Since the API for controlling LED brightness and blinking is defined in
the LED core, move the related timer and work callbacks to the led-core.c,
and initialize them through a new led_core_init API.
Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Pavel Machek <pavel@ucw.cz>
Devices found by class_find_device must be freed with put_device().
Otherwise the reference count will not work properly.
Fixes: a96aa64cb572 ("leds/led-class: Handle LEDs with the same name")
Reported-by: Alan Tull <delicious.quinoa@gmail.com>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem updates from Bryan Wu:
"In this cycle, we finished to merge patches for LED Flash class
driver.
Other than that we have some bug fixes and new drivers for LED
controllers"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (33 commits)
leds:lp55xx: fix firmware loading error
leds: fix max77693-led build errors
leds: fix aat1290 build errors
leds: aat1290: pass flags parameter to devm_gpiod_get
leds: ktd2692: pass flags parameter to devm_gpiod_get
drivers/leds: don't use module_init in non-modular leds-cobalt-raq.c
leds: aat1290: add support for V4L2 Flash sub-device
DT: aat1290: Document handling external strobe sources
leds: max77693: add support for V4L2 Flash sub-device
media: Add registration helpers for V4L2 flash sub-devices
v4l: async: Add a pointer to of_node to struct v4l2_subdev, match it
Documentation: leds: Add description of v4l2-flash sub-device
leds: add BCM6358 LED driver
leds: add DT binding for BCM6358 LED controller
leds: fix brightness changing when software blinking is active
Documentation: leds-lp5523: describe master fader attributes
leds: lp5523: add master_fader support
leds: leds-gpio: Allow compile test if !GPIOLIB
leds: leds-gpio: Add missing #include <linux/of.h>
gpiolib: Add missing dummies for the unified device properties interface
The following sequence:
echo timer >/sys/class/leds/<name>/trigger
echo 1 >/sys/class/leds/<name>/brightness
should change the ON brightness for blinking.
The function led_set_brightness() was mistakenly initiating the
delayed blink stop procedure, which resulted in no blinking with
the timer trigger still active.
This patch fixes the problem by changing led_set_brightness()
to not initiate the delayed blink stop when brightness is not 0.
CC: Richard Purdie <rpurdie@rpsys.net>
CC: Kyungmin Park <kyungmin.park@samsung.com>
CC: linux-leds@vger.kernel.org
CC: linux-kernel@vger.kernel.org
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net>
Signed-off-by: Bryan Wu <cooloney@gmail.com>
Setting a dev_pm_ops suspend/resume pair of callbacks but not a set of
hibernation callbacks means those pm functions will not be
called upon hibernation - that leads to system crash on ARM during
freezing if gpio-led is used in combination with CPU led trigger.
It may happen after freeze_noirq stage (GPIO is suspended)
and before syscore_suspend stage (CPU led trigger is suspended)
- usually when disable_nonboot_cpus() is called.
Log:
PM: noirq freeze of devices complete after 1.425 msecs
Disabling non-boot CPUs ...
^ system may crash or stuck here with message (TI AM572x)
WARNING: CPU: 0 PID: 3100 at drivers/bus/omap_l3_noc.c:148 l3_interrupt_handler+0x22c/0x370()
44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Idle): Data Access in Supervisor mode during Functional access
CPU1: shutdown
^ or here
Fix this by using SIMPLE_DEV_PM_OPS, which appropriately
assigns the suspend and hibernation callbacks and move
led_suspend/led_resume under CONFIG_PM_SLEEP to avoid
build warnings.
Fixes: 73e1ab41a80d (leds: Convert led class driver from legacy pm ops to dev_pm_ops)
Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org>
Cc: 3.11+ <stable@vger.kernel.org> # 3.11+
The LED name was wrongly interpreted as format string. Stop doing that.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
The LED names are expected to be unique in the system. Use KERN_WARNING log
level to notify the user about the matter.
The current code expected that every LED had an unique name. This is a
legit expectation when the device tree can no be modified or extended.
But with device tree overlays this requirement can be easily broken.
This patch finds out if the name is already in use and adds the suffix
_1, _2... if not.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
(cooloney@gmail.com: add _unregister function into the document)
Suggested-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Some LED devices support two operation modes - torch and flash.
