path: root/drivers/isdn/sc/event.c
2007-02-12[PATCH] drivers/isdn/sc/: proper prototypesAdrian Bunk
Add proper prototypes in a header file for global code under drivers/isdn/sc/. Since the GNU C compiler is now able do tell us that caller and callee disagreed about the number of arguments of setup_buffers(), this patch also fixes this bug. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] isdn: more pr_debug() fixesAndrew Morton
drivers/isdn/sc/event.c: In function 'indicate_status': drivers/isdn/sc/event.c:49: error: 'events' undeclared (first use in this function) drivers/isdn/sc/event.c:49: error: (Each undeclared identifier is reported only once drivers/isdn/sc/event.c:49: error: for each function it appears in.) drivers/isdn/sc/event.c:49: warning: format '%d' expects type 'int', but argument 4 has type 'ulong' drivers/isdn/sc/interrupt.c: In function 'interrupt_handler': drivers/isdn/sc/interrupt.c:97: warning: format '%x' expects type 'unsigned int', but argument 4 has type 'long unsigned int' drivers/isdn/sc/timer.c: In function 'check_reset': drivers/isdn/sc/timer.c:80: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Acked-by: Karsten Keil <kkeil@suse.de> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
