commit 968491709e5b1aaf429428814fff3d932fa90b60 upstream.
This patch fixes a problem in the usbtouchscreen driver for DMC TSC-30
touch screen. Due to a missing delay between the RESET and SET_RATE
commands, the touch screen may become unresponsive during system startup or
driver loading.
According to the DMC documentation, a delay is needed after the RESET
command to allow the chip to complete its internal initialization. As this
delay is not guaranteed, we had a system where the touch screen
occasionally did not send any touch data. There was no other indication of
the problem.
The patch fixes the problem by adding a 150ms delay between the RESET and
SET_RATE commands.
Suggested-by: Jakob Mustafa <jakob.mustafa@bytecmed.com>
Signed-off-by: Bernhard Bender <bernhard.bender@bytecmed.com>
commit 692dd1916436164e228608803dfb6cb768d6355a upstream.
This adds new icbody type to the list recognized by Elantech PS/2 driver.
Signed-off-by: Sam Hung <sam.hung@emc.com.tw>
commit 810aa0918b2b032684c8cad13f73d6ba37ad11c0 upstream.
This change allows the driver to recognize newer Elantech touchpads.
Signed-off-by: Yi ju Hong <sam.hung@emc.com.tw>
commit ae4bedf0679d99f0a9b80a7ea9b8dd205de05d06 upstream.
Newer elantech touchpads are not recognized by the current driver, since it
fails to detect their firmware version number. This prevents more advanced
touchpad features from being usable such as two-finger scrolling. This
patch allows newer touchpads to be detected and be fully functional. Tested
on Sony Vaio SVF13N17PXB.
Signed-off-by: Jordan Rife <jrife0@gmail.com>
commit 9cb80b965eaf7af1369f6e16f48a05fbaaccc021 upstream.
Added detection for newer Elantech touchpads, so that kernel doesn't
fall-back to default PS/2 driver. Supports touchpads released after
~August 2013. Fixes bug:
https://lists.launchpad.net/kernel-packages/msg18481.html
Tested on an Acer Aspire S7-392-6302.
Signed-off by: Matt Walker <matt.g.d.walker@gmail.com>
commit 9eebed7de660c0b5ab129a9de4f89d20b60de68c upstream.
* Fix version recognition in elantech_set_properties
The new hardware reports itself as v7 but the packets'
structure is unaltered.
* Fix packet type recognition in elantech_packet_check_v4
The bitmask used for v6 is too wide, only the last three bits of
the third byte in a packet (packet[3] & 0x03) are actually used to
distinguish between packet types.
Starting from v7, additional information (to be interpreted) is
stored in the remaining bits (packets[3] & 0x1c).
In addition, the value stored in (packet[0] & 0x0c) is no longer
a constant but contains additional information yet to be deciphered.
This change should be backwards compatible with v6 hardware.
Additional-author: Giovanni Frigione <gio.frigione@gmail.com>
Signed-off-by: Matteo Delfino <kendatsuba@gmail.com>
known rate
commit 5f0ee9d17aae628b22be86966471db65be21f262 upstream.
Make the check to skip the rate check more lax, so that it applies
to all hw_version 4 models.
This fixes the touchpad not being detected properly on Asus PU551LA
laptops.
Reported-and-tested-by: David Zafra Gómez <dezeta@klo.es>
commit 3c0213d17a09601e0c6c0ae0e27caf70d988290f upstream.
When the v3 hardware sees more than one finger, it uses the semi-mt
protocol to report the touches. However, it currently works when
num_fingers is 0, 1 or 2, but when it is 3 and above, it sends only 1
finger as if num_fingers was 1.
This confuses userspace which knows how to deal with extra fingers
when all the slots are used, but not when some are missing.
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=90101
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit bd884149aca61de269fd9bad83fe2a4232ffab21 upstream.
On ASUS TP500LN and X750JN, the touchpad absolute mode is reset each
time set_rate is done.
