path: root/drivers/leds
2010-04-01leds-gpio: fix default state handling on OF platformsAnton Vorontsov
commit 0493a4ff10959ff4c8e0d65efee25b7ffd4fa5db upstream. The driver wrongly sets default state for LEDs that don't specify default-state property. Currently the driver handles default state this way: memset(&led, 0, sizeof(led)); for_each_child_of_node(np, child) { state = of_get_property(child, "default-state", NULL); if (state) { if (!strcmp(state, "keep")) led.default_state = LEDS_GPIO_DEFSTATE_KEEP; ... } ret = create_gpio_led(&led, ...); } Which means that all LEDs that do not specify default-state will inherit the last value of the default-state property, which is wrong. This patch fixes the issue by moving LED's template initialization into the loop body. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-16leds-gpio: fix possible crash on OF device unbindingDmitry Eremin-Solenikov
If there are leds present in the OF tree, but the GPIOs for (some) of them are unavailable, led_data doesn't get populated with correct devices. Then, on device unbinding, one can crash the kernel. Workaround this by setting led->gpio to invalid value early. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-10-04leds: leds-pca9532 - Drop unused module parametersJean Delvare
The I2C_CLIENT_INSMOD_1 macro is only useful for i2c drivers which implement device detection. The leds-pca9532 driver doesn't, so there is no point in calling it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Riku Voipio <riku.voipio@iki.fi>
2009-09-26Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: move leds-clevo-mail's probe function to .devinit.text leds: Fix indentation in LEDS_LP3944 Kconfig entry leds: Fix LED names leds: Fix leds-pca9532 whitespace issues leds: fix coding style in worker thread code for ledtrig-gpio. leds: gpio-leds: fix typographics fault leds: Add WM831x status LED driver
2009-09-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: add driver for Atmel AT42QT2160 Sensor Chip Input: max7359 - use threaded IRQs Input: add driver for Maxim MAX7359 key switch controller Input: add driver for ADP5588 QWERTY I2C Keypad Input: add touchscreen driver for MELFAS MCS-5000 controller Input: add driver for OpenCores Keyboard Controller Input: dm355evm_keys - remove dm355evm_keys_hardirq Input: synaptics_i2c - switch to using __cancel_delayed_work() Input: ad7879 - add support for AD7889 Input: atkbd - rely on input core to restore state on resume Input: add generic suspend and resume for input devices Input: libps2 - additional locking for i8042 ports
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17Input: libps2 - additional locking for i8042 portsDmitry Torokhov
The serio ports on i8042 are not completely isolated; while we provide enough locking to ensure proper serialization when accessing control and data registers AUX and KBD ports can still have an effect on each other on PS/2 protocol level. The most prominent effect is that issuing a command for the device connected to one port may cause abort of the command currently executing by the device connected to another port. Since i8042 nor serio subsystem are not aware of the details of the PS/2 protocol (length of the commands and their replies and so on) the locking should be done on libps2 level by adding special handling when we see that we are dealing with serio port on i8042. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-09-07leds: move leds-clevo-mail's probe function to .devinit.textUwe Kleine-König
A pointer to clevo_mail_led_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-09-07leds: Fix indentation in LEDS_LP3944 Kconfig entryAntonio Ospite
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-09-07leds: Fix LED names Olaf Hering
This is needed to get kde-powersave to work properly on some g4 powerbooks. From: Olaf Hering <olh@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-09-07leds: Fix leds-pca9532 whitespace issuesRichard Purdie
2009-09-07leds: fix coding style in worker thread code for ledtrig-gpio.Thadeu Lima de Souza Cascardo
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-09-07leds: gpio-leds: fix typographics faultMichal Simek
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-09-07leds: Add WM831x status LED driverMark Brown
The WM831x devices feature two software controlled status LEDs with hardware assisted blinking. The device can also autonomously control the LEDs based on a selection of sources. This can be configured at boot time using either platform data or the chip OTP. A sysfs file in the style of that for triggers allowing the control source to be configured at run time. Triggers can't be used here since they can't depend on the implementation details of a specific LED type. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-08-26leds: after setting inverted attribute, we must update the LEDThadeu Lima de Souza Cascardo
