There is a more complete atmel patch-series out by Nick Dyer that fixes
this and other things, but in the meantime this is the minimal thing to
get the touchscreen going on (at least my) Pixel Chromebook.
Not that I want my dirty fingers near that beautiful screen, but it
seems that a non-initialized touchscreen will also end up being a
constant wakeup source, so you have to disable it to go to sleep. And
it's easier to just fix the initialization sequence.
This same driver can be used by atmel based touchscreens and touchpads
(buttonpads). Platform data may specify a device is a touchpad
using the is_tp flag.
This will cause the driver to perform some touchpad specific
initializations, such as:
* register input device name "Atmel maXTouch Touchpad" instead of
Touchscreen.
* register BTN_LEFT & BTN_TOOL_* event types.
* register axis resolution (as a fixed constant, for now)
* register BUTTONPAD property
* process GPIO buttons using reportid T19
Input event GPIO mapping is done by the platform data key_map array.
key_map[x] should contain the KEY or BTN code to send when processing
GPIOx from T19. To specify a GPIO as not an input source, populate
with KEY_RESERVED, or 0.
Signed-off-by: Daniel Kurtz <djkurtz@chromium.org>
Signed-off-by: Benson Leung <bleung@chromium.org>
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
Tested-by: Olof Johansson <olof@lixom.net>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Javier Martinez Canillas <javier@dowhile0.org>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Use %*ph format specifier to print small buffer.
Preparing to move more repeated code into the mt core, add a flags
argument to the input_mt_slots_init() function.
Reviewed-and-tested-by: Benjamin Tissoires <benjamin.tissoires@enac.fr>
Tested-by: Ping Cheng <pingc@wacom.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
atmel_mxt_ts driver by Daniel and MT protocol addition for win8 devices.
drivers/input/touchscreen/atmel_mxt_ts.c
Dmitry: I understand that I am a bit late to the party :) but I do not
agree with this change. Failure to create attributes is not sometihng
that user could cause (at least not easily) and thus would not be a
setup issue but something more severe. I believe we should fail
loading the driver so sysfs attribute breakage will be noticed as soon
as possible, instead of discovering it much much later in the process.
This reverts commit 639900380062ecd78ee8b265ea23929c565469b4.
Requested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Since commit 1c6c69525b ("genirq: Reject bogus threaded irq requests")
threaded IRQs without a primary handler need to be requested with
IRQF_ONESHOT, otherwise the request will fail. This patch adds the
IRQF_ONESHOT to input drivers where it is missing. Not modified by
this patch are those drivers where the requested IRQ will always be a
nested IRQ (e.g. because it's part of an MFD), since for this special
case IRQF_ONESHOT is not required to be specified when requesting the
IRQ.
The normal messages sent after boot or NVRAM update are T6 reports,
containing a status, and the config memory checksum. Parse them and dump
a useful info message.
This patch tested on an MXT224E.
Each interrupt contains information for all contacts with changing
properties. Process all of this information at once, and send it all in a
a single input report (ie input events ending in EV_SYN/SYN_REPORT).
This patch was tested using an MXT224E.
Atmel mxt devices can report one finger for each T9 reportid.
Therefore, this range can be used to report the max number of MT-B slots
to userspace instead of assuming a fixed 10.
Note that mxt_initialized() must complete early, since the input_dev
properties now depend on values in the object table.
This small refactor is in preparation for checking more report types
in the mxt_interrupt message processing loop.
Streamline interrupt processing by caching the T9 reportid range when
first reading the object table.
In the process, refactor reading the object descriptor table.
First, since the object_table entries are now exactly the same layout
in device memory and in the driver, allocate an appropriately sized
array and fetch the entire table directly into it in a single i2c
transaction. Since a 6 byte table object requires 10 bytes to read,
doing this dramatically reduces overhead.
Note: The cached T9 reportid's are initialized to 0, which is an invalid
reportid. Thus, the checks in the interrupt handler will always fail for
devices that do not support the T9 object. Therefore, after doing a
firmware update, the old object table is destroyed and all cached object
values are reset to 0, before reading the new object table, in case
the new firmware does not have the old objects.
The Object Table is freed in three cases:
1) When the driver is being removed.
2) In the error path of mxt_initialize().
3) Just after a firmware update, when a new object table is
about to be read.
For cases 2 & 3, the driver is not immediately unloaded, so this patch
refactors these cases to use a common cleanup function. It also refactors
the mxt_initialize error paths to ensure that this cleanup happens.
Note: mxt_update_fw_store() does not handle errors during mxt_initialize().
A proposed fix for this is in a subsequent patchset.
Update the debug message:
* print inidividual status bits
* print the pressure value
* use '%u' for unsigned quantities
Instead of carrying around per-finger state in the driver instance, just
report each finger as it arrives to the input layer, and let the input
layer (evdev) hold the event state (which it does anyway).
Note: this driver does not really do MT-B properly. Each input report
(a group of input events followed by a SYN_REPORT) only contains data for
a single contact. When multiple fingers are present on a device, each is
properly reported in its own MT_SLOT. However, there is only ever one
MT_SLOT per SYN_REPORT. This is fixed in a subsequent patch.
