path: root/drivers/irqchip
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-08-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree changes from Jiri Kosina: "Summer edition of trivial tree updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: fix two typos in watchdog-api.txt irq-gic: remove file name from heading comment MAINTAINERS: Add miscdevice.h to file list for char/misc drivers. scsi: mvsas: mv_sas.c: Fix for possible null pointer dereference doc: replace "practise" with "practice" in Documentation befs: remove check for CONFIG_BEFS_RW scsi: doc: fix 'SCSI_NCR_SETUP_MASTER_PARITY' drivers/usb/phy/phy.c: remove a leading space mfd: fix comment cpuidle: fix comment doc: hpfall.c: fix missing null-terminate after strncpy call usb: doc: hotplug.txt code typos kbuild: fix comment in Makefile.modinst SH: add proper prompt to SH_MAGIC_PANEL_R2_VERSION ARM: msm: Remove MSM_SCM crypto: Remove MPILIB_EXTRA doc: CN: remove dead link, kerneltrap.org no longer works media: update reference, kerneltrap.org no longer works hexagon: update reference, kerneltrap.org no longer works doc: LSM: update reference, kerneltrap.org no longer works ...
2014-08-05Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "Nothing spectacular from the irq department this time: - overhaul of the crossbar chip driver - overhaul of the spear shirq chip driver - support for the atmel-aic chip - code move from arch to drivers - the usual tiny fixlets - two reverts worth to mention which undo the too simple attempt of supporting wakeup interrupts on shared interrupt lines" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) Revert "irq: Warn when shared interrupts do not match on NO_SUSPEND" Revert "PM / sleep / irq: Do not suspend wakeup interrupts" irq: Warn when shared interrupts do not match on NO_SUSPEND irqchip: atmel-aic: Define irq fixups for atmel SoCs irqchip: atmel-aic: Implement RTC irq fixup irqchip: atmel-aic: Add irq fixup infrastructure irqchip: atmel-aic: Add atmel AIC/AIC5 drivers irqchip: atmel-aic: Move binding doc to interrupt-controller directory genirq: generic chip: Export irq_map_generic_chip function PM / sleep / irq: Do not suspend wakeup interrupts irqchip: or1k-pic: Migrate from arch/openrisc/ irqchip: crossbar: Allow for quirky hardware with direct hardwiring of GIC documentation: dt: omap: crossbar: Add description for interrupt consumer irqchip: crossbar: Introduce centralized check for crossbar write irqchip: crossbar: Introduce ti, max-crossbar-sources to identify valid crossbar mapping irqchip: crossbar: Add kerneldoc for crossbar_domain_unmap callback irqchip: crossbar: Set cb pointer to null in case of error irqchip: crossbar: Change the goto naming irqchip: crossbar: Return proper error value irqchip: crossbar: Fix kerneldoc warning ...
2014-08-04Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: "Once again, Catalin's off on holiday and I'm looking after the arm64 tree. Please can you pull the following arm64 updates for 3.17? Note that this branch also includes the new GICv3 driver (merged via a stable tag from Jason's irqchip tree), since there is a fix for older binutils on top. Changes include: - context tracking support (NO_HZ_FULL) which narrowly missed 3.16 - vDSO layout rework following Andy's work on x86 - TEXT_OFFSET fuzzing for bootloader testing - /proc/cpuinfo tidy-up - preliminary work to support 48-bit virtual addresses, but this is currently disabled until KVM has been ported to use it (the patches do, however, bring some nice clean-up) - boot-time CPU sanity checks (especially useful on heterogenous systems) - support for syscall auditing - support for CC_STACKPROTECTOR - defconfig updates" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (55 commits) arm64: add newline to I-cache policy string Revert "arm64: dmi: Add SMBIOS/DMI support" arm64: fpsimd: fix a typo in fpsimd_save_partial_state ENDPROC arm64: don't call break hooks for BRK exceptions from EL0 arm64: defconfig: enable devtmpfs mount option arm64: vdso: fix build error when switching from LE to BE arm64: defconfig: add virtio support for running as a kvm guest arm64: gicv3: Allow GICv3 compilation with older binutils arm64: fix soft lockup due to large tlb flush range arm64/crypto: fix makefile rule for aes-glue-%.o arm64: Do not invoke audit_syscall_* functions if !CONFIG_AUDIT_SYSCALL arm64: Fix barriers used for page table modifications arm64: Add support for 48-bit VA space with 64KB page configuration arm64: asm/pgtable.h pmd/pud definitions clean-up arm64: Determine the vmalloc/vmemmap space at build time based on VA_BITS arm64: Clean up the initial page table creation in head.S arm64: Remove asm/pgtable-*level-types.h files arm64: Remove asm/pgtable-*level-hwdef.h files arm64: Convert bool ARM64_x_LEVELS to int ARM64_PGTABLE_LEVELS arm64: mm: Implement 4 levels of translation tables ...
