path: root/drivers/iommu
2015-01-16iommu/vt-d: Fix an off-by-one bug in __domain_mapping()Jiang Liu
commit cc4f14aa170d895c9a43bdb56f62070c8a6da908 upstream. There's an off-by-one bug in function __domain_mapping(), which may trigger the BUG_ON(nr_pages < lvl_pages) when (nr_pages + 1) & superpage_mask == 0 The issue was introduced by commit 9051aa0268dc "intel-iommu: Combine domain_pfn_mapping() and domain_sg_mapping()", which sets sg_res to "nr_pages + 1" to avoid some of the 'sg_res==0' code paths. It's safe to remove extra "+1" because sg_res is only used to calculate page size now. Reported-And-Tested-by: Sudeep Dutt <sudeep.dutt@intel.com> Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17iommu/amd: Fix cleanup_domain for mass device removalJoerg Roedel
commit 9b29d3c6510407d91786c1cf9183ff4debb3473a upstream. When multiple devices are detached in __detach_device, they are also removed from the domains dev_list. This makes it unsafe to use list_for_each_entry_safe, as the next pointer might also not be in the list anymore after __detach_device returns. So just repeatedly remove the first element of the list until it is empty. Tested-by: Marti Raudsepp <marti@juffo.org> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07iommu/amd: Fix interrupt remapping for aliased devicesAlex Williamson
commit e028a9e6b8a637af09ac4114083280df4a7045f1 upstream. An apparent cut and paste error prevents the correct flags from being set on the alias device resulting in MSI on conventional PCI devices failing to work. This also produces error events from the IOMMU like: AMD-Vi: Event logged [INVALID_DEVICE_REQUEST device=00:14.4 address=0x000000fdf8000000 flags=0x0a00] Where 14.4 is a PCIe-to-PCI bridge with a device behind it trying to use MSI interrupts. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13intel-iommu: fix off-by-one in pagetable freeingAlex Williamson
commit 08336fd218e087cc4fcc458e6b6dcafe8702b098 upstream. dma_pte_free_level() has an off-by-one error when checking whether a pte is completely covered by a range. Take for example the case of attempting to free pfn 0x0 - 0x1ff, ie. 512 entries covering the first 2M superpage. The level_size() is 0x200 and we test: static void dma_pte_free_level(... ... if (!(0 > 0 || 0x1ff < 0 + 0x200)) { ... } Clearly the 2nd test is true, which means we fail to take the branch to clear and free the pagetable entry. As a result, we're leaking pagetables and failing to install new pages over the range. This was found with a PCI device assigned to a QEMU guest using vfio-pci without a VGA device present. The first 1M of guest address space is mapped with various combinations of 4K pages, but eventually the range is entirely freed and replaced with a 2M contiguous mapping. intel-iommu errors out with something like: ERROR: DMA PTE for vPFN 0x0 already set (to 5c2b8003 not 849c00083) In this case 5c2b8003 is the pointer to the previous leaf page that was neither freed nor cleared and 849c00083 is the superpage entry that we're trying to replace it with. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <joro@8bytes.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08iommu: Remove stack trace from broken irq remapping warningNeil Horman
commit 05104a4e8713b27291c7bb49c1e7e68b4e243571 upstream. The warning for the irq remapping broken check in intel_irq_remapping.c is pretty pointless. We need the warning, but we know where its comming from, the stack trace will always be the same, and it needlessly triggers things like Abrt. This changes the warning to just print a text warning about BIOS being broken, without the stack trace, then sets the appropriate taint bit. Since we automatically disable irq remapping, theres no need to contiue making Abrt jump at this problem Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Joerg Roedel <joro@8bytes.org> CC: Bjorn Helgaas <bhelgaas@google.com> CC: Andy Lutomirski <luto@amacapital.net> CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limitsJulian Stecklina
