HFCPCI_l1hw()
In drivers/isdn/hisax/hfc_pci.c, the functions hfcpci_interrupt() and
HFCPCI_l1hw() may be concurrently executed.
HFCPCI_l1hw()
line 1173: if (!cs->tx_skb)
hfcpci_interrupt()
line 942: spin_lock_irqsave();
line 1066: dev_kfree_skb_irq(cs->tx_skb);
Thus, a possible concurrency use-after-free bug may occur
in HFCPCI_l1hw().
To fix these bugs, the calls to spin_lock_irqsave() and
spin_unlock_irqrestore() are added in HFCPCI_l1hw(), to protect the
access to cs->tx_skb.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/isdn/hisax/hfc_pci.c:277:6: warning:
variable ‘total’ set but not used [-Wunused-but-set-variable]
It never used since git history start.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Clang warns:
drivers/isdn/hisax/hfc_pci.c:131:34: error: if statement has empty body
[-Werror,-Wempty-body]
if (Read_hfc(cs, HFCPCI_INT_S1));
drivers/isdn/hisax/hfc_pci.c:131:34: note: put the semicolon on a
separate line to silence this warning
In my attempt to hide the warnings because I thought they didn't serve
any purpose[1], Masahiro Yamada pointed out that {Read,Write}_hfc in
hci_pci.c should be using a standard register access method; otherwise,
the compiler will just remove the if statements.
For hfc_pci, use the versions of {Read,Write}_hfc found in
drivers/isdn/hardware/mISDN/hfc_pCI.h while converting pci_io to be
'void __iomem *' (and clean up ioremap) then remove the empty if
statements.
For hfc_sx, {Read,Write}_hfc are already use a proper register accessor
(inb, outb) so just remove the unnecessary if statements.
[1]: https://lore.kernel.org/lkml/20181016021454.11953-1-natechancellor@gmail.com/
Link: https://github.com/ClangBuiltLinux/linux/issues/66
Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Clang warns when multiple sets of parentheses are used for a single
conditional statement.
drivers/isdn/hisax/amd7930_fn.c:628:32: warning: equality comparison
with extraneous parentheses [-Wparentheses-equality]
if ((cs->dc.amd7930.ph_state == 8)) {
drivers/isdn/hisax/amd7930_fn.c:628:32: note: remove extraneous
parentheses around the comparison to silence this warning
drivers/isdn/hisax/amd7930_fn.c:628:32: note: use '=' to turn this
equality comparison into an assignment
1 warning generated.
Replace "fallthru" with a proper "fall through" annotation.
This fix is part of the ongoing efforts to enabling
-Wimplicit-fallthrough
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Clang warns when more than one set of parentheses are used for single
conditional statements:
drivers/isdn/hisax/w6692.c:627:30: warning: equality comparison with
if ((cs->dc.w6692.ph_state == W_L1IND_DRD)) {
drivers/isdn/hisax/w6692.c:627:30: note: remove extraneous parentheses
drivers/isdn/hisax/w6692.c:627:30: note: use '=' to turn this equality
Remove the parentheses to silence this warning.
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
hisax_cs_new() and hisax_cs_setup() are never called in atomic context.
They call kmalloc() and kzalloc() with GFP_ATOMIC, which is not necessary.
GFP_ATOMIC can be replaced with GFP_KERNEL.
This is found by a static analysis tool named DCNS written by myself.
init_PStack() is never called in atomic context.
It calls kmalloc() with GFP_ATOMIC, which is not necessary.
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
Warning level 2 was used: -Wimplicit-fallthrough=2
Using usb_fill_int_urb() helps to find code which initializes an
URB. A grep for members of the struct (like ->complete) reveal lots
of other things, too.
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: netdev@vger.kernel.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The `interval' parameter is now set differently on HS and SS. The
argument is fed from bInterval so it should be the right thing to do.
The kzalloc() function has a 2-factor argument form, kcalloc(). This
patch replaces cases of:
kzalloc(a * b, gfp)
with:
kcalloc(a * b, gfp)
as well as handling cases of:
kzalloc(a * b * c, gfp)
with:
kzalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kzalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kzalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kzalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kzalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kzalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kzalloc(
- sizeof(char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kzalloc(
- sizeof(u8) * COUNT
+ COUNT
kzalloc(
- sizeof(__u8) * COUNT
+ COUNT
kzalloc(
- sizeof(char) * COUNT
+ COUNT
kzalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * COUNT_CONST
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_ID
- kzalloc
+ kcalloc
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kzalloc
+ kcalloc
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kzalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kzalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kzalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kzalloc(
- sizeof(TYPE) * COUNT * STRIDE
kzalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kzalloc(
- sizeof(THING) * (COUNT) * STRIDE
kzalloc(
- sizeof(THING) * COUNT * (STRIDE)
kzalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kzalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kzalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kzalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kzalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kzalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kzalloc(
- COUNT * (STRIDE) * SIZE
kzalloc(
- COUNT * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * SIZE
kzalloc(
- COUNT * (STRIDE) * (SIZE)
kzalloc(
- (COUNT) * STRIDE * (SIZE)
kzalloc(
- (COUNT) * (STRIDE) * (SIZE)
kzalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kzalloc(C1 * C2 * C3, ...)
kzalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kzalloc(
- (E1) * (E2) * E3
kzalloc(
- (E1) * (E2) * (E3)
kzalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kzalloc(sizeof(THING) * C2, ...)
kzalloc(sizeof(TYPE) * C2, ...)
kzalloc(C1 * C2, ...)
- kzalloc
+ kcalloc
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kzalloc
+ kcalloc
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kzalloc
+ kcalloc
- (E1) * E2
+ E1, E2
- kzalloc
+ kcalloc
- (E1) * (E2)
+ E1, E2
- kzalloc
+ kcalloc
- E1 * E2
+ E1, E2
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
kmalloc_array(array_size(a, b), c, gfp)
kmalloc(4 * 1024, gfp)
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
type TYPE;
kmalloc(
+ sizeof(TYPE) * E
kmalloc(
+ sizeof(THING) * E
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
kmalloc(
+ COUNT
type TYPE;
expression THING;
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
expression THING;
type TYPE;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
kmalloc(
- (E1) * (E2) * E3
kmalloc(
kmalloc(
- E1 * E2 * E3
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
A lot of Kconfig symbols have architecture specific dependencies.
In those cases that depend on architectures we have already removed,
they can be omitted.
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
The pnp_irq() function returns -1 if an error occurs.
pnp_irq() error checking for zero is not correct.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
pnp_irq() and pnp_port_start() can fail here and we must check
its return value.
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Geliang Tang <geliangtang@gmail.com>
usb_device_id are not supposed to change at runtime. All functions
working with usb_device_id provided by <linux/usb.h> work with
const usb_device_id. So mark the non-const structs as const.
pci_device_id are not supposed to change at runtime. All functions
working with pci_device_id provided by <linux/pci.h> work with
const pci_device_id. So mark the non-const structs as const.
File size before:
5989 576 0 6565 19a5 isdn/hisax/hisax_fcpcipnp.o
File size After adding 'const':
6085 480 0 6565 19a5 isdn/hisax/hisax_fcpcipnp.o
File size before:
10512 536 4 11052 2b2c drivers/isdn/hisax/hfc4s8s_l1.o
10672 376 4 11052 2b2c drivers/isdn/hisax/hfc4s8s_l1.o
File size before:
13686 2064 4416 20166 4ec6 drivers/isdn/hisax/config.o
15030 720 4416 20166 4ec6 drivers/isdn/hisax/config.o
A common pattern with skb_put() is to just want to memcpy()
some data into the new space, introduce skb_put_data() for
this.
An spatch similar to the one for skb_put_zero() converts many
of the places using it:
identifier p, p2;
expression len, skb, data;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_data(skb, data, len);
-p = (t)skb_put(skb, len);
p2 = (t2)p;
-memcpy(p2, data, len);
-memcpy(p, data, len);
type t, t2;
identifier p, p2;
expression skb, data;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_data(skb, data, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
p2 = (t2)p;
-memcpy(p2, data, sizeof(*p));
-memcpy(p, data, sizeof(*p));
expression skb, len, data;
-memcpy(skb_put(skb, len), data, len);
+skb_put_data(skb, data, len);
(again, manually post-processed to retain some comments)
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull hw lockdown support from David Howells:
"Annotation of module parameters that configure hardware resources
including ioports, iomem addresses, irq lines and dma channels.
This allows a future patch to prohibit the use of such module
parameters to prevent that hardware from being abused to gain access
to the running kernel image as part of locking the kernel down under
UEFI secure boot conditions.
Annotations are made by changing:
module_param(n, t, p)
module_param_named(n, v, t, p)
module_param_array(n, t, m, p)
to:
module_param_hw(n, t, hwtype, p)
module_param_hw_named(n, v, t, hwtype, p)
module_param_hw_array(n, t, hwtype, m, p)
where the module parameter refers to a hardware setting
hwtype specifies the type of the resource being configured. This can
be one of:
ioport Module parameter configures an I/O port
iomem Module parameter configures an I/O mem address
ioport_or_iomem Module parameter could be either (runtime set)
irq Module parameter configures an I/O port
dma Module parameter configures a DMA channel
dma_addr Module parameter configures a DMA buffer address
other Module parameter configures some other value
Note that the hwtype is compile checked, but not currently stored (the
lockdown code probably won't require it). It is, however, there for
future use.