2014-07-26Merge branches 'samsung/cleanup' and 'samsung/s5p-cleanup-v2', tag ↵Arnd Bergmann
'v3.16-rc6' into next/soc The following samsung branches are based on these cleanups, which are already in mainline before this branch gets pulled. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-07-25arm64: gicv3: Allow GICv3 compilation with older binutilsCatalin Marinas
GICv3 introduces new system registers accessible with the full msr/mrs syntax (e.g. mrs x0, Sop0_op1_CRm_CRn_op2). However, only recent binutils understand the new syntax. This patch introduces msr_s/mrs_s assembly macros which generate the equivalent instructions above and converts the existing GICv3 code (both drivers/irqchip/ and arch/arm64/kernel/). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Olof Johansson <olof@lixom.net> Tested-by: Olof Johansson <olof@lixom.net> Suggested-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Cc: Will Deacon <will.deacon@arm.com> Cc: Marc Zyngier <marc.zyngier@arm.com>
2014-07-25Merge tag 'deps-irqchip-gic-3.17' of git://git.infradead.org/users/jcooper/linuxCatalin Marinas
* tag 'deps-irqchip-gic-3.17' of git://git.infradead.org/users/jcooper/linux: irqchip: gic-v3: Initial support for GICv3 irqchip: gic: Move some bits of GICv2 to a library-type file Conflicts: arch/arm64/Kconfig
2014-07-19Merge tag 'exynos-cpuidle' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc Merge "Samsung exynos cpuidle update for v3.17" from Kukjin Kim: - add callbacks exynos_suspend() and exynos_powered_up() for support cpuidle through mcpm - skip exynos_cpuidle for exynos5420 because is uses cpuidle-big-liggle generic cpuidle driver - add generic functions to calculate cpu number is used for pmu and this is required for exynos5420 multi-cluster - add of_device_id structure for big.LITTLE cpuidle and add "samsung,exynos5420" compatible string for exynos5420 * tag 'exynos-cpuidle' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: populate suspend and powered_up callbacks for mcpm ARM: EXYNOS: do not allow cpuidle registration for exynos5420 cpuidle: big.LITTLE: init driver for exynos5420 cpuidle: big.LITTLE: Add ARCH_EXYNOS entry in config ARM: EXYNOS: add generic function to calculate cpu number cpuidle: big.LITTLE: add of_device_id structure + Linux 3.16-rc5 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-18Merge branch 'irqchip/atmel-aic' into irqchip/coreJason Cooper
Topic branch set up to facilitate merging the rest of the series which removes the driver from arch code.
2014-07-18Merge tag 'tags/deps-irqchip-gic-3.17' into irqchip/coreJason Cooper
From local branch irqchip/gic, this is topic branch that was set up to facilitate merging other changes depending on the new GICv3 driver.
2014-07-18irqchip: gic: Fix core ID calculation when topology is read from DTTomasz Figa
Certain GIC implementation, namely those found on earlier, single cluster, Exynos SoCs, have registers mapped without per-CPU banking, which means that the driver needs to use different offset for each CPU. Currently the driver calculates the offset by multiplying value returned by cpu_logical_map() by CPU offset parsed from DT. This is correct when CPU topology is not specified in DT and aforementioned function returns core ID alone. However when DT contains CPU topology, the function changes to return cluster ID as well, which is non-zero on mentioned SoCs and so breaks the calculation in GIC driver. This patch fixes this by masking out cluster ID in CPU offset calculation so that only core ID is considered. Multi-cluster Exynos SoCs already have banked GIC implementations, so this simple fix should be enough. Reported-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com> Fixes: db0d4db22a78d ("ARM: gic: allow GIC to support non-banked setups") Cc: <stable@vger.kernel.org> # v3.3+ Link: https://lkml.kernel.org/r/1405610624-18722-1-git-send-email-t.figa@samsung.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-17irqchip: atmel-aic: Define irq fixups for atmel SoCsBoris BREZILLON
Define SoCs that need irq fixups before enabling the AIC irqchip. At the moment we're only fixing irq generated by the RTC block, but other fixups will be added later on. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Link: https://lkml.kernel.org/r/1405016741-2407-4-git-send-email-boris.brezillon@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-17irqchip: atmel-aic: Implement RTC irq fixupBoris BREZILLON
Provide an implementation to fix RTC irqs before enabling the irqchip. This was previously done in arch/arm/mach-at91/sysirq_mask.c but as we're trying to use standard implementation (IRQCHIP_DECLARE and automatic call of irqchip_init within arch/arm/kernel/irq.c) we need to do those fixups in the irqchip driver. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Link: https://lkml.kernel.org/r/1405016741-2407-3-git-send-email-boris.brezillon@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-17irqchip: atmel-aic: Add irq fixup infrastructureBoris BREZILLON
Add irq fixup infrastructure to handle IP blocks connected to shared irqs that are left in an unknown state when booting the kernel. In this case the IP block which has not masked its interrupt and has no driver loaded (either because it is not compiled or because it is not loaded yet) might generate spurious interrupts when another IP block request the shared irq. A good example of this case is the RTC block on which register configs are kept even after a shutdown (if a proper VDDcore is supplied), and thus might generate spurious interrupts when the platform is switched on. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Link: https://lkml.kernel.org/r/1405016741-2407-2-git-send-email-boris.brezillon@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-17irqchip: atmel-aic: Add atmel AIC/AIC5 driversBoris BREZILLON