commit f9423606ade08653dd8a43334f0a7fb45504c5cc upstream. The BUG_ON in drivers/iommu/intel-iommu.c:785 can be triggered from userspace via VFIO by calling the VFIO_IOMMU_MAP_DMA ioctl on a vfio device with any address beyond the addressing capabilities of the IOMMU. The problem is that the ioctl code calls iommu_iova_to_phys before it calls iommu_map. iommu_map handles the case that it gets addresses beyond the addressing capabilities of its IOMMU. intel_iommu_iova_to_phys does not. This patch fixes iommu_iova_to_phys to return NULL for addresses beyond what the IOMMU can handle. This in turn causes the ioctl call to fail in iommu_map and (correctly) return EFAULT to the user with a helpful warning message in the kernel log. Signed-off-by: Julian Stecklina <jsteckli@os.inf.tu-dresden.de> Acked-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26intel-iommu: Fix leaks in pagetable freeingAlex Williamson
commit 3269ee0bd6686baf86630300d528500ac5b516d7 upstream. At best the current code only seems to free the leaf pagetables and the root. If you're unlucky enough to have a large gap (like any QEMU guest with more than 3G of memory), only the first chunk of leaf pagetables are freed (plus the root). This is a massive memory leak. This patch re-writes the pagetable freeing function to use a recursive algorithm and manages to not only free all the pagetables, but does it without any apparent performance loss versus the current broken version. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25iommu/amd: Only unmap large pages from the first pteAlex Williamson
commit 60d0ca3cfd199b6612bbbbf4999a3470dad38bb1 upstream. If we use a large mapping, the expectation is that only unmaps from the first pte in the superpage are supported. Unmaps from offsets into the superpage should fail (ie. return zero sized unmap). In the current code, unmapping from an offset clears the size of the full mapping starting from an offset. For instance, if we map a 16k physically contiguous range at IOVA 0x0 with a large page, then attempt to unmap 4k at offset 12k, 4 ptes are cleared (12k - 28k) and the unmap returns 16k unmapped. This potentially incorrectly clears valid mappings and confuses drivers like VFIO that use the unmap size to release pinned pages. Fix by refusing to unmap from offsets into the page. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-06Merge tag 'iommu-updates-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "The updates are mostly about the x86 IOMMUs this time. Exceptions are the groundwork for the PAMU IOMMU from Freescale (for a PPC platform) and an extension to the IOMMU group interface. On the x86 side this includes a workaround for VT-d to disable interrupt remapping on broken chipsets. On the AMD-Vi side the most important new feature is a kernel command-line interface to override broken information in IVRS ACPI tables and get interrupt remapping working this way. Besides that there are small fixes all over the place." * tag 'iommu-updates-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (24 commits) iommu/tegra: Fix printk formats for dma_addr_t iommu: Add a function to find an iommu group by id iommu/vt-d: Remove warning for HPET scope type iommu: Move swap_pci_ref function to drivers/iommu/pci.h. iommu/vt-d: Disable translation if already enabled iommu/amd: fix error return code in early_amd_iommu_init() iommu/AMD: Per-thread IOMMU Interrupt Handling iommu: Include linux/err.h iommu/amd: Workaround for ERBT1312 iommu/amd: Document ivrs_ioapic and ivrs_hpet parameters iommu/amd: Don't report firmware bugs with cmd-line ivrs overrides iommu/amd: Add ioapic and hpet ivrs override iommu/amd: Add early maps for ioapic and hpet iommu/amd: Extend IVRS special device data structure iommu/amd: Move add_special_device() to __init iommu: Fix compile warnings with forward declarations iommu/amd: Properly initialize irq-table lock iommu/amd: Use AMD specific data structure for irq remapping iommu/amd: Remove map_sg_no_iommu() iommu/vt-d: add quirk for broken interrupt remapping on 55XX chipsets ...