This patch provides support for flash LED devices in the LED subsystem
by introducing new sysfs attributes and kernel internal interface.
The attributes being introduced are: flash_brightness, flash_strobe,
flash_timeout, max_flash_timeout, max_flash_brightness, flash_fault,
flash_sync_strobe and available_sync_leds. All the flash related
features are placed in a separate module.
The modifications aim to be compatible with V4L2 framework requirements
related to the flash devices management. The design assumes that V4L2
sub-device can take of the LED class device control and communicate
with it through the kernel internal interface. When V4L2 Flash sub-device
file is opened, the LED class device sysfs interface is made
unavailable.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
There are use cases when setting a LED brightness has to
have immediate effect (e.g. setting a torch LED brightness).
This patch extends LED subsystem to support such operations.
The LED subsystem internal API __led_set_brightness is changed
to led_set_brightness_async and new led_set_brightness_sync API
is added.
Add a mechanism for locking LED subsystem sysfs interface.
This patch prepares ground for addition of LED Flash Class
extension, whose API will be integrated with V4L2 Flash API.
Such a fusion enforces introducing a locking scheme, which
will secure consistent access to the LED Flash Class device.
The mechanism being introduced allows for disabling LED
subsystem sysfs interface by calling led_sysfs_disable function
and enabling it by calling led_sysfs_enable. The functions
alter the LED_SYSFS_DISABLE flag state and must be called
under mutex lock. The state of the lock is checked with use
of led_sysfs_is_disabled function. Such a design allows for
providing immediate feedback to the user space on whether
the LED Flash Class device is available or is under V4L2 Flash
sub-device control.
led_update_brightness helper function used to be exploited only locally
in the led-class.c module, where its result was being passed to the
brightness_show sysfs callback. With the introduction of v4l2-flash
subdevice the same functionality becomes required for reading current
brightness from a LED device. This patch adds checking of return value
of the brightness_get callback and moves the led_update_brightness()
function to the LED subsystem public API.
Make definition of the brightness related sysfs attributes
consistent. The modification entails change of the function
name: led_max_brightness_show -> max_brightness_show
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Reorder include directives so that they are arranged
in alphabetical order.
This reverts commit 8b37e1bef5a6b60e949e28a4db3006e4b00bd758.
It's broken as it changes led_blink_set() in a way that it can now sleep
(while synchronously waiting for workqueue to be cancelled). That's a
problem, because it's possible that this function gets called from atomic
context (tpt_trig_timer() takes a readlock and thus disables preemption).
This has been brought up 3 weeks ago already [1] but no proper fix has
materialized, and I keep seeing the problem since 3.17-rc1.
[1] https://lkml.org/lkml/2014/8/16/128
BUG: sleeping function called from invalid context at kernel/workqueue.c:2650
