Fix:
Section mismatch in reference from the function
ir_dev_scope_init() to the function
.init.text:dmar_dev_scope_init() The function
ir_dev_scope_init() references the function __init dmar_dev_scope_init().
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Youquan Song <youquan.song@intel.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Link: http://lkml.kernel.org/r/20111026161507.GB10103@swordfish
Both DMA-remapping aswell as Interrupt-remapping depend on the
dmar dev scope to be initialized. When both DMA and
IRQ-remapping are enabled, we depend on DMA-remapping init code
to call dmar_dev_scope_init(). This resulted in not doing this
init when DMA-remapping was turned off but interrupt-remapping
turned on in the kernel config.
This caused interrupt routing to break with CONFIG_INTR_REMAP=y
and CONFIG_DMAR=n.
This issue was introduced by this commit:
| commit 9d5ce73a64be2be8112147a3e0b551ad9cd1247b
| Author: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
| Date: Tue Nov 10 19:46:16 2009 +0900
| x86: intel-iommu: Convert detect_intel_iommu to use iommu_init hook
Fix this by calling dmar_dev_scope_init() explicitly from the
interrupt remapping code too.
Reported-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: youquan.song@intel.com
Cc: joerg.roedel@amd.com
Cc: tony.luck@intel.com
Cc: dwmw2@infradead.org
Link: http://lkml.kernel.org/r/20110824001456.229207526@sbsiddha-desk.sc.intel.com
On the platforms which are x2apic and interrupt-remapping
capable, Linux kernel is enabling x2apic even if the BIOS
doesn't. This is to take advantage of the features that x2apic
brings in.
Some of the OEM platforms are running into issues because of
this, as their bios is not x2apic aware. For example, this was
resulting in interrupt migration issues on one of the platforms.
Also if the BIOS SMI handling uses APIC interface to send SMI's,
then the BIOS need to be aware of x2apic mode that OS has
enabled.
On some of these platforms, BIOS doesn't have a HW mechanism to
turnoff the x2apic feature to prevent OS from enabling it.
To resolve this mess, recent changes to the VT-d2 specification:
http://download.intel.com/technology/computing/vptech/Intel(r)_VT_for_Direct_IO.pdf
includes a mechanism that provides BIOS a way to request system
software to opt out of enabling x2apic mode.
Look at the x2apic optout flag in the DMAR tables before
enabling the x2apic mode in the platform. Also print a warning
that we have disabled x2apic based on the BIOS request.
Kernel boot parameter "intremap=no_x2apic_optout" can be used to
override the BIOS x2apic optout request.
Signed-off-by: Youquan Song <youquan.song@intel.com>
Link: http://lkml.kernel.org/r/20110824001456.171766616@sbsiddha-desk.sc.intel.com
The irq_2_ir_lock can be taken in atomic context and therefore
cannot be preempted on -rt - annotate it.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
The iommu->register_lock can be taken in atomic context and therefore
must not be preempted on -rt - annotate it.
This should ease finding similarities with different platforms,
with the intention of solving problems once in a generic framework
which everyone can use.
Note: to move intel-iommu.c, the declaration of pci_find_upstream_pcie_bridge()
has to move from drivers/pci/pci.h to include/linux/pci.h. This is handled
in this patch, too.
As suggested, also drop DMAR's EXPERIMENTAL tag while we're at it.
Compile-tested on x86_64.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
