commit a4023f682739439b434165b54af7cb3676a4766e upstream.
The hypervisor may not have full access to the kernel data structures
and hence cannot safely use cpus_have_cap() helper for checking the
system capability. Add a safe helper for hypervisors to check a constant
system capability, which *doesn't* fall back to checking the bitmap
maintained by the kernel. With this, make the cpus_have_cap() only
check the bitmask and force constant cap checks to use the new API
for quicker checks.
Cc: Robert Ritcher <rritcher@cavium.com>
Cc: Tirumalesh Chalamarla <tchalamarla@cavium.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
[4.9: restore cpus_have_const_cap() to previously-backported code]
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
[ Upstream commit b6dd4d83dc2f78cebc9a7e6e7e4bc2be4d29b94d ]
The pr_debug() in gic-v3 gic_send_sgi() can trigger a circular locking
warning:
GICv3: CPU10: ICC_SGI1R_EL1 5000400
WARNING: possible circular locking dependency detected
4.15.0+ #1 Tainted: G W
dynamic_debug01/1873 is trying to acquire lock:
((console_sem).lock){-...}, at: [<0000000099c891ec>] down_trylock+0x20/0x4c
but task is already holding lock:
(&rq->lock){-.-.}, at: [<00000000842e1587>] __task_rq_lock+0x54/0xdc
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (&rq->lock){-.-.}:
__lock_acquire+0x3b4/0x6e0
lock_acquire+0xf4/0x2a8
_raw_spin_lock+0x4c/0x60
task_fork_fair+0x3c/0x148
sched_fork+0x10c/0x214
copy_process.isra.32.part.33+0x4e8/0x14f0
_do_fork+0xe8/0x78c
kernel_thread+0x48/0x54
rest_init+0x34/0x2a4
start_kernel+0x45c/0x488
-> #1 (&p->pi_lock){-.-.}:
_raw_spin_lock_irqsave+0x58/0x70
try_to_wake_up+0x48/0x600
wake_up_process+0x28/0x34
__up.isra.0+0x60/0x6c
up+0x60/0x68
__up_console_sem+0x4c/0x7c
console_unlock+0x328/0x634
vprintk_emit+0x25c/0x390
dev_vprintk_emit+0xc4/0x1fc
dev_printk_emit+0x88/0xa8
__dev_printk+0x58/0x9c
_dev_info+0x84/0xa8
usb_new_device+0x100/0x474
hub_port_connect+0x280/0x92c
hub_event+0x740/0xa84
process_one_work+0x240/0x70c
worker_thread+0x60/0x400
kthread+0x110/0x13c
ret_from_fork+0x10/0x18
-> #0 ((console_sem).lock){-...}:
validate_chain.isra.34+0x6e4/0xa20
__down_trylock_console_sem+0x3c/0x9c
console_trylock+0x20/0xb0
vprintk_emit+0x254/0x390
vprintk_default+0x58/0x90
vprintk_func+0xbc/0x164
printk+0x80/0xa0
__dynamic_pr_debug+0x84/0xac
gic_raise_softirq+0x184/0x18c
smp_cross_call+0xac/0x218
smp_send_reschedule+0x3c/0x48
resched_curr+0x60/0x9c
check_preempt_curr+0x70/0xdc
wake_up_new_task+0x310/0x470
_do_fork+0x188/0x78c
SyS_clone+0x44/0x50
__sys_trace_return+0x0/0x4
Chain exists of:
(console_sem).lock --> &p->pi_lock --> &rq->lock
Possible unsafe locking scenario:
CPU0 CPU1
lock(&rq->lock);
lock(&p->pi_lock);
lock(&rq->lock);
lock((console_sem).lock);
*** DEADLOCK ***
2 locks held by dynamic_debug01/1873:
#0: (&p->pi_lock){-.-.}, at: [<000000001366df53>] wake_up_new_task+0x40/0x470
#1: (&rq->lock){-.-.}, at: [<00000000842e1587>] __task_rq_lock+0x54/0xdc
stack backtrace:
CPU: 10 PID: 1873 Comm: dynamic_debug01 Tainted: G W 4.15.0+ #1
Hardware name: GIGABYTE R120-T34-00/MT30-GS2-00, BIOS T48 10/02/2017
Call trace:
dump_backtrace+0x0/0x188
show_stack+0x24/0x2c
dump_stack+0xa4/0xe0
print_circular_bug.isra.31+0x29c/0x2b8
check_prev_add.constprop.39+0x6c8/0x6dc
printk+0x80/0xa0
SyS_clone+0x44/0x50
GICv3: CPU0: ICC_SGI1R_EL1 12000
This could be fixed with printk_deferred() but that might lessen its
usefulness for debugging. So change it to pr_devel to keep it out of
production kernels. Developers working on gic-v3 can enable it as
needed in their kernels.
Signed-off-by: Mark Salter <msalter@redhat.com>
[ Upstream commit 95a2562590c2f64a0398183f978d5cf3db6d0284 ]
On some platforms there's an ITS available but it's not enabled
because reading or writing the registers is denied by the
firmware. In fact, reading or writing them will cause the system
to reset. We could remove the node from DT in such a case, but
it's better to skip nodes that are marked as "disabled" in DT so
that we can describe the hardware that exists and use the status
property to indicate how the firmware has configured things.
Cc: Stuart Yoder <stuyoder@gmail.com>
Cc: Laurentiu Tudor <laurentiu.tudor@nxp.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Rajendra Nayak <rnayak@codeaurora.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit aa08192a254d362a4d5317647a81de6996961aef upstream.
Most MMIO GIC register accesses use a 1-hot bit scheme that
avoids requiring any form of locking. This isn't true for the
GICD_ICFGRn registers, which require a RMW sequence.
Unfortunately, we seem to be missing a lock for these particular
accesses, which could result in a race condition if changing the
trigger type on any two interrupts within the same set of 16
interrupts (and thus controlled by the same CFGR register).
Introduce a private lock in the GIC common comde for this
particular case, making it cover both GIC implementations
in one go.
