* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
Driver should call pci_disable_device() if it returns from pci_probe()
with error.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
with error.
with error.
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
This patch converts pci_table entries, where .subvendor=PCI_ANY_ID and
.subdevice=PCI_ANY_ID, .class=0 and .class_mask=0, to use the
PCI_VDEVICE macro, and thus improves readability.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
is used)
is used)
All these files use the big kernel lock in a trivial
way to serialize their private file operations,
typically resulting from an earlier semi-automatic
pushdown from VFS.
None of these drivers appears to want to lock against
other code, and they all use the BKL as the top-level
lock in their file operations, meaning that there
is no lock-order inversion problem.
Consequently, we can remove the BKL completely,
replacing it with a per-file mutex in every case.
Using a scripted approach means we can avoid
typos.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: netdev@vger.kernel.org
The function inittiger is only called from nj_init_card, where a lock is held.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock_irqrestore
when any
GFP_KERNEL@p
... when any
@locked@
identifier gfp.fn;
spin_lock_irqsave(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
// </smpl>
Add a spin_unlock missing on the error path. The return value of write_reg
seems to be completely ignored, so it seems that the lock should be
released in every case.
The semantic match that finds this problem is as follows:
// <smpl>
expression E1;
* spin_lock(E1,...);
<+... when != E1
if (...) {
... when != E1
* return ...;
* spin_unlock(E1,...);
// </smpl>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
As a second step, remove any usage of dev_node_t from drivers which
only wrote to this typedef/struct, except one printk() which can
easily be replaced by a dev_info()/dev_warn() call.
CC: Harald Welte <laforge@gnumonks.org>
Acked-by: Karsten Keil <isdn@linux-pingi.de>
Instead of the old pcmcia_request_irq() interface, drivers may now
choose between:
- calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq.
- use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will
clean up automatically on calls to pcmcia_disable_device() or
device ejection.
- drivers still not capable of IRQF_SHARED (or not telling us so) may
use the deprecated pcmcia_request_exclusive_irq() for the time
being; they might receive a shared IRQ nonetheless.
CC: linux-bluetooth@vger.kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Gilles Espinasse <g.esp@free.fr>
A few subdevice IDs seem to have been dropped when hfc_multi was
included upstream, just compare the list at
http://www.openvox.cn/viewvc/misdn/trunk/hfc_multi.c?revision=75&view=annotate#l175
with the IDs in drivers/isdn/hardware/mISDN/hfcmulti.c
Added PCIe 2 Port card and LED settings (same as PCI)
Do not use <linux/pci_ids.h> /KKe
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Karsten Keil <keil@b1-systems.de>
Replace references to the '20' magic number found throughout the Eicon
ISDN driver for the length of the station_id field in the T30_INFO struct
with the T30_MAX_STATION_ID_LENGTH symbolic constant.
Signed-off-by: Ian Munsie <imunsie@au.ibm.com>
Cc: Armin Schindler <mac@melware.de>
Cc: Stoyan Gaydarov <sgayda2@uiuc.edu>
When compiling this driver, the compiler throws the following warnings:
drivers/isdn/hardware/eicon/message.c:8426: warning: array subscript is above array bounds
drivers/isdn/hardware/eicon/message.c:8427: warning: array subscript is above array bounds
drivers/isdn/hardware/eicon/message.c:8434: warning: array subscript is above array bounds
drivers/isdn/hardware/eicon/message.c:8435: warning: array subscript is above array bounds
drivers/isdn/hardware/eicon/message.c:8436: warning: array subscript is above array bounds
drivers/isdn/hardware/eicon/message.c:8447: warning: array subscript is above array bounds
This arises from the particular semantics the driver is using to write to
the nlc array (static byte[256]). The array has a length in byte 0
followed by a T30_INFO struct starting at byte 1.
The T30_INFO struct has a number of variable length strings after the
station_id entry, which cannot be explicitly defined in the struct and the
driver accesses them with an array index to station_id beyond the length
of station_id.
This patch merely changes the semantics that the driver uses to access the
entries after the station_id entry to use the original 256 byte nlc array
taking the offset and length of the station_id entry to calculate where to
write in the array, thereby silencing the warning.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
Trivial patch which adds the __init/__exit macros to the module_init/
module_exit functions of
drivers/isdn/hardware/mISDN/mISDNisar.c
The error return should be negative. Its only caller that acts upon its
return, handle_bmsg(), transmits the positive error but can also return
negative errors.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Remove these compiler warnings:
drivers/isdn/hardware/mISDN/w6692.c:534: warning: `setvolume' defined but not used
drivers/isdn/hardware/mISDN/w6692.c:561: warning: `enable_pots' defined but not used
by moving the functions inside #if 0 ... #endif. And an alternative is
to remove them completely if nobody has plans to use them.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
If setup_instance() fails we kfree() the card, and then use it in the next
loop iteration. So lets bail out of the loop instead.
