path: root/drivers/input
2011-05-09Input: elantech - discard the first 2 positions on some firmwaresÉric Piel
commit 7f29f17b57255b6395046805a98bc663ded63fb8 upstream. According to the Dell/Ubuntu driver, what was previously observed as "jumpy cursor" corresponds to the hardware sending incorrect data for the first two reports of a one touch finger. So let's use the same workaround as in the other driver. Also, detect another firmware version with the same behaviour, as in the other driver. Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> [bwh: Adjust for 2.6.32] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - relax signature checksDmitry Torokhov
commit a083632eaf6231162b33e40561cfec6a9c156945 upstream. Apparently there are Elantech touchpads that report non-zero in the 2nd byte of their signature. Adjust the detection routine so that if 2nd byte is zero and 3rd byte contains value that is not a valid report rate, we still assume that signature is valid. Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> [bwh: Adjust context for 2.6.32] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - use all 3 bytes when checking versionDmitry Torokhov
commit 504e8beed161bd11a2c6cbb8aaf352c14d39b5bb upstream. Apparently all 3 bytes returned by ETP_FW_VERSION_QUERY are significant and should be taken into account when matching hardware version/features. Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - ignore high bits in the position coordinatesFlorian Ragwitz
commit e938fbfd4a7ac829d48b767c4dc365535d5c4f97 upstream. In older versions of the elantech hardware/firmware those bits always were unset, so it didn't actually matter, but newer versions seem to use those high bits for something else, screwing up the coordinates we report to the input layer for those devices. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - allow forcing Elantech protocolFlorian Ragwitz
commit f81bc788ff91d4efd4baf88b2c29713838caa8e5 upstream. Apparently hardware vendors now ship elantech touchpads with different version magic. This options allows for them to be tested easier with the current driver in order to add their magic to the whitelist later. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - fix firmware version checkFlorian Ragwitz
commit 225c61aad38b12924b3df5f4ef43150c0d6bae8c upstream. The check determining whether device should use 4- or 6-byte packets was trying to compare firmware with 2.48, but was failing on majors greater than 2. The new check ensures that versions like 4.1 are checked properly. Signed-off-by: Florian Ragwitz <rafl@debian.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: elantech - do not advertise relative eventsDmitry Torokhov
commit c7a1f3ccfc2f99427f2e1545b3171e98539c3c95 upstream. Elantech touchpads work in absolute mode and do not generate relative events so they should not be advertising them. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: Add support of Synaptics Clickpad deviceTakashi Iwai
commit 5f57d67da87332a9a1ba8fa7a33bf0680e1c76e7 upstream. The new type of touchpads can be detected via a new query command 0x0c. The clickpad flags are in cap[0]:4 and cap[1]:0 bits. When the device is detected, the driver now reports only the left button as the supported buttons so that X11 driver can detect that the device is Clickpad. A Clickpad device gives the button events only as the middle button. The kernel driver morphs to the left button. The real handling of Clickpad is done rather in X driver side. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-09Input: xen-kbdfront - fix mouse getting stuck after save/restoreIgor Mammedov
commit c36b58e8a9112017c2bcc322cc98e71241814303 upstream. Mouse gets "stuck" after restore of PV guest but buttons are in working condition. If driver has been configured for ABS coordinates at start it will get XENKBD_TYPE_POS events and then suddenly after restore it'll start getting XENKBD_TYPE_MOTION events, that will be dropped later and they won't get into user-space. Regression was introduced by hunk 5 and 6 of 5ea5254aa0ad269cfbd2875c973ef25ab5b5e9db ("Input: xen-kbdfront - advertise either absolute or relative coordinates"). Driver on restore should ask xen for request-abs-pointer again if it is available. So restore parts that did it before 5ea5254. Acked-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Igor Mammedov <imammedo@redhat.com> [v1: Expanded the commit description] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-03-27Input: xen-kbdfront - advertise either absolute or relative coordinatesOlaf Hering