Cc: stable@vger.kernel.org
Signed-off-by: Aniruddha Banerjee <aniruddhab@nvidia.com>
[maz: updated changelog]
[ Upstream commit ebe2f8718007d5a1238bb3cb8141b5bb2b4d5773 ]
The ACPI specification says OS shouldn't attempt to use GICC configuration
parameters if the flag ACPI_MADT_ENABLED is cleared. The ARM64-SMP code
skips the disabled GICC entries but not causing any issue. However the
current GICv3 driver probe bails out causing kernel panic() instead of
skipping the disabled GICC interfaces. This issue happens on systems
where redistributor regions are not in the always-on power domain and
one of GICC interface marked with ACPI_MADT_ENABLED=0.
This patch does the two things to fix the panic.
- Don't return an error in gic_acpi_match_gicc() for disabled GICC entry.
- No need to keep GICR region information for disabled GICC entry.
Observed kernel crash on QDF2400 platform GICC entry is disabled.
Kernel crash traces:
Kernel panic - not syncing: No interrupt controller found.
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.13.5 #26
[<ffff000008087770>] dump_backtrace+0x0/0x218
[<ffff0000080879dc>] show_stack+0x14/0x20
[<ffff00000883b078>] dump_stack+0x98/0xb8
[<ffff0000080c5c14>] panic+0x118/0x26c
[<ffff000008b62348>] init_IRQ+0x24/0x2c
[<ffff000008b609fc>] start_kernel+0x230/0x394
[<ffff000008b601e4>] __primary_switched+0x64/0x6c
---[ end Kernel panic - not syncing: No interrupt controller found.
Disabled GICC subtable example:
Subtable Type : 0B [Generic Interrupt Controller]
Length : 50
Reserved : 0000
CPU Interface Number : 0000003D
Processor UID : 0000003D
Flags (decoded below) : 00000000
Processor Enabled : 0
Performance Interrupt Trig Mode : 0
Virtual GIC Interrupt Trig Mode : 0
Parking Protocol Version : 00000000
Performance Interrupt : 00000017
Parked Address : 0000000000000000
Base Address : 0000000000000000
Virtual GIC Base Address : 0000000000000000
Hypervisor GIC Base Address : 0000000000000000
Virtual GIC Interrupt : 00000019
Redistributor Base Address : 0000FFFF88F40000
ARM MPIDR : 000000000000000D
Efficiency Class : 00
Reserved : 000000
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
[ Upstream commit 9459a04b6a5a09967eec94a1b66f0a74312819d9 ]
The register array offset for clearing an interrupt is calculated by:
offset = (hwirq - RESERVED_IRQ_PER_MBIGEN_CHIP) / 32;
This is wrong because the clear register array includes the reserved
interrupts. So the clear operation ends up in the wrong register.
This went unnoticed so far, because the hardware clears the real bit
through a timeout mechanism when the hardware is configured in debug
mode. That debug mode was enabled on early generations of the hardware, so
the problem was papered over.
On newer hardware with updated firmware the debug mode was disabled, so the
bits did not get cleared which causes the system to malfunction.
Remove the subtraction of RESERVED_IRQ_PER_MBIGEN_CHIP, so the correct
register is accessed.
[ tglx: Rewrote changelog ]
Fixes: a6c2f87b8820 ("irqchip/mbigen: Implement the mbigen irq chip operation functions")
Signed-off-by: MaJun <majun258@huawei.com>
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Kefeng Wang <wangkefeng.wang@huawei.com>
Cc: linuxarm@huawei.com
Cc: Wei Yongjun <weiyongjun1@huawei.com>
Link: http://lkml.kernel.org/r/1494561328-39514-4-git-send-email-guohanjun@huawei.com
[ Upstream commit f8dcd9e81797ae24acc44c84f0eb3b9e6cee9791 ]
Since commit 2af70a962070 ("irqchip/mips-gic: Add a IPI hierarchy
domain") introduced the GIC IPI IRQ domain we have tracked both
reservation of interrupts & their use with a single bitmap - ipi_resrv.
If an interrupt is reserved for use as an IPI but not actually in use
then the appropriate bit is set in ipi_resrv. If an interrupt is either
not reserved for use as an IPI or has been allocated as one then the
appropriate bit is clear in ipi_resrv.
Unfortunately this means that checking whether a bit is set in ipi_resrv
to prevent IPI interrupts being allocated for use with a device is
broken, because if the interrupt has been allocated as an IPI first then
its bit will be clear.
Fix this by separating the tracking of IPI reservation & usage,
introducing a separate ipi_available bitmap for the latter. This means
that ipi_resrv will now always have bits set corresponding to all
interrupts reserved for use as IPIs, whether or not they have been
allocated yet, and therefore that checking it when allocating device
interrupts works as expected.
Fixes: 2af70a962070 ("irqchip/mips-gic: Add a IPI hierarchy domain")
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1492679256-14513-2-git-send-email-matt.redfearn@imgtec.com
commit 4f2c7583e33eb08dc09dd2e25574b80175ba7d93 upstream.
When struct its_device instances are created, the nr_ites member
will be set to a power of 2 that equals or exceeds the requested
number of MSIs passed to the msi_prepare() callback. At the same
time, the LPI map is allocated to be some multiple of 32 in size,
where the allocated size may be less than the requested size
depending on whether a contiguous range of sufficient size is
available in the global LPI bitmap.
This may result in the situation where the nr_ites < nr_lpis, and
since nr_ites is what we program into the hardware when we map the
device, the additional LPIs will be non-functional.
For bog standard hardware, this does not really matter. However,
in cases where ITS device IDs are shared between different PCIe
devices, we may end up allocating these additional LPIs without
taking into account that they don't actually work.
So let's make nr_ites at least 32. This ensures that all allocated
LPIs are 'live', and that its_alloc_device_irq() will fail when
attempts are made to allocate MSIs beyond what was allocated in
the first place.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[maz: updated comment]
[ardb: trivial tweak of unrelated context]
commit 21ec30c0ef5234fb1039cc7c7737d885bf875a9e upstream.