2013-05-02Merge branches 'iommu/fixes', 'x86/vt-d', 'x86/amd', 'ppc/pamu', 'core' and ↵Joerg Roedel
'arm/tegra' into next
2013-05-02iommu/tegra: Fix printk formats for dma_addr_tVarun Sethi
Fix printk formats for dma_addr_t: drivers/iommu/tegra-smmu.c: In function 'smmu_iommu_iova_to_phys': >> drivers/iommu/tegra-smmu.c:774:2: warning: format '%lx' expects argument of type 'long unsigned int', but argument 4 has type 'dma_addr_t' [-Wformat] -- drivers/iommu/tegra-gart.c: In function 'gart_iommu_iova_to_phys': >> drivers/iommu/tegra-gart.c:298:3: warning: format '%lx' expects argument of type 'long unsigned int', but argument 3 has type 'dma_addr_t' [-Wformat] Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-30Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "Misc smaller changes all over the map" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/iommu/dmar: Remove warning for HPET scope type x86/mm/gart: Drop unnecessary check x86/mm/hotplug: Put kernel_physical_mapping_remove() declaration in CONFIG_MEMORY_HOTREMOVE x86/mm/fixmap: Remove unused FIX_CYCLONE_TIMER x86/mm/numa: Simplify some bit mangling x86/mm: Re-enable DEBUG_TLBFLUSH for X86_32 x86/mm/cpa: Cleanup split_large_page() and its callee x86: Drop always empty .text..page_aligned section
2013-04-29Merge tag 'pci-v3.10-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v3.10 merge window: PCI device hotplug - Remove ACPI PCI subdrivers (Jiang Liu, Myron Stowe) - Make acpiphp builtin only, not modular (Jiang Liu) - Add acpiphp mutual exclusion (Jiang Liu) Power management - Skip "PME enabled/disabled" messages when not supported (Rafael Wysocki) - Fix fallback to PCI_D0 (Rafael Wysocki) Miscellaneous - Factor quirk_io_region (Yinghai Lu) - Cache MSI capability offsets & cleanup (Gavin Shan, Bjorn Helgaas) - Clean up EISA resource initialization and logging (Bjorn Helgaas) - Fix prototype warnings (Andy Shevchenko, Bjorn Helgaas) - MIPS: Initialize of_node before scanning bus (Gabor Juhos) - Fix pcibios_get_phb_of_node() declaration "weak" annotation (Gabor Juhos) - Add MSI INTX_DISABLE quirks for AR8161/AR8162/etc (Xiong Huang) - Fix aer_inject return values (Prarit Bhargava) - Remove PME/ACPI dependency (Andrew Murray) - Use shared PCI_BUS_NUM() and PCI_DEVID() (Shuah Khan)" * tag 'pci-v3.10-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits) vfio-pci: Use cached MSI/MSI-X capabilities vfio-pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Remove "extern" from function declarations PCI: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK PCI: Drop msi_mask_reg() and remove drivers/pci/msi.h PCI: Use msix_table_size() directly, drop multi_msix_capable() PCI: Drop msix_table_offset_reg() and msix_pba_offset_reg() macros PCI: Drop is_64bit_address() and is_mask_bit_support() macros PCI: Drop msi_data_reg() macro PCI: Drop msi_lower_address_reg() and msi_upper_address_reg() macros PCI: Drop msi_control_reg() macro and use PCI_MSI_FLAGS directly PCI: Use cached MSI/MSI-X offsets from dev, not from msi_desc PCI: Clean up MSI/MSI-X capability #defines PCI: Use cached MSI-X cap while enabling MSI-X PCI: Use cached MSI cap while enabling MSI interrupts PCI: Remove MSI/MSI-X cap check in pci_msi_check_device() PCI: Cache MSI/MSI-X capability offsets in struct pci_dev PCI: Use u8, not int, for PM capability offset [SCSI] megaraid_sas: Use correct #define for MSI-X capability PCI: Remove "extern" from function declarations ...
2013-04-24iommu: Add a function to find an iommu group by idAlexey Kardashevskiy
As IOMMU groups are exposed to the user space by their numbers, the user space can use them in various kernel APIs so the kernel might need an API to find a group by its ID. As an example, QEMU VFIO on PPC64 platform needs it to associate a logical bus number (LIOBN) with a specific IOMMU group in order to support in-kernel handling of DMA map/unmap requests. The patch adds the iommu_group_get_by_id(id) function which performs such search. v2: fixed reference counting. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Acked-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-24iommu/vt-d: Remove warning for HPET scope typeLinn Crosetto
ACPI_DMAR_SCOPE_TYPE_HPET is parsed by ir_parse_ioapic_hpet_scope() and should not be flagged as an unsupported type. Signed-off-by: Linn Crosetto <linn@hp.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-24x86/iommu/dmar: Remove warning for HPET scope typeLinn Crosetto
ACPI_DMAR_SCOPE_TYPE_HPET is parsed by ir_parse_ioapic_hpet_scope() and should not be flagged as an unsupported type. Signed-off-by: Linn Crosetto <linn@hp.com> Cc: joro@8bytes.org Cc: ddutile@redhat.com Cc: suresh.b.siddha@intel.com Link: http://lkml.kernel.org/r/1366741605-71293-1-git-send-email-linn@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-23iommu: Move swap_pci_ref function to drivers/iommu/pci.h.Varun Sethi
