Pull IOVA fixes from David Woodhouse:
"The main fix here is the first one, fixing the over-allocation of
size-aligned requests. The other patches simply make the existing
IOVA code available to users other than the Intel VT-d driver, with no
functional change.
I concede the latter really *should* have been submitted during the
merge window, but since it's basically risk-free and people are
waiting to build on top of it and it's my fault I didn't get it in, I
(and they) would be grateful if you'd take it"
* git://git.infradead.org/intel-iommu:
iommu: Make the iova library a module
iommu: iova: Export symbols
iommu: iova: Move iova cache management to the iova library
iommu/iova: Avoid over-allocating when size-aligned
The seq_<foo> function return values were frequently misused.
See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to
seq_has_overflowed() and make public")
All uses of these return values have been removed, so convert the
return types to void.
Miscellanea:
o Move seq_put_decimal_<type> and seq_escape prototypes closer the
other seq_vprintf prototypes
o Reorder seq_putc and seq_puts to return early on overflow
o Add argument names to seq_vprintf and seq_printf
o Update the seq_escape kernel-doc
o Convert a couple of leading spaces to tabs in seq_escape
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mark Brown <broonie@kernel.org>
Cc: Joerg Roedel <jroedel@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu updates for from Joerg Roedel:
"This time the IOMMU updates are mostly cleanups or fixes. No big new
features or drivers this time. In particular the changes include:
- Bigger cleanup of the Domain<->IOMMU data structures and the code
that manages them in the Intel VT-d driver. This makes the code
easier to understand and maintain, and also easier to keep the data
structures in sync. It is also a preparation step to make use of
default domains from the IOMMU core in the Intel VT-d driver.
- Fixes for a couple of DMA-API misuses in ARM IOMMU drivers, namely
in the ARM and Tegra SMMU drivers.
- Fix for a potential buffer overflow in the OMAP iommu driver's
debug code
- A couple of smaller fixes and cleanups in various drivers
- One small new feature: Report domain-id usage in the Intel VT-d
driver to easier detect bugs where these are leaked"
* tag 'iommu-updates-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (83 commits)
iommu/vt-d: Really use upper context table when necessary
x86/vt-d: Fix documentation of DRHD
iommu/fsl: Really fix init section(s) content
iommu/io-pgtable-arm: Unmap and free table when overwriting with block
iommu/io-pgtable-arm: Move init-fn declarations to io-pgtable.h
iommu/msm: Use BUG_ON instead of if () BUG()
iommu/vt-d: Access iomem correctly
iommu/vt-d: Make two functions static
iommu/vt-d: Use BUG_ON instead of if () BUG()
iommu/vt-d: Return false instead of 0 in irq_remapping_cap()
iommu/amd: Use BUG_ON instead of if () BUG()
iommu/amd: Make a symbol static
iommu/amd: Simplify allocation in irq_remapping_alloc()
iommu/tegra-smmu: Parameterize number of TLB lines
iommu/tegra-smmu: Factor out tegra_smmu_set_pde()
iommu/tegra-smmu: Extract tegra_smmu_pte_get_use()
iommu/tegra-smmu: Use __GFP_ZERO to allocate zeroed pages
iommu/tegra-smmu: Remove PageReserved manipulation
iommu/tegra-smmu: Convert to use DMA API
iommu/tegra-smmu: smmu_flush_ptc() wants device addresses
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
scatterlist: use sg_phys()
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
Pull ARM SoC driver updates from Olof Johansson:
"Some releases this branch is nearly empty, others we have more stuff.
It tends to gather drivers that need SoC modification or dependencies
such that they have to (also) go in through our tree.
For this release, we have merged in part of the reset controller tree
(with handshake that the parts we have merged in will remain stable),
as well as dependencies on a few clock branches.
In general, new items here are:
- Qualcomm driver for SMM/SMD, which is how they communicate with the
coprocessors on (some) of their platforms
- memory controller work for ARM's PL172 memory controller
- reset drivers for various platforms
- PMU power domain support for Marvell platforms
- Tegra support for T132/T210 SoCs: PMC, fuse, memory controller
per-SoC support"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (49 commits)
ARM: tegra: cpuidle: implement cpuidle_state.enter_freeze()
ARM: tegra: Disable cpuidle if PSCI is available
soc/tegra: pmc: Use existing pclk reference
soc/tegra: pmc: Remove unnecessary return statement
soc: tegra: Remove redundant $(CONFIG_ARCH_TEGRA) in Makefile
memory: tegra: Add Tegra210 support
memory: tegra: Add support for a variable-size client ID bitfield
clk: shmobile: rz: Add CPG/MSTP Clock Domain support
clk: shmobile: rcar-gen2: Add CPG/MSTP Clock Domain support
clk: shmobile: r8a7779: Add CPG/MSTP Clock Domain support
clk: shmobile: r8a7778: Add CPG/MSTP Clock Domain support
clk: shmobile: Add CPG/MSTP Clock Domain support
ARM: dove: create a proper PMU driver for power domains, PMU IRQs and resets
reset: reset-zynq: Adding support for Xilinx Zynq reset controller.
docs: dts: Added documentation for Xilinx Zynq Reset Controller bindings.