commit 8c3c283e6bf463ab498d6e7823aff6c4762314b6 upstream. A virtualized display device is usually viewed with the vncviewer application, either by 'xm vnc domU' or with vncviewer localhost:port. vncviewer and the RFB protocol provides absolute coordinates to the virtual display. These coordinates are either passed through to a PV guest or converted to relative coordinates for a HVM guest. A PV guest receives these coordinates and passes them to the kernels evdev driver. There it can be picked up by applications such as the xorg-input drivers. Using absolute coordinates avoids issues such as guest mouse pointer not tracking host mouse pointer due to wrong mouse acceleration settings in the guests X display. Advertise either absolute or relative coordinates to the input system and the evdev driver, depending on what dom0 provides. The xorg-input driver prefers relative coordinates even if a devices provides both. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17input: bcm5974: Add support for MacBookAir3Edgar (gimli) Hucek
commit 6021afcf19d8c6f5db6d11cadcfb6a22d0c28a48 upstream. This patch adds support for the MacBookAir3,1 and MacBookAir3,2 models. [rydberg@euromail.se: touchpad range calibration] Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17Input: i8042 - introduce 'notimeout' blacklist for Dell Vostro V13Jiri Kosina
commit f8313ef1f448006207f12c107123522c8bc00f15 upstream. i8042 controller present in Dell Vostro V13 errorneously signals spurious timeouts. Introduce i8042.notimeout parameter for ignoring i8042-signalled timeouts and apply this quirk automatically for Dell Vostro V13, based on DMI match. In addition to that, this machine also needs to be added to nomux blacklist. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Tim Gardner <tcanonical@tpi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-09Input: i8042 - add Sony VAIO VPCZ122GX to nomux listDmitry Torokhov
[Note that the mainline will not have this particular fix but rather will blacklist entire VAIO line based off DMI board name. For stable I am being a bit more cautious and blacklist one particular product.] Trying to query/activate active multiplexing mode on this VAIO makes both keyboard and touchpad inoperable. Futher kernels will blacklist entire VAIO line, however here we blacklist just one particular model. Reported-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28Input: joydev - fix JSIOCSAXMAP ioctlKenneth Waters
commit d2520a426dc3033c00077e923a553fc6c98c7564 upstream. Fixed JSIOCSAXMAP ioctl to update absmap, the map from hardware axis to event axis in addition to abspam. This fixes a regression introduced by 999b874f. Signed-off-by: Kenneth Waters <kwwaters@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-26Input: add compat support for sysfs and /proc capabilities outputDmitry Torokhov
commit 15e184afa83a45cf8bafdb9dc906b97a8fbc974f upstream. Input core displays capabilities bitmasks in form of one or more longs printed in hex form and separated by spaces. Unfortunately it does not work well for 32-bit applications running on 64-bit kernels since applications expect that number is "worth" only 32 bits when kernel advances by 64 bits. Fix that by ensuring that output produced for compat tasks uses 32-bit units. Reported-and-tested-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-20Input: i8042 - fix device removal on unloadDmitry Torokhov
commit af045b86662f17bf130239a65995c61a34f00a6b upstream. We need to call platform_device_unregister(i8042_platform_device) before calling platform_driver_unregister() because i8042_remove() resets i8042_platform_device to NULL. This leaves the platform device instance behind and prevents driver reload. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=16613 Reported-by: Seryodkin Victor <vvscore@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02Input: twl40300-keypad - fix handling of "all ground" rowsDmitry Torokhov
