path: root/drivers/input/touchscreen/jornada720_ts.c
2014-10-20input: touchscreen: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-31Input: jornada720_ts - get rid of space indentation and use tabPramod Gurav
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-07-31Input: jornada720_ts - switch to using managed resourcesPramod Gurav
This switches the driver to using managed resources to simplify error handling and to do away with remove function. Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-01-06Input: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-05-05Input: jornada720_ts - remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-11-24Input: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-11-24Input: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Javier Martinez Canillas <javier@dowhile0.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-11-24Input: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2012-07-09ARM: sa11x0/pxa: convert OS timer registers to IOMEMRussell King
Make the OS timer registers have IOMEM like properities so they can be passed to readl_relaxed/writel_relaxed() et.al. rather than being straight volatile dereferences. Add linux/io.h includes where required. linux/io.h includes added to arch/arm/mach-sa1100/cpu-sa1100.c, arch/arm/mach-sa1100/jornada720_ssp.c, arch/arm/mach-sa1100/leds-lart.c drivers/input/touchscreen/jornada720_ts.c, drivers/pcmcia/sa1100_shannon.c from Arnd. This fixes these warnings: arch/arm/mach-sa1100/time.c: In function 'sa1100_timer_init': arch/arm/mach-sa1100/time.c:104: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type arch/arm/mach-pxa/time.c: In function 'pxa_timer_init': arch/arm/mach-pxa/time.c:126: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-25ARM: 7341/1: input: prepare jornada720 keyboard and ts for sa11x0 sparse irqRob Herring
In preparation for sa11x0 sparse irq conversion, explicitly include mach/irqs.h as it will not be included for sparse irq. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-30Input: touchscreen - use macro module_platform_driver()JJ Ding
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to save some platform_driver boilerplate code. Use it. Signed-off-by: JJ Ding <dgdunix@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-09-07Input: remove IRQF_DISABLED from driversYong Zhang
This flag is a NOOP and can be removed now. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: jornada720_ts - fix build error ( LONG() usage ) Input: bcm5974 - switch back to normal mode when closing
2008-09-16Input: jornada720_ts - fix build error ( LONG() usage )Kristoffer Ericson
This patch removes the usage of LONG() which is deprecated; we also replace BIT() with BIT_MASK(). signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-21MODULE_LICENSE expects "GPL v2", not "GPLv2"Al Viro
... and we have few enough places using the latter to make it simpler to do search and replace... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24Input: add MODULE_ALIAS() to hotpluggable platform modulesKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable "input" platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-09-26Input: add support for the HP Jornada 7xx (710/720/728) touchscreenKristoffer Ericson
Signed-off-by: Kristoffer Ericson <Kristoffer.Ericson@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
