path: root/drivers/iommu/tegra-gart.c
2015-04-02Merge branches 'iommu/fixes', 'x86/vt-d', 'x86/amd', 'arm/smmu', 'arm/tegra' ↵Joerg Roedel
and 'core' into next Conflicts: drivers/iommu/amd_iommu.c drivers/iommu/tegra-gart.c drivers/iommu/tegra-smmu.c
2015-03-31iommu/tegra: gart: Set aperture at domain initialization timeThierry Reding
The aperture of the domain should always be available, otherwise drivers need to attach first before they can use the aperture geometry. Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-03-31iommu/tegra-gart: Make use of domain_alloc and domain_freeJoerg Roedel
Implement domain_alloc and domain_free iommu-ops as a replacement for domain_init/domain_destroy. Tested-by: Thierry Reding <treding@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-01-26iommu/tegra: gart: Provide default ->map_sg() callbackThierry Reding
Commit 315786ebbf4a ("iommu: Add iommu_map_sg() function") adds a new ->map_sg() callback and provides a default implementation that drivers can use until they implement a hardware-specific variant. Unfortunately the Tegra GART driver was not updated as part of that commit, so that iommu_map_sg() calls on a domain provided by the GART cause an oops. Fixes: 315786ebbf4a ("iommu: Add iommu_map_sg() function") Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2015-01-26iommu/tegra: gart: Do not register with busThierry Reding
The driver currently doesn't work as expected and causes existing setups with Tegra20 to break after commit df06b759f2cf ("drm/tegra: Add IOMMU support"). To restore these setups, do not register the operations with the platform bus for now. Fixing this properly will involve non-trivial changes to the DRM driver, which are unlikely to be accepted at this point in the release cycle. Reported-by: Misha Komarovskiy <zombah@gmail.com> Reported-by: Nicolas Chauvet <kwizart@gmail.com> Tested-by: Misha Komarovskiy <zombah@gmail.com> Tested-by: Dmitry Osipenko <digetx@gmail.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-10-20iommu: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-25iommu: Make of_device_id array constKiran Padwal
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-09-25iommu/tegra: Convert to iommu_capable() API functionJoerg Roedel
Cc: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-07-07iommu: Constify struct iommu_opsThierry Reding
This structure is read-only data and should never be modified. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2013-11-01iommu/tegra-gart: Staticize tegra_gart_pm_opsSachin Kamat
'tegra_gart_pm_ops' is local to this file. Make it static. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-09-24iommu/tegra: gart: cleanup devm_* functions usageWei Yongjun
The devm_[kzalloc|ioremap] functions allocates data that are released when a driver detaches. Thus, there is no reason to explicitly call devm_[kfree|iounmap] in probe or remove functions. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-09-24iommu/tegra: Print phys_addr_t using %paThierry Reding
When enabling LPAE on ARM, phys_addr_t becomes 64 bits wide and printing a variable of that type using a simple %x format specifier causes the compiler to complain. Change the format specifier to %pa, which is used specifically for variables of type phys_addr_t. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-05-02Merge branches 'iommu/fixes', 'x86/vt-d', 'x86/amd', 'ppc/pamu', 'core' and ↵Joerg Roedel
'arm/tegra' into next
2013-05-02iommu/tegra: Fix printk formats for dma_addr_tVarun Sethi
Fix printk formats for dma_addr_t: drivers/iommu/tegra-smmu.c: In function 'smmu_iommu_iova_to_phys': >> drivers/iommu/tegra-smmu.c:774:2: warning: format '%lx' expects argument of type 'long unsigned int', but argument 4 has type 'dma_addr_t' [-Wformat] -- drivers/iommu/tegra-gart.c: In function 'gart_iommu_iova_to_phys': >> drivers/iommu/tegra-gart.c:298:3: warning: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'dma_addr_t' [-Wformat] Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-02iommu/fsl: Make iova dma_addr_t in the iommu_iova_to_phys API.Varun Sethi
This is required in case of PAMU, as it can support a window size of up to 64G (even on 32bit). Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-02-19iommu/tegra: assume CONFIG_OF in gart driverStephen Warren
Tegra only supports, and always enables, device tree. Remove all ifdefs for DT support from the driver. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-01-03Drivers: iommu: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <joro@8bytes.org> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Bharat Nihalani <bnihalani@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28iommu/tegra: gart: Move bus_set_iommu after probe for multi archHiroshi Doyu
For a single image to support multiple SoCs(GART/SMMU). Reported-by: Arto Merilainen <amerilainen@nvidia.com> Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2012-07-11iommu/tegra: Implement DOMAIN_ATTR_GEOMETRY attributeHiroshi DOYU
Implement the attribute for the Tegra IOMMU drivers. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-05-11iommu/tegra: gart: Fix register offset correctlyHiroshi DOYU
DT passes the exact GART register ranges without any overlapping with MC register ranges. GART register offset needs to be adjusted by one passed by DT correctly. Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-04-16iommu: tegra/gart: Add device tree supportThierry Reding
This commit adds device tree support for the GART hardware available on NVIDIA Tegra 20 SoCs. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-04-16iommu: tegra/gart: use correct gart_deviceVandana Salve
Pass the correct gart device pointer. Reviewed-by: Vandana Salve <vsalve@nvidia.com> Tested-by: Vandana Salve <vsalve@nvidia.com> Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-03-13iommu/tegra-gart: fix spin_unlock in map failure pathLucas Stach
This must have been messed up while merging, the intention was clearly to unlock there. Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-26ARM: IOMMU: Tegra20: Add iommu_ops for GART driverHiroshi DOYU
Tegra 20 IOMMU H/W, GART (Graphics Address Relocation Table). This patch implements struct iommu_ops for GART for the upper IOMMU API. This H/W module supports only single virtual address space(domain), and manages a single level 1-to-1 mapping H/W translation page table. [With small fixes by Joerg Roedel] Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
