path: root/drivers/input/touchscreen/mainstone-wm97xx.c
2011-11-30Input: touchscreen - use macro module_platform_driver()JJ Ding
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to save some platform_driver boilerplate code. Use it. Signed-off-by: JJ Ding <dgdunix@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-04Input: wm97xx - remove redundant defineWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-01-28Input: wm97xx - provide coordinate logs for accelerated I/OMark Brown
This aids debug of problematic systems. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-07-20Input: wm97xx - add possibility to control the GPIO_STATUS shiftMarek Vasut
This patch allows tweaking the behaviour of GPIO_STATUS register shift quirk that's in wm97xx-core. The problem with GPIO_STATUS register being shifted by one doesn't appear on all hardware it seems and causes problems with accelerated touchscreen drivers on Palm hardware. Therefore an accelerated touchscreen driver can select if the shift is/isn't happening on the hardware. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-07-20Input: wm97xx - add Palm support to Mainstone accelerated touchMarek Vasut
This patch refactors the Mainstone accelerated touch code a little and adds support for interrupt driven touchscreen on Palm LifeDrive, TX and Tungsten T5. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-04-15Input: mainstone-wm97xx - fix condition in pen_upJiri Slaby
The loop body was never executed, because the condition is always false. Convert to for with more obvious condition. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-03-08Input: ucb1400_ts, mainstone-wm97xx - add BTN_TOUCH eventsMike Rapoport
Add BTN_TOUCH event reporting to ucb1400_ts and accelerated mainstone-wm97xx touchscreen drivers. Together with previously posted similar patch for wm97xx-core this will make all touchscreen drivers behave consistently wrt. BTN_TOUCH. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-03-08Input: wm97xx - use disable_irq_nosync() for MainstoneMark Brown
This should make no practical difference since the Mainstone can't be SMP but it is more correct. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-12-02[ARM] pxa: move AC97 register definitions into dedicated regs-ac97.hEric Miao
The optimal change would be to move the AC97 register definitions into the AC97 driver, unfortunately, the registers are shared between several files. Move them into a dedicated regs-ac97.h first. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-10-15Merge branch 'next' into for-linusDmitry Torokhov
2008-10-13Input: wm97xx - update email address for Liam GirdwoodLiam Girdwood
This updates the email address for Liam Girdwood as my old address is no longer valid. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-02Input: WM97xx - add support for streaming mode on MainstoneMark Brown
Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com> Signed-off-by: Mike Arthur <mike.arthur@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