A bonus is that the hwtype can also be used for grepping.
The intention is for the kernel to ignore or reject attempts to set
annotated module parameters if lockdown is enabled. This applies to
options passed on the boot command line, passed to insmod/modprobe or
direct twiddling in /sys/module/ parameter files.
The module initialisation then needs to handle the parameter not being
set, by (1) giving an error, (2) probing for a value or (3) using a
reasonable default.
What I can't do is just reject a module out of hand because it may
take a hardware setting in the module parameters. Some important
modules, some ipmi stuff for instance, both probe for hardware and
allow hardware to be manually specified; if the driver is aborts with
any error, you don't get any ipmi hardware.
Further, trying to do this entirely in the module initialisation code
doesn't protect against sysfs twiddling.
[!] Note that in and of itself, this series of patches should have no
effect on the the size of the kernel or code execution - that is
left to a patch in the next series to effect. It does mark
annotated kernel parameters with a KERNEL_PARAM_FL_HWPARAM flag in
an already existing field"
* tag 'hwparam-20170420' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: (38 commits)
Annotate hardware config module parameters in sound/pci/
Annotate hardware config module parameters in sound/oss/
Annotate hardware config module parameters in sound/isa/
Annotate hardware config module parameters in sound/drivers/
Annotate hardware config module parameters in fs/pstore/
Annotate hardware config module parameters in drivers/watchdog/
Annotate hardware config module parameters in drivers/video/
Annotate hardware config module parameters in drivers/tty/
Annotate hardware config module parameters in drivers/staging/vme/
Annotate hardware config module parameters in drivers/staging/speakup/
Annotate hardware config module parameters in drivers/staging/media/
Annotate hardware config module parameters in drivers/scsi/
Annotate hardware config module parameters in drivers/pcmcia/
Annotate hardware config module parameters in drivers/pci/hotplug/
Annotate hardware config module parameters in drivers/parport/
Annotate hardware config module parameters in drivers/net/wireless/
Annotate hardware config module parameters in drivers/net/wan/
Annotate hardware config module parameters in drivers/net/irda/
Annotate hardware config module parameters in drivers/net/hamradio/
Annotate hardware config module parameters in drivers/net/ethernet/
When the kernel is running in secure boot mode, we lock down the kernel to
prevent userspace from modifying the running kernel image. Whilst this
includes prohibiting access to things like /dev/mem, it must also prevent
access by means of configuring driver modules in such a way as to cause a
device to access or modify the kernel image.
To this end, annotate module_param* statements that refer to hardware
configuration and indicate for future reference what type of parameter they
specify. The parameter parser in the core sees this information and can
skip such parameters with an error message if the kernel is locked down.
The module initialisation then runs as normal, but just sees whatever the
default values for those parameters is.
Note that we do still need to do the module initialisation because some
drivers have viable defaults set in case parameters aren't specified and
some drivers support automatic configuration (e.g. PNP or PCI) in addition
to manually coded parameters.
This patch annotates drivers in drivers/isdn/.
Suggested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
cc: Karsten Keil <isdn@linux-pingi.de>
cc: netdev@vger.kernel.org
Use setup_timer() instead of init_timer() to simplify the code.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Fix typos and add the following to the scripts/spelling.txt:
disble||disable
disbled||disabled
I kept the TSL2563_INT_DISBLED in /drivers/iio/light/tsl2563.c
untouched. The macro is not referenced at all, but this commit is
touching only comment blocks just in case.
Link: http://lkml.kernel.org/r/1481573103-11329-20-git-send-email-yamada.masahiro@socionext.com
Pull networking fixes and cleanups from David Miller:
1) Revert bogus nla_ok() change, from Alexey Dobriyan.
2) Various bpf validator fixes from Daniel Borkmann.
3) Add some necessary SET_NETDEV_DEV() calls to hsis_femac and hip04
drivers, from Dongpo Li.
4) Several ethtool ksettings conversions from Philippe Reynes.
5) Fix bugs in inet port management wrt. soreuseport, from Tom Herbert.
6) XDP support for virtio_net, from John Fastabend.
7) Fix NAT handling within a vrf, from David Ahern.
