path: root/drivers/ipack/ipack.c
2016-10-27ipack: print a hex number after a 0x prefixUwe Kleine-König
It makes the result hard to interpret correctly if a base 10 number is prefixed by 0x. So change to a hex number. Link: http://lkml.kernel.org/r/20161026125658.25728-4-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Cc: Jens Taprogge <jens.taprogge@taprogge.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-23ipack: save carrier owner to allow device to get itFederico Vaga
There was not any kind of protection against carrier driver removal. In this way, device driver can 'get' the carrier driver when it is using it. Signed-off-by: Federico Vaga <federico.vaga@cern.ch> Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-16ipack: convert bus code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the ipack bus code to use the correct field. Acked-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Cc: Jens Taprogge <jens.taprogge@taprogge.org> Cc: <industrypack-devel@lists.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15ipack: split ipack_device_register() in several functionsSamuel Iglesias Gonsalvez
One function is ipack_device_init(). If it fails, the caller should execute ipack_put_device(). The second function is ipack_device_add that only adds the device. If it fails, the caller should execute ipack_put_device(). Then the device is removed with refcount = 0, as device_register() kernel documentation says. ipack_device_del() is added to remove the device. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-15ipack: add ipack_get_device() ipack_put_device()Samuel Iglesias Gonsalvez
Prepare everything for later use. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-16ipack: remove ipack_ids.h fileSamuel Iglesias Gonsalvez
Its contents are merged into ipack.h. So this file is not needed. Doing that, it simplifies the ipack-related driver development. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-16ipack: move header files to include/linuxSamuel Iglesias Gonsalvez
Move ipack header files to include/linux/ directory where they belong. Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-16Staging: ipack: move out of stagingGreg Kroah-Hartman
The ipack subsystem is cleaned up enough to now move out of the staging tree, and into drivers/ipack. Cc: Samuel Iglesias Gonsalvez <siglesias@igalia.com> Cc: Jens Taprogge <jens.taprogge@taprogge.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
