path: root/drivers/isdn/gigaset/interface.c
2007-02-12[PATCH] drivers/isdn/gigaset: reduce mutex scopeTilman Schmidt
Do not lock the cardstate structure mutex earlier than necessary. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01Driver core: convert tty core to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Also fixes up the isdn drivers that were putting something in the class device's directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] i4l gigaset: move sysfs entry to tty class deviceHansjoerg Lipp
Using the class device pointer returned by tty_register_device() with part 1 of the patch, attach the Gigaset drivers' "cidmode" sysfs entry to its tty class device, where it can be found more easily by users who do not know nor care which USB port the device is attached to. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: make some variables non-atomicTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Replace some atomic_t variables in the Gigaset drivers by non-atomic ones, using spinlocks instead to assure atomicity, as proposed in discussions on the linux-kernel mailing list. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: mutex conversionTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Convert the semaphores used by the Gigaset drivers to mutexes. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: eliminate from_user argumentTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Eliminate the from_user argument from a debugging function, thus easing the job of sparse. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: logging usageTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Improve error reporting of the Gigaset drivers, by using the dev_err/dev_warn/dev_info macros from device.h instead of err/warn/info from usb.h whereever possible. Also rename the private dbg macro to gig_dbg in order to avoid confusion with the macro of the same name in usb.h. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] isdn4linux: Siemens Gigaset drivers: code cleanupTilman Schmidt
With Hansjoerg Lipp <hjlipp@web.de> Source code formatting cleanups for the Siemens Gigaset drivers, such as line length, comments, removal of unused declarations, and typo corrections. It does not introduce any functional changes. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] isdn4linux: Siemens Gigaset drivers - tty interfaceHansjoerg Lipp
And: Tilman Schmidt <tilman@imap.cc> This patch adds the tty interface to the gigaset module. The tty interface provides direct access to the AT command set of the Gigaset devices. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