A DMB instruction can be used to ensure the relative order of only
memory accesses before and after the barrier. Since writes to system
registers are not memory operations, barrier DMB is not sufficient
for observability of memory accesses that occur before ICC_SGI1R_EL1
writes.
A DSB instruction ensures that no instructions that appear in program
order after the DSB instruction, can execute until the DSB instruction
has completed.
Acked-by: Will Deacon <will.deacon@arm.com>,
[ Upstream commit fa23b9d1b89fdc34f296f02e496a20aeff5736be ]
This driver uses the MSI domain but has no strict dependency on PCI_MSI, so we
may run into a build failure when CONFIG_GENERIC_MSI_IRQ_DOMAIN is disabled:
drivers/irqchip/irq-mvebu-odmi.c:152:15: error: variable 'odmi_msi_ops' has initializer but incomplete type
static struct msi_domain_ops odmi_msi_ops = {
drivers/irqchip/irq-mvebu-odmi.c:155:15: error: variable 'odmi_msi_domain_info' has initializer but incomplete type
static struct msi_domain_info odmi_msi_domain_info = {
drivers/irqchip/irq-mvebu-odmi.c:156:3: error: 'struct msi_domain_info' has no member named 'flags'
.flags = (MSI_FLAG_USE_DEF_DOM_OPS | MSI_FLAG_USE_DEF_CHIP_OPS),
drivers/irqchip/irq-mvebu-odmi.c:156:12: error: 'MSI_FLAG_USE_DEF_DOM_OPS' undeclared here (not in a function)
drivers/irqchip/irq-mvebu-odmi.c:156:39: error: 'MSI_FLAG_USE_DEF_CHIP_OPS' undeclared here (not in a function); did you mean 'MSI_FLAG_USE_DEF_DOM_OPS'?
Selecting the option from this driver seems to solve this nicely, though I could
not find any other instance of this in irqchip drivers.
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
[ Upstream commit 4b9de5da7e120c7f02395da729f0ec77ce7a6044 ]
The 'size' variable is unsigned according to the dt-bindings.
As this variable is used as integer in other places, create a new variable
that allows to fix the following sparse issue (-Wtypesign):
drivers/irqchip/irq-crossbar.c:279:52: warning: incorrect type in argument 3 (different signedness)
drivers/irqchip/irq-crossbar.c:279:52: expected unsigned int [usertype] *out_value
drivers/irqchip/irq-crossbar.c:279:52: got int *<noident>
Signed-off-by: Franck Demathieu <fdemathieu@gmail.com>
commit 00ee9a1ca5080202bc37b44e998c3b2c74d45817 upstream.
Fix child-node lookup during initialisation, which ended up searching
the whole device tree depth-first starting at the parent rather than
just matching on its children.
To make things worse, the parent gic node was prematurely freed, while
the ppi-partitions node was leaked.
Fixes: e3825ba1af3a ("irqchip/gic-v3: Add support for partitioned PPIs")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit b28ace12661fbcfd90959c1e84ff5a85113a82a1 ]
The max and entry variables are unsigned according to the dt-bindings.
Fix following 3 sparse issues (-Wtypesign):
drivers/irqchip/irq-crossbar.c:222:52: warning: incorrect type in argument 3 (different signedness)
drivers/irqchip/irq-crossbar.c:222:52: expected unsigned int [usertype] *out_value
drivers/irqchip/irq-crossbar.c:222:52: got int *<noident>
drivers/irqchip/irq-crossbar.c:245:56: warning: incorrect type in argument 4 (different signedness)
drivers/irqchip/irq-crossbar.c:245:56: expected unsigned int [usertype] *out_value
drivers/irqchip/irq-crossbar.c:245:56: got int *<noident>
drivers/irqchip/irq-crossbar.c:263:56: warning: incorrect type in argument 4 (different signedness)
drivers/irqchip/irq-crossbar.c:263:56: expected unsigned int [usertype] *out_value
drivers/irqchip/irq-crossbar.c:263:56: got int *<noident>
Cc: marc.zyngier@arm.com
Cc: jason@lakedaemon.net
Link: http://lkml.kernel.org/r/20170223094855.6546-1-fdemathieu@gmail.com
commit 2c0e8382386f618c85d20cb05e7cf7df8cdd382c upstream.
A SYNC is required between enabling the GIC region and actually trying
to use it, even if the first access is a read, otherwise its possible
depending on the timing (and in my case depending on the precise
alignment of certain kernel code) to hit CM bus errors on that first
access.
Add the SYNC straight after setting the GIC base.
[paul.burton@imgtec.com:
Changes later in this series increase our likelihood of hitting this
by reducing the amount of code that runs between enabling the GIC &
accessing it.]
Fixes: a7057270c280 ("irqchip: mips-gic: Add device-tree support")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/17019/
commit 277867ade8262583f4280cadbe90e0031a3706a7 upstream.
of_find_compatible_node() is calling of_node_put() on its first argument
thus leading to an unbalanced of_node_get/put() issue if the node has not
been retained before that.
Instead of passing the root node, pass NULL, which does exactly the same:
iterate over all DT nodes, starting from the root node.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reported-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fixes: 3d61467f9bab ("irqchip: atmel-aic: Implement RTC irq fixup")
commit 469bcef53c546bb792aa66303933272991b7831d upstream.
aic_common_irq_fixup() is calling twice of_node_put() on the same node
thus leading to an unbalanced refcount on the root node.
Fixes: b2f579b58e93 ("irqchip: atmel-aic: Add irq fixup infrastructure")
[ Upstream commit 88e20c74ee020f9e0c99dfce0dd9aa61c3f0cca0 ]
The ICOLL controller doesn't provide any facility to configure the
wakeup sources. That's the reason why this implementation lacks
the irq_set_wake implementation. But this prevent us from properly
entering power management states like "suspend to idle".