In order to fix this, we will verify the firmware version, and if it
matches the one in those laptops, the set_rate function is overloaded
with a function elantech_set_rate_restore_reg_07 that performs the
set_rate with the original function, followed by a restore of reg_07
(the register that sets the absolute mode on elantech v4 hardware).
Also the ASUS TP500LN and X750JN firmware version, capabilities, and
button constellation is added to elantech.c
Reported-and-tested-by: George Moutsopoulos <gmoutso@yahoo.co.uk>
Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
[bwh: Backported to 3.2:
- Adjust context
- Drop the insertion into a comment we don't have]
commit ebc80840b850db72f7ae84fbcf77630ae5409629 upstream.
The Fimware 8.1 has a bug in which the extra buttons are only sent when the
ExtBit is 1. This should be fixed in a future FW update which should have
a bump of the minor version.
Acked-by: Hans de Goede <hdegoede@redhat.com>
commit dc5465dc8a6d5cae8a0e1d8826bdcb2e4cb261ab upstream.
On the X1 Carbon 3rd gen (with a 2015 broadwell cpu), the physical middle
button of the trackstick (attached to the touchpad serio device, of course)
seems to get lost.
Actually, the touchpads reports 3 extra buttons, which falls in the switch
below to the '2' case. Let's handle the case of odd numbers also, so that
the middle button finds its way back.
[bwh: Backported to 3.2: open-code GENMASK()]
commit ac097930f0730a9b777737de2b51e0fc49d2be7a upstream.
Query the min dimensions even if the check
SYN_EXT_CAP_REQUESTS(priv->capabilities) >= 7 fails, but we know that the
firmware version 8.1 is safe.
With that we don't need quirks for post-2013 models anymore as they expose
correct min and max dimensions.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=91541
Signed-off-by: Daniel Martin <consume.noise@gmail.com>
re-order the tests to check SYN_CAP_MIN_DIMENSIONS even on FW 8.1
commit 1d90d6d5522befa8efa1a7ea406be65cf865ded4 upstream.
Without this the aux port does not get detected, and consequently the touchpad
will not work.
With this patch the touchpad is detected:
$ dmesg | grep -E "(SYN|i8042|serio)"
pnp 00:03: Plug and Play ACPI device, IDs SYN1d22 PNP0f13 (active)
i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x126800, board id: 2863, fw id: 1473085
input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input6
dmidecode excerpt for this laptop is:
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Medion
Product Name: Akoya E7225
Version: 1.0
Signed-off-by: Jochen Hein <jochen@jochen.org>
commit 9333caeaeae4f831054e0e127a6ed3948b604d3e upstream.
When KBC is in active multiplexing mode the touchpad on this laptop does
not work.
Reported-by: Bilal Koc <koc.bilo@googlemail.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit a1f9a4072655843fc03186acbad65990cc05dd2d upstream.
The xpad wireless endpoint is not a bulk endpoint on my devices, but
rather an interrupt one, so the USB core complains when it is submitted.
I'm guessing that the author really did mean that this should be an
interrupt urb, but as there are a zillion different xpad devices out
there, let's cover out bases and handle both bulk and interrupt
endpoints just as easily.
Signed-off-by: "Pierre-Loup A. Griffais" <pgriffais@valvesoftware.com>
commit 9d720b34c0a432639252f63012e18b0507f5b432 upstream.
On some Dell Latitude laptops ALPS device or Dell EC send one invalid byte
in 6 bytes ALPS packet. In this case psmouse driver enter out of sync
state. It looks like that all other bytes in packets are valid and also
device working properly. So there is no need to do full device reset, just
need to wait for byte which match condition for first byte (start of
packet). Because ALPS packets are bigger (6 or 8 bytes) default limit is
small.
This patch increase number of invalid bytes to size of 2 ALPS packets which
psmouse driver can drop before do full reset.
Resetting ALPS devices take some time and when doing reset on some Dell
laptops touchpad, trackstick and also keyboard do not respond. So it is
better to do it only if really necessary.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit 4ab8f7f320f91f279c3f06a9795cfea5c972888a upstream.
