Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
There is a general move towards the use of dev_pm_ops rather than
bus specific suspend APIs as this simplifies both the bus and PM core
implementations. Convert the mcs5000_ts driver over.
Compile tested only.
This adds support for MELPAS MCS5000/MSC5080 touch key controllers.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The MELPAS MCS-5000 is the touchscreen controller. The overview of this
controller can see at the following website:
http://www.melfas.com/product/product01.asp?k_r=eng_
This driver is tested on s3c6410 NCP board and supports only the i2c
interface.