So enable the flags IRQCHIP_SKIP_SET_WAKE and
IRQCHIP_MASK_ON_SUSPEND to let the irqchip core allows and handles
the power management.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Link: https://lkml.kernel.org/r/1482863397-11400-1-git-send-email-stefan.wahren@i2se.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
[ Upstream commit 2f884e6e688a0deb69e6c9552e51aef8b7e3f5f1 ]
The below call chain generates "scheduling while atomic" backtrace and
causes system crash when Keystone 2 IRQ chip driver is used with RT-kernel:
gic_handle_irq()
|-__handle_domain_irq()
|-generic_handle_irq()
|-keystone_irq_handler()
|-regmap_read()
|-regmap_lock_spinlock()
|-rt_spin_lock()
The reason is that Keystone driver dispatches IRQ using chained IRQ handler
and accesses I/O memory through syscon->regmap(mmio) which is implemented
as fast_io regmap and uses regular spinlocks for synchronization, but
spinlocks transformed to rt_mutexes on RT.
Hence, convert Keystone 2 IRQ driver to use generic irq handler instead of
chained IRQ handler. This way it will be compatible with RT kernel where it
will be forced thread IRQ handler while in non-RT kernel it still will be
executed in HW IRQ context.
Cc: Suman Anna <s-anna@ti.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Suman Anna <s-anna@ti.com>
Link: https://lkml.kernel.org/r/20161208233310.10329-1-grygorii.strashko@ti.com
commit 866d7c1b0a3c70387646c4e455e727a58c5d465a upstream.
The GICv3 driver doesn't check if the target CPU for gic_set_affinity
is valid before going ahead and making the changes. This triggers the
following splat with KASAN:
[ 141.189434] BUG: KASAN: global-out-of-bounds in gic_set_affinity+0x8c/0x140
[ 141.189704] Read of size 8 at addr ffff200009741d20 by task swapper/1/0
[ 141.189958]
[ 141.190158] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.12.0-rc7
[ 141.190458] Hardware name: Foundation-v8A (DT)
[ 141.190658] Call trace:
[ 141.190908] [<ffff200008089d70>] dump_backtrace+0x0/0x328
[ 141.191224] [<ffff20000808a1b4>] show_stack+0x14/0x20
[ 141.191507] [<ffff200008504c3c>] dump_stack+0xa4/0xc8
[ 141.191858] [<ffff20000826c19c>] print_address_description+0x13c/0x250
[ 141.192219] [<ffff20000826c5c8>] kasan_report+0x210/0x300
[ 141.192547] [<ffff20000826ad54>] __asan_load8+0x84/0x98
[ 141.192874] [<ffff20000854eeec>] gic_set_affinity+0x8c/0x140
[ 141.193158] [<ffff200008148b14>] irq_do_set_affinity+0x54/0xb8
[ 141.193473] [<ffff200008148d2c>] irq_set_affinity_locked+0x64/0xf0
[ 141.193828] [<ffff200008148e00>] __irq_set_affinity+0x48/0x78
[ 141.194158] [<ffff200008bc48a4>] arm_perf_starting_cpu+0x104/0x150
[ 141.194513] [<ffff2000080d73bc>] cpuhp_invoke_callback+0x17c/0x1f8
[ 141.194783] [<ffff2000080d94ec>] notify_cpu_starting+0x8c/0xb8
[ 141.195130] [<ffff2000080911ec>] secondary_start_kernel+0x15c/0x200
[ 141.195390] [<0000000080db81b4>] 0x80db81b4
[ 141.195603]
[ 141.195685] The buggy address belongs to the variable:
[ 141.196012] __cpu_logical_map+0x200/0x220
[ 141.196176]
[ 141.196315] Memory state around the buggy address:
[ 141.196586] ffff200009741c00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 141.196913] ffff200009741c80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 141.197158] >ffff200009741d00: 00 00 00 00 fa fa fa fa 00 00 00 00 00 00 00 00
[ 141.197487] ^
[ 141.197758] ffff200009741d80: 00 00 00 00 00 00 00 00 fa fa fa fa 00 00 00 00
[ 141.198060] ffff200009741e00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 141.198358] ==================================================================
[ 141.198609] Disabling lock debugging due to kernel taint
[ 141.198961] CPU1: Booted secondary processor [410fd051]
This patch adds the check to make sure the cpu is valid.
Fixes: commit 021f653791ad17e03f98 ("irqchip: gic-v3: Initial support for GICv3")
commit e5c86679d5e864947a52fb31e45a425dea3e7fa9 upstream.
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 75eb5e1e7b4edbc8e8f930de59004d21cb46961f upstream.
The raw_spinlock in the IMX GPCV2 interupt chip is not initialized before
usage. That results in a lockdep splat:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
Add the missing raw_spin_lock_init() to the setup code.
Fixes: e324c4dc4a59 ("irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources")
Signed-off-by: Tyler Baker <tyler.baker@linaro.org>
Cc: shawnguo@kernel.org
Cc: andrew.smirnov@gmail.com
Link: http://lkml.kernel.org/r/20170413222731.5917-1-tyler.baker@linaro.org
commit 90922a2d03d84de36bf8a9979d62580102f31a92 upstream.
On Qualcomm Datacenter Technologies QDF2400 SoCs, the ITS hardware
implementation uses 16Bytes for Interrupt Translation Entry (ITE),
but reports an incorrect value of 8Bytes in GITS_TYPER.ITTE_size.
It might cause kernel memory corruption depending on the number
of MSI(x) that are configured and the amount of memory that has
been allocated for ITEs in its_create_device().
This patch fixes the potential memory corruption by setting the
correct ITE size to 16Bytes.
commit 34c535793bcbf9263cf22f8a52101f796cdfab8e upstream.
We did not implement an irq_cpu_offline callback for our irqchip, yet we
support setting a given IRQ's affinity. This resulted in interrupts
whose affinity mask included CPUs being taken offline not to work
correctly once the CPU had been put offline.
