path: root/drivers/isdn
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-09-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Another merge window, another set of networking changes. I've heard rumblings that the lightweight tunnels infrastructure has been voted networking change of the year. But what do I know? 1) Add conntrack support to openvswitch, from Joe Stringer. 2) Initial support for VRF (Virtual Routing and Forwarding), which allows the segmentation of routing paths without using multiple devices. There are some semantic kinks to work out still, but this is a reasonably strong foundation. From David Ahern. 3) Remove spinlock fro act_bpf fast path, from Alexei Starovoitov. 4) Ignore route nexthops with a link down state in ipv6, just like ipv4. From Andy Gospodarek. 5) Remove spinlock from fast path of act_gact and act_mirred, from Eric Dumazet. 6) Document the DSA layer, from Florian Fainelli. 7) Add netconsole support to bcmgenet, systemport, and DSA. Also from Florian Fainelli. 8) Add Mellanox Switch Driver and core infrastructure, from Jiri Pirko. 9) Add support for "light weight tunnels", which allow for encapsulation and decapsulation without bearing the overhead of a full blown netdevice. From Thomas Graf, Jiri Benc, and a cast of others. 10) Add Identifier Locator Addressing support for ipv6, from Tom Herbert. 11) Support fragmented SKBs in iwlwifi, from Johannes Berg. 12) Allow perf PMUs to be accessed from eBPF programs, from Kaixu Xia. 13) Add BQL support to 3c59x driver, from Loganaden Velvindron. 14) Stop using a zero TX queue length to mean that a device shouldn't have a qdisc attached, use an explicit flag instead. From Phil Sutter. 15) Use generic geneve netdevice infrastructure in openvswitch, from Pravin B Shelar. 16) Add infrastructure to avoid re-forwarding a packet in software that was already forwarded by a hardware switch. From Scott Feldman. 17) Allow AF_PACKET fanout function to be implemented in a bpf program, from Willem de Bruijn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1458 commits) netfilter: nf_conntrack: make nf_ct_zone_dflt built-in netfilter: nf_dup{4, 6}: fix build error when nf_conntrack disabled net: fec: clear receive interrupts before processing a packet ipv6: fix exthdrs offload registration in out_rt path xen-netback: add support for multicast control bgmac: Update fixed_phy_register() sock, diag: fix panic in sock_diag_put_filterinfo flow_dissector: Use 'const' where possible. flow_dissector: Fix function argument ordering dependency ixgbe: Resolve "initialized field overwritten" warnings ixgbe: Remove bimodal SR-IOV disabling ixgbe: Add support for reporting 2.5G link speed ixgbe: fix bounds checking in ixgbe_setup_tc for 82598 ixgbe: support for ethtool set_rxfh ixgbe: Avoid needless PHY access on copper phys ixgbe: cleanup to use cached mask value ixgbe: Remove second instance of lan_id variable ixgbe: use kzalloc for allocating one thing flow: Move __get_hash_from_flowi{4,6} into flow_dissector.c ixgbe: Remove unused PCI bus types ...
2015-08-10arch, drivers: don't include <asm/io.h> directly, use <linux/io.h> insteadDan Williams
Preparation for uniform definition of ioremap, ioremap_wc, ioremap_wt, and ioremap_cache, tree-wide. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-08-10isdn: Remove reverse_bits(), use revbit8()yalin wang
This change isdn driver, remove reverse_bits() function, use the generic revbit8() function instead. Signed-off-by: yalin wang <yalin.wang2010@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-07treewide: Fix typo in printkMasanari Iida
This patch fix spelling typo inv various part of sources. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-07-15isdn/gigaset: drop unused ldisc methodsTilman Schmidt
The line discipline read and write methods are optional so the dummy methods in ser_gigaset are unnecessary and can be removed. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-15isdn/gigaset: reset tty->receive_room when attaching ser_gigasetTilman Schmidt