The swap_pci_ref function is used by the IOMMU API code for swapping pci device pointers, while determining the iommu group for the device. Currently this function was being implemented for different IOMMU drivers. This patch moves the function to a new file, drivers/iommu/pci.h so that the implementation can be shared across various IOMMU drivers. Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-23iommu/vt-d: Disable translation if already enabledTakao Indoh
This patch disables translation(dma-remapping) before its initialization if it is already enabled. This is needed for kexec/kdump boot. If dma-remapping is enabled in the first kernel, it need to be disabled before initializing its page table during second kernel boot. Wei Hu also reported that this is needed when second kernel boots with intel_iommu=off. Basically iommu->gcmd is used to know whether translation is enabled or disabled, but it is always zero at boot time even when translation is enabled since iommu->gcmd is initialized without considering such a case. Therefor this patch synchronizes iommu->gcmd value with global command register when iommu structure is allocated. Signed-off-by: Takao Indoh <indou.takao@jp.fujitsu.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-23iommu/amd: fix error return code in early_amd_iommu_init()Wei Yongjun
Fix to return -ENOMEM int the memory alloc error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-23iommu/AMD: Per-thread IOMMU Interrupt HandlingSuravee Suthikulpanit
In the current interrupt handling scheme, there are as many threads as the number of IOMMUs. Each thread is created and assigned to an IOMMU at the time of registering interrupt handlers (request_threaded_irq). When an IOMMU HW generates an interrupt, the irq handler (top half) wakes up the corresponding thread to process event and PPR logs of all IOMMUs starting from the 1st IOMMU. In the system with multiple IOMMU,this handling scheme complicates the synchronization of the IOMMU data structures and status registers as there could be multiple threads competing for the same IOMMU while the other IOMMU could be left unhandled. To simplify, this patch is proposing a different interrupt handling scheme by having each thread only managing interrupts of the corresponding IOMMU. This can be achieved by passing the struct amd_iommu when registering the interrupt handlers. This structure is unique for each IOMMU and can be used by the bottom half thread to identify the IOMMU to be handled instead of calling for_each_iommu. Besides this also eliminate the needs to lock the IOMMU for processing event and PPR logs. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Workaround for ERBT1312Joerg Roedel
Work around an IOMMU hardware bug where clearing the EVT_INT or PPR_INT bit in the status register may race with the hardware trying to set it again. When not handled the bit might not be cleared and we lose all future event or ppr interrupts. Reported-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Don't report firmware bugs with cmd-line ivrs overridesJoerg Roedel
When the IVRS entries for IOAPIC and HPET are overridden on the kernel command line, a problem detected in the check function might not be a firmware bug anymore. So disable the firmware bug reporting if the user provided valid ivrs_ioapic or ivrs_hpet entries on the command line. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Add ioapic and hpet ivrs overrideJoerg Roedel
Add two new kernel commandline parameters ivrs_ioapic and ivrs_hpet to override the Id->DeviceId mapping from the IVRS ACPI table. This can be used to work around broken BIOSes to get interrupt remapping working on AMD systems. Tested-by: Borislav Petkov <bp@suse.de> Tested-by: Suravee Suthikulanit <suravee.suthikulpanit@amd.com> Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Add early maps for ioapic and hpetJoerg Roedel
This is needed in a later patch were ioapic_map and hpet_map entries are created before the slab allocator is initialized (and thus add_special_device() can't be used). Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Extend IVRS special device data structureJoerg Roedel
This patch extends the devid_map data structure to allow ioapic and hpet entries in ivrs to be overridden on the kernel command line. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-19iommu/amd: Move add_special_device() to __initJoerg Roedel
The function is only called by other __init functions, so it can be moved to __init too. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-18iommu/amd: Properly initialize irq-table lockJoerg Roedel