5th and 6th byte of ALPS trackstick V3 protocol match condition for first
byte of PS/2 3 bytes packet. When driver enters out of sync state and ALPS
trackstick is sending data then driver match 5th, 6th and next 1st bytes as
PS/2.
It basically means if user is using trackstick when driver is in out of
sync state driver will never resync. Processing these bytes as 3 bytes PS/2
data cause total mess (random cursor movements, random clicks) and make
trackstick unusable until psmouse driver decide to do full device reset.
Lot of users reported problems with ALPS devices on Dell Latitude E6440,
E6540 and E7440 laptops. ALPS device or Dell EC for unknown reason send
some invalid ALPS PS/2 bytes which cause driver out of sync. It looks like
that i8042 and psmouse/alps driver always receive group of 6 bytes packets
so there are no missing bytes and no bytes were inserted between valid
ones.
This patch does not fix root of problem with ALPS devices found in Dell
Latitude laptops but it does not allow to process some (invalid)
subsequence of 6 bytes ALPS packets as 3 bytes PS/2 when driver is out of
sync.
So with this patch trackstick input device does not report bogus data when
also driver is out of sync, so trackstick should be usable on those
machines.
commit 993b3a3f80a7842a48cd46c2b41e1b3ef6302468 upstream.
These models need i8042.notimeout, otherwise the touchpad will not work.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=69731
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1111138
commit 9ff84a17302aeb8913ff244ecc0d8f9d219fecb5 upstream.
https://bugzilla.redhat.com/show_bug.cgi?id=1110011
commit aa972409951e0675e07918620427517cad5090e0 upstream.
Unfortunately, ForcePad capability is not actually exported over PS/2, so
we have to resort to DMI checks.
Reported-by: Nicole Faerber <nicole.faerber@kernelconcepts.de>
[bwh: Backported to 3.2: adjust context]
commit d2682118f4bb3ceb835f91c1a694407a31bb7378 upstream.
The sys_vendor / product_name are somewhat generic unfortunately, so this
may lead to some false positives. But nomux usually does no harm, where as
not having it clearly is causing problems on the Avatar AVIU-145A6.
https://bugzilla.kernel.org/show_bug.cgi?id=77391
Reported-by: Hugo P <saurosii@gmail.com>
commit cc18a69c92d0972bc2fc5a047ee3be1e8398171b upstream.
Reported-by: Jason Robinson <mail@jasonrobinson.me>
commit a80d8b02751060a178bb1f7a6b7a93645a7a308b upstream.
When running a 32-bit inputattach utility in a 64-bit system, there will be
error code "inputattach: can't set device type". This is caused by the
serport device driver not supporting compat_ioctl, so that SPIOCSTYPE ioctl
fails.
Signed-off-by: John Sung <penmount.touch@gmail.com>
commit 5715fc764f7753d464dbe094b5ef9cffa6e479a4 upstream.
ForcePads are found on HP EliteBook 1040 laptops. They lack any kind of
physical buttons, instead they generate primary button click when user
presses somewhat hard on the surface of the touchpad. Unfortunately they
also report primary button click whenever there are 2 or more contacts
on the pad, messing up all multi-finger gestures (2-finger scrolling,
multi-finger tapping, etc). To cope with this behavior we introduce a
delay (currently 50 msecs) in reporting primary press in case more
contacts appear.
commit 271329b3c798b2102120f5df829071c211ef00ed upstream.
Adjust Elantech signature validation to account fo rnewer models of
touchpads.
Reported-and-tested-by: Màrius Monton <marius.monton@gmail.com>
commit d49cb7aeebb974713f9f7ab2991352d3050b095b upstream.
commit 421e08c41fda fixed the reported min/max for the X and Y axis,
but unfortunately, it broke the resolution of those same axis.
On the t540p, the resolution is the same regarding X and Y. It is not
a problem for xf86-input-synaptics because this driver is only interested
in the ratio between X and Y.
Unfortunately, xf86-input-cmt uses directly the resolution, and having a
null resolution leads to some divide by 0 errors, which are translated by
-infinity in the resulting coordinates.
