commit 797a8b4d768c58caac58ee3e8cb36a164d1b7751 upstream.
We wouldn't normally expect ops->attach_dev() to fail, but on IOMMUs
with limited hardware resources, or generally misconfigured systems,
it is certainly possible. We report failure correctly from the external
iommu_attach_device() interface, but do not do so in iommu_group_add()
when attaching to the default domain. The result of failure there is
that the device, group and domain all get left in a broken,
part-configured state which leads to weird errors and misbehaviour down
the line when IOMMU API calls sort-of-but-don't-quite work.
Check the return value of __iommu_attach_device() on the default domain,
and refactor the error handling paths to cope with its failure and clean
up correctly in such cases.
Fixes: e39cb8a3aa98 ("iommu: Make sure a device is always attached to a domain")
Reported-by: Punit Agrawal <punit.agrawal@arm.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit eebb8034a5be8c2177cbf07ca2ecd2ff8a058958 upstream.
IOMMU drivers that do not support default domains, but make
use of the the group->domain pointer can get that pointer
overwritten with NULL on device add/remove.
Make sure this can't happen by only overwriting the domain
pointer when it is NULL.
Fixes: 1228236de5f9 ('iommu: Move default domain allocation to iommu_group_get_for_dev()')
commit db0fa0cb0157 "scatterlist: use sg_phys()" did replacements of
the form:
phys_addr_t phys = page_to_phys(sg_page(s));
phys_addr_t phys = sg_phys(s) & PAGE_MASK;
However, this breaks platforms where sizeof(phys_addr_t) >
sizeof(unsigned long). Revert for 4.3 and 4.4 to make room for a
combined helper in 4.5.
Cc: <stable@vger.kernel.org>
Cc: Jens Axboe <axboe@fb.com>
Fixes: db0fa0cb0157 ("scatterlist: use sg_phys()")
Suggested-by: Joerg Roedel <joro@8bytes.org>
Reported-by: Vitaly Lavrov <vel21ripn@gmail.com>
Now that the iommu core support for iommu groups is not
pci-centric anymore, we can move default domain allocation
to the bus independent iommu_group_get_for_dev() function.
All callers of iommu_group_get_for_dev() provide a
device_group call-back now, so this fall-back is no longer
needed.
This function can be used as a device_group call-back and
just allocates one iommu-group per device.
Rename that function to pci_device_group() and export it, so
that IOMMU drivers can use it as their device_group
call-back.
That call-back is currently unused, change it into a
call-back function for finding the right IOMMU group for a
device.
This is a first step to remove the hard-coded PCI dependency
in the iommu-group code.
Coccinelle cleanup to replace open coded sg to physical address
translations. This is in preparation for introducing scatterlists that
reference __pfn_t.
// sg_phys.cocci: convert usage page_to_phys(sg_page(sg)) to sg_phys(sg)
// usage: make coccicheck COCCI=sg_phys.cocci MODE=patch
virtual patch
struct scatterlist *sg;
- page_to_phys(sg_page(sg)) + sg->offset
+ sg_phys(sg)
+ sg_phys(sg) & PAGE_MASK
Signed-off-by: Jens Axboe <axboe@fb.com>
The -ENODEV error just means that the device is not
translated by an IOMMU. We shouldn't bail out of iommu
driver initialization when that happens, as this is a common
scenario on ARM.
Not returning -ENODEV in the drivers would be a bad idea, as
the IOMMU core would have no indication whether a device is
translated or not. This indication is not used at the
moment, but will probably be in the future.
Fixes: 19762d7 ("iommu: Propagate error in add_iommu_group")
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Eric Auger <eric.auger@linaro.org>
Tested-by: Heiko Stuebner <heiko@sntech.de>
'x86/amd', 'default-domains' and 'core' into next
The iommu_group_alloc() and iommu_group_get_for_dev()
functions return error pointers, they never return NULL.
This function can be called by an IOMMU driver to request
that a device's default domain is direct mapped.
This will be used to handle unity mappings in the iommu
drivers.
Use the information exported by the IOMMU drivers to create
direct mapped regions in the default domains.
Add two new functions to the IOMMU-API to allow the IOMMU
drivers to export the requirements for direct mapped regions
per device.
This is useful for exporting the information in Intel VT-d's
RMRR entries or AMD-Vi's unity mappings.
This function can be used to request the current domain a
device is attached to.
