path: root/drivers/input
2010-05-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: ad7877 - keep dma rx buffers in seperate cache lines Input: psmouse - reset all types of mice before reconnecting Input: elantech - use all 3 bytes when checking version Input: iforce - fix Guillemot Jet Leader 3D entry Input: iforce - add Guillemot Jet Leader Force Feedback
2010-05-13Input: ad7877 - keep dma rx buffers in seperate cache linesOskar Schirmer
With dma based spi transmission, data corruption is observed occasionally. With dma buffers located right next to msg and xfer fields, cache lines correctly flushed in preparation for dma usage may be polluted again when writing to fields in the same cache line. Make sure cache fields used with dma do not share cache lines with fields changed during dma handling. As both fields are part of a struct that is allocated via kzalloc, thus cache aligned, moving the fields to the 1st position and insert padding for alignment does the job. Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Daniel Glöckner <dg@emlix.com> Signed-off-by: Oliver Schneidewind <osw@emlix.com> Signed-off-by: Johannes Weiner <jw@emlix.com> Acked-by: Mike Frysinger <vapier@gentoo.org> [dtor@mail.ru - changed to use ___cacheline_aligned as suggested by akpm] Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-13Input: psmouse - reset all types of mice before reconnectingDmitry Torokhov
Synaptics hardware requires resetting device after suspend to ram in order for the device to be operational. The reset lives in synaptics-specific reconnect handler, but it is not being invoked if synaptics support is disabled and the device is handled as a standard PS/2 device (bare or IntelliMouse protocol). Let's add reset into generic reconnect handler as well. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-13Input: elantech - use all 3 bytes when checking versionDmitry Torokhov
Apparently all 3 bytes returned by ETP_FW_VERSION_QUERY are significant and should be taken into account when matching hardware version/features. Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-10Input: iforce - fix Guillemot Jet Leader 3D entryMarek Vasut
USB ID entry for "Guillemot Jet Leader 3D" in iforce-main.c did not match one used in iforce-usb.c Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-10Input: iforce - add Guillemot Jet Leader Force FeedbackMarek Vasut
This device features a RUDDER on the knob. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: joydev - allow binding to button-only devices Input: elantech - ignore high bits in the position coordinates Input: elantech - allow forcing Elantech protocol Input: elantech - fix firmware version check Input: ati_remote - add some missing devices from lirc_atiusb Input: eeti_ts - cancel pending work when going to suspend Input: Add support of Synaptics Clickpad device Revert "Input: ALPS - add signature for HP Pavilion dm3 laptops" Input: psmouse - ignore parity error for basic protocols
2010-05-03Input: joydev - allow binding to button-only devicesChristoph Fritz
Dance pads don't have an axis, so allow this kind of controllers to be used via legacy joystick interface. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-03Input: elantech - ignore high bits in the position coordinatesFlorian Ragwitz
In older versions of the elantech hardware/firmware those bits always were unset, so it didn't actually matter, but newer versions seem to use those high bits for something else, screwing up the coordinates we report to the input layer for those devices. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-03Input: elantech - allow forcing Elantech protocolFlorian Ragwitz
Apparently hardware vendors now ship elantech touchpads with different version magic. This options allows for them to be tested easier with the current driver in order to add their magic to the whitelist later. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-03Input: elantech - fix firmware version checkFlorian Ragwitz
The check determining whether device should use 4- or 6-byte packets was trying to compare firmware with 2.48, but was failing on majors greater than 2. The new check ensures that versions like 4.1 are checked properly. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-05-03Input: ati_remote - add some missing devices from lirc_atiusbJarod Wilson
The (out-of-tree) lirc_atiusb driver has a much longer list of devices it supports. Some of them look like they may just be guesses at possible device IDs, but a few are definitely confirmed devices. This adds the nVidia-branded RF receiver and the X10 Lola Wireless Video Sender device (which contains an RF receiver) to the list of devices in ati_remote. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-20Input: eeti_ts - cancel pending work when going to suspendDaniel Mack
This fixes a race between the suspend code and input events. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-20Input: Add support of Synaptics Clickpad deviceTakashi Iwai
The new type of touchpads can be detected via a new query command 0x0c. The clickpad flags are in cap[0]:4 and cap[1]:0 bits. When the device is detected, the driver now reports only the left button as the supported buttons so that X11 driver can detect that the device is Clickpad. A Clickpad device gives the button events only as the middle button. The kernel driver morphs to the left button. The real handling of Clickpad is done rather in X driver side. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-20Revert "Input: ALPS - add signature for HP Pavilion dm3 laptops"Dmitry Torokhov
This reverts commit 5e28d8eb68c12eab9c4a47b42ba993a6420d71d3 since the magic knock does not work for this model of the touchpad and the device stays in PS/2 compatibility mode.
