path: root/drivers/isdn/icn
2011-02-01isdn: icn: Fix potentially wrong string handlingStefan Weil
This warning was reported by cppcheck: drivers/isdn/icn/icn.c:1641: error: Dangerous usage of 'rev' (strncpy doesn't always 0-terminate it) If strncpy copied 20 bytes, the destination string rev was not terminated. The patch adds one more byte to rev and makes sure that this byte is always 0. Cc: Karsten Keil <isdn@linux-pingi.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Tejun Heo <tj@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: netdev@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24isdn: icn: Fix stack corruption bug.Steven Rostedt
Running randconfig with ktest.pl I hit this bug: [ 16.101158] ICN-ISDN-driver Rev 1.65.6.8 mem=0x000d0000 [ 16.106376] icn: (line0) ICN-2B, port 0x320 added [ 16.111064] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: c1642880 [ 16.111066] [ 16.121214] Pid: 1, comm: swapper Not tainted 2.6.37-rc2-test-00124-g6656b3f #8 [ 16.128499] Call Trace: [ 16.130942] [<c0f51662>] ? printk+0x1d/0x23 [ 16.135200] [<c0f5153f>] panic+0x5c/0x162 [ 16.139286] [<c0d62a9a>] ? icn_addcard+0x6d/0xbe [ 16.143975] [<c0445783>] print_tainted+0x0/0x8c [ 16.148582] [<c1642880>] ? icn_init+0xd8/0xdf [ 16.153012] [<c1642880>] icn_init+0xd8/0xdf [ 16.157271] [<c04012e5>] do_one_initcall+0x8c/0x143 [ 16.162222] [<c16427a8>] ? icn_init+0x0/0xdf [ 16.166566] [<c15f1a05>] kernel_init+0x13f/0x1da [ 16.171256] [<c15f18c6>] ? kernel_init+0x0/0x1da [ 16.175945] [<c0403bfe>] kernel_thread_helper+0x6/0x10 [ 16.181181] panic occurred, switching back to text console Looking into it I found that the stack was corrupted by the assignment of the Rev #. The variable rev is given 10 bytes, and in this output the characters that were copied was: " 1.65.6.8 $". Which was 11 characters plus the null ending character for a total of 12 bytes, thus corrupting the stack. This patch ups the variable size to 20 bytes as well as changes the strcpy to strncpy. I also added a check to make sure '$' is found. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-09Kconfig: Remove useless and sometimes wrong commentsMichael Roth
Additionally, some excessive newlines removed. Signed-off-by: Michael Roth <mroth@nessie.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-02-06fix ! versus & precedence in various placesAlexey Dobriyan
Fix various instances of if (!expr & mask) which should probably have been if (!(expr & mask)) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21Use menuconfig objects - CONFIG_ISDN_I4LTilman Schmidt
Remove a menu statement and several dependencies from the Kconfig files in the drivers/isdn tree as they have become unnecessary by the transformation of CONFIG_ISDN from "menu, config" into "menuconfig". (Modified version of a patch originally proposed by Jan Engelhardt.) Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: Jan Engelhardt <jengelh@computergmbh.de> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] isdn: replace kmalloc+memset with kzallocBurman Yan
Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] ISDN: check for userspace copy faultsJeff Garzik
Most of the ISDN ->readstat() implementations needed to check copy_to_user() and put_user() return values. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] isdn: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] icn driver fails to unload when no hardware presentDave Jones
Fix a null dereference in module unload path. Found by a simple modprobe icn ; rmmod icn Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