Fixes: 5f7f0317ed28 ("IRQCHIP: Add new driver for BCM7038-style level 1 interrupt controllers")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: cernekee@gmail.com
Cc: jaedon.shin@gmail.com
Cc: ralf@linux-mips.org
Cc: justinpopo6@gmail.com
Link: http://lkml.kernel.org/r/1477948656-12966-2-git-send-email-f.fainelli@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/urgent
Pull GIC updates from Marc Zyngier:
- Fix for 32bit accesses that should be 64bit on 64bit machines
- Fix for a field decoding macro
- Beautify a warning message
It really looks bad without a newline.
Core drivers for J-Core SoCs will be selected implicitly via
CONFIG_SH_JCORE_SOC instead. Based on a corresponding change to the
clocksource/timer driver requested by Daniel Lezcano.
Signed-off-by: Rich Felker <dalias@libc.org>
Cc: linux-sh@vger.kernel.org
Link: http://lkml.kernel.org/r/883a3d17084003e3cf21bab73ec12828fe4ff6c6.1476899495.git.dalias@libc.org
There is no need to have the 'struct irq_domain *nps400_root_domain'
variable static since new value is always assigned before use.
Fixes: 44df427c894a ("irqchip: add nps Internal and external irqchips")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Link: http://lkml.kernel.org/r/1476714417-12095-1-git-send-email-weiyj.lk@gmail.com
Pull irq fixes from Ingo Molnar:
"Three irqchip driver fixes"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/gicv3: Handle loop timeout proper
irqchip/jcore: Fix lost per-cpu interrupts
irqchip/eznps: Acknowledge NPS_IPI before calling the handler
The GICv3 architecture specification mentions that a 64bit
register can be accessed using two 32bit accesses. What it
doesn't mention is that this is only guaranteed on a system
that implements AArch32, and a pure AArch64 system is allowed
not to support this. This causes issues with the GICR_TYPER
and GITS_TYPER registers, which are both RO 64bit registers.
In order to solve this, this patch switches the TYPER accesses
to the gic_read_typer macro already used in other parts of the
driver. This makes sure that we always use a 64bit access on
64bit systems, and two 32bit accesses on 32bit system.
Pull MIPS updates from Ralf Baechle:
"This is the main MIPS pull request for 4.9:
MIPS core arch code:
- traps: 64bit kernels should read CP0_EBase 64bit
- traps: Convert ebase to KSEG0
- c-r4k: Drop bc_wback_inv() from icache flush
- c-r4k: Split user/kernel flush_icache_range()
- cacheflush: Use __flush_icache_user_range()
- uprobes: Flush icache via kernel address
- KVM: Use __local_flush_icache_user_range()
- c-r4k: Fix flush_icache_range() for EVA
- Fix -mabi=64 build of vdso.lds
- VDSO: Drop duplicated -I*/-E* aflags
- tracing: move insn_has_delay_slot to a shared header
- tracing: disable uprobe/kprobe on compact branch instructions
- ptrace: Fix regs_return_value for kernel context
- Squash lines for simple wrapper functions
- Move identification of VP(E) into proc.c from smp-mt.c
- Add definitions of SYNC barrierstype values
- traps: Ensure full EBase is written
- tlb-r4k: If there are wired entries, don't use TLBINVF
- Sanitise coherentio semantics
- dma-default: Don't check hw_coherentio if device is non-coherent
- Support per-device DMA coherence
- Adjust MIPS64 CAC_BASE to reflect Config.K0
- Support generating Flattened Image Trees (.itb)
- generic: Introduce generic DT-based board support
- generic: Convert SEAD-3 to a generic board
- Enable hardened usercopy
- Don't specify STACKPROTECTOR in defconfigs
Octeon:
- Delete dead code and files across the platform.
- Change to use all memory into use by default.
- Rename upper case variables in setup code to lowercase.
- Delete legacy hack for broken bootloaders.
- Leave maintaining the link state to the actual ethernet/PHY drivers.
- Add DTS for D-Link DSR-500N.
- Fix PCI interrupt routing on D-Link DSR-500N.
Pistachio:
- Remove ANDROID_TIMED_OUTPUT from defconfig
TX39xx:
- Move GPIO setup from .mem_setup() to .arch_init()
- Convert to Common Clock Framework
TX49xx:
txx9wdt:
- Add missing clock (un)prepare calls for CCF
BMIPS:
- Add PW, GPIO SDHCI and NAND device node names
- Support APPENDED_DTB
- Add missing bcm97435svmb to DT_NONE
- Rename bcm96358nb4ser to bcm6358-neufbox4-sercom
- Add DT examples for BCM63268, BCM3368 and BCM6362
- Add support for BCM3368 and BCM6362
PCI
- Reduce stack frame usage
- Use struct list_head lists
- Support for CONFIG_PCI_DOMAINS_GENERIC
- Make pcibios_set_cache_line_size an initcall
- Inline pcibios_assign_all_busses
- Split pci.c into pci.c & pci-legacy.c
- Introduce CONFIG_PCI_DRIVERS_LEGACY
- Support generic drivers
CPC
- Convert bare 'unsigned' to 'unsigned int'
- Avoid lock when MIPS CM >= 3 is present
GIC:
- Delete unused file smp-gic.c
mt7620:
- Delete unnecessary assignment for the field "owner" from PCI
BCM63xx:
- Let clk_disable() return immediately if clk is NULL
pm-cps:
- Change FSB workaround to CPU blacklist
- Update comments on barrier instructions
- Use MIPS standard lightweight ordering barrier
- Use MIPS standard completion barrier
- Remove selection of sync types
- Add MIPSr6 CPU support
- Support CM3 changes to Coherence Enable Register
SMP:
- Wrap call to mips_cpc_lock_other in mips_cm_lock_other
- Introduce mechanism for freeing and allocating IPIs
cpuidle:
- cpuidle-cps: Enable use with MIPSr6 CPUs.
SEAD3:
- Rewrite to use DT and generic kernel feature.