2010-04-19Input: psmouse - ignore parity error for basic protocolsDmitry Torokhov
Observing behavior of the other OS it appears that parity errors reported by the keyboard controller are being ignored and the data is processed as usual. Let's do the same for standard PS/2 protocols (bare, Intellimouse and Intellimouse Explorer) to provide better compatibility. Thsi should fix teh following bug: https://bugzilla.kernel.org/show_bug.cgi?id=6105 Thanks for Damjan Jovanovic for locating the source of issue and ideas for the patch. Tested-by: Damjan Jovanovic <damjan.jov@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - switch mode upon system resume Revert "Input: wacom - merge out and in prox events" Input: matrix_keypad - allow platform to disable key autorepeat Input: ALPS - add signature for HP Pavilion dm3 laptops Input: i8042 - spelling fix Input: sparse-keymap - implement safer freeing of the keymap Input: update the status of the Multitouch X driver project Input: clarify the no-finger event in multitouch protocol Input: bcm5974 - retract efi-broken suspend_resume Input: sparse-keymap - free the right keymap on error
2010-04-15Input: wacom - switch mode upon system resumePing Cheng
When Wacom devices wake up from a sleep, the switch mode command (wacom_query_tablet_data) is needed before wacom_open is called. wacom_query_tablet_data should not be executed inside wacom_open since wacom_open is called more than once during probe. wacom_retrieve_hid_descriptor is removed from wacom_resume due to the fact that the required descriptors are stored properly upon system resume. Reported-and-tested-by: Anton Anikin <Anton@Anikin.name> Signed-off-by: Ping Cheng <pingc@wacom.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-13Revert "Input: wacom - merge out and in prox events"Dmitry Torokhov
This reverts commit 776943fd6f104a6e8457dc95a17282e69e963666 as it causes issues with ISDv4 E3 touchscreens: https://bugzilla.kernel.org/show_bug.cgi?id=15670 Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-05Input: matrix_keypad - allow platform to disable key autorepeatH Hartley Sweeten
In an embedded system the matrix_keypad driver might be used to interface with an external control panel and not an actual keyboard. On the control panel some of the keys could be used to turn on/off various functions. If key autorepeat is enabled this causes the function to quickly toggle between the on and off states and makes operation difficult. Add an option in the platform-specific data to disable the key autorepeat. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-05Input: ALPS - add signature for HP Pavilion dm3 laptopsChase Douglas
Tested by a user running Ubuntu 9.10 in the following bug report. BugLink: http://bugs.launchpad.net/bugs/545307 Signed-off-by: Chase Douglas <chase.douglas@canonical.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-04-05Input: i8042 - spelling fixDominik Brodowski
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-21Input: sparse-keymap - implement safer freeing of the keymapDmitry Torokhov
Allow calling sparse_keymap_free() before unregistering input device whithout risk of racing with EVIOCGETKEYCODE and EVIOCSETKEYCODE. This makes life of drivers writers easier. Acked-by: Yong Wang <yong.y.wang@intel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-20Input: bcm5974 - retract efi-broken suspend_resumeHenrik Rydberg
With the recent system-wide improvements on suspend/resume and EFI booting the suspend_resume method of the bcm5974 has broken. When waking up from the S3 state on the MacBookAir, the trackpad is found in a yet unknown state, unable to switch to the proper multitouch mode. The result is a frozen touchpad, and a flood of errors of the kind bcm5974: bad trackpad package, length: 8. This patch retracts the reset_resume method altogether, falling back on the generic unbind/rebind functionality of the usb layer until further investigations can be made as how to reset the device when booting from efi. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-19Input: sparse-keymap - free the right keymap on errorYong Wang
'map' is allocated in sparse_keymap_setup() and it it the one that should be freed on error instead of 'keymap'. Signed-off-by: Yong Wang <yong.y.wang@intel.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset table Input: ALPS - fix stuck buttons on some touchpads Input: wm831x-on - convert to use genirq Input: ads7846 - add wakeup support Input: appletouch - fix integer overflow issue Input: ad7877 - increase pen up imeout Input: ads7846 - add support for AD7843 parts Input: bf54x-keys - fix system hang when pressing a key Input: alps - add support for the touchpad on Toshiba Tecra A11-11L Input: remove BKL, fix input_open_file() locking Input: serio_raw - remove BKL Input: mousedev - remove BKL Input: add driver for TWL4030 vibrator device Input: enable remote wakeup for PNP i8042 keyboard ports Input: scancode in get/set_keycodes should be unsigned Input: i8042 - use platfrom_create_bundle() helper Input: wacom - merge out and in prox events Input: gamecon - fix off by one range check Input: wacom - replace WACOM_PKGLEN_PENABLED
2010-03-13Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset tableChristoph Fritz
ALDI/MEDION netbook E1222 needs to be in the reset quirk list for its touchpad's proper function. Reported-by: Michael Fischer <mifi@gmx.de> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-13Input: ALPS - fix stuck buttons on some touchpadsMartin Buck
Enable button release event redirection to the device that got the button press not only for touchpads with interleaved protocols, but unconditionally for all Alps touchpads. This is required at least for the touchpads in Dell Inspiron 8200 and Latitude d630. Signed-off-by: Martin Buck <mb-tmp-yvahk-vachg@gromit.dyndns.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-11Input: wm831x-on - convert to use genirqMark Brown