If we change the inverted attribute to another value, the LED will not be inverted until we change the GPIO state. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Samuel R. C. Vale <srcvale@holoscopio.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-26leds: fix multiple requests and releases of IRQ for GPIO LED TriggerThadeu Lima de Souza Cascardo
When setting the same GPIO number, multiple IRQ shared requests will be done without freing the previous request. It will also try to free a failed request or an already freed IRQ if 0 was written to the gpio file. All these oops and leaks were fixed with the following solution: keep the previous allocated GPIO (if any) still allocated in case the new request fails. The alternative solution would desallocate the previous allocated GPIO and set gpio as 0. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Samuel R. C. Vale <srcvale@holoscopio.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-03Update Yoichi Yuasa's e-mail addressYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-23leds: Add options to have GPIO LEDs start on or keep their stateTrent Piepho
There already is a "default-on" trigger but there are problems with it. For one, it's a inefficient way to do it and requires led trigger support to be compiled in. But the real reason is that is produces a glitch on the LED. The GPIO is allocate with the LED *off*, then *later* when the trigger runs it is turned back on. If the LED was already on via the GPIO's reset default or action of the firmware, this produces a glitch where the LED goes from on to off to on. While normally this is fast enough that it wouldn't be noticeable to a human observer, there are still serious problems. One is that there may be something else on the GPIO line, like a hardware alarm or watchdog, that is fast enough to notice the glitch. Another is that the kernel may panic before the LED is turned back on, thus hanging with the LED in the wrong state. This is not just speculation, but actually happened to me with an embedded system that has an LED which should turn off when the kernel finishes booting, which was left in the incorrect state due to a bug in the OF LED binding code. We also let GPIO LEDs get their initial value from whatever the current state of the GPIO line is. On some systems the LEDs are put into some state by the firmware or hardware before Linux boots, and it is desired to have them keep this state which is otherwise unknown to Linux. This requires that the underlying GPIO driver support reading the value of output GPIOs. Some drivers support this and some do not. The platform device binding gains a field in the platform data "default_state" that controls this. There are three constants defined to select from on, off, or keeping the current state. The OpenFirmware binding uses a property named "default-state" that can be set to "on", "off", or "keep". The default if the property isn't present is off. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: LED driver for National Semiconductor LP3944 Funlight ChipAntonio Ospite
LEDs driver for National Semiconductor LP3944 Funlight Chip http://www.national.com/pf/LP/LP3944.html This helper chip can drive up to 8 leds, with two programmable DIM modes; it could even be used as a gpio expander but this driver assumes it is used as a led controller. The DIM modes are used to set _blink_ patterns for leds, the pattern is specified supplying two parameters: - period: from 0s to 1.6s - duty cycle: percentage of the period the led is on, from 0 to 100 LP3944 can be found on Motorola A910 smartphone, where it drives the rgb leds, the camera flash light and the displays backlights. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: pca9532 - Indent using tabs, not spaces.Antonio Ospite
Indent using tabs, not spaces. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Acked-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: Remove an orphan Kconfig entryRichard Purdie
Remove an orphan Kconfig entry (LEDS_LP5521) Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: alix-leds2 fixed for Award BIOSTobias Mueller
Add initialisation of GPIO ports for compatibility with boards with Award BIOS (e.g. ALIX.3D3). Signed-off-by: Tobias Mueller <Tobias_Mueller@twam.info> Reviewed-by: Constantin Baranov <const@mimas.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: leds-gpio - fix a section mismatchZhenwen Xu
WARNING: drivers/leds/leds-gpio.o(.text+0x153): Section mismatch in reference from the function gpio_led_probe() to the function .devinit.text:create_gpio_led() The function gpio_led_probe() references the function __devinit create_gpio_led(). This is often because gpio_led_probe lacks a __devinit annotation or the annotation of create_gpio_led is wrong. Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: add the sysfs interface into the leds-bd2802 driver for changing wave ↵Kim Kyuwon