Commit 79901317ce80 ("n_tty: Don't flush buffer when closing ldisc"), first merged in kernel release 3.10, caused the following regression in the Gigaset M101 driver: Before that commit, when closing the N_TTY line discipline in preparation to switching to N_GIGASET_M101, receive_room would be reset to a non-zero value by the call to n_tty_flush_buffer() in n_tty's close method. With the removal of that call, receive_room might be left at zero, blocking data reception on the serial line. The present patch fixes that regression by setting receive_room to an appropriate value in the ldisc open method. Fixes: 79901317ce80 ("n_tty: Don't flush buffer when closing ldisc") Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add TX fast path in mac80211, from Johannes Berg. 2) Add TSO/GRO support to ibmveth, from Thomas Falcon 3) Move away from cached routes in ipv6, just like ipv4, from Martin KaFai Lau. 4) Lots of new rhashtable tests, from Thomas Graf. 5) Run ingress qdisc lockless, from Alexei Starovoitov. 6) Allow servers to fetch TCP packet headers for SYN packets of new connections, for fingerprinting. From Eric Dumazet. 7) Add mode parameter to pktgen, for testing receive. From Alexei Starovoitov. 8) Cache access optimizations via simplifications of build_skb(), from Alexander Duyck. 9) Move page frag allocator under mm/, also from Alexander. 10) Add xmit_more support to hv_netvsc, from KY Srinivasan. 11) Add a counter guard in case we try to perform endless reclassify loops in the packet scheduler. 12) Extern flow dissector to be programmable and use it in new "Flower" classifier. From Jiri Pirko. 13) AF_PACKET fanout rollover fixes, performance improvements, and new statistics. From Willem de Bruijn. 14) Add netdev driver for GENEVE tunnels, from John W Linville. 15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso. 16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet. 17) Add an ECN retry fallback for the initial TCP handshake, from Daniel Borkmann. 18) Add tail call support to BPF, from Alexei Starovoitov. 19) Add several pktgen helper scripts, from Jesper Dangaard Brouer. 20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa. 21) Favor even port numbers for allocation to connect() requests, and odd port numbers for bind(0), in an effort to help avoid ip_local_port_range exhaustion. From Eric Dumazet. 22) Add Cavium ThunderX driver, from Sunil Goutham. 23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata, from Alexei Starovoitov. 24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai. 25) Double TCP Small Queues default to 256K to accomodate situations like the XEN driver and wireless aggregation. From Wei Liu. 26) Add more entropy inputs to flow dissector, from Tom Herbert. 27) Add CDG congestion control algorithm to TCP, from Kenneth Klette Jonassen. 28) Convert ipset over to RCU locking, from Jozsef Kadlecsik. 29) Track and act upon link status of ipv4 route nexthops, from Andy Gospodarek. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits) bridge: vlan: flush the dynamically learned entries on port vlan delete bridge: multicast: add a comment to br_port_state_selection about blocking state net: inet_diag: export IPV6_V6ONLY sockopt stmmac: troubleshoot unexpected bits in des0 & des1 net: ipv4 sysctl option to ignore routes when nexthop link is down net: track link-status of ipv4 nexthops net: switchdev: ignore unsupported bridge flags net: Cavium: Fix MAC address setting in shutdown state drivers: net: xgene: fix for ACPI support without ACPI ip: report the original address of ICMP messages net/mlx5e: Prefetch skb data on RX net/mlx5e: Pop cq outside mlx5e_get_cqe net/mlx5e: Remove mlx5e_cq.sqrq back-pointer net/mlx5e: Remove extra spaces net/mlx5e: Avoid TX CQE generation if more xmit packets expected net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq() net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device ...