in_atomic(): 1, irqs_disabled(): 0, pid: 2335, name: wpa_supplicant
5 locks held by wpa_supplicant/2335:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff814c7c92>] rtnl_lock+0x12/0x20
#1: (&wdev->mtx){+.+.+.}, at: [<ffffffffc06e649c>] cfg80211_mgd_wext_siwessid+0x5c/0x180 [cfg80211]
#2: (&local->mtx){+.+.+.}, at: [<ffffffffc0817dea>] ieee80211_prep_connection+0x17a/0x9a0 [mac80211]
#3: (&local->chanctx_mtx){+.+.+.}, at: [<ffffffffc08081ed>] ieee80211_vif_use_channel+0x5d/0x2a0 [mac80211]
#4: (&trig->leddev_list_lock){.+.+..}, at: [<ffffffffc081e68c>] tpt_trig_timer+0xec/0x170 [mac80211]
CPU: 0 PID: 2335 Comm: wpa_supplicant Not tainted 3.17.0-rc3 #1
Hardware name: LENOVO 7470BN2/7470BN2, BIOS 6DET38WW (2.02 ) 12/19/2008
ffff8800360b5a50 ffff8800751f76d8 ffffffff8159e97f ffff8800360b5a30
ffff8800751f76e8 ffffffff810739a5 ffff8800751f77b0 ffffffff8106862f
ffffffff810685d0 0aa2209200000000 ffff880000000004 ffff8800361c59d0
Call Trace:
[<ffffffff8159e97f>] dump_stack+0x4d/0x66
[<ffffffff810739a5>] __might_sleep+0xe5/0x120
[<ffffffff8106862f>] flush_work+0x5f/0x270
[<ffffffff810685d0>] ? mod_delayed_work_on+0x80/0x80
[<ffffffff810945ca>] ? mark_held_locks+0x6a/0x90
[<ffffffff81068a5f>] ? __cancel_work_timer+0x6f/0x100
[<ffffffff810946ed>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[<ffffffff81068a6b>] __cancel_work_timer+0x7b/0x100
[<ffffffff81068b0e>] cancel_delayed_work_sync+0xe/0x10
[<ffffffff8147cf3b>] led_blink_set+0x1b/0x40
[<ffffffffc081e6b0>] tpt_trig_timer+0x110/0x170 [mac80211]
[<ffffffffc081ecdd>] ieee80211_mod_tpt_led_trig+0x9d/0x160 [mac80211]
[<ffffffffc07e4278>] __ieee80211_recalc_idle+0x98/0x140 [mac80211]
[<ffffffffc07e59ce>] ieee80211_idle_off+0xe/0x10 [mac80211]
[<ffffffffc0804e5b>] ieee80211_add_chanctx+0x3b/0x220 [mac80211]
[<ffffffffc08062e4>] ieee80211_new_chanctx+0x44/0xf0 [mac80211]
[<ffffffffc080838a>] ieee80211_vif_use_channel+0x1fa/0x2a0 [mac80211]
[<ffffffffc0817df8>] ieee80211_prep_connection+0x188/0x9a0 [mac80211]
[<ffffffffc081c246>] ieee80211_mgd_auth+0x256/0x2e0 [mac80211]
[<ffffffffc07eab33>] ieee80211_auth+0x13/0x20 [mac80211]
[<ffffffffc06cb006>] cfg80211_mlme_auth+0x106/0x270 [cfg80211]
[<ffffffffc06ce085>] cfg80211_conn_do_work+0x155/0x3b0 [cfg80211]
[<ffffffffc06cf670>] cfg80211_connect+0x3f0/0x540 [cfg80211]
[<ffffffffc06e6148>] cfg80211_mgd_wext_connect+0x158/0x1f0 [cfg80211]
[<ffffffffc06e651e>] cfg80211_mgd_wext_siwessid+0xde/0x180 [cfg80211]
[<ffffffffc06e36c0>] ? cfg80211_wext_giwessid+0x50/0x50 [cfg80211]
[<ffffffffc06e36dd>] cfg80211_wext_siwessid+0x1d/0x40 [cfg80211]
[<ffffffff81584d0c>] ioctl_standard_iw_point+0x14c/0x3e0
[<ffffffff8158502a>] ioctl_standard_call+0x8a/0xd0
[<ffffffff81584fa0>] ? ioctl_standard_iw_point+0x3e0/0x3e0
[<ffffffff81584b76>] wireless_process_ioctl.constprop.10+0xb6/0x100
[<ffffffff8158521d>] wext_handle_ioctl+0x5d/0xb0
[<ffffffff814cfb29>] dev_ioctl+0x329/0x620
[<ffffffff8149c7f2>] sock_ioctl+0x142/0x2e0
[<ffffffff811b0140>] do_vfs_ioctl+0x300/0x520
[<ffffffff815a67fb>] ? sysret_check+0x1b/0x56
[<ffffffff811b03e1>] SyS_ioctl+0x81/0xa0
[<ffffffff815a67d6>] system_call_fastpath+0x1a/0x1f
wlan0: send auth to 00:0b:6b:3c:8c:e4 (try 1/3)
wlan0: authenticated
wlan0: associate with 00:0b:6b:3c:8c:e4 (try 1/3)
wlan0: RX AssocResp from 00:0b:6b:3c:8c:e4 (capab=0x431 status=0 aid=2)