Add AIC (Advanced Interrupt Controller) and AIC5 (AIC5 is an evolution of the AIC block) drivers. Put common code in irq-atmel-aic-common.c/.h so that both driver can access shared functions (this will ease maintenance). These drivers are only compatible with dt enabled board and replace the old implementation found in arch/arm/mach-at91/irq.c. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Link: https://lkml.kernel.org/r/1405012462-766-4-git-send-email-boris.brezillon@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-17irqchip: gic: Add binding probe for ARM GIC400Suravee Suthikulpanit
Commit 3ab72f9156bb "dt-bindings: add GIC-400 binding" added the "arm,gic-400" compatible string, but the corresponding IRQCHIP_DECLARE was never added to the gic driver. Therefore add the missing irqchip declaration for it. Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Removed additional empty line and adapted commit message to mark it as fixing an issue. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Will Deacon <will.deacon@arm.com> Fixes: 3ab72f9156bb ("dt-bindings: add GIC-400 binding") Cc: <stable@vger.kernel.org> # v3.14+ Link: https://lkml.kernel.org/r/2621565.f5eISveXXJ@diego Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-12Merge tag 'ux500-core-for-v3.17-1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/cleanup Merge "Ux500 core changes for v3.17 take 1" from Linus Walleij: Some minor cleanups to the Ux500 core. DT-only probe path and some constification from static code analysis. * tag 'ux500-core-for-v3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: ARM: ux500: remove pointless cache setup complexity ARM: ux500: storage class should be before const qualifier ARM: ux500: Staticize ab8505_regulators ARM: ux500: Staticize local symbols in cpu-db8500.c ARM: ux500: Staticise ux500_soc_attr + Linux 3.16-rc4 Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-13ARM: S5PC100: no more support S5PC100 SoCKukjin Kim
This patch removes supporting codes for s5pc100 because no more used now. [jason@lakedaemon.net: for drivers/irqchip/Kconfig] Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-08irqchip: gic: Add support for cortex a7 compatible stringMatthias Brugger
Patch 0a68214b "ARM: DT: Add binding for GIC virtualization extentions (VGIC)" added the "arm,cortex-a7-gic" compatible string, but the corresponding IRQCHIP_DECLARE was never added to the gic driver. To let real Cortex-A7 SoCs use it, add the necessary declaration to the device driver. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com> Link: https://lkml.kernel.org/r/1404388732-28890-1-git-send-email-matthias.bgg@gmail.com Fixes: 0a68214b76ca ("ARM: DT: Add binding for GIC virtualization extentions (VGIC)") Cc: <stable@vger.kernel.org> # v3.5+ Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-08irqchip: gic-v3: Initial support for GICv3Marc Zyngier
The Generic Interrupt Controller (version 3) offers services that are similar to GICv2, with a number of additional features: - Affinity routing based on the CPU MPIDR (ARE) - System register for the CPU interfaces (SRE) - Support for more that 8 CPUs - Locality-specific Peripheral Interrupts (LPIs) - Interrupt Translation Services (ITS) This patch adds preliminary support for GICv3 with ARE and SRE, non-secure mode only. It relies on higher exception levels to grant ARE and SRE access. Support for LPI and ITS will be added at a later time. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Zi Shen Lim <zlim@broadcom.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Tirumalesh Chalamarla <tchalamarla@cavium.com> Reviewed-by: Yun Wu <wuyun.wu@huawei.com> Reviewed-by: Zhen Lei <thunder.leizhen@huawei.com> Tested-by: Tirumalesh Chalamarla<tchalamarla@cavium.com> Tested-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Acked-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Mark Rutland <mark.rutland@arm.com> Link: https://lkml.kernel.org/r/1404140510-5382-3-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-08irqchip: gic: Move some bits of GICv2 to a library-type fileMarc Zyngier
A few GICv2 low-level function are actually very useful to GICv3, and it makes some sense to share them across the two drivers. They end-up in their own file, with an additional parameter used to ensure an optional synchronization (unused on GICv2). Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Link: https://lkml.kernel.org/r/1404140510-5382-2-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-07-01Merge branch 'irqchip/crossbar' into irqchip/coreJason Cooper
2014-07-01irqchip: or1k-pic: Migrate from arch/openrisc/Stefan Kristiansson
In addition to consolidating the or1k-pic with other interrupt controllers, this makes OpenRISC less tied to its on-cpu interrupt controller. All or1k-pic specific parts are moved out of irq.c and into drivers/irqchip/irq-or1k-pic.c In that transition, the functionality have been divided into three chip variants. One that handles level triggered interrupts, one that handles edge triggered interrupts and one that handles the interrupt controller that is present in the or1200 OpenRISC cpu implementation. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Link: https://lkml.kernel.org/r/1401136302-27654-1-git-send-email-stefan.kristiansson@saunalahti.fi Acked-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Allow for quirky hardware with direct hardwiring of GICNishanth Menon