USB:
- host: ehci-sead3: Remove SEAD-3 EHCI code
FBDEV:
- cobalt_lcdfb: Drop SEAD3 support
dt-bindings:
- Document a binding for simple ASCII LCDs
auxdisplay:
- img-ascii-lcd: driver for simple ASCII LCD displays
irqchip i8259:
- i8259: Add domain before mapping parent irq
- i8259: Allow platforms to override poll function
- i8259: Remove unused i8259A_irq_pending
Malta:
- Rewrite to use DT
of/platform:
- Probe "isa" busses by default
CM:
- Print CM error reports upon bus errors
Module:
- Migrate exception table users off module.h and onto extable.h
- Make various drivers explicitly non-modular:
- Audit and remove any unnecessary uses of module.h
mailmap:
- Canonicalize to Qais' current email address.
Documentation:
- MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
Loongson1C:
- Add CPU support for Loongson1C
- Add board support
- Add defconfig
- Add RTC support for Loongson1C board
All this except one Documentation fix has sat in linux-next and has
survived Imagination's automated build test system"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits)
Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
MIPS: ptrace: Fix regs_return_value for kernel context
MIPS: VDSO: Drop duplicated -I*/-E* aflags
MIPS: Fix -mabi=64 build of vdso.lds
MIPS: Enable hardened usercopy
MIPS: generic: Convert SEAD-3 to a generic board
MIPS: generic: Introduce generic DT-based board support
MIPS: Support generating Flattened Image Trees (.itb)
MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0
MIPS: Print CM error reports upon bus errors
MIPS: Support per-device DMA coherence
MIPS: dma-default: Don't check hw_coherentio if device is non-coherent
MIPS: Sanitise coherentio semantics
MIPS: PCI: Support generic drivers
MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY
MIPS: PCI: Split pci.c into pci.c & pci-legacy.c
MIPS: PCI: Inline pcibios_assign_all_busses
MIPS: PCI: Make pcibios_set_cache_line_size an initcall
MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC
MIPS: PCI: Use struct list_head lists
The timeout loop terminates when the loop count is zero, but the decrement
of the count variable is post check. So count is -1 when we check for the
timeout and therefor the error message is supressed.
Change it to predecrement, so the error message is emitted.
[ tglx: Massaged changelog ]
Fixes: a2c225101234 ("irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Cc: kernel-janitors@vger.kernel.org
Link: http://lkml.kernel.org/r/20161014072534.GA15168@mwanda
The J-Core AIC does not have separate interrupt numbers reserved for
cpu-local vs global interrupts. Instead, the driver requesting the irq
is expected to know whether its device uses per-cpu interrupts or not.
Previously it was assumed that handle_simple_irq could work for both
cases, but it intentionally drops interrupts for an irq number that
already has a handler running. This resulted in the timer interrupt
for one cpu being lost when multiple cpus' timers were set for
approximately the same expiration time, leading to stalls. In theory
the same could also happen with IPIs.
To solve the problem, instead of registering handle_simple_irq as the
handler, register a wrapper function which checks whether the irq to
be handled was requested as per-cpu or not, and passes it to
handle_simple_irq or handle_percpu_irq accordingly.
Fixes: 981b58f66cfc ("irqchip/jcore-aic: Add J-Core AIC driver")
Link: http://lkml.kernel.org/r/f18cec30bc17e3f52e478dd9f6714bfab02f227f.1476390724.git.dalias@libc.org
IPI_IRQ (also TIMER0_IRQ) should be acked before the action->handler is called
in handle_percpu_devid_irq.
The IPI irq is edge sensitive and we might miss an IPI interrupt if it is
triggered again while the handler runs.
Signed-off-by: Noam Camus <noamca@mellanox.com>
Link: http://lkml.kernel.org/r/1476364532-12634-1-git-send-email-noamca@mellanox.com
Merge more updates from Andrew Morton:
- a few block updates that fell in my lap
- lib/ updates
- checkpatch
- autofs
- ipc
- a ton of misc other things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits)
mm: split gfp_mask and mapping flags into separate fields
fs: use mapping_set_error instead of opencoded set_bit
treewide: remove redundant #include <linux/kconfig.h>
hung_task: allow hung_task_panic when hung_task_warnings is 0
kthread: add kerneldoc for kthread_create()
kthread: better support freezable kthread workers
kthread: allow to modify delayed kthread work
kthread: allow to cancel kthread work
kthread: initial support for delayed kthread work
kthread: detect when a kthread work is used by more workers
kthread: add kthread_destroy_worker()
kthread: add kthread_create_worker*()
kthread: allow to call __kthread_create_on_node() with va_list args
kthread/smpboot: do not park in kthread_create_on_cpu()
kthread: kthread worker API cleanup
kthread: rename probe_kthread_data() to kthread_probe_data()
scripts/tags.sh: enable code completion in VIM
mm: kmemleak: avoid using __va() on addresses that don't have a lowmem mapping
kdump, vmcoreinfo: report memory sections virtual addresses
ipc/sem.c: add cond_resched in exit_sme
Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- support for interrupt virtualization in the AMD IOMMU driver. These
patches were shared with the KVM tree and are already merged through
that tree.
- generic DT-binding support for the ARM-SMMU driver. With this the
driver now makes use of the generic DMA-API code. This also required
some changes outside of the IOMMU code, but these are acked by the
respective maintainers.
- more cleanups and fixes all over the place.
* tag 'iommu-updates-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (40 commits)
iommu/amd: No need to wait iommu completion if no dte irq entry change
iommu/amd: Free domain id when free a domain of struct dma_ops_domain
iommu/amd: Use standard bitmap operation to set bitmap
iommu/amd: Clean up the cmpxchg64 invocation
iommu/io-pgtable-arm: Check for v7s-incapable systems
iommu/dma: Avoid PCI host bridge windows
iommu/dma: Add support for mapping MSIs
iommu/arm-smmu: Set domain geometry
iommu/arm-smmu: Wire up generic configuration support
Docs: dt: document ARM SMMU generic binding usage
iommu/arm-smmu: Convert to iommu_fwspec
iommu/arm-smmu: Intelligent SMR allocation
iommu/arm-smmu: Add a stream map entry iterator
iommu/arm-smmu: Streamline SMMU data lookups
iommu/arm-smmu: Refactor mmu-masters handling
iommu/arm-smmu: Keep track of S2CR state
iommu/arm-smmu: Consolidate stream map entry state
iommu/arm-smmu: Handle stream IDs more dynamically
iommu/arm-smmu: Set PRIVCFG in stage 1 STEs
iommu/arm-smmu: Support non-PCI devices with SMMUv3
Pull irq fixes from Thomas Gleixner:
"Two small kerneldoc fixes from Julia Lawall"
irqchip/metag-ext: Improve function-level documentation
irqchip/vic: Improve function-level documentation
Pull ARM SoC cleanups from Arnd Bergmann:
"The cleanups for v4.9 are a little larger that usual, but thankfully
that is almost exclusively due to removing a significant number of
files that have become obsolete after the still ongoing conversion of
old board files to devicetree.
