Registering/unregistering the Gigaset CAPI driver when a device is
connected/disconnected causes an Oops when disconnecting two Gigaset
devices in a row, because the same capi_driver structure gets
unregistered twice. Fix by making driver registration/unregistration
a separate operation (empty in the ISDN4Linux case) called when the
main module is loaded/unloaded.
Impact: bugfix
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Acked-by: Karsten Keil <keil@b1-systems.de>
CC: stable@kernel.org
Samll cleanup in drivers/isdn/gigaset/capi.c where own implementation of
isxdigit() has been changed to kernel native one.
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com>
Acked-by: Tilman Schmidt <tilman@imap.cc>
Improve readability of the Gigaset driver's kernel messages by
removing a few unnecessary messages and limiting the emission
of some debug messages more narrowly.
Impact: logging
Copy the mechanism from ser_/usb_gigaset to avoid producing
spurious empty responses for CR/LF sequences from the device.
Add a comment in all drivers documenting that behaviour.
Correct an off by one error that might result in a one byte
buffer overflow when receiving an unexpectedly long reply.
Impact: minor bugfix
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
[akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix]
Signed-off-by: Karsten Keil <keil@b1-systems.de>
When built with debugging support, the Gigaset driver enabled some
debugging messages by default. Change the default to "all off".
second arg
Changed function pointer use from non-majority address-of style
to majority short form without & via:
grep -rPl "\btasklet_init\s*\([^,\)]+,\s*\&" drivers/isdn | while read file ; do \
perl -i -e 'local $/; while (<>) { s@(\btasklet_init\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\
done
Compile tested allyesconfig x86
drivers/isdn/gigaset/bas-gigaset.c | 4 ++--
drivers/isdn/gigaset/common.c | 2 +-
drivers/isdn/gigaset/interface.c | 2 +-
drivers/isdn/gigaset/ser-gigaset.c | 2 +-
drivers/isdn/gigaset/usb-gigaset.c | 2 +-
5 files changed, 6 insertions(+), 6 deletions(-)
Replace the sequence of strcmp calls for interpreting ZSAU parameter
strings by a table of known strings and lookup loop to improve
readability.
Impact: readability improvement, no functional change
On more step towards the holy grail of checkpatch.pl silence.
Impact: cosmetic
On the quest for the holy grail of checkpatch.pl silence.
Impact: cosmetic
Duly uglified as demanded by checkpatch.pl.
Impact: cosmetic
Dum sanctis checkpatch.pl'ae legibus obsequimur.
Impact: cosmetic
Reorganize the code of the Gigaset M10x driver to make it more
readable, less redundant, better aligned to the style of other
parts of the driver, and cause fewer checkpatch.pl complaints.
Impact: code reorganization, no functional change
The CAPI interface incorrectly assumed that CAPI messages would always
start at the beginning of the data buffer: fix by treating DATA_B3
messages as the link layer header to their payload data. This fix
changes the way acknowledgement information is propagated through the
hardware specific modules and thereby impacts the ISDN4Linux variant
of the driver, too.
Also some assumptions about methods not being called from interrupt
context turned out to be unwarranted; fix by using dev_kfree_skb_any()
wherever non-interrupt context isn't guaranteed.
Impact: bugfix
A missing dot lead to garbage characters being included in the
dial command generated from a CAPI CONNECT_REQ message, which
interestingly enough worked anyway, illustrating the resilience
of the device.
Impact: bugfix
Replace the "ignoring Additional Info" warning message by better
readable ones citing the specific subparameters being ignored.
Make parts of the code more readable by using a local cmsg
pointer variable.
Add a Kernel CAPI interface to the Gigaset driver.
Impact: optional new functionality
Add a dummy LL interface to the Gigaset driver so that it can be
built and, in a limited way, used without the ISDN4Linux subsystem.
Impact: new configuration alternative
Reorganize the code of the Gigaset driver, moving all isdn4linux
dependencies to the source file i4l.c so that it can be replaced
by a file capi.c interfacing to Kernel CAPI instead.
Impact: refactoring, no functional change
Add kerneldoc comments to some functions in the Gigaset driver.