MIPS: ath79: Add the reset controller to the AR9132 dtsi
reset: Add a driver for the reset controller on the AR71XX/AR9XXX
devicetree: Add bindings for the ATH79 reset controller
reset: socfpga: Update reset-socfpga to read the altr,modrst-offset property
doc: dt: add documentation for lpc1850-rgu reset driver
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.3 merge window:
Enumeration:
- Allocate ATS struct during enumeration (Bjorn Helgaas)
- Embed ATS info directly into struct pci_dev (Bjorn Helgaas)
- Reduce size of ATS structure elements (Bjorn Helgaas)
- Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas)
- iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas)
- Move MPS configuration check to pci_configure_device() (Bjorn Helgaas)
- Set MPS to match upstream bridge (Keith Busch)
- ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri)
- Add pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi)
Resource management:
- Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi)
PCI device hotplug:
- pciehp: Remove unused interrupt events (Bjorn Helgaas)
- pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas)
- pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson)
- pciehp: Simplify pcie_poll_cmd() (Yijing Wang)
- Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang)
- Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang)
- Hold pci_slot_mutex while searching bus->slots list (Yijing Wang)
Power management:
- Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui)
Virtualization:
- Add ACS quirks for Intel I219-LM/V (Alex Williamson)
- Restore ACS configuration as part of pci_restore_state() (Alexander Duyck)
MSI:
- Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu)
- Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu)
- ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi)
- Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi)
Generic host bridge driver:
- Remove dependency on ARM-specific struct hw_pci (Jayachandran C)
- Build setup-irq.o for arm64 (Jayachandran C)
- Add arm64 support (Jayachandran C)
APM X-Gene host bridge driver:
- Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang)
- Add support for a 64-bit prefetchable memory window (Duc Dang)
- Drop owner assignment from platform_driver (Krzysztof Kozlowski)
Broadcom iProc host bridge driver:
- Allow BCMA bus driver to be built as module (Hauke Mehrtens)
- Delete unnecessary checks before phy calls (Markus Elfring)
- Add arm64 support (Ray Jui)
Synopsys DesignWare host bridge driver:
- Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri)
TI DRA7xx host bridge driver:
- Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I)
- Add PM support (Kishon Vijay Abraham I)
- Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I)
- Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I)
Xilinx AXI host bridge driver:
- Check for MSI interrupt flag before handling as INTx (Russell Joyce)
Miscellaneous:
- Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa)
- Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas)
- Fix generic NCR 53c810 class code quirk (Bjorn Helgaas)
- Fix TI816X class code quirk (Bjorn Helgaas)
- Remove unused "pci_probe" flags (Bjorn Helgaas)
- Host bridge driver code simplifications (Fabio Estevam)
- Add dev_flags bit to access VPD through function 0 (Mark Rustad)
- Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad)
- Kill off set_irq_flags() usage (Rob Herring)
- Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar)
- Clean up pci_find_capability() (Wei Yang)"
* tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits)
PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI
PCI: Set MPS to match upstream bridge
PCI: Move MPS configuration check to pci_configure_device()
PCI: Drop references acquired by of_parse_phandle()
PCI/MSI: Remove unused pcibios_msi_controller() hook
PCI: Add pci_scan_root_bus_msi()
ARM/PCI: Replace panic with WARN messages on failures
PCI: generic: Add arm64 support
PCI: Build setup-irq.o for arm64
PCI: generic: Remove dependency on ARM-specific struct hw_pci
PCI: imx6: Simplify a trivial if-return sequence
PCI: spear: Use BUG_ON() instead of condition followed by BUG()
PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
PCI: Remove pci_ats_enabled()
PCI: Stop caching ATS Invalidate Queue Depth
PCI: Move ATS declarations to linux/pci.h so they're all together
PCI: Clean up ATS error handling
PCI: Use pci_physfn() rather than looking up physfn by hand
'x86/amd', 'ppc/pamu' and 'core' into next
There is a bug in iommu_context_addr() which will always use
the lower context table, even when the upper context table
needs to be used. Fix this issue.