pattern and led current. Allow the user application to change the wave pattern and led current by 'wave_pattern' and 'rgb_current' sysfs files. Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: change the license informationKim Kyuwon
Change the license to 'GPL v2' Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23leds: fix led-bd2802 errors while resumingKim Kyuwon
LED_CORE_SUSPENDRESUME flag is not needed in the bd2802 driver, because all works for suspend/resume is done in bd2802_suspend and bd2802_suspend functions. And this patch allows bd2802 to be configured again when it resumes from suspend. Signed-off-by: Kim Kyuwon <q1.kim@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-05-18[ARM] S3C24XX: GPIO: Move gpio functions out of <mach/hardware.h>Ben Dooks
Move all the gpio functions out of <mach/hardware.h> as this file is for defining the generic IO base addresses for the kernel IO calls. Make a new header <mach/gpio-fns.h> to take this and include it via the chain from <linux/gpio.h> which is what most of these files should be using (and will be changed as soon as possible). Note, this does make minor changes to some drivers but should not mess up any pending merges. CC: Richard Purdie <rpurdie@rpsys.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-08leds: just ignore invalid GPIOs in leds-gpioDavid Brownell
Fix build problems with leds-gpio: CC drivers/leds/leds-gpio.o drivers/leds/leds-gpio.c: In function 'create_gpio_led': drivers/leds/leds-gpio.c:85: warning: 'return' with no value, in function returning non-void Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: introduce lp5521 led driverFelipe Balbi
LP5521 is a three channel led driver with support for hardware accelerated patterns (currently used via lp5521-only sysfs interface). Currently, it's used on n810 device. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: just ignore invalid GPIOs in leds-gpioDavid Brownell
Sometimes it's awkward to make sure that the array in the platform_data handed to the leds-gpio driver has only valid data ... some leds may not be always available, and coping with that currently requires patching or rebuilding the array. This patch fixes that by making it be OK to pass an invalid GPIO (such as "-EINVAL") ... such table entries are skipped. [rpurdie@linux.intel.com: adjusted to apply against other led tree changes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Tested-by: Diego Dompe <diego.dompe@ridgerun.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Fix &&/|| confusion in leds-pca9532.cRiku Voipio
This fixes the expression in the driver to do the correct thing, not that I think anyone would send SND_* without EV_SND. Thanks to Roel Kluin <roel.kluin@gmail.com> for noticing. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: move h1940-leds's probe function to .devinit.textUwe Kleine-König
A pointer to h1940leds_probe is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: remove an unnecessary "goto" on drivers/leds/leds-s3c24.cZhenwen Xu
This goto is unnecessary. Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: add BD2802GU LED driverKim Kyuwon
ROHM BD2802GU is a RGB LED controller attached to i2c bus and specifically engineered for decoration purposes. This RGB controller incorporates lighting patterns and illuminates. This driver is designed to minimize power consumption, so when there is no emitting LED, it enters to reset state. And because the BD2802GU has lots of features that can't be covered by the current LED framework, it provides Advanced Configuration Function(ADF) mode, so that user applications can set registers of BD2802GU directly. Here are basic usage examples : ; to turn on LED (not blink) $ echo 1 > /sys/class/leds/led1_R/brightness ; to blink LED $ echo timer > /sys/class/leds/led1_R/trigger $ echo 1 > /sys/class/leds/led1_R/delay_on $ echo 1 > /sys/class/leds/led1_R/delay_off ; to turn off LED $ echo 0 > /sys/class/leds/led1_R/brightness [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kim Kyuwon <chammoru@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: remove experimental flag from leds-clevo-mailNémeth Márton
The leds-clevo-mail driver is in the mainline kernel since 2.6.25 and works without severe problems. Make this driver available for a larger audience. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Prevent multiple LED triggers with the same nameAdam Nielsen
Signed-off-by: Adam Nielsen <a.nielsen@shikadi.net> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Add gpio-led triggerFelipe Balbi