Fixes a lockdep warning. Cc: stable@vger.kernel.org # >= v3.7 Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-18iommu/amd: Use AMD specific data structure for irq remappingJoerg Roedel
For compatibility reasons the irq remapping code for the AMD IOMMU used the same per-irq data structure as the Intel implementation. Now that support for the AMD specific data structure is upstream we can use this one instead. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-18iommu/amd: Remove map_sg_no_iommu()Joerg Roedel
This function was intended as a fall-back if the map_sg function is called for a device not mapped by the IOMMU. Since the AMD IOMMU driver uses per-device dma_ops this can never happen. So this function isn't needed anymore. Reviewed-by: Shuah Khan <shuahkhan@gmail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-18iommu/vt-d: add quirk for broken interrupt remapping on 55XX chipsetsNeil Horman
A few years back intel published a spec update: http://www.intel.com/content/dam/doc/specification-update/5520-and-5500-chipset-ioh-specification-update.pdf For the 5520 and 5500 chipsets which contained an errata (specificially errata 53), which noted that these chipsets can't properly do interrupt remapping, and as a result the recommend that interrupt remapping be disabled in bios. While many vendors have a bios update to do exactly that, not all do, and of course not all users update their bios to a level that corrects the problem. As a result, occasionally interrupts can arrive at a cpu even after affinity for that interrupt has be moved, leading to lost or spurrious interrupts (usually characterized by the message: kernel: do_IRQ: 7.71 No irq handler for vector (irq -1) There have been several incidents recently of people seeing this error, and investigation has shown that they have system for which their BIOS level is such that this feature was not properly turned off. As such, it would be good to give them a reminder that their systems are vulnurable to this problem. For details of those that reported the problem, please see: https://bugzilla.redhat.com/show_bug.cgi?id=887006 [ Joerg: Removed CONFIG_IRQ_REMAP ifdef from early-quirks.c ] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Prarit Bhargava <prarit@redhat.com> CC: Don Zickus <dzickus@redhat.com> CC: Don Dutile <ddutile@redhat.com> CC: Bjorn Helgaas <bhelgaas@google.com> CC: Asit Mallick <asit.k.mallick@intel.com> CC: David Woodhouse <dwmw2@infradead.org> CC: linux-pci@vger.kernel.org CC: Joerg Roedel <joro@8bytes.org> CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Arkadiusz Miśkiewicz <arekm@maven.pl> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-02iommu/fsl: Add the window permission flag as a parameter to ↵Varun Sethi
iommu_window_enable API. Each iommu window can have access permissions associated with it. Extended the window_enable API to incorporate window access permissions. In case of PAMU each window can have its specific set of permissions. Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-02iommu/fsl: Make iova dma_addr_t in the iommu_iova_to_phys API.Varun Sethi
This is required in case of PAMU, as it can support a window size of up to 64G (even on 32bit). Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-04-02iommu/amd: Re-enable IOMMU event log interrupt after handling.Suravee Suthikulpanit
Current driver does not clear the IOMMU event log interrupt bit in the IOMMU status register after processing an interrupt. This causes the IOMMU hardware to generate event log interrupt only once. This has been observed in both IOMMU v1 and V2 hardware. This patch clears the bit by writing 1 to bit 1 of the IOMMU status register (MMIO Offset 2020h) Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-27Merge tag 'iommu-fixes-v3.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU fixes from Joerg Roedel: "Here are some fixes which have collected since Linux v3.9-rc1. The most important one fixes a long-standing regressen which make re-hotplugged devices unusable when AMD IOMMU is used. The other patches fix build issues (build regression on OMAP and a section mismatch). One patch just removes a duplicate header include." * tag 'iommu-fixes-v3.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/amd: Make sure dma_ops are set for hotplug devices x86, io_apic: remove duplicated include from irq_remapping.c iommu: OMAP: build only on OMAP2+ amd_iommu_init: remove __init from amd_iommu_erratum_746_workaround
2013-03-27iommu/amd: Make sure dma_ops are set for hotplug devicesJoerg Roedel
There is a bug introduced with commit 27c2127 that causes devices which are hot unplugged and then hot-replugged to not have per-device dma_ops set. This causes these devices to not function correctly. Fixed with this patch. Cc: stable@vger.kernel.org Reported-by: Andreas Degert <andreas.degert@googlemail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-26iommu/amd: Remove calc_devid() and use PCI_DEVID() from PCIShuah Khan
