path: root/drivers/leds
2008-05-20LEDS: fix race in device_createGreg Kroah-Hartman
There is a race from when a device is created with device_create() and then the drvdata is set with a call to dev_set_drvdata() in which a sysfs file could be open, yet the drvdata will be NULL, causing all sorts of bad things to happen. This patch fixes the problem by using the new function, device_create_drvdata(). Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25leds: Add default-on triggerNick Forbes
Add a trigger which allows LEDs to default to the full brightness state. Signed-off-by: Nick Forbes <Nick.Forbes@huntsworth.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: Add new driver for the LEDs on the Freecom FSG-3Rod Whitby
The LEDs on the Freecom FSG-3 are connected to an external memory-mapped latch on the ixp4xx expansion bus, and therefore cannot be supported by any of the existing LEDs drivers. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: Add support to leds with readable statusHenrique de Moraes Holschuh
Some led hardware allows drivers to query the led state, and this patch adds a hook to let the led class take advantage of that information when available. Without this functionality, when access to the led hardware is not exclusive (i.e. firmware or hardware might change its state behind the kernel's back), reality goes out of sync with the led class' idea of what the led is doing, which is annoying at best. Behaviour for drivers that do not or cannot read the led status is unchanged. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: enable support for blink_set() platform hook in leds-gpioHerbert Valerio Riedel
Enhance leds-gpio to provide hardware-based led flashing by passing through the blink_set() call to a optionally set platform-specific function pointer. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: Cleanup various whitespace and code style issuesNémeth Márton
Break the lines which were more than 80 characters into more lines; replace SPACEs with TABs; correct ident at switch-case; change character encoding from ISO-8859-2 to UTF-8. The order of the functions in led-triggers.c changed in order the similar functions can still be together under titles "Used by LED Class", "LED Trigger Interface" and "Simple LED Tigger Interface" as was grouped before when exported with EXPORT_SYMBOL. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: disable triggers on brightness setNémeth Márton
Disable any active triggers when the brightness attribute is set to zero. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-24leds: Add mail LED support for "Clevo D400P"Mrton Nmeth
The leds-clevo-mail module also works with model "Clevo D400P", add this model to the white list. Signed-off-by: Mrton Nmeth <nm127@freemail.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Fix built-in compilation of iwlcore net: Unexport move_addr_to_{kernel,user} rt2x00: Select LEDS_CLASS. iwlwifi: Select LEDS_CLASS. leds: Do not guard NEW_LEDS with HAS_IOMEM [IPSEC]: Fix catch-22 with algorithm IDs above 31 time: Export set_normalized_timespec. tcp: Make use of before macro in tcp_input.c hamradio: Remove unneeded and deprecated cli()/sti() calls in dmascc.c [NETNS]: Remove empty ->init callback. [DCCP]: Convert do_gettimeofday() to getnstimeofday(). [NETNS]: Don't initialize err variable twice. [NETNS]: The ip6_fib_timer can work with garbage on net namespace stop. [IPV4]: Convert do_gettimeofday() to getnstimeofday(). [IPV4]: Make icmp_sk_init() static. [IPV6]: Make struct ip6_prohibit_entry_template static. tcp: Trivial fix to correct function name in a comment in net/ipv4/tcp.c [NET]: Expose netdevice dev_id through sysfs skbuff: fix missing kernel-doc notation [ROSE]: Fix soft lockup wrt. rose_node_list_lock
2008-04-23leds: Do not guard NEW_LEDS with HAS_IOMEMDavid S. Miller
The LEDS infrastructure itself does not require anything that a platform dependant upon HAS_IOMEM. The individual drivers do, but they are properly guarded with the necessary platform dependencies. One can even imagine a hypervisor based LED driver that a platform without HAS_IOMEM might have. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits) SCSI: convert struct class_device to struct device DRM: remove unused dev_class IB: rename "dev" to "srp_dev" in srp_host structure IB: convert struct class_device to struct device memstick: convert struct class_device to struct device driver core: replace remaining __FUNCTION__ occurrences sysfs: refill attribute buffer when reading from offset 0 PM: Remove destroy_suspended_device() Firmware: add iSCSI iBFT Support PM: Remove legacy PM (fix) Kobject: Replace list_for_each() with list_for_each_entry(). SYSFS: Explicitly include required header file slab.h. Driver core: make device_is_registered() work for class devices PM: Convert wakeup flag accessors to inline functions PM: Make wakeup flags available whenever CONFIG_PM is set PM: Fix misuse of wakeup flag accessors in serial core Driver core: Call device_pm_add() after bus_add_device() in device_add() PM: Handle device registrations during suspend/resume block: send disk "change" event for rescan_partitions() sysdev: detect multiple driver registrations ... Fixed trivial conflict in include/linux/memory.h due to semaphore header file change (made irrelevant by the change to mutex).