8) Endianness fixes in dpaa_eth driver, from Claudiu Manoil
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (63 commits)
net: mv643xx_eth: fix build failure
isdn: Constify some function parameters
mlxsw: spectrum: Mark split ports as such
cgroup: Fix CGROUP_BPF config
qed: fix old-style function definition
net: ipv6: check route protocol when deleting routes
r6040: move spinlock in r6040_close as SOFTIRQ-unsafe lock order detected
irda: w83977af_ir: cleanup an indent issue
net: sfc: use new api ethtool_{get|set}_link_ksettings
net: davicom: dm9000: use new api ethtool_{get|set}_link_ksettings
net: cirrus: ep93xx: use new api ethtool_{get|set}_link_ksettings
net: chelsio: cxgb3: use new api ethtool_{get|set}_link_ksettings
net: chelsio: cxgb2: use new api ethtool_{get|set}_link_ksettings
bpf: fix mark_reg_unknown_value for spilled regs on map value marking
bpf: fix overflow in prog accounting
bpf: dynamically allocate digest scratch buffer
gtp: Fix initialization of Flags octet in GTPv1 header
gtp: gtp_check_src_ms_ipv4() always return success
net/x25: use designated initializers
isdn: use designated initializers
The coming initify gcc plugin expects const pointer types, and caught
some __printf arguments that weren't const yet. This fixes those.
Signed-off-by: Emese Revfy <re.emese@gmail.com>
[kees: expanded commit message]
Pull trivial updates from Jiri Kosina.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
NTB: correct ntb_spad_count comment typo
misc: ibmasm: fix typo in error message
Remove references to dead make variable LINUX_INCLUDE
Remove last traces of ikconfig.h
treewide: Fix printk() message errors
Documentation/device-mapper: s/getsize/getsz/
This patch fix spelling typos in printk and kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
In function hfc4s8s_probe(), the value of return variable err should be
negative on failures. However, when the call to request_region() returns
NULL, the value of err is 0. This patch fixes the bug, assigning
"-EBUSY" to err on the path that request_region() fails.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=188931
Signed-off-by: Pan Bian <bianpan2016@163.com>
Fix variable assignment inside if statement. It is error-prone and hard to read.
Signed-off-by: Cosmin-Gabriel Samoila <gabrielcsmo@gmail.com>
Commit 35a4a57 ("isdn: clean up debug format string usage") introduced
a safeguard to avoid accidential format string interpolation of data
when calling debugl1 or HiSax_putstatus. This did however not take into
account VHiSax_putstatus (called by HiSax_putstatus) does *not* call
vsprintf if the head parameter is NULL - the format string is treated
as plain text then instead. As a result, the string "%s" is processed
literally, and the actual information is lost. This affects the isdnlog
userspace program which stopped logging information since that commit.
So revert the HiSax_putstatus invocations to the previous state.
Fixes: 35a4a5733b0a ("isdn: clean up debug format string usage")
Signed-off-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
net/ipv6/xfrm6_output.c
net/openvswitch/flow_netlink.c
net/openvswitch/vport-gre.c
net/openvswitch/vport-vxlan.c
net/openvswitch/vport.c
net/openvswitch/vport.h
The openvswitch conflicts were overlapping changes. One was
the egress tunnel info fix in 'net' and the other was the
vport ->send() op simplification in 'net-next'.
The xfrm6_output.c conflicts was also a simplification
overlapping a bug fix.
The skb_clone() return value was not checked and the skb_realloc_headroom()
usage was wrong, the old skb was not freed. It turned out, that the
skb_clone is not needed at all, the skb_realloc_headroom() will create a
private copy with enough headroom and the original SKB can be used for the
ACK queue.
We need to requeue the original skb if the call failed, since the upper
layer cannot be informed about memory shortage.
Thanks to Insu Yun <wuninsu@gmail.com> to remind me on this issue.
Signed-off-by: Karsten Keil <keil@b1-systems.de>
Difference of unsigned values is also unsigned so it does not make
sense to check its sign.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
drivers/net/ethernet/mellanox/mlx4/main.c
net/packet/af_packet.c
Both conflicts were cases of simple overlapping changes.
Fix an allmodconfig compilation failer on microblaze due to big endian
architectures being apparently unsupported by the NetJet code:
drivers/isdn/hisax/nj_s.c: In function 'setup_netjet_s':
drivers/isdn/hisax/nj_s.c:265:2:
error: #error "not running on big endian machines now"
Modify the relevant Kconfig such that the NetJet code is not built on
microblaze anymore.
Note that endianess on microblaze is not determined through Kconfig,
but by means of a compiler provided CPP macro, namely __MICROBLAZEEL__.
However, gcc defaults to big endianess on that platform.
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Acked-by: Jean Delvare <jdelvare@suse.de>