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/mellanox/mlx4/main.c net/packet/af_packet.c Both conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "As usual, mostly comment, kerneldoc and printk() fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: lpfc: Grammar s/an negative/a negative/ ARM: lib/lib1funcs.S: fix typo s/substractions/subtractions/ cx25821: cx25821-medusa-reg.h: fix 0x0x prefix lib: crc-itu-t.[ch] fix 0x0x prefix in integer constants rapidio: Fix kerneldoc and comment qla4xxx: Fix printk() in qla4_83xx_read_reset_template() and qla4_83xx_pre_loopback_config() treewide: Kconfig: fix wording / spelling usb/serial: fix grammar in Kconfig help text for FTDI_SIO megaraid_sas: fix kerneldoc netfilter: ebtables: fix comment grammar drm/radeon: fix comment isdn: fix grammar in comment ARM: KVM: fix comment
2015-06-21isdn: disable HiSax NetJet driver on microblaze archNicolai Stange
Fix an allmodconfig compilation failer on microblaze due to big endian architectures being apparently unsupported by the NetJet code: drivers/isdn/hisax/nj_s.c: In function 'setup_netjet_s': drivers/isdn/hisax/nj_s.c:265:2: error: #error "not running on big endian machines now" Modify the relevant Kconfig such that the NetJet code is not built on microblaze anymore. Note that endianess on microblaze is not determined through Kconfig, but by means of a compiler provided CPP macro, namely __MICROBLAZEEL__. However, gcc defaults to big endianess on that platform. Signed-off-by: Nicolai Stange <nicstange@gmail.com> Acked-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-07isdn/hisax: Convert use of __constant_cpu_to_le16 to cpu_to_le16Vaishali Thakkar
In big endian cases, macro cpu_to_le16 unfolds to __swab16 which provides special case for constants. In little endian cases, __constant_cpu_to_le16 and cpu_to_le16 expand directly to the same expression. So, replace __constant_cpu_to_le16 with cpu_to_le16 with the goal of getting rid of the definition of __constant_cpu_to_le16 completely. The semantic patch that performs this transformation is as follows: @@expression x;@@ - __constant_cpu_to_le16(x) + cpu_to_le16(x) Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31isdn/capi: Use setup_timerVaishali Thakkar
Use the timer API function setup_timer instead of structure field assignments to initialize a timer. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @change@ expression e1, e2, e3, e4, a, b; @@ -init_timer(&e1); +setup_timer(&e1, a, b); ... when != a = e2 when != b = e3 -e1.data = b; ... when != a = e4 -e1.function = a; Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-26isdn: fix grammar in commentGeert Uytterhoeven
Fix grammar / typo in comment. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Karsten Keil <isdn@linux-pingi.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-05-11net: Pass kern from net_proto_family.create to sk_allocEric W. Biederman
In preparation for changing how struct net is refcounted on kernel sockets pass the knowledge that we are creating a kernel socket from sock_create_kern through to sk_alloc. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add BQL support to via-rhine, from Tino Reichardt. 2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers can support hw switch offloading. From Floria Fainelli. 3) Allow 'ip address' commands to initiate multicast group join/leave, from Madhu Challa. 4) Many ipv4 FIB lookup optimizations from Alexander Duyck. 5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel Borkmann. 6) Remove the ugly compat support in ARP for ugly layers like ax25, rose, etc. And use this to clean up the neigh layer, then use it to implement MPLS support. All from Eric Biederman. 7) Support L3 forwarding offloading in switches, from Scott Feldman. 8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed up route lookups even further. From Alexander Duyck. 9) Many improvements and bug fixes to the rhashtable implementation, from Herbert Xu and Thomas Graf. In particular, in the case where an rhashtable user bulk adds a large number of items into an empty table, we expand the table much more sanely. 10) Don't make the tcp_metrics hash table per-namespace, from Eric Biederman. 11) Extend EBPF to access SKB fields, from Alexei Starovoitov. 12) Split out new connection request sockets so that they can be established in the main hash table. Much less false sharing since hash lookups go direct to the request sockets instead of having to go first to the listener then to the request socks hashed underneath. From Eric Dumazet. 13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk. 14) Support stable privacy address generation for RFC7217 in IPV6. From Hannes Frederic Sowa. 15) Hash network namespace into IP frag IDs, also from Hannes Frederic Sowa. 16) Convert PTP get/set methods to use 64-bit time, from Richard Cochran. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits) fm10k: Bump driver version to 0.15.2 fm10k: corrected VF multicast update fm10k: mbx_update_max_size does not drop all oversized messages fm10k: reset head instead of calling update_max_size fm10k: renamed mbx_tx_dropped to mbx_tx_oversized fm10k: update xcast mode before synchronizing multicast addresses fm10k: start service timer on probe fm10k: fix function header comment fm10k: comment next_vf_mbx flow fm10k: don't handle mailbox events in iov_event path and always process mailbox fm10k: use separate workqueue for fm10k driver fm10k: Set PF queues to unlimited bandwidth during virtualization fm10k: expose tx_timeout_count as an ethtool stat fm10k: only increment tx_timeout_count in Tx hang path fm10k: remove extraneous "Reset interface" message fm10k: separate PF only stats so that VF does not display them fm10k: use hw->mac.max_queues for stats fm10k: only show actual queues, not the maximum in hardware fm10k: allow creation of VLAN on default vid fm10k: fix unused warnings ...