Make use of the default domain and re-attach a device to it
when it is detached from another domain. Also enforce that a
device has to be in the default domain before it can be
attached to a different domain.
This patch changes the behavior of the iommu_attach_device
and iommu_detach_device functions. With this change these
functions only work on devices that have their own group.
For all other devices the iommu_group_attach/detach
functions must be used.
The default domain will be used (if supported by the iommu
driver) when the devices in the iommu group are not attached
to any other domain.
Do not remove the device from the IOMMU while the driver is
still attached.
Make sure we call the ->remove_device call-back on all
devices already initialized with ->add_device when the bus
initialization fails.
Make sure any errors reported from the IOMMU drivers get
progapated back to the IOMMU core.
Write a message to the kernel log when a device is added or
removed from a group and add debug messages to group
allocation and release routines.
Including the function name is only useful for debugging
messages. They don't belong into other messages from the
iommu core.
iommu_group_alloc might be called very early in case of iommu controllers
activated from of_iommu, so ensure that this part of subsystem is ready
when devices are being populated from device-tree (core_initcall seems to
be okay for this case).
Tested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
All drivers have been converted to the new domain_alloc and
domain_free iommu-ops. So remove the old ones and get rid of
iommu_domain->priv too, as this is no longer needed when the
struct iommu_domain is embedded in the private structures of
the iommu drivers.
Tested-by: Thierry Reding <treding@nvidia.com>
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Check for the new __IOMMU_DOMAIN_PAGING flag before calling
into the iommu drivers ->map and ->unmap call-backs.
This allows to handle domains differently based on their
type in the future. An IOMMU driver can implement certain
optimizations for DMA-API domains for example.
The domain types can be extended later and some of the
existing domain attributes can be migrated to become domain
flags.
These new call-backs defer the allocation and destruction of
'struct iommu_domain' to the iommu driver. This allows
drivers to embed this struct into their private domain
structures and to get rid of the domain_init and
domain_destroy call-backs when all drivers have been
converted.
The AMD address is dead for a long time already, replace it
with a working one.
iommu_map() calls trace_map() with iova and size. trace_map()
should report original iova and original size as opposed to
iova and size after they get changed during mapping. size is
always zero at the end of mapping which is useless to report
and iova as it gets incremented, it is not as useful as the
original iova. Change iommu_map() to call trace_map() to
report original iova and original size.
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Currently map and unmap are implemented as events under a
common trace class declaration. The common class forces
trace_unmap() to require a bogus physical address argument
that it doesn't use. Changing unmap to report unmapped size
will provide useful information for debugging. Remove common
map_unmap trace class and change map and unmap into separate
events as opposed to events under the same class to allow for
differences in the reporting information. In addition, map and
unmap are changed to handle size value as size_t instead of int
to match the passed size value and avoid overflow.
Suggested-by: Alex Williamson <alex.williamson@redhat.com>
iommu_unmap() calls trace_unmap() with changed iova and original
size. trace_unmap() should report original iova instead. Change
iommu_unmap() to call trace_unmap() with original iova.
Pull ARM SoC/iommu configuration update from Arnd Bergmann:
"The iomm-config branch contains work from Will Deacon, quoting his
description:
This series adds automatic IOMMU and DMA-mapping configuration for
OF-based DMA masters described using the generic IOMMU devicetree
bindings. Although there is plenty of future work around splitting up
iommu_ops, adding default IOMMU domains and sorting out automatic IOMMU
group creation for the platform_bus, this is already useful enough for
people to port over their IOMMU drivers and start using the new probing
infrastructure (indeed, Marek has patches queued for the Exynos IOMMU).
The branch touches core ARM and IOMMU driver files, and the respective
maintainers (Russell King and Joerg Roedel) agreed to have the
contents merged through the arm-soc tree.
