Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to
save some platform_driver boilerplate code. Use it.
Signed-off-by: JJ Ding <dgdunix@gmail.com>
This flag is a NOOP and can be removed now.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
No need to take address, w90p910_ts is already a pointer.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (52 commits)
Input: bcm5974 - silence uninitialized variables warnings
Input: wistron_btns - add keymap for AOpen 1557
Input: psmouse - use boolean type
Input: i8042 - use platform_driver_probe
Input: i8042 - use boolean type where it makes sense
Input: i8042 - try disabling and re-enabling AUX port at close
Input: pxa27x_keypad - allow modifying keymap from userspace
Input: sunkbd - fix formatting
Input: i8042 - bypass AUX IRQ delivery test on laptops
Input: wacom_w8001 - simplify querying logic
Input: atkbd - allow setting force-release bitmap via sysfs
Input: w90p910_keypad - move a dereference below a NULL test
Input: add twl4030_keypad driver
Input: matrix-keypad - add function to build device keymap
Input: tosakbd - fix cleaning up KEY_STROBEs after error
Input: joydev - validate axis/button maps before clobbering current ones
Input: xpad - add USB ID for the drumkit controller from Rock Band
Input: w90p910_keypad - rename driver name to match platform
Input: add new driver for Sentelic Finger Sensing Pad
Input: psmouse - allow defining read-only attributes
Add the cpu.c and dev.c and modify w90p910 platform
to apply to use the common API(provided by cpu.c and dev.c)
at the same time, I renamed all w90x900 to nuc900 in every
c file of w90x900 platform and touchscreen's driver name.
Now that clk API is available on ARM we can use it in the driver.
Use the function resource_size, which reduces the chance of
introducing off-by-one errors in calculating the resource size.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct resource *res;
- (res->end - res->start) + 1
+ resource_size(res)
// </smpl>
The touchscreen works in two modes, wait trigger mode and auto-semi
mode. The device starts in wait trigger mode and waits until pressure
is detected, then device sets WT_INT bit and raises an interrupt.
The driver should put the device into auto-semi mode and prepare for
reading first X and then Y coordinates. When coordinate data is ready
the driver sets ADC_INT bit and raises interrupt again.
[dtor@mail.ru: various cleanups]
