path: root/drivers/leds/leds-bd2802.c
2011-08-25drivers/leds/leds-bd2802.c: bd2802_unregister_led_classdev() should ↵Axel Lin
unregister all registered leds bd2802_unregister_led_classdev() should unregister all registered instances of led_classdev class that had registered by bd2802_register_led_classdev(). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Kim Kyuwon <q1.kim@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: convert bd2802 driver to dev_pm_opsMark Brown
There is a move to deprecate bus-specific PM operations and move to using dev_pm_ops instead in order to reduce the amount of boilerplate code in buses and facilitiate updates to the PM core. Do this move for the bs2802 driver. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kim Kyuwon <q1.kim@samsung.com> Cc: Kim Kyuwon <chammoru@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05leds: Remove owner field from attribute initialization in bd2802 driverGuenter Roeck
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-23leds: add the sysfs interface into the leds-bd2802 driver for changing wave ↵Kim Kyuwon
pattern and led current. Allow the user application to change the wave pattern and led current by 'wave_pattern' and 'rgb_current' sysfs files. Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: change the license informationKim Kyuwon
Change the license to 'GPL v2' Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: fix led-bd2802 errors while resumingKim Kyuwon
LED_CORE_SUSPENDRESUME flag is not needed in the bd2802 driver, because all works for suspend/resume is done in bd2802_suspend and bd2802_suspend functions. And this patch allows bd2802 to be configured again when it resumes from suspend. Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: add BD2802GU LED driverKim Kyuwon
ROHM BD2802GU is a RGB LED controller attached to i2c bus and specifically engineered for decoration purposes. This RGB controller incorporates lighting patterns and illuminates. This driver is designed to minimize power consumption, so when there is no emitting LED, it enters to reset state. And because the BD2802GU has lots of features that can't be covered by the current LED framework, it provides Advanced Configuration Function(ADF) mode, so that user applications can set registers of BD2802GU directly. Here are basic usage examples : ; to turn on LED (not blink) $ echo 1 > /sys/class/leds/led1_R/brightness ; to blink LED $ echo timer > /sys/class/leds/led1_R/trigger $ echo 1 > /sys/class/leds/led1_R/delay_on $ echo 1 > /sys/class/leds/led1_R/delay_off ; to turn off LED $ echo 0 > /sys/class/leds/led1_R/brightness [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kim Kyuwon <chammoru@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
