path: root/drivers/isdn/sc/init.c
2005-11-07[PATCH] isdn: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] Remove unnecessary check_region references in commentsPeter Osterlund
Remove check_region references from comments and printk statements so that searching for real users of this deprecated function gets easier. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] drivers/isdn/sc/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanips: - make some needlessly global code static - remove the compiled but completely unused debug.c - remove or #if 0 the following unused global functions: - command.c: loopback - command.c: loadproc - init.c: irq_supported - packet.c: print_skb - shmem.c: memset_shmem - timer.c: trace_timer Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
