git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A bunch of fixes for minor defects reported by Coverity, a few driver
fixups and revert of i8042.nomux change so that we are once again
enable active MUX mode if box claims to support it"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Revert "Input: i8042 - disable active multiplexing by default"
Input: altera_ps2 - use correct type for irq return value
Input: altera_ps2 - write to correct register when disabling interrupts
Input: max77693-haptic - fix potential overflow
Input: psmouse - remove unneeded check in psmouse_reconnect()
Input: vsxxxaa - fix code dropping bytes from queue
Input: ims-pcu - fix dead code in ims_pcu_ofn_reg_addr_store()
Input: opencores-kbd - fix error handling
Input: wm97xx - adapt parameters to tosa touchscreen.
Input: i8042 - quirks for Fujitsu Lifebook A544 and Lifebook AH544
Input: stmpe-keypad - fix valid key line bitmask
Input: soc_button_array - update calls to gpiod_get*()
Sharp SL-6000 (tosa) touchscreen needs wider limits to properly map all
points on the screen. Expand ranges in abs_x and abs_y arrays according
to the touchscreen area.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Pull second round of input updates from Dmitry Torokhov:
"Mostly simple bug fixes, although we do have one brand new driver for
Microchip AR1021 i2c touchscreen.
Also there is the change to stop trying to use i8042 active
multiplexing by default (it is still possible to activate it via
i8042.nomux=0 on boxes that implement it)"
Input: xpad - add Thrustmaster as Xbox 360 controller vendor
Input: xpad - add USB ID for Thrustmaster Ferrari 458 Racing Wheel
Input: max77693-haptic - fix state check in imax77693_haptic_disable()
Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backend
Input: alps - fix v4 button press recognition
Input: i8042 - add noloop quirk for Asus X750LN
Input: synaptics - gate forcepad support by DMI check
Input: Add Microchip AR1021 i2c touchscreen
Input: cros_ec_keyb - add of match table
Input: serio - avoid negative serio device numbers
Input: avoid negative input device numbers
Input: automatically set EV_ABS bit in input_set_abs_params
Input: adp5588-keys - cancel workqueue in failure path
Input: opencores-kbd - switch to using managed resources
Input: evdev - fix EVIOCG{type} ioctl
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Synchronize with mainline to bring in changes to Synaptics and i8042
drivers.
This patch adds support for the ar1021 i2c based touchscreen.
The driver is quite simple and only supports the Touch
Reporting Protocol.
This is the final version for an RFC patch send a while ago.
http://www.spinics.net/lists/linux-input/msg29419.html
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[Nick Dyer: reworked to move free of input device into separate function
and only call in paths that require it.]
Signed-off-by: Nick Dyer <nick.dyer@itdev.co.uk>
In the case where the CHG/interrupt line mode is not configured correctly,
this warning is output to dmesg output for each interrupt. Downgrade the
message to debug.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Prepare second round of input updates for 3.17.
Somehow we ended up with a duplicate line in edt_ft5x06_register_write()
Signed-off-by: Maks Naumov <maksqwe1@ukr.net>
This should fix the following issues reported by Coverity:
*** CID 1230625: Logically dead code (DEADCODE)
/drivers/input/touchscreen/atmel_mxt_ts.c: 1692 in mxt_initialize()
*** CID 1230627: Missing break in switch (MISSING_BREAK)
/drivers/input/touchscreen/atmel_mxt_ts.c: 1436 in mxt_get_object_table()
*** CID 1230629: Out-of-bounds write (OVERRUN)
/drivers/input/touchscreen/atmel_mxt_ts.c: 1267 in mxt_update_cfg()
*** CID 1230632: Unused pointer value (UNUSED_VALUE)
/drivers/input/touchscreen/atmel_mxt_ts.c: 1211 in mxt_update_cfg()
Acked-by: Nick Dyer <nick.dyer@itdev.co.uk>
Let's split config update code a bit so it is hopefully a bit easier to
read. Also, the firmware update callback should be the entity releasing
firmware blob, not lower layers.
I think having control flow with 2 goto/labels/flags is quite hard to read,
this version is a bit more readable IMO.
Prepare first round of input updates for 3.17.
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com>
This switches the driver to using managed resources to simplify error
handling and to do away with remove function.
We can annonate the suspend/resume functions with '__maybe_unused' and get
rid of the ifdef, which makes the code smaller and simpler.
When a kernel has CONFIG_PM=y and CONFIG_PM_SLEEP=n the following warnings are
seen:
drivers/input/touchscreen/mcs5000_ts.c:252:12: warning: 'mcs5000_ts_suspend' defined but not used [-Wunused-function]
static int mcs5000_ts_suspend(struct device *dev)
drivers/input/touchscreen/mcs5000_ts.c:262:12: warning: 'mcs5000_ts_resume' defined but not used [-Wunused-function]
static int mcs5000_ts_resume(struct device *dev)
Protect the suspend/resume functions with CONFIG_PM_SLEEP in order to fix these
build warnings.
Input device must be released(input_free_device) when ads7846_probe_dt
fails. This fixes the same by releasing resources on failure.
By writing zero to both the active and idle cycle times the maXTouch device
is put into a deep sleep mode when it consumes minimal power. It is
unnecessary to change the configuration of any other objects (for example
to disable T9 touchscreen).
It is counterproductive to reset the chip on resume, it will result in a
long delay. However it is necessary to issue a calibrate command after the
chip has spent any time in deep sleep.
This patch also deals with the situation where the power configuration is
zero on probe, which would mean that the device never wakes up to execute
commands.
Acked-by: Benson Leung <bleung@chromium.org>
Acked-by: Yufeng Shen <miletus@chromium.org>
Provide device tree support and binding information. Also provide support
for a new chip "pixcir_tangoc".