commit 3fea60261e73dbf4a51130d40cafcc8465b0f2c3 upstream. The Nokia RX51 board code (arch/arm/mach-omap2/board-rx51-peripherals.c) defines a key map for the matrix keypad keyboard. The hardware seems to use all of the 8 rows and 8 columns of the keypad, although not all possible locations are used. The TWL4030 supports keypads with at most 8 rows and 8 columns. Most keys are defined with a row and column number between 0 and 7, except KEY(0xff, 2, KEY_F9), KEY(0xff, 4, KEY_F10), KEY(0xff, 5, KEY_F11), which represent keycodes that should be emitted when entire row is connected to the ground. since the driver handles this case as if we had an extra column in the key matrix. Unfortunately we do not allocate enough space and end up owerwriting some random memory. Reported-and-tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02Input: i8042 - add Gigabyte Spring Peak to dmi_noloop_tableKamal Mostafa
commit 3e1bbc8d5018a05c0793c8a32b777a1396eb4414 upstream. Gigabyte "Spring Peak" notebook indicates wrong chassis-type, tripping up i8042 and breaking the touchpad. Add this model to i8042_dmi_noloop_table[] to resolve. BugLink: https://bugs.launchpad.net/bugs/580664 Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05Input: psmouse - reset all types of mice before reconnectingDmitry Torokhov
commit ef110b24e28f36620f63dab94708a17c7e267358 upstream. Synaptics hardware requires resetting device after suspend to ram in order for the device to be operational. The reset lives in synaptics-specific reconnect handler, but it is not being invoked if synaptics support is disabled and the device is handled as a standard PS/2 device (bare or IntelliMouse protocol). Let's add reset into generic reconnect handler as well. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Cc: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26Input: wacom - switch mode upon system resumePing Cheng
commit 014f61504af276ba9d9544d8a7401d8f8526eb73 upstream. When Wacom devices wake up from a sleep, the switch mode command (wacom_query_tablet_data) is needed before wacom_open is called. wacom_query_tablet_data should not be executed inside wacom_open since wacom_open is called more than once during probe. Reported-and-tested-by: Anton Anikin <Anton@Anikin.name> Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01Input: wacom - ensure the device is initialized properly upon resumePing Cheng
commit 232f5693e5c9483e222528ef81979e42ea2f2908 upstream. Call wacom_query_tablet_data() from wacom_resume() so the device will be switched to Wacom mode upon resume. Devices that require this are: regular tablets and two finger touch devices. Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01Input: i8042 - add ALDI/MEDION netbook E1222 to qurik reset tableChristoph Fritz
commit 31968ecf584330b51a25b7bf881c2b632a02a3fb upstream. ALDI/MEDION netbook E1222 needs to be in the reset quirk list for its touchpad's proper function. Reported-by: Michael Fischer <mifi@gmx.de> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01Input: alps - add support for the touchpad on Toshiba Tecra A11-11LThomas Bächler
commit eb8bff85c5bd5caef7c374ff32b86545029efb56 upstream. Signed-off-by: Thomas Bächler <thomas@archlinux.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-09Input: winbond-cir - remove dmesg spamDavid Härdeman
commit 93fb84b50fe03aabca8d9dea5d3ba521a07e8571 upstream. I missed converting one dev_info call to deb_dbg before submitting the driver. Without this change, a message will be printed to dmesg for each button press if a RC6 remote is used. Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28Input: i8042 - add Dritek quirk for Acer Aspire 5610.Elliott Sales de Andrade
commit e6edbdc52bc0755cbfe0721ca91d4fd87649bc13 upstream. Signed-off-by: Elliott Sales de Andrade <quantum.analyst@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28Input: i8042 - add Gigabyte M1022M to the noloop listDmitry Torokhov
commit a61cd03827eceefcec19eefc6e1173703fdc5e5d upstream. Gigabyte netbook model M1022M requires i8042.noloop, otherwise AUX port will not detected and the touchpad will not work. Unfortunately chassis type in DMI set to "Other" and thus generic laptop entry does not fire on it. Reported-by: Darryl Bond <dbond@nrggos.com.au> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28Input: i8042 - remove identification strings from DMI tablesDmitry Torokhov
commit f909b1df0a068f30e252d8dc3e9d45ca25bf266f upstream. The driver does not reference identification strings in DMI tables and since these strings are no longer required by DMI core we can safely remove them and save some memory. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-28Input: ALPS - add interleaved protocol support (Dell E6x00 series)Sebastian Kapfer