On certain platforms such as DRA7, SPIs 0, 1, 2, 3, 5, 6, 10, 131, 132, 133 are direct wired to hardware blocks bypassing crossbar. This quirky implementation is *NOT* supposed to be the expectation of crossbar hardware usage. However, these are already marked in our description of the hardware with SKIP and RESERVED where appropriate. Unfortunately, we need to be able to refer to these hardwired IRQs. So, to request these, crossbar driver can use the existing information from it's table that these SKIP/RESERVED maps are direct wired sources and generic allocation/programming of crossbar should be avoided. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-17-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Introduce centralized check for crossbar writeNishanth Menon
This is a basic check to ensure that crossbar register needs to be written. This ensures that we have a common check which is used in both map and unmap logic. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-15-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Introduce ti, max-crossbar-sources to identify valid ↵Nishanth Menon
crossbar mapping Currently we attempt to map any crossbar value to an IRQ, however, this is not correct from hardware perspective. There is a max crossbar event number upto which hardware supports. So describe the same in device tree using 'ti,max-crossbar-sources' property and use it to validate requests. [ jac - remove MAX_SOURCES from binding doc, use integer because we shouldn't put implementation details in the binding docs ] Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-14-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Add kerneldoc for crossbar_domain_unmap callbackSricharan R
Adding kerneldoc for unmap callback function. Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-13-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Set cb pointer to null in case of errorSricharan R
If crossbar_of_init returns with a error, then set the cb pointer to null. Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-12-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Change the goto namingNishanth Menon
Using err1,2,3,4 etc makes it hard to ensure a new exit path in the middle will not result in spurious changes, so rename the error paths as per the function it does. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-11-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Return proper error valueNishanth Menon
crossbar_of_init always returns -ENOMEM in case of errors. There can be other causes of failure like invalid data from DT. So return a appropriate error value for that case. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-10-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Fix kerneldoc warningNishanth Menon
Adding missing properties for kerneldoc (@write) and cleanup of harmless warnings while we are here. kerneldoc warnings: Warning(drivers/irqchip/irq-crossbar.c:27): missing initial short description on line: * struct crossbar_device: crossbar device description Info(drivers/irqchip/irq-crossbar.c:27): Scanning doc for struct Warning(drivers/irqchip/irq-crossbar.c:39): No description found for parameter 'write' 2 warnings Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-9-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Fix sparse and checkpatch warningsNishanth Menon
There is absolutely no need for crossbar driver to expose functions and variables into global namespace. So make them all static Also fix a couple of checkpatch warnings. Fixes sparse warnings: drivers/irqchip/irq-crossbar.c:129:29: warning: symbol 'routable_irq_domain_ops' was not declared. Should it be static? drivers/irqchip/irq-crossbar.c:261:12: warning: symbol 'irqcrossbar_init' was not declared. Should it be static? Checkpatch warnings: WARNING: Prefer kcalloc over kzalloc with multiply + cb->irq_map = kzalloc(max * sizeof(int), GFP_KERNEL); WARNING: Prefer kcalloc over kzalloc with multiply + cb->register_offsets = kzalloc(max * sizeof(int), GFP_KERNEL); Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-8-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Remove IS_ERR_VALUE checkNishanth Menon
IS_ERR_VALUE makes sense only *if* there could be valid values in negative error range. But in the cases that we do use it, there is no such case. Just remove the same. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-7-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Change allocation logic by reversing search for free irqsNishanth Menon
Reverse the search algorithm to ensure that address mapping and IRQ allocation logics are proper. This makes the below bugs visible sooner. class 1. address space errors -> example: reg = <a size_b> ti,max-irqs = is a wrong parameter class 2: irq-reserved list - which decides which entries in the address space is not actually wired in class 3: wrong list of routable-irqs. In general allocating from max to min tends to have benefits in ensuring the different issues that may be present in dts is easily caught at definition time, rather than at a later point in time. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-6-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Initialise the crossbar with a safe valueNishanth Menon