This patch was tested with an mXT224E.
Make firmware and hardware version strings available to userspace.
This is useful, for example, to allow a userspace program to implement
a firwmare update policy.
Change-Id: I1eddb4bbf5f3f9ae6947a8528598973ddead18cf
Print unsigned values as '%u'.
Also, parse and print the firmware version in its canonical format, as
suggested by Nick Dyer.
Reading the whole info block in one i2c transaction speeds up driver
probe significantly, especially on slower i2c busses.
Write each object using a single bulk i2c write transfer.
Reviewed-by: Joonyoung Shim <jy0922.shim@samsung.com>
The i2c bus requires 4 bytes to do a 1-byte write
(1 byte i2c address + 2 byte offset + 1 byte data).
By taking a length with writes, the driver can amortize transaction
overhead by performing larger transactions where appropriate.
This patch just sets up the new API. Later patches refactor writes
to take advantage of the larger transactions.
The i2c layer can report a variety of errors, including -ENXIO for an i2c
NAK. Instead of treating them all as -EIO, pass the actual i2c layer
error up to the caller.
However, still report as -EIO the unlikely case that a transaction was
partially completed, and no error message was returned from i2c_*().
For objects with multiple instances, dump them all, prepending each with
its "Instance #".
[rydberg@euromail.se: break out mxt_show_instance()]
Conserve limited (PAGE_SIZE) sysfs output buffer space by only showing
readable objects and not printing the object's index, which is not useful
to userspace.
Read each object in a single i2c transaction instead of byte-by-byte
Using scnprintf() is a cleaner way to ensure that we don't overwrite the
PAGE_SIZE sysfs output buffer.
T5 is the message processor object. Reading it will only have two
outcomes, neither of which is particularly useful:
1) the message count decrements, and a valid message will be lost
2) an invalid message will be read (reportid == 0xff)
If sysfs entry creation fails, the driver is still usable, so don't
just abort probe. Just warn and continue.
Hopefully this new code path will never be used, but better safe than
sorry...
The atmel_mxt_ts driver can support multiple devices simultaneously.
Use the i2c_client name instead of the driver name when requesting an
interrupt to make the different interrupts distinguishable in
/proc/interrupts and top.
This allows userspace to more easily distinguish which bus a particular
atmel_mxt_ts device is attached to.
The resulting phys will be something like:
i2c-1-0067/input0
Helps ensure all bytes for a single message together in the system log.
Acked-by: Nick Dyer <nick.dyer@itdev.co.uk>
atmel_mxt devices will send a checksum byte at the end of a message if
the MSB of the object address is set.
However, since this driver does not set this bit, the checksum byte
isn't actually sent, so don't even try to read it.
Don't allow writing past the length of an object.
Restrict permissions on the update_fw sysfs entry to read only for root
only.
Also, update object permission to use a macro S_IRUGO macro instead of
hard coded 0444.
Simple cleanup to use newer PM APIs.
This patch converts the drivers in drivers/input/* to use the
module_i2c_driver() macro which makes the code smaller and a bit
simpler.
Sysfs attribute show methods are always passed a buffer of length
PAGE_SIZE. To keep from overwriting this buffer and causing havoc, use
snprintf() to guarantee we never write more than the buffer can hold.
In addition, at least for my touchscreen, the number and size of objects
was far too big to fit in a single 4K page. Therefore, this patch also
trims some redundant framing text to leave more room for actual data.
Atmel mxt1386 touch controller has the touch pressure information so
let's report it to the user space.
[dtor@mail.ru: added ABS_RESSURE reporting for ST emulation.]
Signed-off-by: Yufeng Shen <miletus@chromium.org>
Acked-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
Handle the objects with multiple instances correctly when the configuration
data is loaded.
Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com>
Update the object list to include new objects, and add unique identifiers
so we can distinguish between old & new generation of the same object.
Atmel touchscreen chips can use MT protocol B because they can assign
unique id to ABS_MT_TRACKING_ID from finger id provided by hardware.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Make the CHG line (interrupt line) go high after the interrupts have been
enabled to make sure we don't miss the falling edge.
Acked-by: Joonyoung Shim <jy0922.shim@samsung.com>
Atmel touchscreen chip can support 12bit resolution and this patch
modifies to get maximum x and y size from platform data.
Acked-by: Iiro Valkonen <iiro.valkonen@atmel.com>
Atmel mXT1386 chip is operated by atmel_mxt_ts driver and it has some
different objects.
Atmel touchscreen chips have different firmware version with each chip,
so we cannot distinguish attribute of chip by firmware version.
The mxt_check_matrix_size() is currently setting the CTE mode to match
xline/yline information that is in the platform data, but it does not
take into account for example the fact that we could have a key array
in use too (key array would use some x/y lines as well).
It would be better to simply rely on the configuration data, and make
sure that the CTE mode set in there matches the touch object (touchscreen,
key array, proximity) configuration (which are set in the config data too).
Different board have different requirements/setups so let's be more
flexible.