Fixes: 03ecc32c5274 ("iommu/vt-d: support extended root and context entries")
Reported-by: Xiao, Nan <nan.xiao@hp.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
'0f1fb99 iommu/fsl: Fix section mismatch' was intended to address the modpost
warning and the potential crash. Crash which is actually easy to trigger with a
'unbind' followed by a 'bind' sequence. The fix is wrong as
fsl_of_pamu_driver.driver gets added by bus_add_driver() to a couple of
klist(s) which become invalid/corrupted as soon as the init sections are freed.
Depending on when/how the init sections storage is reused various/random errors
and crashes will happen
'cd70d46 iommu/fsl: Various cleanups' contains annotations that go further down
the wrong path laid by '0f1fb99 iommu/fsl: Fix section mismatch'
Now remove all the incorrect annotations from the above mentioned patches (not
exactly a revert) and those previously existing in the code, This fixes the
modpost warning(s), the unbind/bind sequence crashes and the random
errors/crashes
Fixes: 0f1fb99b62ce ("iommu/fsl: Fix section mismatch")
Fixes: cd70d4659ff3 ("iommu/fsl: Various cleanups")
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Acked-by: Varun Sethi <Varun.Sethi@freescale.com>
Cc: stable@vger.kernel.org
Tested-by: Madalin Bucur <Madalin.Bucur@freescale.com>
When installing a block mapping, we unconditionally overwrite a non-leaf
PTE if we find one. However, this can cause a problem if the following
sequence of events occur:
(1) iommu_map called for a 4k (i.e. PAGE_SIZE) mapping at some address
- We initialise the page table all the way down to a leaf entry
- No TLB maintenance is required, because we're going from invalid
to valid.
(2) iommu_unmap is called on the mapping installed in (1)
- We walk the page table to the final (leaf) entry and zero it
- We only changed a valid leaf entry, so we invalidate leaf-only
(3) iommu_map is called on the same address as (1), but this time for
a 2MB (i.e. BLOCK_SIZE) mapping)
- We walk the page table down to the penultimate level, where we
find a table entry
- We overwrite the table entry with a block mapping and return
without any TLB maintenance and without freeing the memory used
by the now-orphaned table.
This last step can lead to a walk-cache caching the overwritten table
entry, causing unexpected faults when the new mapping is accessed by a
device. One way to fix this would be to collapse the page table when
freeing the last page at a given level, but this would require expensive
iteration on every map call. Instead, this patch detects the case when
we are overwriting a table entry and explicitly unmaps the table first,
which takes care of both freeing and TLB invalidation.
Cc: <stable@vger.kernel.org>
Reported-by: Brian Starkey <brian.starkey@arm.com>
Tested-by: Brian Starkey <brian.starkey@arm.com>
Coccinelle cleanup to replace open coded sg to physical address
translations. This is in preparation for introducing scatterlists that
reference __pfn_t.
// sg_phys.cocci: convert usage page_to_phys(sg_page(sg)) to sg_phys(sg)
// usage: make coccicheck COCCI=sg_phys.cocci MODE=patch
virtual patch
struct scatterlist *sg;
- page_to_phys(sg_page(sg)) + sg->offset
+ sg_phys(sg)
+ sg_phys(sg) & PAGE_MASK
Signed-off-by: Jens Axboe <axboe@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into arm/tegra
iommu/tegra-smmu: Changes for v4.3-rc1
A bunch of improvements by Russell King, along with a fix to restore
display support when using the SMMU. This was due to the SMMU driver
writing the wrong value of active TLB lines, effectively disabling the
TLB and causing massive underflows on the display controller because
of the latency introduced by the SMMU.
Avoid extern declarations in c files.
Found by a coccicheck script.
This fixes wrong accesses to iomem introduced by the kdump
fixing code.
These functions are only used in that file and can be
static.
The function return type is bool, so return false instead
of 0.
Symbol is only used in that file and can be static.
Allocate the irq data only in the loop.
The number of TLB lines was increased from 16 on Tegra30 to 32 on
Tegra114 and later. Parameterize the value so that the initial default
can be set accordingly.
On Tegra30, initializing the value to 32 would effectively disable the
TLB and hence cause massive latencies for memory accesses translated
through the SMMU. This is especially noticeable for isochronuous clients
such as display, whose FIFOs would continuously underrun.
Fixes: 891846516317 ("memory: Add NVIDIA Tegra memory controller support")
Signed-off-by: Thierry Reding <treding@nvidia.com>
Add the table of memory clients and SWGROUPs for Tegra210 to enable SMMU
support for this new SoC.
This code is used both when creating a new page directory entry and when
tearing it down, with only the PDE value changing between both cases.
Factor the code out so that it can be reused.
[treding@nvidia.com: make commit message more accurate]
Extract the use count reference accounting into a separate function and
separate it from allocating the PTE.