- for mach-omap2, which is still the largest platform in arch/arm/,
the conversion to DT is finally complete after the Nokia N900 is
now fully supported there, along with the omap3 LDP, and we can
remove those two board files. If no regressions are found, another
large cleanup for the platform will happen as a follow-up, removing
dead code and restructuring the platform based on being DT-only.
- In mach-imx, similar work is ongoing, but has not come that far.
This time, we remove the obsolete board file for the i.MX1
generation, which like i.MX25, i.MX5, i.MX6, and i.MX7 is now
DT-only. The remaining board files are for i.MX2 and i.MX3 machines
based on old ARM926 or ARM1136 cores that should work with DT in
principle.
- realview has just been converted from board files to DT, and a lot
of code gets removed in the process. This is the last
ARM/Keil/Versatile derived platform that was still using board
files, the other ones being integrator, versatile and vexpress. We
can probably merge the remaining code into a single directory in
the near future.
- clps711x had completed the conversion in v4.8, but we accidentally
left the files in place that should have been deleted then"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits)
ARM: select PCI_DOMAINS config from ARCH_MULTIPLATFORM
ARM: stop *MIGHT_HAVE_PCI* config from being selected redundantly
ARM: imx: (trivial) fix typo and grammar
ARM: clps711x: remove extraneous files
ARM: imx: use IS_ENABLED() instead of checking for built-in or module
ARM: OMAP2+: use IS_ENABLED() instead of checking for built-in or module
ARM: OMAP1: use IS_ENABLED() instead of checking for built-in or module
ARM: imx: remove platform-mxc_rnga
ARM: realview: imply device tree boot
ARM: realview: no need to select SMP_ON_UP explicitly
ARM: realview: delete the RealView board files
ARM: imx: no need to select SMP_ON_UP explicitly
ARM: i.MX: Move SOC_IMX1 into 'Device tree only'
ARM: i.MX: Remove i.MX1 non-DT support
ARM: i.MX: Remove i.MX1 Synertronixx SCB9328 board support
ARM: i.MX: Remove i.MX1 Armadeus APF9328 board support
ARM: mxs: remove obsolete startup code for TX28
ARM: i.MX31 iomux: remove duplicates with alternate name
ARM: i.MX31 iomux: remove plain duplicates
ARM: OMAP2+: Drop legacy board file for LDP
The i8259A_irq_pending function is unused. Remove the dead code.
Patchwork: https://patchwork.linux-mips.org/patch/14271/
The default i8259 polling function (i8259_irq) is nicely generic but is
fairly costly. Platforms often provide an alternative means of polling
for an i8259 interrupt, and when using the i8259 without device tree
have typically just chained its parent interrupt to their own handler
function. In order to allow for platform-specific polling functions to
be used in cases where the driver is probed via device tree, provide an
i8259_set_poll function that accepts a pointer to an alternative poll
function that will override the default.
Patchwork: https://patchwork.linux-mips.org/patch/14270/
Mapping the parent IRQ will use a virq number which may conflict with
the hardcoded I8259A_IRQ_BASE..I8259A_IRQ_BASE+15 range that the i8259
driver expects to be free. If this occurs then we'll hit errors when
adding the i8259 IRQ domain, since one of its virq numbers will already
be in use.
Avoid this by adding the i8259 domain before mapping the parent IRQ,
such that the i8259 virq numbers become used before the parent interrupt
controller gets a chance to use any of them.
Patchwork: https://patchwork.linux-mips.org/patch/14269/
Drop the variable irq which ceased to be a parameter.
Issue detected using Coccinelle (http://coccinelle.lip6.fr/)
Fixes: bd0b9ac405e1 ("genirq: Remove irq argument from irq flow handlers").
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-metag@vger.kernel.org
Link: http://lkml.kernel.org/r/1475351192-27079-15-git-send-email-Julia.Lawall@lip6.fr
The associated function, vic_init_cascaded, has never had a variable
irq_start.
Link: http://lkml.kernel.org/r/1475351192-27079-14-git-send-email-Julia.Lawall@lip6.fr
into irq/core
Pull irqchip core changes for v4.9 from Jason Cooper
- jcore: Add AIC driver
- mips-gic: Use for_each_set_bit
- mvebu: Add PIC driver
The STM32 external interrupt controller consists of edge detectors that
generate interrupts requests or wake-up events.
Each line can be independently configured as interrupt or wake-up source,
and triggers either on rising, falling or both edges. Each line can also
be masked independently.
Originally-from: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Signed-off-by: Alexandre TORGUE <alexandre.torgue@st.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: devicetree@vger.kernel.org
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: arnd@arndb.de
Cc: bruherrera@gmail.com
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: linux-gpio@vger.kernel.org
Cc: Rob Herring <robh+dt@kernel.org>
Cc: lee.jones@linaro.org
Link: http://lkml.kernel.org/r/1474387259-18926-3-git-send-email-alexandre.torgue@st.com
The MIPS GIC driver has previously iterated over bits set in a bitmap
representing pending local IRQs by calling find_first_bit, clearing that
bit then calling find_first_bit again until all bits are clear. If
multiple interrupts are pending then this is wasteful, as find_first_bit
will have to loop over the whole bitmap from the start. Use the
for_each_set_bit macro which performs exactly what we need here instead.