wlan0: associated
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
cfg80211: Calling CRDA for country: NA
wlan0: Limiting TX power to 27 (27 - 0) dBm as advertised by 00:0b:6b:3c:8c:e4
[ INFO: inconsistent lock state ]
3.17.0-rc3 #1 Not tainted
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
swapper/0/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
((&(&led_cdev->blink_work)->work)){+.?...}, at: [<ffffffff810685d0>] flush_work+0x0/0x270
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff81094dbe>] __lock_acquire+0x30e/0x1a30
[<ffffffff81096c81>] lock_acquire+0x91/0x110
[<ffffffff81068608>] flush_work+0x38/0x270
irq event stamp: 493416
hardirqs last enabled at (493416): [<ffffffff81068a5f>] __cancel_work_timer+0x6f/0x100
hardirqs last disabled at (493415): [<ffffffff81067e9f>] try_to_grab_pending+0x1f/0x160
softirqs last enabled at (493408): [<ffffffff81053ced>] _local_bh_enable+0x1d/0x50
softirqs last disabled at (493409): [<ffffffff81054c75>] irq_exit+0xa5/0xb0
Possible unsafe locking scenario:
CPU0
lock((&(&led_cdev->blink_work)->work));
<Interrupt>
*** DEADLOCK ***
2 locks held by swapper/0/0:
#0: (((&tpt_trig->timer))){+.-...}, at: [<ffffffff810b4c50>] call_timer_fn+0x0/0x180
#1: (&trig->leddev_list_lock){.+.?..}, at: [<ffffffffc081e68c>] tpt_trig_timer+0xec/0x170 [mac80211]
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.17.0-rc3 #1
ffffffff8246eb30 ffff88007c203b00 ffffffff8159e97f ffffffff81a194c0
ffff88007c203b50 ffffffff81599c29 0000000000000001 ffffffff00000001
ffff880000000000 0000000000000006 ffffffff81a194c0 ffffffff81093ad0
Call Trace:
<IRQ> [<ffffffff8159e97f>] dump_stack+0x4d/0x66
[<ffffffff81599c29>] print_usage_bug+0x1f4/0x205
[<ffffffff81093ad0>] ? check_usage_backwards+0x140/0x140
[<ffffffff810944d3>] mark_lock+0x223/0x2b0
[<ffffffff81094d60>] __lock_acquire+0x2b0/0x1a30
[<ffffffffc081e5a0>] ? __ieee80211_get_rx_led_name+0x10/0x10 [mac80211]
[<ffffffff8109469d>] ? trace_hardirqs_on_caller+0xad/0x1c0
[<ffffffff810b4cc5>] call_timer_fn+0x75/0x180
[<ffffffff810b4c50>] ? process_timeout+0x10/0x10
[<ffffffff810b50ac>] run_timer_softirq+0x1fc/0x2f0
[<ffffffff81054805>] __do_softirq+0x115/0x2e0
[<ffffffff810049b3>] do_IRQ+0x53/0xf0
[<ffffffff815a74af>] common_interrupt+0x6f/0x6f
<EOI> [<ffffffff8147b56e>] ? cpuidle_enter_state+0x6e/0x180
[<ffffffff8147b732>] cpuidle_enter+0x12/0x20
[<ffffffff8108bba0>] cpu_startup_entry+0x330/0x360
[<ffffffff8158fb51>] rest_init+0xc1/0xd0
[<ffffffff8158fa90>] ? csum_partial_copy_generic+0x170/0x170
[<ffffffff81af3ff2>] start_kernel+0x44f/0x45a
[<ffffffff81af399c>] ? set_init_arg+0x53/0x53
[<ffffffff81af35ad>] x86_64_start_reservations+0x2a/0x2c
[<ffffffff81af36a0>] x86_64_start_kernel+0xf1/0xf4
Cc: Vincent Donnefort <vdonnefort@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
This patch converts the blink timer from led-core to workqueue which is more
suitable for this kind of non-priority operations. Moreover, timer may lead to
errors when a LED setting function use a scheduling function such as pinctrl
which is using mutex.
Signed-off-by: Vincent Donnefort <vdonnefort@gmail.com>
Allow led-class devices to be created with optional attribute groups.
This is needed in order to allow led drivers to create custom device
attributes in a race-free manner.
