] YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
[ 10.936000] PSW: 00000000000001000000000000001111 Not tainted
[ 10.992000] r00-03 0004000f 104fe3e0 10201ea0 00000000
[ 11.060000] r04-07 4fc405c8 00000006 4fc405c8 4fc40694
[ 11.124000] r08-11 4fc40708 10438aa0 00000001 1043bfc8
[ 11.184000] r12-15 104ff2a0 104ff2a0 4fc38634 104ff2a0
[ 11.248000] r16-19 f0001570 10479af0 f000006c 1044fe50
[ 11.308000] r20-23 00000000 00000028 104cd858 00000000
[ 11.372000] r24-27 ffffffff 0000000e 1044fe10 1043bbe0
[ 11.436000] r28-31 0000002b 00000078 4fc40800 0000000d
[ 11.496000] sr00-03 00000000 00000000 00000000 00000000
[ 11.560000] sr04-07 00000000 00000000 00000000 00000000
[ 11.624000]
[ 11.688000] IASQ: 00000000 00000000 IAOQ: 10201ea0 10201ea4
[ 11.704000] IIR: 03ffe01f ISR: 00000000 IOR: 0000000d
[ 11.772000] CPU: 0 CR30: 4fc40000 CR31: f01043b0
[ 11.836000] ORIG_R28: 4fc40940
[ 11.904000] IAOQ[0]: __xlate_proc_name+0x90/0xd0
[ 11.940000] IAOQ[1]: __xlate_proc_name+0x94/0xd0
[ 11.996000] RP(r2): __xlate_proc_name+0x90/0xd0
[ 12.052000] Backtrace:
[ 12.108000] [<10257790>] vsnprintf+0x290/0x4f4
[ 12.136000]
[ 12.188000] ---[ end trace 91bf6ece17e322dd ]---
[ 12.208000] serio: GSC PS/2 keyboard port at 0x0001c000 irq 19 @ 10:12:7
[ 12.264000] name 'GSC PS/2 mouse'
[ 12.344000] ------------[ cut here ]------------
[ 12.384000] WARNING: at fs/proc/generic.c:323
[ 12.436000] Modules linked in:
[ 12.524000]
[ 12.528000] YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
[ 12.544000] PSW: 00000000000001000000000000001111 Tainted: G W
[ 12.600000] r00-03 0004000f 104fe3e0 10201ea0 00000000
[ 12.680000] r04-07 4fc405c8 00000006 4fc405c8 4fc40694
[ 12.740000] r08-11 4fc40708 10438aa0 00000001 1043bfc8
[ 12.804000] r12-15 104ff2a0 104ff2a0 4fc38634 104ff2a0
[ 12.868000] r16-19 f0001570 10479af0 f000006c 1044fe50
[ 12.928000] r20-23 00000000 00000025 104cd858 00000000
[ 12.992000] r24-27 ffffffff 0000000e 1044fe10 1043bbe0
[ 13.056000] r28-31 00000028 00000078 4fc40800 0000000d
[ 13.116000] sr00-03 00000000 00000000 00000000 00000000
[ 13.180000] sr04-07 00000000 00000000 00000000 00000000
[ 13.244000]
[ 13.308000] IASQ: 00000000 00000000 IAOQ: 10201ea0 10201ea4
[ 13.324000] IIR: 03ffe01f ISR: 00000000 IOR: 0000000d
[ 13.392000] CPU: 0 CR30: 4fc40000 CR31: f01043b0
[ 13.456000] ORIG_R28: 4fc40940
[ 13.524000] IAOQ[0]: __xlate_proc_name+0x90/0xd0
[ 13.560000] IAOQ[1]: __xlate_proc_name+0x94/0xd0
[ 13.616000] RP(r2): __xlate_proc_name+0x90/0xd0
[ 13.672000] Backtrace:
[ 13.728000] [<10257790>] vsnprintf+0x290/0x4f4
[ 13.756000]
[ 13.808000] ---[ end trace 91bf6ece17e322de ]---
[ 13.828000] serio: GSC PS/2 mouse port at 0x00020100 irq 19 @ 10:12:8
Signed-off-by: Guy Martin <gmsoft@tuxicoman.be>
Acked-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Standardized message logging prefixes.
Removed \n from dbg macro, added \n to each dbg call site.
Removed direct use of __FILE__ from dbg, converted to pr_fmt(fmt)
Added non-debug printf argument verification of dbg calls
Removed "i8042.c" from printks, converted to pr_<level>
omap-for-linus
This patches removes a config option that was used to select a FIQ
handler to be build for Amstrad Delta, as required by the on-board serio
interface driver. Not having any problem reports received since it was
introduced in 2.6.35, the FIQ handler can now be built and initialized by
default, thus reqiring no extra config option.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
We already call serio_register_port() in ct82c710_probe(),
thus remove a redundant serio_register_port() in ct82c710_init().
Looks like this bug is introduced by
916d83cfe5da1cda454d8b0ae233f06b58bd7f91
"Input: ct82c710 - convert to the new platform device interface"
[dtor@mail.ru: also move printk to where we register port]
serio_unregister_port() will call put_device() to free the memory.
Thus remove kfree(ams_delta_serio) after
serio_unregister_port(ams_delta_serio).
While reviewing various users of kernel memory allocation functions I came
across drivers/input/serio/hil_mlc.c::hil_mlc_register() and noticed that:
- it calls kzalloc() but fails to check for a NULL return before use.
- it makes several allocations and if one fails it doesn't free the
previous ones.
- It doesn't return -ENOMEM in the failed memory allocation case (it just
crashes).
This patch corrects all of the above and also reworks the only caller of
this function that I could find
(drivers/input/serio/hp_sdc_mlc.c::hp_sdc_mlc_out()) so that it now checks
the return value of hil_mlc_register() and properly propagates it on
failure and I also restructured the code to remove some labels and goto's
to make it, IMHO nicer to read.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Tested-by: Helge Deller <deller@gmx.de>
Instead of creating an exclusive thread to handle serio events (which
happen rarely), let's switch to using common workqueue. With the arrival
of concurrency-managed workqueue infrastructure we are not concerned
that our callers or callees also using workqueue (no deadlocks anymore)
and it should reduce total number of threads in the system.
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
The Sony VPCZ1 doesn't support active multiplexing and trying to enable
it causes keyboard to stop working. Since most (all?) VAIOs do not have
external PS/2 ports nor they implement active multiplexing properly, and
trying to enable MUX usually messes up keyboard/touchpad, let's simply
disable MUX probing based on board name (VAIO).
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