Impact: documentation
Dump payload data consistently only when DEBUG_STREAM_DUMP debug bit
is set.
Impact: debugging aid
When the Gigaset base stops responding, try resetting the USB
connection to recover.
Impact: error handling improvement
Clear out pending command that got rejected with 'ERROR' response.
This fixes the bug where unloading the driver module would hang
with the message: "gigaset: not searching scheduled commands: busy"
after a device communication error.
Impact: error handling bugfix
Mention in the driver load announcement whether the driver was built
with debugging messages enabled, to facilitate support.
Impact: informational message
Don't drop the remainder of an URB if an isochronous frame has an error.
The code of the Gigaset driver assumes that sk_buff-s coming
from the ISDN4Linux subsystem are always linear. Explicitly
calling skb_linearize() is cheap if they are, but much more
robust in case they ever aren't.
Impact: robustness improvement
Signal D channel disconnect in a few cases where it was missed,
including when an incoming call is disconnected before it was
accepted.
The tty_operation chars_in_buffer() is not allowed to return a negative
value to signal an error. Corrects the problem flagged by commit
23198fda7182969b619613a555f8645fdc3dc334, "tty: fix chars_in_buffers".
Cc: stable <stable@kernel.org>
This function does not have an error return and returning an error is
instead interpreted as having a lot of pending bytes.
Reported by Jeff Harris who provided a list of some of the remaining
offenders.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Drop a sanity check which doesn't serve any useful purpose anymore.
ISDN connection setup failed if the "connection active" and
"B channel up" messages from the device arrived in a different
order than expected. Modify the state machine to accept them in
any order.
Impact: bugfix
CC: stable <stable@kernel.org>
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/iwlwifi/iwl-agn.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The B channel data structure member rcvbytes was never set to
anything else but zero, so drop it.
Impact: cleanup
Drop the kernel config option GIGASET_UNDOCREQ, permanently
activating the code it controlled, as there have been no reports
of problems caused by its activation but many problems caused by
it being disabled.
Also fix a few bad comments while we're at it.
Impact: cleanup
In preparation for porting to kernel CAPI subsystem, include the
Gigaset driver's Kconfig directly from ISDN's instead of I4L's.
Impact: Kconfig reorganisation, no functional change
gigaset_register_to_LL() is expected to print a message and return 0
on failure. Make it do so consistently.
Don't generate the hex representation of the payload data if it
isn't actually used afterwards.
Impact: optimization
Use pr_warning() / pr_err() instead of dev_warn() / dev_err() in two
places where the dev pointer isn't guaranteed to be valid.
The separation of state tables for base and M10x has long been
removed. Clean up remaining traces of it.
Impact: cleanup
When the device is disconnected, the dev structure goes away, so
trying to report another error via dev_printk is bound to oops.
To avoid that, first check whether the device is still connected
and return quietly if it isn't.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Tested-by: Paul Bolle <pebolle@tiscali.nl>
The tasklets for isochronous data transfer need to run within 8 msec
to avoid over/underruns, so schedule them with high priority to fix
reported issues with occasional over/underruns.
drivers/net/wimax/i2400m/usb-notif.c
This helps the code look more consistent and cleaner.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
drivers/net/virtio_net.c
Every USB transfer buffer has to be allocated individually by kmalloc.
Impact: bugfix, no functional change
Tested-by: Kolja Waschk <kawk@users.sourceforge.net>
A number of functions in the usb_gigaset module will return -EINVAL if
CONFIG_GIGASET_UNDOCREQ is not set. Make these return -ENOTTY as it's
more specific and it might make it easier to see (from userspace) why
these functions actually fail.
Impact: some error return codes changed
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Streamline dependencies and remove some obsolete or redundant comments
in the Gigaset ISDN driver's Kconfig file. In particular, remove the
strong warning against the GIGASET_UNDOCREQ option, as in seven years
of existence, the code in question has never been reported to cause
any harm.
Impact: Kconfig cleanup, no functional change
Remove unnecessary #ifdef-s and #if-0-ed code sections.
Switch from private printk wrapper macros to using pr_err() and
pr_info() from linux/kernel.h, at the same time unifying a few
error messages.