The final version was ready just before the merge window, so we ended
up delaying it a bit longer than the rest, but we don't expect to see
regressions because this is just additional infrastructure that will
get used in drivers starting in 3.20 but is unused so far"
* tag 'iommu-config-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
iommu: store DT-probed IOMMU data privately
arm: dma-mapping: plumb our iommu mapping ops into arch_setup_dma_ops
arm: call iommu_init before of_platform_populate
dma-mapping: detect and configure IOMMU in of_dma_configure
iommu: fix initialization without 'add_device' callback
iommu: provide helper function to configure an IOMMU for an of master
iommu: add new iommu_ops callback for adding an OF device
dma-mapping: replace set_arch_dma_coherent_ops with arch_setup_dma_ops
iommu: provide early initialisation hook for IOMMU drivers
If the IOMMU supports pages smaller than the CPU page size, segments
which lie at offsets within the CPU page may be mapped based on the
finer-grained IOMMU page boundaries. This minimises the amount of
non-buffer memory between the CPU page boundary and the start of the
segment which must be mapped and therefore exposed to the device, and
brings the default iommu_map_sg implementation in line with
iommu_map/unmap with respect to alignment.
IOMMU drivers can be initialized from of_iommu helpers. Such drivers don't
need to provide device_add callbacks to operate properly, so there is no
need to fail initialization if the callback is missing.
When some part of bus_set_iommu fails it should undo any made changes
and not simply leave everything as is.
This includes unregistering the bus notifier in iommu_bus_init when
add_iommu_group fails and also setting the bus->iommu_ops back to NULL.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The IOMMU-API works on page boundarys, unlike the DMA-API
which can work with sub-page buffers. The sg->offset
field does not make sense on the IOMMU level, so force it to
be 0. Do some error-path consolidation while at it.
Mapping and unmapping are more often than not in the critical path.
map_sg allows IOMMU driver implementations to optimize the process
of mapping buffers into the IOMMU page tables.
Instead of mapping a buffer one page at a time and requiring potentially
expensive TLB operations for each page, this function allows the driver
to map all pages in one go and defer TLB maintenance until after all
pages have been mapped.
Additionally, the mapping operation would be faster in general since
clients does not have to keep calling map API over and over again for
each physically contiguous chunk of memory that needs to be mapped to a
virtually contiguous region.
Signed-off-by: Olav Haugan <ohaugan@codeaurora.org>
iommu_bus_init() registers a bus notifier on the given bus by using
a statically defined notifier block:
static struct notifier_block iommu_bus_nb = {
.notifier_call = iommu_bus_notifier,
This same notifier block is used for all busses. This causes a
problem for notifiers registered after iommu has registered this
callback on multiple busses. The problem is that a subsequent
notifier being registered on a bus which has this iommu notifier
will also get linked in to the notifier list of all other busses
which have this iommu notifier.
This patch fixes this by allocating the notifier_block at runtime.
Some error checking is also added to catch any allocation failure
or notifier registration error.
Signed-off-by: Mark Salter <msalter@redhat.com>
It turns out that our assumption that aliases are always to the same
slot isn't true. One particular platform reports an IVRS alias of the
SATA controller (00:11.0) for the legacy IDE controller (00:14.1).
When we hit this, we attempt to use a single IOMMU group for
everything on the same bus, which in this case is the root complex.
We already have multiple groups defined for the root complex by this
point, resulting in multiple WARN_ON hits.
This patch makes these sorts of aliases work again with IOMMU groups
by reworking how we search through the PCI address space to find
existing groups. This should also now handle looped dependencies and
all sorts of crazy inter-dependencies that we'll likely never see.
The recursion used here should never be very deep. It's unlikely to
have individual aliases and only theoretical that we'd ever see a
chain where one alias causes us to search through to yet another
alias. We're also only dealing with PCIe device on a single bus,
which means we'll typically only see multiple slots in use on the root
complex. Loops are also a theoretically possibility, which I've
tested using fake DMA alias quirks and prevent from causing problems
using a bitmap of the devfn space that's been visited.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Cc: stable@vger.kernel.org # 3.17
This function will replace the current iommu_domain_has_cap
function and clean up the interface while at it.
Allow compile-time type-checking.
When a non-PCI device is passed to that function it might
pass group == NULL to iommu_group_add_device() which then
dereferences it and cause a crash this way. Fix it by
just returning an error for non-PCI devices.
Fixes: 104a1c13ac66e40cf8c6ae74d76ff14ff24b9b01
Cc: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Check for the ->map and not the ->unmap pointer.
This structure is read-only data and should never be modified.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Currently each IOMMU driver that supports IOMMU groups has its own
code for discovering the base device used in grouping. This code
is generally not specific to the IOMMU hardware, but to the bus of
the devices managed by the IOMMU. We can therefore create a common
interface for supporting devices on different buses.
'arm/smmu' and 'arm/shmobile' into next