2008-04-19PM: Remove destroy_suspended_device()Rafael J. Wysocki
After 2.6.24 there was a plan to make the PM core acquire all device semaphores during a suspend/hibernation to protect itself from concurrent operations involving device objects. That proved to be too heavy-handed and we found a better way to achieve the goal, but before it happened, we had introduced the functions device_pm_schedule_removal() and destroy_suspended_device() to allow drivers to "safely" destroy a suspended device and we had adapted some drivers to use them. Now that these functions are no longer necessary, it seems reasonable to remove them and modify their users to use the normal device unregistration instead. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19Merge branch 'merge-fixes' into develRussell King
2008-04-19Merge branch 'omap2-upstream' into develRussell King
2008-04-19[ARM] 4974/1: Drop unused leds-tosa.Dmitry Baryshkov
As now tosa uses leds-gpio, drop leds-tosa driver. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] Remove leds-tosa.cRussell King
See f99ee0b99214cf5329e711859e3f5fd02c820a24 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-15leds: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable platform LED drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-31leds: Remove incorrect use of preempt_count() from leds-gpioDavid Brownell
It appears that we can't just check to see if we're in a task context ... so instead of trying that, just make the relevant leds always schedule a little worklet. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-03-31leds: Fix potential leds-gpio oopsUwe Kleine-König
Call gpio_cansleep only after gpio_request succeeded avoiding an oops. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-08PWM LED driverDavid Brownell
This is a LED driver using the PWM on newer SOCs from Atmel; brightness is controlled by changing the PWM duty cycle. So for example if you've set up two leds labeled "pwm0" and "pwm1": echo 0 > /sys/class/leds/pwm2/brightness # off (0%) echo 80 > /sys/class/leds/pwm2/brightness echo 255 > /sys/class/leds/pwm2/brightness # on (100%) Note that "brightness" here isn't linear; maybe that should change. Going from 4 to 8 probably doubles perceived brightness, while 244 to 248 is imperceptible. This is mostly intended to be a simple example of PWM, although it's realistic since LCD backlights are often driven with PWM to conserve battery power (and offer brightness options). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07leds: Add HP Jornada 6xx driverKristoffer Ericson
Add support for the LEDs on the HP Jornada 620/660/680/690 devices. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Remove the now uneeded ixp4xx driverRod Whitby
All boards using the IXP4XX-GPIO-LED driver have been updated to use the generic leds-gpio driver instead. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Add power LED to the wrap driverMichael Loeffler
The 3rd LED on this board is something like a power-led, it is on all the time. With this change to the leds-wrap driver it is possible to use this LED too. Signed-off-by: Michael Loeffler <zvpunry@zvpunry.de> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Fix led-gpio active_low default brightnessRaphael Assenat
When gpio_direction_output() is called, led_dat->active_low is used as default value. This means that the led will always be off by default. cdev.brightness should really have been set to LED_OFF unconditionally to reflect this behavior. Signed-off-by: Raphael Assenat <raph@8d.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: hw acceleration for Clevo mail LED driverMárton Németh
Add support for hardware accelerated LED blinking for the mail LED commonly found on Clevo notebooks. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Add support for hardware accelerated LED flashingMárton Németh
Extends the leds subsystem with a blink_set() callback function which can be optionally implemented by a LED driver. If implemented, the driver can use the hardware acceleration for blinking a LED. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Standardise LED naming schemeRichard Purdie
As discussed on LKML some notion of 'function' is needed in LED naming. This patch adds this to the documentation and standardises existing LED drivers. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-07leds: Add clevo notebook LED driverMárton Németh
The driver supports the mail LED commonly found on different Clevo notebooks. The driver access the LED through the i8042 hardware which is handled by the input subsystem. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2008-02-05leds: add possibility to remove leds classdevs during suspend/resumeRafael J. Wysocki