Since crossbar is s/w configurable, the initial settings of the crossbar cannot be assumed to be sane. This implies that: a) On initialization all un-reserved crossbars must be initialized to a known 'safe' value. b) When unmapping the interrupt, the safe value must be written to ensure that the crossbar mapping matches with interrupt controller usage. So provide a safe value in the dt data to map if '0' is not safe for the platform and use it during init and unmap While at this, fix the below checkpatch warning. Fixes checkpatch warning: WARNING: Unnecessary space before function pointer arguments #37: FILE: drivers/irqchip/irq-crossbar.c:37: + void (*write) (int, int); Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-5-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Introduce ti, irqs-skip to skip irqs that bypass crossbarNishanth Menon
When, in the system due to varied reasons, interrupts might be unusable due to hardware behavior, but register maps do exist, then those interrupts should be skipped while mapping irq to crossbars. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-4-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Check for premapped crossbar before allocatingNishanth Menon
If irq_of_parse_and_map is executed twice, the same crossbar is mapped to two different GIC interrupts. This is completely undesirable. Instead, check if the requested crossbar event is pre-allocated and provide that GIC mapping back to caller if already allocated. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-3-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-30irqchip: crossbar: Dont use '0' to mark reserved interruptsNishanth Menon
Today '0' is actually reserved, but may not be the same in the future. So, use a flag to mark the GIC interrupts that are reserved. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Link: https://lkml.kernel.org/r/1403766634-18543-2-git-send-email-r.sricharan@ti.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: versatile-fpga: add support for arm,versatile-sicRob Herring
The secondary controller on ARM Versatile AB and PB is similar to other ARM platforms, but has a pass-thru register to connect some interrupts directly to interrupt inputs on the primary interrupt controller. The PIC_ENABLES register needs to be configured for proper operation when the matching node is arm,versatile-sic. Add the the necessary IRQCHIP_DECLARE as well. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2014-06-24irqchip: versatile-fpga: Add IRQCHIP_DECLARE supportRob Herring
Add support for initialization using IRQCHIP_DECLARE. This also requires that the controller initialization set the handle_irq function pointer itself when it is a primary controller. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2014-06-24irqchip: spear_shirq: Simplify register access codeThomas Gleixner
The extra register data structure is pointless. Move the offsets of the status and the mask register into the shirq block structure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.923306179@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Use proper irq chips for the different SoCsThomas Gleixner
Only spear300 has an actual mask register for the RAS interrupts. Add an irq chip pointer to the shirq struct and initialize spear300 with the actual implementation and the others with dummy_irq_chip. The disabled RAS3 block has no irq chip assigned, so we can check for this and remove the disabled member. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.831341023@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Remove the parent irq "ack"/unmaskThomas Gleixner
"ack" is actually a mask in the parent irq. The demultiplexer and the handlers run with interrupts disabled. No point in masking and unmasking the parent. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.754300980@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Simplify chained handlerThomas Gleixner
I don't know if there are less efficient ways to code that. Get rid of the loop mess and use efficient code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.662897061@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Kill the clear_reg nonsenseThomas Gleixner
None of the chips has a ACK register. The code brainlessly fiddles with the enable register, so it might even reenable a disabled interrupt at least on spear300. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.570396433@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Precalculate status maskThomas Gleixner
Calculate the status mask at compile time, not at runtime. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.496614337@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Use the proper interfacesThomas Gleixner
No point in doing a full irq lookup, when the desc pointer is available. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.404243909@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Reorder the spear320 ras blocksThomas Gleixner
Order the ras blocks in the order of interrupts not alphabetically. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.310591579@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-06-24irqchip: spear_shirq: Namespace cleanupThomas Gleixner
The struct members of the shirq block struct are named to confuse the hell out of the casual reader. Clean it up. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/20140619212713.219411832@linutronix.de Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