Change to remove calc_devid() and use PCI_DEVID() from PCI instead. Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Joerg Roedel <joro@8bytes.org>
2013-03-26iommu/amd: Remove local PCI_BUS() define and use PCI_BUS_NUM() from PCIShuah Khan
Change to remove local PCI_BUS() define and use the new PCI_BUS_NUM() interface from PCI. Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Joerg Roedel <joro@8bytes.org>
2013-03-26iommu/vt-d: dmar_fault should only clear PPF/PFO field.Li, Zhen-Hua
When there is a dmar irq, dmar_fault is called and all of the fields in FSTS are cleared. But ICE/IQE/ITE should not be cleared here, they need to be processed and cleared in function qi_check_fault. [Minor cleanup by Joerg Roedel] Signed-off-by: Li, Zhen-Hua <zhen-hual@hp.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-26x86, io_apic: remove duplicated include from irq_remapping.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-09iommu: OMAP: build only on OMAP2+Arnd Bergmann
The OMAP IOMMU driver intentionally fails to build on OMAP1 platforms, so we should not allow enabling it there. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Joerg Roedel <joro@8bytes.org> Cc: iommu@lists.linux-foundation.org Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-09amd_iommu_init: remove __init from amd_iommu_erratum_746_workaroundNikola Pajkovsky
commit 318fe78 ("IOMMU, AMD Family15h Model10-1Fh erratum 746 Workaround") added amd_iommu_erratum_746_workaround and it's marked as __init, which is wrong WARNING: drivers/iommu/built-in.o(.text+0x639c): Section mismatch in reference from the function iommu_init_pci() to the function .init.text:amd_iommu_erratum_746_workaround() The function iommu_init_pci() references the function __init amd_iommu_erratum_746_workaround(). This is often because iommu_init_pci lacks a __init annotation or the annotation of amd_iommu_erratum_746_workaround is wrong. Signed-off-by: Nikola Pajkovsky <npajkovs@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-06iommu, x86: Add DMA remap fault reasonLi, Zhen-Hua
The number of DMA fault reasons in intel's document are from 1 to 0xD, but in dmar.c fault reason 0xD is not printed out. In this document: "Intel Virtualization Technology for Directed I/O Architecture Specification" http://download.intel.com/technology/computing/vptech/Intel(r)_VT_for_Direct_IO.pdf Chapter 4. Support For Device-IOTLBs Table 6. Unsuccessful Translated Requests There is fault reason for 0xD not listed in kernel: Present context-entry used to process translation request specifies blocking of Translation Requests (Translation Type (T) field value not equal to 01b). This patch adds reason 0xD as well. Signed-off-by: Li, Zhen-Hua <zhen-hual@hp.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Donald Dutile <ddutile@redhat.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Hannes Reinecke <hare@suse.de> Link: http://lkml.kernel.org/r/1362537797-6034-1-git-send-email-zhen-hual@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge tag 'iommu-updates-v3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU Updates from Joerg Roedel: "Besides some fixes and cleanups in the code there are three more important changes to point out this time: * New IOMMU driver for the ARM SHMOBILE platform * An IOMMU-API extension for non-paging IOMMUs (required for upcoming PAMU driver) * Rework of the way the Tegra IOMMU driver accesses its registetrs - register windows are easier to extend now. There are also a few changes to non-iommu code, but that is acked by the respective maintainers." * tag 'iommu-updates-v3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (23 commits) iommu/tegra: assume CONFIG_OF in SMMU driver iommu/tegra: assume CONFIG_OF in gart driver iommu/amd: Remove redundant NULL check before dma_ops_domain_free(). iommu/amd: Initialize device table after dma_ops iommu/vt-d: Zero out allocated memory in dmar_enable_qi iommu/tegra: smmu: Fix incorrect mask for regbase iommu/exynos: Make exynos_sysmmu_disable static ARM: mach-shmobile: r8a7740: Add IPMMU device ARM: mach-shmobile: sh73a0: Add IPMMU device ARM: mach-shmobile: sh7372: Add IPMMU device iommu/shmobile: Add iommu driver for Renesas IPMMU modules iommu: Add DOMAIN_ATTR_WINDOWS domain attribute iommu: Add domain window handling functions iommu: Implement DOMAIN_ATTR_PAGING attribute iommu: Check for valid pgsize_bitmap in iommu_map/unmap iommu: Make sure DOMAIN_ATTR_MAX is really the maximum iommu/tegra: smmu: Change SMMU's dependency on ARCH_TEGRA iommu/tegra: smmu: Use helper function to check for valid register offset iommu/tegra: smmu: Support variable MMIO ranges/blocks iommu/tegra: Add missing spinlock initialization ...