Make it possible to unregister a led classdev object in a safe way during a suspend/resume cycle. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Michael Buesch <mb@bu3sch.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-31leds: Fix locomo LED driver oopsRichard Purdie
Fix locomo-leds to use the correct struct device to prevent an oops. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-12-31leds: Fix leds_list_lock locking issuesRichard Purdie
Covert leds_list_lock to a rw_sempahore to match previous LED trigger locking fixes, fixing lock ordering. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-12-07leds: Fix led trigger locking bugsRichard Purdie
Convert part of the led trigger core from rw spinlocks to rw semaphores. We're calling functions which can sleep from invalid contexts otherwise. Fixes bug #9264. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-11-05leds: bugfixes for leds-gpioDavid Brownell
Three bugfixes to the leds-gpio driver, plus minor whitespace tweaks: - Do the INIT_WORK() before registering each LED, so if its trigger becomes immediately active it can schedule work without oopsing.. - Use normal registration, not platform_driver_probe(), so that devices appearing "late" (hotplug type) can still be bound. - Mark the driver remove code as "__devexit", preventing oopses when the underlying device is removed. These issues came up when using this driver with some GPIO expanders living on serial busses, which act unlike "normal" platform devices: they can appear and vanish along with the serial bus driver. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-10-20fix typo "sort" -> "short"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-15[ARM] 4576/1: CM-X270 machine supportMike Rapoport
This patch provides core support for CM-X270 platform. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12kconfig: syntax cleanup - drop support for "depends/requires/def_boolean"Adrian Bunk
Remove the following redundant and never or rarely used kconfig syntax: - "def_boolean" (same as "def_bool") - "requires" (same as "depends on") - "depends" (same as "depends on") This patch contains the code changes and Kconfig updates. The shipped files are in next patch to let actual codechange stand out. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11leds: Update Cobalt Qube series front LED supportYoichi Yuasa
Update Cobalt Qube series front LED support. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-10-11leds: Add Cobalt Raq series LEDs supportYoichi Yuasa
Add Cobalt Raq series LEDs support. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-10-11leds: Rename leds-cobalt driverYoichi Yuasa
The leds-cobalt driver only supports the Coable Qube series (not included in Cobalt Raq series). Rename the driver and update Kconfig/Makefile. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Convert from struct class_device to struct deviceRichard Purdie
Convert the LEDs class from struct class_device to struct device since class_device is scheduled for removal. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-16leds: Add warning printks in error pathsRichard Purdie
Add warning printks if led_trigger_register_simple() fails. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Fix trigger unregister_simple if register_simple failsRichard Purdie
Fix led_trigger_unregister_simple to handle the case where led_trigger_register_simple fails, avoiding a NULL pointer dereference. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Use menuconfig objects II - LEDJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Teach leds-gpio to handle timer-unsafe GPIOsDavid Brownell
Teach the new leds-gpio driver that some GPIOs can't be accessed from timer callbacks ... which is how all today's standard triggers use them. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-16leds: Add generic GPIO LED driverRaphael Assenat
This patch adds support for GPIO connected leds via the new GPIO framework. Information about leds (gpio, polarity, name, default trigger) is passed to the driver via platform_data. Signed-off-by: Raphael Assenat <raph@8d.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-05-10[S390] Kconfig: menus with depends on HAS_IOMEM.Martin Schwidefsky
Add "depends on HAS_IOMEM" to a number of menus to make them disappear for s390 which does not have I/O memory. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-15leds: Add support for Cobalt Server front LEDFlorian Fainelli
Add support for Cobalt Server front LED (MIPS) Signed-off-by: Florian Fainell <florian.fainelli@int-evry.fr> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