Coverity CID: 13357
Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com>
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
[akpm@linux-foundation.org: CONFIG_PROC_FS=n build fix]
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits)
sky2: Fix oops in sky2_xmit_frame() after TX timeout
Documentation/3c509: document ethtool support
af_packet: Don't use skb after dev_queue_xmit()
vxge: use pci_dma_mapping_error to test return value
netfilter: ebtables: enforce CAP_NET_ADMIN
e1000e: fix and commonize code for setting the receive address registers
e1000e: e1000e_enable_tx_pkt_filtering() returns wrong value
e1000e: perform 10/100 adaptive IFS only on parts that support it
e1000e: don't accumulate PHY statistics on PHY read failure
e1000e: call pci_save_state() after pci_restore_state()
netxen: update version to 4.0.72
netxen: fix set mac addr
netxen: fix smatch warning
netxen: fix tx ring memory leak
tcp: update the netstamp_needed counter when cloning sockets
TI DaVinci EMAC: Handle emac module clock correctly.
dmfe/tulip: Let dmfe handle DM910x except for SPARC on-board chips
ixgbe: Fix compiler warning about variable being used uninitialized
netfilter: nf_ct_ftp: fix out of bounds read in update_nl_seq()
mv643xx_eth: don't include cache padding in rx desc buffer size
Fix trivial conflict in drivers/scsi/cxgb3i/cxgb3i_offload.c
drivers/net/benet/be_cmds.h
include/linux/sysctl.h
The code checked slot_rx twice. Check slot_tx by analogy with the bank
case.
// <smpl>
expression E;
*E && E
*E || E
// </smpl>
pcmcia: CodingStyle fixes
pcmcia: remove unused IRQ_FIRST_SHARED
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
Komuro pointed out that IRQ_FIRST_SHARED is not used at all in the
PCMCIA subsystem, so remove it. Also, remove two bogus assignments.
CC: Karsten Keil <keil@b1-systems.de>
CC: Komuro <komurojun-mbn@nifty.com>
kernel/irq/chip.c
drivers/net/pcmcia/fmvj18x_cs.c
drivers/net/pcmcia/nmclan_cs.c
drivers/net/pcmcia/xirc2ps_cs.c
drivers/net/wireless/ray_cs.c
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits)
pcmcia: rework the irq_req_t typedef
pcmcia: remove deprecated handle_to_dev() macro
pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer
pcmcia: remove unused "window_t" typedef
pcmcia: move some window-related code to pcmcia_ioctl.c
pcmcia: Change window_handle_t logic to unsigned long
pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page()
pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page()
pcmcia: Pass struct pcmcia_device to pcmcia_release_window()
drivers/pcmcia: remove unnecessary kzalloc
pcmcia: correct handling for Zoomed Video registers in topic.h
pcmcia: fix printk formats
pcmcia: autoload module pcmcia
pcmcia/staging: update comedi drivers
PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket
PCMCIA: ss: allow PCI IRQs > 255
PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket
PCMCIA: soc_common: constify soc_pcmcia_socket ops member
PCMCIA: sa1111: remove duplicated initializers
PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Most of the irq_req_t typedef'd struct can be re-worked quite
easily:
(1) IRQInfo2 was unused in any case, so drop it.
(2) IRQInfo1 was used write-only, so drop it.
(3) Instance (private data to be passed to the IRQ handler):
Most PCMCIA drivers using pcmcia_request_irq() to actually
register an IRQ handler set the "dev_id" to the same pointer
as the "priv" pointer in struct pcmcia_device. Modify the two
exceptions (ipwireless, ibmtr_cs) to also work this waym and
set the IRQ handler's "dev_id" to p_dev->priv unconditionally.
(4) Handler is to be of type irq_handler_t.
(5) Handler != NULL already tells whether an IRQ handler is present.
Therefore, we do not need the IRQ_HANDLER_PRESENT flag in
irq_req_t.Attributes.
CC: linux-scsi@vger.kernel.org
CC: Jaroslav Kysela <perex@perex.cz>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Karsten Keil <isdn@linux-pingi.de>
for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org>
drivers/net/can/Kconfig
The returned error should stay negative
Acked-by: Karsten Keil <keil@b1-systems.de>
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of
requiring manual settings of PCMCIA_DEBUG.
Also, remove all usages of the CS_CHECK macro and replace them with proper
Linux style calling and return value checking. The extra error reporting may
be dropped, as the PCMCIA core already complains about any (non-driver-author)
errors.
When diva_strace_read_uint returns an error, return even from
process_idi_event, because l2_state is uninitialized.
Acked-by: Armin Schindler <armin@melware.de>