2013-02-26tegra: don't wank with d_find_alias()Al Viro
2013-02-25Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm merge from Dave Airlie: "Highlights: - TI LCD controller KMS driver - TI OMAP KMS driver merged from staging - drop gma500 stub driver - the fbcon locking fixes - the vgacon dirty like zebra fix. - open firmware videomode and hdmi common code helpers - major locking rework for kms object handling - pageflip/cursor won't block on polling anymore! - fbcon helper and prime helper cleanups - i915: all over the map, haswell power well enhancements, valleyview macro horrors cleaned up, killing lots of legacy GTT code, - radeon: CS ioctl unification, deprecated UMS support, gpu reset rework, VM fixes - nouveau: reworked thermal code, external dp/tmds encoder support (anx9805), fences sleep instead of polling, - exynos: all over the driver fixes." Lovely conflict in radeon/evergreen_cs.c between commit de0babd60d8d ("drm/radeon: enforce use of radeon_get_ib_value when reading user cmd") and the new changes that modified that evergreen_dma_cs_parse() function. * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (508 commits) drm/tilcdc: only build on arm drm/i915: Revert hdmi HDP pin checks drm/tegra: Add list of framebuffers to debugfs drm/tegra: Fix color expansion drm/tegra: Split DC_CMD_STATE_CONTROL register write drm/tegra: Implement page-flipping support drm/tegra: Implement VBLANK support drm/tegra: Implement .mode_set_base() drm/tegra: Add plane support drm/tegra: Remove bogus tegra_framebuffer structure drm: Add consistency check for page-flipping drm/radeon: Use generic HDMI infoframe helpers drm/tegra: Use generic HDMI infoframe helpers drm: Add EDID helper documentation drm: Add HDMI infoframe helpers video: Add generic HDMI infoframe helpers drm: Add some missing forward declarations drm: Move mode tables to drm_edid.c drm: Remove duplicate drm_mode_cea_vic() gma500: Fix n, m1 and m2 clock limits for sdvo and lvds ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-19Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic changes from Ingo Molnar: "Main changes: - Multiple MSI support added to the APIC, PCI and AHCI code - acked by all relevant maintainers, by Alexander Gordeev. The advantage is that multiple AHCI ports can have multiple MSI irqs assigned, and can thus spread to multiple CPUs. [ Drivers can make use of this new facility via the pci_enable_msi_block_auto() method ] - x86 IOAPIC code from interrupt remapping cleanups from Joerg Roedel: These patches move all interrupt remapping specific checks out of the x86 core code and replaces the respective call-sites with function pointers. As a result the interrupt remapping code is better abstraced from x86 core interrupt handling code. - Various smaller improvements, fixes and cleanups." * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) x86/intel/irq_remapping: Clean up x2apic opt-out security warning mess x86, kvm: Fix intialization warnings in kvm.c x86, irq: Move irq_remapped out of x86 core code x86, io_apic: Introduce eoi_ioapic_pin call-back x86, msi: Introduce x86_msi.compose_msi_msg call-back x86, irq: Introduce setup_remapped_irq() x86, irq: Move irq_remapped() check into free_remapped_irq x86, io-apic: Remove !irq_remapped() check from __target_IO_APIC_irq() x86, io-apic: Move CONFIG_IRQ_REMAP code out of x86 core x86, irq: Add data structure to keep AMD specific irq remapping information x86, irq: Move irq_remapping_enabled declaration to iommu code x86, io_apic: Remove irq_remapping_enabled check in setup_timer_IRQ0_pin x86, io_apic: Move irq_remapping_enabled checks out of check_timer() x86, io_apic: Convert setup_ioapic_entry to function pointer x86, io_apic: Introduce set_affinity function pointer x86, msi: Use IRQ remapping specific setup_msi_irqs routine x86, hpet: Introduce x86_msi_ops.setup_hpet_msi x86, io_apic: Introduce x86_io_apic_ops.print_entries for debugging x86, io_apic: Introduce x86_io_apic_ops.disable() x86, apic: Mask IO-APIC and PIC unconditionally on LAPIC resume ...
2013-02-20intel/iommu: force writebuffer-flush quirk on Gen 4 ChipsetsDaniel Vetter
We already have the quirk entry for the mobile platform, but also reports on some desktop versions. So be paranoid and set it everywhere. References: http://www.mail-archive.com/dri-devel@lists.freedesktop.org/msg33138.html Cc: stable@vger.kernel.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: "Sankaran, Rajesh" <rajesh.sankaran@intel.com> Reported-and-tested-by: Mihai Moldovan <ionic@ionic.de> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