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Usual trivial tree updates. Nothing outstanding -- mostly printk() and comment fixes and unused identifier removals" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: goldfish: goldfish_tty_probe() is not using 'i' any more powerpc: Fix comment in smu.h qla2xxx: Fix printks in ql_log message lib: correct link to the original source for div64_u64 si2168, tda10071, m88ds3103: Fix firmware wording usb: storage: Fix printk in isd200_log_config() qla2xxx: Fix printk in qla25xx_setup_mode init/main: fix reset_device comment ipwireless: missing assignment goldfish: remove unreachable line of code coredump: Fix do_coredump() comment stacktrace.h: remove duplicate declaration task_struct smpboot.h: Remove unused function prototype treewide: Fix typo in printk messages treewide: Fix typo in printk messages mod_devicetable: fix comment for match_flags
2015-03-23isdn/gigaset: restructure modem response parser (4)Tilman Schmidt
Restructure the control structure of the modem response parser to improve readability and error handling. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23isdn/gigaset: restructure modem response parser (3)Tilman Schmidt
Separate CID detection from main parser loop. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23isdn/gigaset: restructure modem response parser (2)Tilman Schmidt
Separate literal string handling from main parser loop. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23isdn/gigaset: restructure modem response parser (1)Tilman Schmidt
Factor out queueing of modem response events into helper function add_cid_event(). Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c net/core/sysctl_net_core.c net/ipv4/inet_diag.c The be_main.c conflict resolution was really tricky. The conflict hunks generated by GIT were very unhelpful, to say the least. It split functions in half and moved them around, when the real actual conflict only existed solely inside of one function, that being be_map_pci_bars(). So instead, to resolve this, I checked out be_main.c from the top of net-next, then I applied the be_main.c changes from 'net' since the last time I merged. And this worked beautifully. The inet_diag.c and sysctl_net_core.c conflicts were simple overlapping changes, and were easily to resolve. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-15isdn: icn: use strlcpy() when parsing setup optionsDan Carpenter
If you pass an invalid string here then you probably deserve the memory corruption, but it annoys static analysis tools so lets fix it. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-06treewide: Fix typo in printk messagesMasanari Iida
This patch fix spelling typo in printk messages. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/rocker/rocker.c The rocker commit was two overlapping changes, one to rename the ->vport member to ->pport, and another making the bitmask expression use '1ULL' instead of plain '1'. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) If an IPVS tunnel is created with a mixed-family destination address, it cannot be removed. Fix from Alexey Andriyanov. 2) Fix module refcount underflow in netfilter's nft_compat, from Pablo Neira Ayuso. 3) Generic statistics infrastructure can reference variables sitting on a released function stack, therefore use dynamic allocation always. Fix from Ignacy Gawędzki. 4) skb_copy_bits() return value test is inverted in ip_check_defrag(). 5) Fix network namespace exit in openvswitch, we have to release all of the per-net vports. From Pravin B Shelar. 6) Fix signedness bug in CAIF's cfpkt_iterate(), from Dan Carpenter. 7) Fix rhashtable grow/shrink behavior, only expand during inserts and shrink during deletes. From Daniel Borkmann. 8) Netdevice names with semicolons should never be allowed, because they serve as a separator. From Matthew Thode. 9) Use {,__}set_current_state() where appropriate, from Fabian Frederick. 10) Revert byte queue limits support in r8169 driver, it's causing regressions we can't figure out. 11) tcp_should_expand_sndbuf() erroneously uses tp->packets_out to measure packets in flight, properly use tcp_packets_in_flight() instead. From Neal Cardwell. 12) Fix accidental removal of support for bluetooth in CSR based Intel wireless cards. From Marcel Holtmann. 13) We accidently added a behavioral change between native and compat tasks, wrt testing the MSG_CMSG_COMPAT bit. Just ignore it if the user happened to set it in a native binary as that was always the behavior we had. From Catalin Marinas. 14) Check genlmsg_unicast() return valud in hwsim netlink tx frame handling, from Bob Copeland. 15) Fix stale ->radar_required setting in mac80211 that can prevent starting new scans, from Eliad Peller. 16) Fix memory leak in nl80211 monitor, from Johannes Berg. 17) Fix race in TX index handling in xen-netback, from David Vrabel. 18) Don't enable interrupts in amx-xgbe driver until all software et al. state is ready for the interrupt handler to run. From Thomas Lendacky. 