path: root/drivers/leds/leds-pca955x.c
2012-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (47 commits) leds: leds-lp5521: return an error code on error in probe() leds: leds-clevo-mail: Use pr_* instead of printks leds: leds-rb532: Fix checkpatch errors leds: led-triggers: Fix checkpatch warnings leds: ledtrig-backlight: Fix checkpatch error leds: leds-wrap: Use <linux/io.h> instead of <asm/io.h> leds: leds-wm8350: Use dev_err instead of printk leds: leds-pwm: Fix checkpatch warning leds: leds-pca955x: Use dev_info instead of printk leds: leds-net48xx: Use linux/io.h instead of asm/io.h leds: leds-lt3593: Fix checkpatch warnings leds: leds-gpio: Use dev_info instead of printk leds: leds-da903x: Fix checkpatch error and warnings leds: leds-bd2802: Fix checkpatch warnings leds: leds-adp5520: Fix checkpatch warnings leds: led-class: Fix checkpatch warning leds: leds-ns2: use devm_gpio_request_one leds: leds-lt3593: use devm_gpio_request_one leds: leds-gpio: use devm_gpio_request_one leds: lp3944: Fix return value ...
2012-11-28leds: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28leds: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28leds: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jan-Simon Moeller <jansimon.moeller@gmx.de> Acked-by: Bryan Wu <cooloney@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-27leds: leds-pca955x: Use dev_info instead of printkSachin Kamat
Fixes the following checkpatch warning: WARNING: Prefer netdev_info(netdev, ... then dev_info(dev, ... then pr_info(... to printk(KERN_INFO ... Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Bryan Wu <cooloney@gmail.com>
2012-07-24leds: convert PCA955x LED driver to devm_kzalloc() and cleanup error exit pathBryan Wu
Cc: Nate Case <ncase@xes-inc.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-05-29drivers/leds/leds-pca955x.c: fix race condition while setting brightness on ↵Alexander Stein
several LEDs When issuing the following command: for I in 0 1 2 3 4 5 6 7; do echo 0 > /sys/class/leds/pca955x\:${I}/brightness; done It is possible that all the pca955x_read_ls calls are done sequentially before any pca955x_write_ls call is done. This updates the LS only to the last LED update in its set. Fix this by using a global lock for the pca995x device during pca955x_led_work. Also used a struct for shared data betreen all LEDs. [akpm@linux-foundation.org: revert unintentional rename of pca955x_ledsel()] Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Bryan Wu <bryan.wu@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10leds: convert led i2c drivers to module_i2c_driverAxel Lin
Factor out some boilerplate code for i2c driver registration into module_i2c_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Haojian Zhuang <hzhuang1@marvell.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Michael Hennerich <hennerich@blackfin.uclinux.org> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-10-20leds: leds-pca955x - Mark pca955x_led_set() staticSven Wegener
Mark pca955x_led_set() as static Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2008-10-03leds-pca955x: add proper error handling and fix bogus memory handlingSven Wegener
Check the return value of led_classdev_register and unregister all registered devices, if registering one device fails. Also the dynamic memory handling is totally bogus. You can't allocate multiple chunks via kzalloc() and expect them to be in order later. I wonder how this ever worked. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Acked-by: Nate Case <ncase@xes-inc.com> Tested-by: Nate Case <ncase@xes-inc.com> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-23leds: Add support for Philips PCA955x I2C LED driversNate Case
This driver supports the PCA9550, PCA9551, PCA9552, and PCA9553 LED driver chips. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