commit 1d9f26262aef6d63ff65eba0fd5f1583f342b69b upstream Properly handle version of the protocol where standard PS/2 packets from trackpoint are stuffed into middle (byte 3-6) of the standard ALPS packets when both the touchpad and trackpoint are used together. The patch is based on work done by Matthew Chapman and additional research done by David Kubicek and Erik Osterholm: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/296610 Many thanks to David Kubicek for his efforts in researching fine points of this new version of the protocol, especially interaction between pad and stick in these models. Cc: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Sebastian Kapfer <sebastian_kapfer@gmx.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-22Input: pmouse - move Sentelic probe down the listTai-hwa Liang
commit 4a18b3ab6ed537b055e3fcfca64ab870b4f9acf0 upstream. Sentelic probes confuse IBM trackpoints so they stop responding to TP_READ_ID command. See: http://bugzilla.kernel.org/show_bug.cgi?id=14970 Let's move FSP detection lower so it is probed after trackpoint and others, just before we strat probing for Intellimouse Explorer. Signed-off-by: Tai-hwa Liang <avatar@sentelic.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-02Input: i8042 - add Dell Vostro 1320, 1520 and 1720 to the reset listAnisse Astier
These laptops often leave i8042 in a wierd state resulting in non- operational touchpad and keyboard. Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-16Input: lifebook - fix settings for CF-72Abner Holsinger
Panasonic CF-72 uses 6-byte protocol and does not need to be tied to a particular port. Signed-off-by: Abner Holsinger <9zabner@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-16Input: psmouse - fix breakage introduced by b7802c5c1eaJiri Kosina
Commit b7802c5c1ea ("Input: psmouse - use boolean type") caused the synaptics_hardware variable to be completely useless, as it is constantly set to 'true' throughout the whole psmouse_extensions(). This was caused by the following hunk in the commit in question - int synaptics_hardware = 0; + bool synaptics_hardware = true; which is wrong and causes driver to issue extra reset when falling back to bare PS/2 protocol. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-12Input: psmouse - remove unneeded '\n' from psmouse.proto parameterTakashi Iwai
The get parameter function should return a string without a life-feed. Otherwise you'll see additional empty line in sysfs parameters file. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-12Input: atkbd - restore LED state at reconnectDmitry Torokhov
Even though input core tells us to restore LED state and repeat rate at resume keyboard may be reconnected either by request from userspace (via sysfs) or just by pulling it from the box and plugging it back in. In these cases we still need to restore state ourselves. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-12Input: force LED reset on resumeDmitry Torokhov
We should be sending EV_LED event down to drivers upon resume even in cases when in-kernel state of the LED is off since device could come up with some leds turned on. Reported-and-tested-by: Mikko Vinni <mmvinni@yahoo.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-10Input: fix locking in memoryless force-feedback devicesDmitry Torokhov
Now that input core acquires dev->event_lock spinlock and disables interrupts when propagating input events, using spin_lock_bh() in ff-memless driver is not allowed. Actually, the timer_lock itself is not needed anymore, we should simply use dev->event_lock as well. Also do a small cleanup in force-feedback core. Reported-by: kerneloops.org Reported-by: http://www.kerneloops.org/searchweek.php?search=ml_ff_set_gain Reported-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-02Input: gpio-keys - use IRQF_SHAREDDmitry Eremin-Solenikov
There is nothing that disallows gpio-keys to share it's IRQ line w/ other drivers. Make it use IRQF_SHARED in request_irq(). An example of other driver with which I'd like to share IRQ line for GPIO buttons is ledtrig-gpio. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-02Input: winbond-cir - select LEDS_TRIGGERSDavid Härdeman
drivers/input/misc/winbond-cir.c depends on LEDS_TRIGGERS so add an appropriate select to drivers/input/misc/Kconfig Signed-off-by: David Härdeman <david@hardeman.nu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-02Input: i8042 - try to get stable CTR value when initializingDmitry Torokhov
