path: root/drivers/isdn/hysdn/hysdn_net.c
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] isdn: replace kmalloc+memset with kzallocBurman Yan
Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Remove MODULE_PARMRusty Russell
MODULE_PARM was actually breaking: recent gcc version optimize them out as unused. It's time to replace the last users, which are generally in the most unloved drivers anyway. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] hysdn: remove custom typesAndrew Morton
hysdn defines its own types: ulong, uint, uchar and word. Problem is, the module_param macros rely upon some of those identifiers having special meanings too. The net effect is that module_param() and friends cannot be used in ISDN because of this namespace clash. So remove the hysdn-private defines and open-code them all. Cc: Karsten Keil <kkeil@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
