commit 286e633ef0ff5bb63c07b4516665da8004966fec upstream.
Check whether index is within bounds before testing the element.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Karsten Keil <isdn@linux-pingi.de>
commit a4304f2d5a3823deea894026ec95e43b33912357 upstream.
The tty_operation chars_in_buffer() is not allowed to return a negative
value to signal an error. Corrects the problem flagged by commit
23198fda7182969b619613a555f8645fdc3dc334, "tty: fix chars_in_buffers".
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits)
ehea: Fix napi list corruption on ifconfig down
igbvf: Allow VF driver to correctly recognize failure to set mac
3c59x: Fix build failure with gcc 3.2
sky2: Avoid transmits during sky2_down()
iwlagn: do not send key clear commands when rfkill enabled
libertas: Read buffer overflow
drivers/net/wireless: introduce missing kfree
drivers/net/wireless/iwlwifi: introduce missing kfree
zd1211rw: fix unaligned access in zd_mac_rx
cfg80211: fix regression on beacon world roaming feature
cfg80211: add two missing NULL pointer checks
ixgbe: Patch to modify 82598 PCIe completion timeout values
bluetooth: rfcomm_init bug fix
mlx4_en: Fix double pci unmapping.
mISDN: Fix handling of receive buffer size in L1oIP
pcnet32: VLB support fixes
pcnet32: remove superfluous NULL pointer check in pcnet32_probe1()
net: restore the original spinlock to protect unicast list
netxen: fix coherent dma mask setting
mISDN: Read buffer overflow
The size of receive buffer pointer was used to get size of
receive buffer instead of recvbuf_size itself, so only 4/8
bytes could be transfered.
This is a regression to 2.6.30 introduced by commit 8c90e11e3543d7de612194a042a148caeaab5f1d
mISDN: Use kernel_{send,recv}msg instead of open coding
Signed-off-by: Andreas Eversberg <andreas@eversberg.eu>
Signed-off-by: Karsten Keil <keil@b1-systems.de>
Acked-by: Karsten Keil <keil@b1-systems.de>
8c90e11e3543d7de612194a042a148caeaab5f1d ("mISDN: Use
kernel_{send,recv}msg instead of open coding")
This function does not have an error return and returning an error is
instead interpreted as having a lot of pending bytes.
Reported by Jeff Harris who provided a list of some of the remaining
offenders.
Signed-off-by: Alan Cox <alan@linux.intel.com>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Drop a sanity check which doesn't serve any useful purpose anymore.
ISDN connection setup failed if the "connection active" and
"B channel up" messages from the device arrived in a different
order than expected. Modify the state machine to accept them in
any order.
Impact: bugfix
CC: stable <stable@kernel.org>
Fix up remaining drivers returning a magic or an errno value from their
ndo_start_xmit() functions that were missed in the first pass:
- isdn_net: missed conversion
- bpqether: missed conversion: skb is freed, so return NETDEV_TX_OK
- hp100: intention appears to be to resubmit skb once resources are
available, but due to no queue handling it is dropped for now.
- lapbether: skb is freed, so return NETDEV_TX_OK
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
Signed-off-by: Martin Olsson <martin@minimum.se>
documentation and source comments.
This fix triggering the WARN_ON_ONCE(in_irq() || irqs_disabled()); in
local_bh_enable().
Here is no need to grab this lock, this was wrong at all and may
cause a deadlock and access to freed memory, since on a TEI remove
the current listelement can be deleted under us. So this is clearly
a case for list_for_each_entry_safe.
The check for overindexing of dev->mdm.info[] has an off-by-one.
If we get no interrupts for after 3 resets we need to unregister
the interrupt function, which is already done outside the loop.
Signed-off-by: Andreas Mohr <andi@lisas.de>
Remove code rewriting a buffer by itself.
This fix bug 12970 on bugzilla.kernel.org.
Replace wrong code with correct DMA API functions.
The dereferencing of the private pointer cmsg->m in capi_cmsg2str() may
cause an Oops in case of an error, which is particularly inconvenient
as that function is typically used to format an error message. Add a
NULL pointer check to avoid this.
Impact: error handling improvement
Add kerneldoc comments for the exported funtions in capiutil.c.
Impact: documentation
Change the name of the Kernel CAPI exported function capi_ctr_reseted()
to something representing its purpose better.
Impact: renaming, no functional change
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/iwlwifi/iwl-agn.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
The new ID is validated by Cologne Chip.
LEDs control is also supported.
DTMF detection was enabled when it was not supposed to.
Reducing the number of direct users of sock_{recv,send}msg.
Modified version to match the latest context.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This patch make debug printk's KERN_DEBUG and also fix some
codestyle issues.
new id for HFC-8S
dev->id is unsigned so a get_free_devid() error is ignored.
New version without emulating arch specific stuff for the other
architectures, the special IO and init functions for the 8xx
microcontroller are in a separate include file.
If the channel receive function returns an error the skb must be freed.
Using sapi values other than 0 work now.
The "OpenBSC" project does not require special kernel patch anymore.
Before: 1656 bytes on i386, now 164.
Modified by Andreas Eversberg <andreas@eversberg.eu>
Signed-off-by: Frank Seidel <frank@f-seidel.de>
Added SAPI value to use SAPIs different than 0.
Now fixed TEIs work in NT mode. This allows PTP endpoint to be connected
to PTMP ports together with other PTMP endpoints.
New enhanced version, thanks to Sam Ravnborg <sam@ravnborg.org> for the
hints.
Audio recording requires software audio processing.
Both hardware and software processing is simultaniously possible now.
DTMF digits were sent up to socket in locked state.
Receive audio stream was not enabled in certain condition.
Add IMHOLD_L1 ioctl.
The feature will be disabled on closing.
Need to protect the complete pipeline.
Reduce stack size memory footprint of mISDN_dsp.
(From 1468 bytes for dsp_cmx_send on i386 down to 44).
Added tx-fifo information for calculation of current delay to sync tx and rx
streams for echo canceler.
DSP now uses ring buffer for echo canceler.
Added missing include in l1oip_codec.c
This patch was made by Titus Moldovan and provides IOCTL functions for enabling
and disabling the controller's built in watchdog. The use is optional.
The B channel data structure member rcvbytes was never set to
anything else but zero, so drop it.
Impact: cleanup
Drop the kernel config option GIGASET_UNDOCREQ, permanently
activating the code it controlled, as there have been no reports
of problems caused by its activation but many problems caused by
it being disabled.
Also fix a few bad comments while we're at it.
Impact: cleanup
In preparation for porting to kernel CAPI subsystem, include the
Gigaset driver's Kconfig directly from ISDN's instead of I4L's.
Impact: Kconfig reorganisation, no functional change
gigaset_register_to_LL() is expected to print a message and return 0
on failure. Make it do so consistently.
Impact: error handling bugfix
Don't generate the hex representation of the payload data if it
isn't actually used afterwards.
Impact: optimization