It will use find_next_bit and thus only scan over the relevant part of
the bitmap, and it makes the intent of the code clearer.
This makes the same change for local interrupts that commit cae750bae4e4
("irqchip: mips-gic: Use for_each_set_bit to iterate over IRQs") made
for shared interrupts.
Link: http://lkml.kernel.org/r/20160913165427.31686-1-paul.burton@imgtec.com
Merge urgent fixes so pending patches for 4.9 can be applied.
Since the device hierarchy domain was added by commit c98c1822ee13
("irqchip/mips-gic: Add device hierarchy domain"), GIC local interrupts
have been broken.
Users attempting to setup a per-cpu local IRQ, for example the GIC timer
clock events code in drivers/clocksource/mips-gic-timer.c, the
setup_percpu_irq function would refuse with -EINVAL because the GIC
irqchip driver never called irq_set_percpu_devid so the
IRQ_PER_CPU_DEVID flag was never set for the IRQ. This happens because
irq_set_percpu_devid was being called from the gic_irq_domain_map
function which is no longer called.
Doing only that runs into further problems because gic_dev_domain_alloc
set the struct irq_chip for all interrupts, local or shared, to
gic_level_irq_controller despite that only being suitable for shared
interrupts. The typical outcome of this is that gic_level_irq_controller
callback functions are called for local interrupts, and then hwirq
number calculations overflow & the driver ends up attempting to access
some invalid register with an address calculated from an invalid hwirq
number. Best case scenario is that this then leads to a bus error. This
is fixed by abstracting the setup of the hwirq & chip to a new function
gic_setup_dev_chip which is used by both the root GIC IRQ domain & the
device domain.
Finally, decoding local interrupts failed because gic_dev_domain_alloc
only called irq_domain_alloc_irqs_parent for shared interrupts. Local
ones were therefore never associated with hwirqs in the root GIC IRQ
domain and the virq in gic_handle_local_int would always be 0. This is
fixed by calling irq_domain_alloc_irqs_parent unconditionally & having
gic_irq_domain_alloc handle both local & shared interrupts, which is
easy due to the aforementioned abstraction of chip setup into
gic_setup_dev_chip.
This fixes use of the MIPS GIC timer for clock events, which has been
broken since c98c1822ee13 ("irqchip/mips-gic: Add device hierarchy
domain") but hadn't been noticed due to a silent fallback to the MIPS
coprocessor 0 count/compare clock events device.
Fixes: c98c1822ee13 ("irqchip/mips-gic: Add device hierarchy domain")
Cc: Qais Yousef <qsyousef@gmail.com>
Link: http://lkml.kernel.org/r/20160913165335.31389-1-paul.burton@imgtec.com
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into arm/smmu
gic_raise_softirq() walks the list of cpus using for_each_cpu(), it calls
gic_compute_target_list() which advances the iterator by the number of
CPUs in the cluster.
If gic_compute_target_list() reaches the last CPU it leaves the iterator
pointing at the last CPU. This means the next time round the for_each_cpu()
loop cpumask_next() will be called with an invalid CPU.
This triggers a warning when built with CONFIG_DEBUG_PER_CPU_MAPS:
[ 3.077738] GICv3: CPU1: found redistributor 1 region 0:0x000000002f120000
[ 3.077943] CPU1: Booted secondary processor [410fd0f0]
[ 3.078542] ------------[ cut here ]------------
[ 3.078746] WARNING: CPU: 1 PID: 0 at ../include/linux/cpumask.h:121 gic_raise_softirq+0x12c/0x170
[ 3.078812] Modules linked in:
[ 3.078869]
[ 3.078930] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.8.0-rc5+ #5188
[ 3.078994] Hardware name: Foundation-v8A (DT)
[ 3.079059] task: ffff80087a1a0080 task.stack: ffff80087a19c000
[ 3.079145] PC is at gic_raise_softirq+0x12c/0x170
[ 3.079226] LR is at gic_raise_softirq+0xa4/0x170
[ 3.079296] pc : [<ffff0000083ead24>] lr : [<ffff0000083eac9c>] pstate: 200001c9
[ 3.081139] Call trace:
[ 3.081202] Exception stack(0xffff80087a19fbe0 to 0xffff80087a19fd10)
[ 3.082269] [<ffff0000083ead24>] gic_raise_softirq+0x12c/0x170
[ 3.082354] [<ffff00000808e614>] smp_send_reschedule+0x34/0x40
[ 3.082433] [<ffff0000080e80a0>] resched_curr+0x50/0x88
[ 3.082512] [<ffff0000080e89d0>] check_preempt_curr+0x60/0xd0
[ 3.082593] [<ffff0000080e8a60>] ttwu_do_wakeup+0x20/0xe8
[ 3.082672] [<ffff0000080e8bb8>] ttwu_do_activate+0x90/0xc0
[ 3.082753] [<ffff0000080ea9a4>] try_to_wake_up+0x224/0x370
[ 3.082836] [<ffff0000080eabc8>] default_wake_function+0x10/0x18
[ 3.082920] [<ffff000008103134>] __wake_up_common+0x5c/0xa0
[ 3.083003] [<ffff0000081031f4>] __wake_up_locked+0x14/0x20
[ 3.083086] [<ffff000008103f80>] complete+0x40/0x60
[ 3.083168] [<ffff00000808df7c>] secondary_start_kernel+0x15c/0x1d0
[ 3.083240] [<00000000808911a4>] 0x808911a4
[ 3.113401] Detected PIPT I-cache on CPU2
Avoid updating the iterator if the next call to cpumask_next() would
cause the for_each_cpu() loop to exit.
There is no change to gic_raise_softirq()'s behaviour, (cpumask_next()s
eventual call to _find_next_bit() will return early as start >= nbits),
this patch just silences the warning.
Fixes: 021f653791ad ("irqchip: gic-v3: Initial support for GICv3")
Signed-off-by: James Morse <james.morse@arm.com>
Link: http://lkml.kernel.org/r/1474306155-3303-1-git-send-email-james.morse@arm.com