19) Add missing netlink_ns_capable() checks to rtnl_newlink(), from Eric W Biederman. 20) The amount of header space needed in macvtap was not calculated properly, fix it otherwise we splat past the beginning of the packet. From Eric Dumazet. 21) Fix bcmgenet TCP TX perf regression, from Jaedon Shin. 22) Don't raw initialize or mod timers, use setup_timer() and mod_timer() instead. From Vaishali Thakkar. 23) Fix software maintained statistics in bcmgenet and systemport drivers, from Florian Fainelli. 24) DMA descriptor updates in sh_eth need proper memory barriers, from Ben Hutchings. 25) Don't do UDP Fragmentation Offload on RAW sockets, from Michal Kubecek. 26) Openvswitch's non-masked set actions aren't constructed properly into netlink messages, fix from Joe Stringer. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) openvswitch: Fix serialization of non-masked set actions. gianfar: Reduce logging noise seen due to phy polling if link is down ibmveth: Add function to enable live MAC address changes net: bridge: add compile-time assert for cb struct size udp: only allow UFO for packets from SOCK_DGRAM sockets sh_eth: Really fix padding of short frames on TX Revert "sh_eth: Enable Rx descriptor word 0 shift for r8a7790" sh_eth: Fix RX recovery on R-Car in case of RX ring underrun sh_eth: Ensure proper ordering of descriptor active bit write/read net/mlx4_en: Disbale GRO for incoming loopback/selftest packets net/mlx4_core: Fix wrong mask and error flow for the update-qp command net: systemport: fix software maintained statistics net: bcmgenet: fix software maintained statistics rxrpc: don't multiply with HZ twice rxrpc: terminate retrans loop when sending of skb fails net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR interface. net: pasemi: Use setup_timer and mod_timer net: stmmac: Use setup_timer and mod_timer net: 8390: axnet_cs: Use setup_timer and mod_timer net: 8390: pcnet_cs: Use setup_timer and mod_timer ...
2015-03-02net: Kill dev_rebuild_headerEric W. Biederman
Now that there are no more users kill dev_rebuild_header and all of it's implementations. This is long overdue. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-22mISDN: replace current->state by set_current_state()Fabian Frederick
Use helper function to access current->state. Direct assignments are prone to races and therefore buggy. Thanks to Peter Zijlstra for the exact definition of the problem. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-19Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "Yann E Morin was supposed to take over kconfig maintainership, but this hasn't happened. So I'm sending a few kconfig patches that I collected: - Fix for missing va_end in kconfig - merge_config.sh displays used if given too few arguments - s/boolean/bool/ in Kconfig files for consistency, with the plan to only support bool in the future" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: use va_end to match corresponding va_start merge_config.sh: Display usage if given too few arguments kconfig: use bool instead of boolean for type definition attributes
2015-02-05drivers: isdn: isdnloop: isdnloop.c: Remove parenthesis around return ↵Bas Peters
values, as specified in CodingStyle. Signed-off-by: Bas Peters <baspeters93@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05drivers: isdn: isdnloop: isdnloop.c: Fix brace positions according to ↵Bas Peters
CodingStyle specifications. Signed-off-by: Bas Peters <baspeters93@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05drivers: isdn: isdnloop: isdnloop.c: remove assignment of variables in if ↵Bas Peters
conditions, in accordance with the CodingStyle. Signed-off-by: Bas Peters <baspeters93@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vxlan.c drivers/vhost/net.c include/linux/if_vlan.h net/core/dev.c The net/core/dev.c conflict was the overlap of one commit marking an existing function static whilst another was adding a new function. In the include/linux/if_vlan.h case, the type used for a local variable was changed in 'net', whereas the function got rewritten to fix a stacked vlan bug in 'net-next'. In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next' overlapped with an endainness fix for VHOST 1.0 in 'net'. In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter in 'net-next' whereas in 'net' there was a bug fix to pass in the correct network namespace pointer in calls to this function. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-02isdn: off by one in connect_res()Dan Carpenter
The bug here is that we use "Reject" as the index into the cau_t[] array in the else path. Since the cau_t[] has 9 elements if Reject == 9 then we are reading beyond the end of the array. My understanding of the code is that it's saying that if Reject is 1 or too high then that's invalid and we should hang up. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-18Drivers: Isdn: sc: Fixed coding style & spelling mistakes.Akash Shende