Signed-off-by: Johan Hovold <johan@kernel.org>
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the led class code to use the
correct field.
Acked-by: Bryan Wu <cooloney@gmail.com>
Convert drivers/leds/led-class to use dev_pm_ops for power management and
remove Legacy PM ops hooks. With this change, led class registers
suspend/resume callbacks via class->pm (dev_pm_ops) instead of Legacy
class->suspend/resume. When __device_suspend() runs call-backs, it will
find class->pm ops for the led class.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Fixes the following checkpatch warning:
WARNING: Prefer netdev_dbg(netdev, ... then dev_dbg(dev, ... then pr_debug(... to printk(KERN_DEBUG ...
FILE: leds/led-class.c:214:
printk(KERN_DEBUG "Registered led device: %s\n",
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Delay execution of led_set_brightness() if need to stop soft-blink
timer.
This allows led_set_brightness to be called in hard-irq context even if
soft-blink was activated on that LED.
Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
Rename leds external interface led_brightness_set() to led_set_brightness().
This is the second phase of the change to reduce confusion between the
leds internal and external interfaces that set brightness. With this change,
now the external interface is led_set_brightness(). The first phase renamed
the internal interface led_set_brightness() to __led_set_brightness().
There are no changes to the interface implementations.
Signed-off-by: Shuah Khan <shuahkhan@gmail.com>
Rename leds internal interface led_set_brightness() to __led_set_brightness()
to reduce confusion between led_set_brightness() and the external interface
led_brightness_set(). led_brightness_set() cancels the timer and then calls
Add two new functions, led_blink_set_oneshot and
led_trigger_blink_oneshot, to be used by triggers for one-shot blink of
led devices.
This is implemented extending the existing software-blink code, and uses
the same timer and handler function.
The behavior of the code is to do a blink-on, blink-off sequence when
the function is called, ignoring other calls until the sequence is
completed so that the leds keep blinking at constant rate if the
functions are called repeatedly.
This is meant to be used by drivers which needs to trigger on sporadic
event, but doesn't have clear busy/idle trigger points.
After the blink sequence the led remains off. This behavior can be
inverted setting the "invert" argument, which blink the led off, than on
and leave the led on after the sequence.
(bryan.wu@canonical.com: rebase to commit 'leds: don't disable blinking
when writing the same value to delay_on or delay_off')
Acked-by: Shuah Khan <shuahkhan@gmail.com>
Fixed a coding style issue relating to trailing
white space error found by checkpatch.pl tool in drivers/leds/led-class.c
Signed-off-by: Jeffrin Jose <ahiliation@yahoo.co.in>
led-class.c and ledtrig-timer.c still use simple_strtoul(). Change them
to use kstrtoul() instead of obsolete simple_strtoul().
Also fix the existing int ret declaration to be ssize_t to match the
return type for _store functions in ledtrig-timer.c.
Cc: Joe Perches <joe@perches.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
After moving some core functions to led-core.c, led-class.c can be built
as module again.
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: "Venkatesh Pallipadi
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Revert commit 6123b0e274503a0d3588e84fbe07c9aa01bfaf5d.
The problem this patch intends to solve has alreadqy been fixed by
commit 7a5caabd090b ("drivers/leds/ledtrig-timer.c: fix broken sysfs
delay handling").
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Antonio Ospite <ospite@studenti.unina.it>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: <stable@vger.kernel.org>
Depending on the implementation of the hardware blinking function in
blink_set(), the led can support hardware blinking for some values of
delay_on and delay_off and fall-back to software blinking for some other
values.
Turning off the blink_timer unconditionally before starting to blink
make sure that a sequence like:
OFF
hardware blinking
software blinking
hardware blinking
does not leave the software blinking timer active.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Cc: <stable@kernel.org>
When calling the hardware blinking function implemented by blink_set(),
the delay_on and delay_off values are not preserved across calls.
Fix that and make the "timer" trigger work as expected when hardware
blinking is available.
