path: root/drivers/leds/leds-alix2.c
2009-12-16leds: leds-alix2c - take port address from MSRDaniel Mack
This makes the LEDs driver for ALIX2.C boards work with Coreboot by looking up the port address in the MSR rather than hard-coding it. The BIOS scan also needed some tweaks as the string in Coreboot differs from the one in the legacy BIOS. Successfully tested with both the legacy tinyBIOS as well as Coreboot v3. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: alix-leds2 fixed for Award BIOSTobias Mueller
Add initialisation of GPIO ports for compatibility with boards with Award BIOS (e.g. ALIX.3D3). Signed-off-by: Tobias Mueller <Tobias_Mueller@twam.info> Reviewed-by: Constantin Baranov <const@mimas.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: Add suspend/resume to the core classRichard Purdie
Add suspend/resume to the core class and remove all the now unneeded code from various drivers. Originally the class code couldn't support suspend/resume but since class_device can there is no reason for each driver doing its own suspend/resume anymore.
2009-01-08leds: ALIX.2 LEDs driverConstantin Baranov
Driver for PC Engines ALIX.2 and ALIX.3 LEDs. Signed-off-by: Constantin Baranov <const@mimas.ru> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