Reported-by: Peter Hutterer <peter.hutterer@who-t.net>
[bwh: Backported to 3.2: I didn't apply the PNP ID changes, so the
code being moved looks different]
commit fb4f8f568a9def02240ef9bf7aabd246dc63a081 upstream.
The touchpad on the GIGABYTE U2442 not only stops communicating when we try
to set bit 3 (enable real hardware resolution) of reg_10, but on some BIOS
versions also when we set bit 1 (enable two finger mode auto correct).
I've asked the original reporter of:
https://bugzilla.kernel.org/show_bug.cgi?id=61151
To check that not setting bit 1 does not lead to any adverse effects on his
model / BIOS revision, and it does not, so this commit fixes the touchpad
not working on these versions by simply never setting bit 1 for laptop
models with the no_hw_res quirk.
Reported-and-tested-by: James Lademann <jwlademann@gmail.com>
Tested-by: Philipp Wolfer <ph.wolfer@gmail.com>
commit cd9e83e2754465856097f31c7ab933ce74c473f8 upstream.
At least the Dell Vostro 5470 elantech *clickpad* reports right button
clicks when clicked in the right bottom area:
https://bugzilla.redhat.com/show_bug.cgi?id=1103528
This is different from how (elantech) clickpads normally operate, normally
no matter where the user clicks on the pad the pad always reports a left
button event, since there is only 1 hardware button beneath the path.
It looks like Dell has put 2 buttons under the pad, one under each bottom
corner, causing this.
Since this however still clearly is a real clickpad hardware-wise, we still
want to report it as such to userspace, so that things like finger movement
in the bottom area can be properly ignored as it should be on clickpads.
So deal with this weirdness by simply mapping a right click to a left click
on elantech clickpads. As an added advantage this is something which we can
simply do on all elantech clickpads, so no need to add special quirks for
this weird model.
Reported-and-tested-by: Elder Marco <eldermarco@gmail.com>
commit 6d396ede224dc596d92d7cab433713536e68916c upstream.
The T540p has a touchpad with pnp-id LEN0034, all the models with this
pnp-id have the same min/max values, except the T540p where the values are
slightly off. Fix them to be identical.
This is a preparation patch for simplifying the quirk table.
commit 0b5fe736fe923f1f5e05413878d5990e92ffbdf5 upstream.
https://bugzilla.redhat.com/show_bug.cgi?id=1096436
Tested-and-reported-by: ajayr@bigfoot.com
commit 36189cc3cd57ab0f1cd75241f93fe01de928ac06 upstream.
The hw_version 3 Elantech touchpad on the Gigabyte U2442 does not accept
0x0b as initialization value for r10, this stand-alone version of the
driver: http://planet76.com/drivers/elantech/psmouse-elantech-v6.tar.bz2
Uses 0x03 which does work, so this means not setting bit 3 of r10 which
sets: "Enable Real H/W Resolution In Absolute mode"
Which will result in half the x and y resolution we get with that bit set,
so simply not setting it everywhere is not a solution. We've been unable to
find a way to identify touchpads where setting the bit will fail, so this
patch uses a dmi based blacklist for this.
Reported-by: Philipp Wolfer <ph.wolfer@gmail.com>
commit 27a38856a948c3e8de30dc71647ff9e1778c99fc upstream.
and X1
commit 46a2986ebbe18757c2d8c352f8fb6e0f4f0754e3 upstream.
We expect that all the Haswell series will need such quirks, sigh.
The T431s seems to be T430 hardware in a T440s case, using the T440s touchpad,
with the same min/max issue.
The X1 Carbon 3rd generation name says 2nd while it is a 3rd generation.
The X1 and T431s share a PnPID with the T540p, but the reported ranges are
closer to those of the T440s.
HdG: Squashed 5 quirk patches into one. T431s + L440 + L540 are written by me,
S1 Yoga and X1 are written by Benjamin Tissoires.
