Change-Id: I3a43dc58edff3687e294c2d2a09d1f6e06e27fce
Signed-off-by: Gary King <gking@nvidia.com>
driver supports the MGG1010AI06 and EGG1010AI06 capacitive touch panels
Change-Id: I038030bf4c9acbd0d3d504427a32f4e46632c115
Adds INPUT_PROP_POINTER or INPUT_PROP_DIRECT as necessary to the
hardware supported by the Wacom driver. The DIRECT property is
assigned to devices with an embedded screen (i.e. touchscreens
and display tablets). The POINTER property is assigned to those
without embedded screens.
Signed-off-by: Jason Gerecke <killertofu@gmail.com>
Reviewed-by: Ping Cheng <pingc@wacom.com>
tnetv107x-ts.c uses interfaces from linux/module.h,
so it should include that file. This patch fixes build errors.
The original license statement was confusing since it was unclear if
the license was pure GPLv2 or GPLv2+ and did not match the license
of the driver max11801_ts was derived from. The license is GPLv2+.
Signed-off-by: Jiejing Zhang <jiejing.zhang@freescale.com>
Atmel mxt1386 touch controller has the touch pressure information so
let's report it to the user space.
[dtor@mail.ru: added ABS_RESSURE reporting for ST emulation.]
Signed-off-by: Yufeng Shen <miletus@chromium.org>
Acked-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Acked-by: Henrik Rydberg <rydberg@euromail.se>
Input close or device disable should not interact with the exported
gpiolib functionality. However that's the case. __ad7879_disable()
clears the entire AD7879_REG_CTRL2, while it should just power down
the ADC and its reference.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
The implementation does break from the for loop after we assign 'i' to
variable 'found'.
The implementation in cy8ctmg110_probe() does not properly set reset_pin
and irq_pin from platform data. Let's fix it.
i2c_master_send returns negative errno, or else the number of bytes written.
Currently, battery drivers also use poll_sample() provided by the
wm97xx-core but this code always checks if the pen is down. Mark the
channels which really need this (i.e. for the touchscreen) with the
PEN_DOWN bit, and skip the checks otherwise. Now, the battery channels
can always be read.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The current implementation of poll_sample() has the problem that one of
its arguments, the channel to be selected, differs from wm9713 to other
variants. This parameter gets passed to the (currently unused)
mach-specific functions pre_sample() and post_sample() which thus have
to deal with codec-specific differences. Refactor the routine so that
the argument to poll_sample() is generic for all codecs and do necessary
conversions only in the codec-specific driver. The outcome even uses
less code and removes the non-standard use of the PEN_DOWN bit to mark
the AUX-channels.
Handle the objects with multiple instances correctly when the configuration
data is loaded.
Signed-off-by: Iiro Valkonen <iiro.valkonen@atmel.com>
Update the object list to include new objects, and add unique identifiers
so we can distinguish between old & new generation of the same object.
This patch updates the email address of the gpio_mouse, at32psif, and
atmel-wm97xx drivers supported by me to an email account I will use on a more
regular basis in the future.
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Use gpio_request_one() instead of multiple gpiolib calls.
This also simplifies error handling a bit.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Remove the space between "platform:" prefix and the driver name.
These new platform-specific values can be used to set the fuzz parameter
passed to the input_set_abs_params() function for the ABS_X, ABS_Y and
ABS_PRESSURE axes.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
This new parameter allows the polling frequency to be configured while
keeping the default of once every millisecond.
Depending on the quality of the touch panel, the time for the X-, X+, Y-
and Y+ inputs to settle may vary. The poll_delay parameter can be used
to override the default of 1 millisecond.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Kwangwoo Lee <kwangwoo.lee@gmail.com>
Finger touch events or very quick stylus events on low-quality panels
can cause the tsc2007 to read bogus values. Looking at oscilloscope
snapshots, this seems to be caused by the touch event disappearing
during the measurements. These bogus values result in misclicks, where
the X and Y values deviate from the real position.
Most of these misclicks can be filtered out by setting a low enough
threshold for the maximum resistance (which is loosely the inverse of
the pressure) allowed to consider a set of values valid. Since this
behaviour is largely dependent on the type and quality of the panel,
this commit introduces the max_rt parameter. The default value is kept
at MAX_12BIT.
When the controller signals a pen-down event via the platform-specific
GPIO, while the sample values indicate an invalid measurement, the
measurement needs to be repeated.
This error handling code can be reached before ts_dev->input is
initialized, so it is safer to always use the original name,
input_dev.
The pendown gpio was requested but not configured for input.
