path: root/drivers/leds/leds-netxbig.c
2012-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (47 commits) leds: leds-lp5521: return an error code on error in probe() leds: leds-clevo-mail: Use pr_* instead of printks leds: leds-rb532: Fix checkpatch errors leds: led-triggers: Fix checkpatch warnings leds: ledtrig-backlight: Fix checkpatch error leds: leds-wrap: Use <linux/io.h> instead of <asm/io.h> leds: leds-wm8350: Use dev_err instead of printk leds: leds-pwm: Fix checkpatch warning leds: leds-pca955x: Use dev_info instead of printk leds: leds-net48xx: Use linux/io.h instead of asm/io.h leds: leds-lt3593: Fix checkpatch warnings leds: leds-gpio: Use dev_info instead of printk leds: leds-da903x: Fix checkpatch error and warnings leds: leds-bd2802: Fix checkpatch warnings leds: leds-adp5520: Fix checkpatch warnings leds: led-class: Fix checkpatch warning leds: leds-ns2: use devm_gpio_request_one leds: leds-lt3593: use devm_gpio_request_one leds: leds-gpio: use devm_gpio_request_one leds: lp3944: Fix return value ...
2012-11-28leds: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28leds: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28leds: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26leds: leds-netxbig: replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-09-19ARM: orion: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the orion include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de>
2012-07-24leds: convert Big Networks LED driver to devm_kzalloc()Bryan Wu
Cc: Simon Guinot <sguinot@lacie.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-05-10drivers/leds: correct __devexit annotationsArnd Bergmann
__devexit functions are discarded without CONFIG_HOTPLUG, so they need to be referenced carefully. A __devexit function may also not be called from a __devinit function. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Cc: Bryan Wu <bryan.wu@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10drivers/leds/leds-netxbig.c: use gpio_request_one()Axel Lin
Use gpio_request_one() instead of multiple gpiolib calls. This also simplifies error handling a bit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Simon Guinot <sguinot@lacie.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10leds: convert led platform drivers to module_platform_driverAxel Lin
Factor out some boilerplate code for platform driver registration into module_platform_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Haojian Zhuang <hzhuang1@marvell.com> [led-88pm860x.c] Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07leds: add LED driver for Big Network series LEDsSimon Guinot
This patch add a LED class driver for LEDs found on the LaCie 2Big and 5Big Network v2 boards. The LEDs are wired to a CPLD and are controlled through a GPIO extension bus. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