Hdg: Standardized S1 Yoga and X1 values, Yoga uses the same touchpad as the
X240, X1 uses the same touchpad as the T440.
commit 8a0435d958fb36d93b8df610124a0e91e5675c82 upstream.
This extends Benjamin Tissoires manual min/max quirk table with support for
the ThinkPad X240.
commit 421e08c41fda1f0c2ff6af81a67b491389b653a5 upstream.
The new Lenovo Haswell series (-40's) contains a new Synaptics touchpad.
However, these new Synaptics devices report bad axis ranges.
Under Windows, it is not a problem because the Windows driver uses RMI4
over SMBus to talk to the device. Under Linux, we are using the PS/2
fallback interface and it occurs the reported ranges are wrong.
Of course, it would be too easy to have only one range for the whole
series, each touchpad seems to be calibrated in a different way.
We can not use SMBus to get the actual range because I suspect the firmware
will switch into the SMBus mode and stop talking through PS/2 (this is the
case for hybrid HID over I2C / PS/2 Synaptics touchpads).
So as a temporary solution (until RMI4 land into upstream), start a new
list of quirks with the min/max manually set.
commit a455e2985f57e2a71566bb8850094af38b2c932d upstream.
The driver's timer must be set up before enabling IRQ handler, otherwise
bad things may happen.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Peter Popovec <popovec@fei.tuke.sk>
commit ad68652412276f68ad4fe3e1ecf5ee6880876783 upstream.
Some MSI laptop BIOSes are broken - INT 15h code uses port 92h to enable A20
line but resume code assumes that KBC was used.
The laptop will not resume from S3 otherwise but powers off after a while
and then powers on again stuck with a blank screen.
Fix it by enabling A20 using KBC in i8042_platform_init for x86.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=12878
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Link: http://lkml.kernel.org/r/201212112218.06551.linux@rainbow-software.org
commit 52965cc012f7a3cf35f06485ec275ebf3b3fddae upstream.
Some bcm5974 trackpads have a physical button beneath the physical surface.
This patch sets the property bit so user space applications can detect the
trackpad type and act accordingly.
Signed-off-by: Jussi Pakkanen <jussi.pakkanen@canonical.com>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
commit 1729ad1f4f9e167ade84ca8b5269695c42351160 upstream.
In addition to some laptops needing i8042 reset after resuming from S2R to
get their touchpads working there is another class of laptops - ones that
need i8042 reset before going to S2R, otherwise they will simply reboot
instead of resuming.
See https://bugzilla.kernel.org/show_bug.cgi?id=15612
This change forces reset of i8042 before doing S2R.
Reported-by: Stefan Koch <stefan_koch@gmx.net>
Tested-by: Alexander van Loon <a.vanloon@alexandervanloon.nl>
commit 32ed1911fc79908d704023317d4ddeb3883fd07e upstream.
The tsc40 driver announces it supports the pressure event, but will never
send one. The announcement will cause tslib to wait for such events and
sending all touch events with a pressure of 0. Removing the announcement
will make tslib fall back to emulating the pressure on touch events so
everything works as expected.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
commit 824efd37415961d38821ecbd9694e213fb2e8b32 upstream.
Commit c039450 (Input: synaptics - handle out of bounds values from the
hardware) caused any hardware reported values over 7167 to be treated as
a wrapped-around negative value. It turns out that some firmware uses
the value 8176 to indicate a finger near the edge of the touchpad whose
actual position cannot be determined. This value now gets treated as
negative, which can cause pointer jumps and broken edge scrolling on
these machines.
I only know of one touchpad which reports negative values, and this
hardware never reports any value lower than -8 (i.e. 8184). Moving the
threshold for treating a value as negative up to 8176 should work fine
then for any hardware we currently know about, and since we're dealing
with unspecified behavior it's probably the best we can do. The special
8176 value is also likely to result in sudden jumps in position, so
let's also clamp this to the maximum specified value for the axis.