If user presses keys while i8042 is being initialized there is a chance that keyboard data will be mistaken for results of Read Control Register command causing futher troubles. Work around this issue by reading CTR several times and stop when we get matching results. Reported-and-tested-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-11-02Merge commit 'v2.6.32-rc5' into for-linusDmitry Torokhov
2009-10-21Input: atkbd - add a quirk for OQO 01+ multimedia keysJamie Lentin
OQO 01+ multimedia keys produce 6x on press, e0 6x upon release. As a result, Linux thinks that another key has been pressed (or is repeating), when it is actually a release of the same key. Mangle the release scancode when running on OQO so that driver recognizes it as such. Since the device does not have external PS/2 ports mangling is safe since there is no chance that an external keyboard is connected. Signed-off-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-18Input: hp_sdc_rtc - fix test in hp_sdc_rtc_read_rt()Roel Kluin
If left unsigned the hp_sdc_rtc_read_i8042timer() return value will not be checked correctly. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-18Input: atkbd - consolidate force release quirks for volume keysHerton Ronaldo Krzesinski
Some machines share same key list for volume up/down release key quirks, use only one key list. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-18Input: logips2pp - model 73 is actually TrackMan FXDmitry Torokhov
Reported-and-tested-by: Harald Dunkel <harald.dunkel@t-online.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-18Input: i8042 - add Sony Vaio VGN-FZ240E to the nomux listDmitry Torokhov
On this model, when KBD is in active multiplexing mode, acknowledgements to reset and get ID commands issued on KBD port sometimes are delivered to AUX3 port (touchpad) which messes up device detection. Legacy KBC mode works fine and since there are no external PS/2 ports on this laptop and no support for docking station we can safely disable active MUX mode. Tested-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-14Input: fix locking issue in /proc/bus/input/ handlersDmitry Torokhov
input_devices_seq_start() uses mutex_lock_interruptible() to acquire the input_mutex, but doesn't properly handle the situation when the call fails (for example due to interrupt). Instead of returning NULL (which indicates that there is no more data) we should return ERR_PTR()-encoded error. We also need explicit flag indicating whether input_mutex was acquired since input_devices_seq_stop() is called whether input_devices_seq_start() was successful or not. The same applies to input_handlers_seq_start(). Reported-by: iceberg <strakh@ispras.ru> Reviewed-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-14Input: atkbd - postpone restoring LED/repeat rate at resumeDmitry Torokhov
We need to postpone restoring LED state and typematic settings until keyboard is finished reconnecting upon resume. Normally driver core and PM infrastructure takes care of proper ordering and dependencies, but or case actual reconnect is done asynchronously from kseriod. So while driver core thinks that keyboard was resumed and it is time to let input core run it's resume handlers in reality keyboard is not ready yet. The solution is to keep rescheduling work that adjusts LED and rate settings until keyboard is fully enabled. Reported-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-13Input: atkbd - restore resetting LED state at startupDmitry Torokhov
Fix breakage caused by commit 9605fb48e1998935a5ee70c965f90ad1ac023add While the input core indeed takes care of restoring led state and typematic settings upon resume the driver still need to initialize them properly when registering a new device Reported-and-tested-by: Marin Mitov <mitov@issp.bas.bg> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-12Input: i8042 - make pnp_data_busted variable boolean instead of intDmitry Torokhov
This small snippet escaped last round of int -> bool conversion. Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-10-12Input: synaptics - add another Protege M300 to rate blacklistDmitry Torokhov
Apparently some of Toshiba Protege M300 identify themselves as "Portable PC" in DMI so we need to add that to the DMI table as well. We need DMI data so we can automatically lower Synaptics reporting rate from 80 to 40 pps to avoid over-taxing their keyboard controllers. Tested-by: Rod Davison <roddavison@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