Configure it for input.
Just set vref_mv in your platform config to use external vref. Otherwise
the internal one is used.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
req.sample needs its own cacheline otherwise accessing req.msg fetches
it in again.
Note: This effect doesn't occur if the underlying SPI driver doesn't use
DMA at all.
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
Make sure we are passing the same cookie in all calls to request_irq() and
free_irq().
Don't report BTN_TOUCH until we've got data as some less robust applications
can be confused by getting a touch event by itself and it doesn't seem
unreasonable for them to expect coordinates along with a touch.
This allows maximum flexibility for configuring the direct GPIO based
interrupts.
If the WM831x pen down and data IRQs run in parallel it is possible for the
data and pen down IRQs to deadlock themselves as one is part way through
disabling its operation while the other is part way through enabling. Fix
this by always disabling the pen down interrupt while data is active and
vice versa. When a changeover is required we disable the IRQ that is to
be stopped then schedule work that will enable the new IRQ.
We need to handle the data flow in the data IRQ as the readback from the
device needs to be ordered correctly with the IRQ for robust operation.
This also fixes an issue when using the built in IRQs due to enable_irq()
not being valid from interrupt context on an interrupt controller with bus
operations like the built in IRQ controller - this issue may also have
affected other interrupt controllers. We can't rely on having the data
and pen down IRQs available via GPIOs on the CPU on every system.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xen-kbdfront - fix mouse getting stuck after save/restore
Input: estimate number of events per packet
Input: evdev - indicate buffer overrun with SYN_DROPPED
Input: document event types and codes and their intended use
Input: add KEY_IMAGES specifically for AL Image Browser
Input: twl4030_keypad - fix potential NULL dereference in twl4030_kp_probe()
Input: h3600_ts - fix error handling at connect
Input: twl4030_keypad - avoid potential NULL-pointer dereference
Atmel touchscreen chips can use MT protocol B because they can assign
unique id to ABS_MT_TRACKING_ID from finger id provided by hardware.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Make the CHG line (interrupt line) go high after the interrupts have been
enabled to make sure we don't miss the falling edge.
Acked-by: Joonyoung Shim <jy0922.shim@samsung.com>
Atmel touchscreen chip can support 12bit resolution and this patch
modifies to get maximum x and y size from platform data.
Acked-by: Iiro Valkonen <iiro.valkonen@atmel.com>
Add MAXI max11801 resistive touchscreen controller driver. This driver
uses Auto Mode and Aperture Mode.
Support for other max1180x devices can be added to this driver as well,
as they use almost the same register addresses and codes.
You can find data sheet here:
http://www.maxim-ic.com/datasheet/index.mvp/id/5943
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
In case of an error in h3600ts_connect(), deconstruct in correct order
and with the right calls.
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Input: rpckbd - fix a leak of the IRQ during init failure
Input: wacom - add support for Lenovo tablet ID (0xE6)
Input: i8042 - downgrade selftest error message to dbg()
Input: synaptics - fix crash in synaptics_module_init()
Input: spear-keyboard - fix inverted condition in interrupt handler
Input: uinput - allow for 0/0 min/max on absolute axes.
Input: sparse-keymap - report KEY_UNKNOWN for unknown scan codes
Input: sparse-keymap - report scancodes with key events
Input: h3600_ts_input - fix a spelling error
Input: wacom - report resolution for pen devices
Input: wacom - constify wacom_features for a new missed Bamboo models
Scripted with coccinelle.
Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org>
Input: tsc2005 - fix locking issue
Input: tsc2005 - use relative jiffies to schedule the watchdog
Input: tsc2005 - driver should depend on GENERIC_HARDIRQS
Commit 0b950d3 (Input: tsc2005 - add open/close) introduced a
locking issue with the ESD watchdog: __tsc2005_disable() is calling
cancel_delayed_work_sync() with mutex held, and the work also needs the
same mutex.
Fix the problem by using mutex_trylock() in tsc2005_esd_work(). If the
mutex is taken, we know we are in the middle of disable or enable and
the watchdog check can be skipped.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Use relative jiffies to schedule the watchdog. Otherwise it will run
like a mad one.
drivers/input/touchscreen/tsc2005.c: In function ‘tsc2005_probe’:
drivers/input/touchscreen/tsc2005.c:666: error: implicit declaration of function ‘set_irq_wake’
In addition, migrate from set_irq_wake() (marked "do not use" as of commit
a0cd9ca2b907d7ee26575e7b63ac92dad768a75e ("genirq: Namespace cleanup")) to
irq_set_irq_wake().
