path: root/drivers/input/touchscreen/zylonite-wm97xx.c
2012-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (64 commits) Input: tc3589x-keypad - add missing kerneldoc Input: ucb1400-ts - switch to using dev_xxx() for diagnostic messages Input: ucb1400_ts - convert to threaded IRQ Input: ucb1400_ts - drop inline annotations Input: usb1400_ts - add __devinit/__devexit section annotations Input: ucb1400_ts - set driver owner Input: ucb1400_ts - convert to use dev_pm_ops Input: psmouse - make sure we do not use stale methods Input: evdev - do not block waiting for an event if fd is nonblock Input: evdev - if no events and non-block, return EAGAIN not 0 Input: evdev - only allow reading events if a full packet is present Input: add driver for pixcir i2c touchscreens Input: samsung-keypad - implement runtime power management support Input: tegra-kbc - report wakeup key for some platforms Input: tegra-kbc - add device tree bindings Input: add driver for AUO In-Cell touchscreens using pixcir ICs Input: mpu3050 - configure the sampling method Input: mpu3050 - ensure we enable interrupts Input: mpu3050 - add of_match table for device-tree probing Input: sentelic - document the latest hardware ... Fix up fairly trivial conflicts (device tree matching conflicting with some independent cleanups) in drivers/input/keyboard/samsung-keypad.c
2011-12-28Input: zylonite-wm97xx - replace IRQ_GPIO() with gpio_to_irq()Axel Lin
Since commit 6384fd "ARM: pxa: rename IRQ_GPIO to PXA_GPIO_TO_IRQ", I got below buid errors due to implicit declaration of function 'IRQ_GPIO'. Use common gpio_to_irq() to replace machine dependant macro IRQ_GPIO(). CC drivers/input/touchscreen/zylonite-wm97xx.o drivers/input/touchscreen/zylonite-wm97xx.c: In function 'zylonite_wm97xx_probe': drivers/input/touchscreen/zylonite-wm97xx.c:195: error: implicit declaration of function 'IRQ_GPIO' make[3]: *** [drivers/input/touchscreen/zylonite-wm97xx.o] Error 1 make[2]: *** [drivers/input/touchscreen] Error 2 make[1]: *** [drivers/input] Error 2 make: *** [drivers] Error 2 Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-11-30Input: touchscreen - use macro module_platform_driver()JJ Ding
Commit 940ab88962bc1aff3273a8356d64577a6e386736 introduced a new macro to save some platform_driver boilerplate code. Use it. Signed-off-by: JJ Ding <dgdunix@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-07-04Input: wm97xx - remove redundant defineWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-01-28Input: wm97xx - provide coordinate logs for accelerated I/OMark Brown
This aids debug of problematic systems. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-08Input: add accelerated touchscreen support for Marvell ZyloniteMark Brown
This patch implements accelerated touchscreen support for the Marvell Zylonite development platform, supporting pen down interrupts and continuous mode data transfers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