Now that the WM831x core has been converted to use genirq for the interrupt controller there is no need for the client drivers to use a WM831x-specific API rather than just calling genirq directly. Also fixes a leak of the IRQ during init failure - the error path free_irq() was using NULL rather than the driver data as the data pointer so free_irq() wouldn't have matched. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-11Input: ads7846 - add wakeup supportRanjith Lohithakshan
Add wakeup support to the ads7846 driver. Platforms can enable wakeup capability by setting the wakeup flag in ads7846_platform_data. With this patch the ads7846 driver can be used to wake the system from suspend. Signed-off-by: Ranjith Lohithakshan <ranjithl@ti.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-11Input: appletouch - fix integer overflow issueVadim Zaliva
When reading data from Geyser 2 touchpads used on post Oct 2005 Apple PowerBooks the driver was casting X and Y coordinates values to 'signed char'. Testing on one of such PowerBooks I have noticed that touchpad always generates positive values, but some of them are greater that 127, and thus, when cast to 'signed char' being interpreted as a negative. Such bigger values have been observed infrequently, closer to the edges of a touchpad, so the problem was not very visible. Nevertheless, the patch would potentially improve touchpad driver accuracy. Signed-off-by: Vadim Zaliva <lord@crocodile.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: ad7877 - increase pen up imeoutMichael Hennerich
The time interval between consecutive interrupts depends on a number of tunables: first_conversion_delay, acquisition_time, averaging and foremost the pen_down_acc_interval. Since the mod_timer() action for the PEN UP event happens in the spi_async() callback function, latencies incurred by the spi bus drivers also need to be taken into account. So all in all, give the PEN UP event a bit more wiggle room and increase timeout to 100ms. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: ads7846 - add support for AD7843 partsMichael Hennerich
The AD7873 is almost identical to the ADS7846; the only difference is related to the Power Management bits PD0 and PD1. This results in a slightly different PENIRQ enable behavior. For the AD7873, VREF should be turned off during differential measurements. So, add the AD7873/43 to the list of driver supported devices, and prevent VREF usage during differential/ratiometric conversion modes. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: bf54x-keys - fix system hang when pressing a keyMike Frysinger
We need to use the nosync version of disable_irq so that we don't hang in the IRQ handler as we don't ACK the interrupt until later. This used to work regardless, but at some point, the IRQ behavior changed. Not sure when exactly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: alps - add support for the touchpad on Toshiba Tecra A11-11LThomas Bächler
Signed-off-by: Thomas Bächler <thomas@archlinux.org> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: remove BKL, fix input_open_file() lockingArnd Bergmann
Holding the BKL in input_open_file seems pointless because it does not protect against updates of input_table, and all open functions from the underlying drivers have proper mutex locking. This makes input_open_file take the input_mutex when accessing the table and no lock when calling into the lower function. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: serio_raw - remove BKLThadeu Lima de Souza Cascardo
serio_raw open function already uses a mutex. Also change formatting a bit. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: mousedev - remove BKLThadeu Lima de Souza Cascardo
There's no need for BKL in mousedev, relevan protection is provided by a private mutex. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: add driver for TWL4030 vibrator deviceJari Vanhala
TWL4030 Vibrator implemented via Force Feedback interface. This uses MFD TWL4030 codec and own dynamic workqueue. Signed-off-by: Jari Vanhala <ext-jari.vanhala@nokia.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-09Input: enable remote wakeup for PNP i8042 keyboard portsAlan Stern
This patch (as1355) enables remote wakeup by default on PNP i8042 keyboard ports. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-08Input: scancode in get/set_keycodes should be unsignedDmitry Torokhov
The HID layer has some scan codes of the form 0xffbc0000 for logitech devices which do not work if scancode is typed as signed int, so we need to switch to unsigned it instead. While at it keycode being signed does not make much sense either. Acked-by: Márton Németh <nm127@freemail.hu> Acked-by: Matthew Garrett <mjg@redhat.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-08Input: i8042 - use platfrom_create_bundle() helperDmitry Torokhov
2010-03-08Merge commit 'v2.6.34-rc1' into for-linusDmitry Torokhov
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-07input: Support onkey in 88pm860xHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07mfd: Use genirq in 88pm860xHaojian Zhuang
Use genirq to simplify IRQ handling in 88pm860x. Remove the interface of mask/free IRQs on 88pm860x. All these work is taken by genirq. Update the touchscreen driver of 88pm860x since IRQ handling is changed. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-03-07input: Enable touch on 88pm860xHaojian Zhuang
Enable touchscreen driver for the 88pm860x multi function core. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
