To protect the command buffer from hanging when a device
does not respond to an IOTLB invalidation, set a timeout of
1s for outstanding IOTLB invalidations.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Add infrastructure for errata-handling and handle two known
erratas in the IOMMUv2 code.
The AMD IOMMUv2 driver needs to get the IOMMUv2 domain
associated with a particular device. This patch adds a
function to get this information.
To send completions for PPR requests this patch adds a
function which can be used by the IOMMUv2 driver.
This patch adds functions necessary to set and clear the
GCR3 values associated with a particular PASID in an IOMMUv2
domain.
The functions added with this patch allow to manage the
IOMMU and the device TLBs for all devices in an IOMMUv2
domain.
This patch adds support for protection domains that
implement two-level paging for devices.
Add a notifer at which a module can attach to get informed
about incoming PPR faults.
If the device starts to use IOMMUv2 features the dma handles
need to stay valid. The only sane way to do this is to use a
identity mapping for the device and not translate it by the
iommu. This is implemented with this patch. Since this lifts
the device-isolation there is also a new kernel parameter
which allows to disable that feature.
In mixed IOMMU setups this flag inidicates whether an IOMMU
supports the v2 features or not. This patch also adds a
global flag together with a function to query that flag from
other code. The flag shows if at least one IOMMUv2 is in the
system.
This feature needs to be enabled before IOMMUv2 DTEs can be
set up.
Allocate and enable a log buffer for peripheral page faults
when the IOMMU supports this feature.
Read the number of PASIDs supported by each IOMMU in the
system and take the smallest number as the maximum value
supported by the IOMMU driver.
Convert the contents of 'struct dev_table_entry' to u64 to
allow updating the DTE wit 64bit writes as required by the
spec.
arch/x86/include/asm/amd_iommu_types.h
arch/x86/kernel/amd_iommu.c
A few parts of the driver were missing in drivers/iommu.
Move them there to have the complete driver in that
directory.