BugLink: http://bugs.launchpad.net/bugs/1046512
https://bugzilla.kernel.org/show_bug.cgi?id=46371
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Reviewed-by: Daniel Kurtz <djkurtz@chromium.org>
Tested-by: Alan Swanson <swanson@ukfsn.org>
Tested-by: Arteom <arutemus@gmail.com>
commit 8669cf6793bb38307a30fb6b9565ddc8840ebd3f upstream.
On Toshiba Satellite C850D, the touchpad and the keyboard might randomly
not work at boot. Preventing MUX mode activation solves this issue.
Signed-off-by: Anisse Astier <anisse@astier.eu>
commit 7b125b94ca16b7e618c6241cb02c4c8060cea5e3 upstream.
They all define their chassis type as "Other" and therefore are not
categorized as "laptops" by the driver, which tries to perform AUX IRQ
delivery test which fails and causes touchpad not working.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42620
commit 4eef6cbfcc03b294d9d334368a851b35b496ce53 upstream.
The EETI touchscreen asserts its IRQ line as soon as it has data in its
internal buffers. The line is automatically deasserted once all data has
been read via I2C. Hence, the driver has to monitor the GPIO line and
cannot simply rely on the interrupt handler reception.
In the current implementation of the driver, irq_to_gpio() is used to
determine the GPIO number from the i2c_client's IRQ value.
As irq_to_gpio() is not available on all platforms, this patch changes
this and makes the driver ignore the passed in IRQ. Instead, a GPIO is
added to the platform_data struct and gpio_to_irq is used to derive the
IRQ from that GPIO. If this fails, bail out. The driver is only able to
work in environments where the touchscreen GPIO can be mapped to an
IRQ.
Without this patch, building raumfeld_defconfig results in:
drivers/input/touchscreen/eeti_ts.c: In function 'eeti_ts_irq_active':
drivers/input/touchscreen/eeti_ts.c:65:2: error: implicit declaration of function 'irq_to_gpio' [-Werror=implicit-function-declaration]
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: Sven Neumann <s.neumann@raumfeld.com>
Cc: linux-input@vger.kernel.org
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
[bwh: Backported to 3.2: raumfeld_controller_i2c_board_info.irq was
initialised using gpio_to_irq(), but this doesn't seem to matter]
commit c0394506e69b37c47d391c2a7bbea3ea236d8ec8 upstream.
The touchpad on the Acer Aspire One D250 will report out of range values
in the extreme lower portion of the touchpad. These appear as abrupt
changes in the values reported by the hardware from very low values to
very high values, which can cause unexpected vertical jumps in the
position of the mouse pointer.
What seems to be happening is that the value is wrapping to a two's
compliment negative value of higher resolution than the 13-bit value
reported by the hardware, with the high-order bits being truncated. This
patch adds handling for these values by converting them to the
appropriate negative values.
The only tricky part about this is deciding when to treat a number as
negative. It stands to reason that if out of range values can be
reported on the low end then it could also happen on the high end, so
not all out of range values should be treated as negative. The approach
taken here is to split the difference between the maximum legitimate
value for the axis and the maximum possible value that the hardware can
report, treating values greater than this number as negative and all
other values as positive. This can be tweaked later if hardware is found
that operates outside of these parameters.
BugLink: http://bugs.launchpad.net/bugs/1001251
commit e76b8ee25e034ab601b525abb95cea14aa167ed3 upstream.
I couldn't find the vendor ID in any of the online databases, but this
mat has a Pump It Up logo on the top side of the controller compartment,
and a disclaimer stating that Andamiro will not be liable on the bottom.
Signed-off-by: Yuri Khan <yurivkhan@gmail.com>
commit cc71a7e899cc6b2ff41e1be48756782ed004d802 upstream.
Signed-off-by: Ilia Katsnelson <k0009000@gmail.com>
commit 3ffb62cb9ac2430c2504c6ff9727d0f2476ef0bd upstream.
The device should be handled by xpad driver instead of generic HID driver.
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 3dde22a98e94eb18527f0ff0068fb2fb945e58d4 upstream.
Add support for the 15'' MacBook Pro Retina model (MacBookPro10,1).
Patch originally written by clipcarl (forums.opensuse.org).
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