[treding@nvidia.com: extract and write commit message]
Rather than explicitly zeroing pages allocated via alloc_page(), add
__GFP_ZERO to the gfp mask to ask the allocator for zeroed pages.
Remove the unnecessary manipulation of the PageReserved flags in the
Tegra SMMU driver. None of this is required as the page(s) remain
private to the SMMU driver.
Use the DMA API instead of calling architecture internal functions in
the Tegra SMMU driver.
Pass smmu_flush_ptc() the device address rather than struct page
pointer.
smmu_flush_ptc() is used in two modes: one is to flush an individual
entry, the other is to flush all entries. We know at the call site
which we require. Split the function into smmu_flush_ptc_all() and
smmu_flush_ptc().
Drivers should not be using __cpuc_* functions nor outer_cache_flush()
directly. This change partly cleans up tegra-smmu.c.
The only difference between cache handling of the tegra variants is
Denver, which omits the call to outer_cache_flush(). This is due to
Denver being an ARM64 CPU, and the ARM64 architecture does not provide
this function. (This, in itself, is a good reason why these should not
be used.)
[treding@nvidia.com: fix build failure on 64-bit ARM]
Use kcalloc() to allocate the use-counter array for the page directory
entries/page tables. Using kcalloc() allows us to be provided with
zero-initialised memory from the allocators, rather than initialising
it ourselves.
Store the struct page pointer for the second level page tables, rather
than working back from the page directory entry. This is necessary as
we want to eliminate the use of physical addresses used with
arch-private functions, switching instead to use the streaming DMA API.
Fix the page table lookup in the unmap and iova_to_phys methods.
Neither of these methods should allocate a page table; a missing page
table should be treated the same as no mapping present.
More importantly, using as_get_pte() for an IOVA corresponding with a
non-present page table entry increments the use-count for the page
table, on the assumption that the caller of as_get_pte() is going to
setup a mapping. This is an incorrect assumption.
Fix both of these bugs by providing a separate helper which only looks
up the page table, but never allocates it. This is akin to pte_offset()
for CPU page tables.
Add a pair of helpers to get the page directory and page table indexes.
Factor out the common PTE setting code into a separate function.
The Tegra SMMU unmap path has several problems:
1. as_pte_put() can perform a write-after-free
2. tegra_smmu_unmap() can perform cache maintanence on a page we have
just freed.
3. when a page table is unmapped, there is no CPU cache maintanence of
the write clearing the page directory entry, nor is there any
maintanence of the IOMMU to ensure that it sees the page table has
gone.
Fix this by getting rid of as_pte_put(), and instead coding the PTE
unmap separately from the PDE unmap, placing the PDE unmap after the
PTE unmap has been completed.
iova_to_phys() has several problems:
(a) iova_to_phys() is supposed to return 0 if there is no entry present
for the iova.
(b) if as_get_pte() fails, we oops the kernel by dereferencing a NULL
pointer. Really, we should not even be trying to allocate a page
table at all, but should only be returning the presence of the 2nd
level page table. This will be fixed in a subsequent patch.
Treat both of these conditions as "no mapping" conditions.
When a 'struct device_domain_info' is created as an alias
for another device, this struct will not be re-used when the
real device is encountered. Fix that to avoid duplicate
device_domain_info structures being added.
For devices without an PCI alias there will be two
device_domain_info structures added. Prevent that by
checking if the alias is different from the device.
This struct contains all necessary information for the
function already. Also handle the info->dev == NULL case
while at it.
The code in the locked section does not touch anything
protected by the dmar_global_lock. Remove it from there.
When this lock is held the device_domain_lock is also
required to make sure the device_domain_info does not vanish
while in use. So this lock can be removed as it gives no
additional protection.
There is no need to make a difference here between VM and
non-VM domains, so simplify this code here.
Move the code to attach/detach domains to iommus and vice
verce into a single function to make sure there are no
dangling references.
This makes domain attachment more synchronous with domain
deattachment. The domain<->iommu link is released in
dmar_remove_one_dev_info.
This allows to do domain->iommu attachment after domain_init
has run.
Rename this function and the ones further down its
call-chain to domain_context_clear_*. In particular this
means:
iommu_detach_dependent_devices -> domain_context_clear
iommu_detach_dev_cb -> domain_context_clear_one_cb
iommu_detach_dev -> domain_context_clear_one
These names match a lot better with its
domain_context_mapping counterparts.
Rename the function to dmar_remove_one_dev_info to match is
name better with its dmar_insert_one_dev_info counterpart.
Rename this function to dmar_insert_one_dev_info() to match
the name better with its counter part function
domain_remove_one_dev_info().