The gpio led trigger will allow leds to be triggered by gpio events. When we give the led a gpio number, the trigger will request_irq() on that so we don't have to keep polling for gpio state. It's useful for usecases as n810's keypad leds that could be triggered by the gpio event generated when user slides up to show the keypad. We also provide means for userland to tell us what is the desired brightness for that special led when it goes on so userland could use information from ambient light sensors and not set led brightness too high if it's not necessary. Signed-off-by: Felipe Balbi <me@felipebalbi.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Add rb532 LED driver for the User LEDPhil Sutter
Mikrotik built six LEDs into the Routerboard 532, from which one is destined for custom use, the so called "User LED". This patch adds a driver for it, based on the LEDs class. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Add suspend/resume state flags to leds-gpioRichard Purdie
Add an option to preserve LED state when suspending/resuming to the LED gpio driver. Based on a suggestion from Robert Jarzmik. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: simple driver for pwm driven LEDsLuotao Fu
Add a simple driver for pwm driver LEDs. pwm_id and period can be defined in board file. It is developed for pxa, however it is probably generic enough to be used on other platforms with pwm. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Fix leds-gpio driver multiple module_init/exit usageRichard Purdie
You can't have multiple module_init()/module_exit calls so resort to messy ifdefs potentially pending some code refactoring. Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Add dac124s085 driverGuennadi Liakhovetski
Add an LED driver using the DAC124S085 DAC from NatSemi [randy.dunlap@oracle.com: use header files for interfaces] Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: allow led-drivers to use a variable range of brightness valuesGuennadi Liakhovetski
This patch allows drivers to override the default maximum brightness value of 255. We take care to preserve backwards-compatibility as much as possible, so that user-space ABI doesn't change for existing drivers. LED trigger code has also been updated to use the per-LED maximum. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-04-06leds: Add openfirmware platform device supportTrent Piepho
Add bindings to support LEDs defined as of_platform devices in addition to the existing bindings for platform devices. New options in Kconfig allow the platform binding code and/or the of_platform code to be turned on. The of_platform code is of course only available on archs that have OF support. The existing probe and remove methods are refactored to use new functions create_gpio_led(), to create and register one led, and delete_gpio_led(), to unregister and free one led. The new probe and remove methods for the of_platform driver can then share most of the common probe and remove code with the platform driver. The suspend and resume methods aren't shared, but they are very short. The actual led driving code is the same for LEDs created by either binding. The OF bindings are based on patch by Anton Vorontsov <avorontsov@ru.mvista.com>. They have been extended to allow multiple LEDs per device. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-03-30trivial: Update my email addressRiku Voipio
Update my email address. Signed-off-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-20netfilter: x_tables: add LED trigger targetAdam Nielsen
Kernel module providing implementation of LED netfilter target. Each instance of the target appears as a led-trigger device, which can be associated with one or more LEDs in /sys/class/leds/ Signed-off-by: Adam Nielsen <a.nielsen@shikadi.net> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-01-15lis3lv02d: merge with leds hp diskEric Piel
Move the second part of the HP laptop disk protection functionality (a red led) to the same driver. From a purely Linux developer's point of view, the led and the accelerometer have nothing related. However, they correspond to the same ACPI functionality, and so will always be used together, moreover as they share the same ACPI PNP alias, there is no other simple to allow to have same loaded at the same time if they are not in the same module. Also make it requires the led class to compile and update the Kconfig text. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08leds: ledtrig-timer - on deactivation hardware blinking should be disabledRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-01-08leds: Add suspend/resume to the core classRichard Purdie
Add suspend/resume to the core class and remove all the now unneeded code from various drivers. Originally the class code couldn't support suspend/resume but since class_device can there is no reason for each driver doing its own suspend/resume anymore.