Fix some spelling mistakes, coding style and don't assign value to static var. Signed-off-by: Akash Shende <akash0x53s@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/xen-netfront.c Minor overlapping changes in xen-netfront.c, mostly to do with some buffer management changes alongside the split of stats into TX and RX. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-13mISDN: avoid arch specific __builtin_return_address callArnd Bergmann
Not all architectures are able to call __builtin_return_address(). On ARM, the mISDN code produces this warning: hardware/mISDN/w6692.c: In function 'w6692_dctrl': hardware/mISDN/w6692.c:1181:75: warning: unsupported argument to '__builtin_return_address' pr_debug("%s: %s dev(%d) open from %p\n", card->name, __func__, ^ hardware/mISDN/mISDNipac.c: In function 'open_dchannel': hardware/mISDN/mISDNipac.c:759:75: warning: unsupported argument to '__builtin_return_address' pr_debug("%s: %s dev(%d) open from %p\n", isac->name, __func__, ^ In a lot of cases, this is relatively easy to work around by passing the value of __builtin_return_address(0) from the callers into the functions that want it. One exception is the indirect 'open' function call in struct isac_hw. While it would be possible to fix this as well, this patch only addresses the other callers properly and lets this one return the direct parent function, which should be good enough. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-12isdn: fix NUL (\0 or \x00) specification in stringGiel van Schijndel
In C one can either use '\0' or '\x00' (or '\000') to add a NUL byte to a string. '\0x00' isn't part of these and will in fact result in a single NUL followed by "x00". This fixes that. Signed-off-by: Giel van Schijndel <me@mortis.eu> Reported-at: http://www.viva64.com/en/b/0299/ Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-07kconfig: use bool instead of boolean for type definition attributesChristoph Jaeger
Support for keyword 'boolean' will be dropped later on. No functional change. Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com Signed-off-by: Christoph Jaeger <cj@linux.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-01-02isdn: hisax: hfc4s8s_l1: Remove some unused functionsRickard Strandqvist
Removes some functions that are not used anywhere: Read_hfc32() Write_hfc32() Write_hfc16() This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree update from Jiri Kosina: "Usual stuff: documentation updates, printk() fixes, etc" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) intel_ips: fix a type in error message cpufreq: cpufreq-dt: Move newline to end of error message ps3rom: fix error return code treewide: fix typo in printk and Kconfig ARM: dts: bcm63138: change "interupts" to "interrupts" Replace mentions of "list_struct" to "list_head" kernel: trace: fix printk message scsi: mpt2sas: fix ioctl in comment zbud, zswap: change module author email clocksource: Fix 'clcoksource' typo in comment arm: fix wording of "Crotex" in CONFIG_ARCH_EXYNOS3 help gpio: msm-v1: make boolean argument more obvious usb: Fix typo in usb-serial-simple.c PCI: Fix comment typo 'COMFIG_PM_OPS' powerpc: Fix comment typo 'CONIFG_8xx' powerpc: Fix comment typos 'CONFiG_ALTIVEC' clk: st: Spelling s/stucture/structure/ isci: Spelling s/stucture/structure/ usb: gadget: zero: Spelling s/infrastucture/infrastructure/ treewide: Fix company name in module descriptions ...
2014-12-10isdn/capi: correct argument types of command_2_indexTilman Schmidt
Utility function command_2_index is always called with arguments of type u8. Adapt its declaration accordingly. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: enable Kernel CAPI support by defaultTilman Schmidt
Kernel CAPI has been the recommended ISDN subsystem for the Gigaset driver since kernel release 2.6.34.2. It provides full backwards compatibility to the old I4L subsystem thanks to the capidrv module. I4L has been marked as deprecated for more than seven years. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: elliminate unnecessary argument from send_cb()Tilman Schmidt
No need to pass a member of the cardstate structure as a separate argument if the entire structure is already passed. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: clarify gigaset_modem_fill control structureTilman Schmidt
Replace the flag-controlled retry loop by explicit goto statements in the error branches to make the control structure easier to understand. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10isdn/gigaset: drop duplicate declarationTilman Schmidt
Function gigaset_skb_sent was declared twice, identically, in gigaset.h. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09isdn: fix misspelling of current function in stringJulia Lawall
Replace a misspelled function name by %s and then __func__. In the first case, the print is just dropped, because kmalloc itself does enough error reporting. This was done using Coccinelle, including the use of Levenshtein distance, as proposed by Rasmus Villemoes. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-21mISDN: Deletion of unnecessary checks before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