BEFORE the fix:
$ cd /sys/class/leds/someled
$ echo timer > trigger
$ cat delay_on delay_off
0
0
$ echo 100 > delay_on
0
0
$ echo 100 > delay_off
0
0
AFTER the fix:
0
0
100
0
100
100
By setting initial values blink_delay_on and blink_delay_off in a
led_classdev struct, this change starts the blinking when the led is
initialized.
With this patch, you can initialize blink_delay_on and blink_delay_off in
led_classdev with default_trigger set to "timer", and the led will start
up blinking. The current ledtrig-timer implementation ignores any initial
blink_delay_on/blink_delay_off settings, and requires setting
blink_delay_on/blink_delay_off (typically from userspace) before the led
blinks.
Signed-off-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: Randy Dunlap <rdunlap@xenotime.net>
When I added led_blink_set I had a typo: the return value of the hw
offload is a regular error code that is zero when succesful, and in that
case software emulation should not be used, rather than the other way
around.
Cc: Richard Purdie <rpurdie@linux.intel.com>
Currently, blinking LEDs can be awkward because it is not guaranteed that
all LEDs implement blinking. The trigger that wants it to blink then
needs to implement its own timer solution.
Rather than require that, add led_blink_set() API that triggers can use.
This function will attempt to use hw blinking, but if that fails
implements a timer for it. To stop blinking again, brightness_set() also
needs to be wrapped into API that will stop the software blink.
As a result of this, the timer trigger becomes a very trivial one, and
hopefully we can finally see triggers using blinking as well because it's
always easy to use.
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
max_brightness is not writable, thus set permissions to 0444.
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
If we were to dynamically register/unregister leds and have udev or other
daemons handle the leds class uevents, we would be notified of the adding of a
new LED and if the daemon immediately tries to open one of the attributes of
the led device, it would fail with a "no such file or directory" error since
this the attributes are not yet created. Fix this by switching attributes to be
class-wide, such that the driver core will register these attributes with
device_add_attrs and then emit the kobject_uevent ADD signal.
Signed-off-by: Fainelli <ffainelli@freebox.fr>
As each led device gets registered a kernel message gets printed. In
an embedded system with a number of leds this can produce a lot
of output that just looks like noise.
Change the message type to KERN_DEBUG since it might be useful
in the dmesg output "after" booting.
Makes use of skip_spaces() defined in lib/string.c for removing leading
spaces from strings all over the tree.
It decreases lib.a code size by 47 bytes and reuses the function tree-wide:
64688 584 592 65864 10148 (TOTALS-BEFORE)
64641 584 592 65817 10119 (TOTALS-AFTER)
Also, while at it, if we see (*str && isspace(*str)), we can be sure to
remove the first condition (*str) as the second one (isspace(*str)) also
evaluates to 0 whenever *str == 0, making it redundant. In other words,
"a char equals zero is never a space".
Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below,
and found occurrences of this pattern on 3 more files:
drivers/video/output.c
expression str;
( // ignore skip_spaces cases
while (*str && isspace(*str)) { \(str++;\|++str;\) }
- *str &&
isspace(*str)
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: <linux-ext4@vger.kernel.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Takashi Iwai <tiwai@suse.de>
This patch allows drivers to override the default maximum brightness value
of 255. We take care to preserve backwards-compatibility as much as
possible, so that user-space ABI doesn't change for existing drivers.
LED trigger code has also been updated to use the per-LED maximum.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Add suspend/resume to the core class and remove all the now unneeded
code from various drivers. Originally the class code couldn't support
suspend/resume but since class_device can there is no reason for
each driver doing its own suspend/resume anymore.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Signed-off-by: Richard Purdie <rpurdie@intel.linux.com>
Fix a race during trigger registration where we could try and use a lock
before it was initialised.
led_classdev_unregister() has no "__" prefix, remove it.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
There's no need for the additional call to strlen(), we can directly
return the value returned by sprintf(). We now return a length value
that doesn't include the final '\0', but user space shouldn't bother
about it anyway.
Now that device_create() has been audited, rename things back to the
original call to be sane.
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_drvdata().
Cc: Kay Sievers <kay.sievers@vrfy.org>
Some drivers have duplicated unlikely() macros. IS_ERR() already has
unlikely() in itself.
This patch cleans up such pointless code.
Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Jaroslav Kysela <perex@perex.cz>