Signed-off-by: Roger Quadros <rogerq@ti.com>
Some variants of the Pixcir touch controller support up to 5 simultaneous
fingers and hardware tracking IDs. Prepare the driver for that.
Switch to using the Type-B Multi-Touch protocol.
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Wire up open/close so we do not try to send events until someone uses them;
this also allows us to remove micro_ts_remove() and rely fully on managed
resources.
This adds a driver for the touchscreen connected to the Atmel
microcontroller on the iPAQ h3xxx series.
Based on a driver from handhelds.org 2.6.21 kernel, written by Alessandro
GARDICH, with the bulk of the code for the new input architecture rewritten
by Dmitry Atamonow, and the final polish by Linus Walleij.
Signed-off-by: Alessandro GARDICH <gremlin@gremlin.it>
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
Merge with mainline to bring in changes to MFD to allow merging
ipaq-micro-ts driver.
maXTouch chips allow the reading of multiple messages in a single I2C
transaction, which reduces bus overhead and improves performance/latency. The
number of messages available to be read is given by the value in the T44
object which is located directly before the T5 object.
This is in preparation for support of the T44 message count object.
Also, cache T5 address to avoid lookup on every interrupt cycle.
By storing the previous T6 status byte multiple debug output of the same
status can be suppressed (for example CFGERR).
The T5 object may have various sizes depending on the objects used on the
particular maXTouch chip and firmware version, therefore it can't be
hardcoded in the driver. Allocate a buffer on probe instead.
The MXT device may be in bootloader mode on probe, due to:
1) APP CRC failure, either:
a) flash corruption
b) bad power or other intermittent problem while checking CRC
2) If the device has been reset 10 or more times without accessing comms
3) Warm probe, device was in bootloader mode already
This code attempts to recover from 1(b) and 3.
There is an additional complexity: we have to try two possible bootloader
addresses because the mapping is not one-to-one and we don't know the exact
model yet.
Later chips (for example mXT1664S) different mappings for bootloader
addresses. This means that we must look at the family ID to determine
which address to use.
On a warm probe, the device might be in a state where an flash operation was
not completed.
If the bootloader on the touchscreen controller fails to initialise the
firmware image, it stays in bootloader mode and reports a failure. It is
possible to reflash a working firmware image from this state.
By validating the checksum, we can identify if the configuration is
corrupt. In addition, this patch writes the configuration in a short
series of block writes rather than as many individual values.
The existing implementation which encodes the configuration as a binary
blob in platform data is unsatisfactory since it requires a kernel
recompile for the configuration to be changed, and it doesn't deal well
with firmware changes that move values around on the chip.
Atmel define an ASCII format for the configuration which can be exported
from their tools. This patch implements a parser for that format which
loads the configuration via the firmware loader and sends it to the MXT
chip.
Touchpads are pointers, so make sure to pass the correct values to
input_mt_report_pointer_emulation(). Without this, tap-to-click doesn't
work.
Signed-off-by: Benson Leung <bleung@chromium.org>
It is useful to initialise the input device later:
- Screen parameters may not be not known yet, for instance if waiting for
firmware loader to return.
- Device may be in bootloader mode on probe (but could still be recovered by
firmware download).
In addition, later devices have a different touchscreen object (T100) which
requires handling differently.
This also reduces the complexity of the probe function.
The maXTouch chips use the CHG line to generate status events in bootloader
mode, and during configuration download, before there is enough information
to configure the input device. Therefore set up the interrupt handler
earlier.
However, this introduces states where parts of the interrupt processing
must not run. Use data->object_table as a way to tell whether the chip
information is valid, and data->input_dev as a way to tell whether it is
valid to generate input report.
It's possible that the controller has an individually switchable power supply.
Therefore add support to control a supplying regulator.
As this is not always the case, the regulator is requested as optional.
Signed-off-by: Heiko Stuebner <heiko.stuebner@bq.com>
Use clk_prepare_enable/clk_disable_unprepare to make the driver
work properly with common clock framework.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Fix checkpatch warning:
"WARNING: debugfs_remove_recursive(NULL) is safe this check is probably not required"
Signed-off-by: Fabian Frederick <fabf@skynet.be>
In the hopes that people run new kernels on their devices, let's add a
warning message asking users to have their DTS file fixed.
The goal is that by Linux 4.0 we will be able to remove support for the
bogus version of our touchscreen's DTS.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
"A big update to the Atmel touchscreen driver, devm support for polled
input devices, several drivers have been converted to using managed
resources, and assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (87 commits)
Input: synaptics - fix resolution for manually provided min/max
Input: atmel_mxt_ts - fix invalid return from mxt_get_bootloader_version
Input: max8997_haptic - add error handling for regulator and pwm
Input: elantech - don't set bit 1 of reg_10 when the no_hw_res quirk is set
Input: elantech - deal with clickpads reporting right button events
Input: edt-ft5x06 - fix an i2c write for M09 support
Input: omap-keypad - remove platform data support
ARM: OMAP2+: remove unused omap4-keypad file and code
Input: ab8500-ponkey - switch to using managed resources
Input: max8925_onkey - switch to using managed resources
Input: 88pm860x-ts - switch to using managed resources
Input: 88pm860x_onkey - switch to using managed resources
Input: intel-mid-touch - switch to using managed resources
Input: wacom - process outbound for newer Cintiqs
Input: wacom - set stylus_in_proximity when pen is in range
DTS: ARM: OMAP3-N900: Add tsc2005 support
Input: tsc2005 - add DT support
Input: add common DT binding for touchscreens
Input: jornada680_kbd - switch top using managed resources
Input: adp5520-keys - switch to using managed resources
Prepare input updates for 3.16.
