path: root/drivers/leds/ledtrig-backlight.c
2008-10-20leds: Add backlight LED triggerRodolfo Giometti
This allows LEDs to be controlled as a backlight device where they turn off and on when the display is blanked and unblanked. This is useful where you need various key backlight LEDs to dim at the same time as the backlight. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
